22 #ifndef __CONFIGURATION_TEMPLATE_h 23 #define __CONFIGURATION_TEMPLATE_h 33 #ifdef CONFIGURE_DISABLE_BSP_SETTINGS 34 #undef BSP_DEFAULT_UNIFIED_WORK_AREAS 35 #undef BSP_IDLE_TASK_BODY 36 #undef BSP_IDLE_TASK_STACK_SIZE 37 #undef BSP_INITIAL_EXTENSION 38 #undef BSP_INTERRUPT_STACK_SIZE 39 #undef BSP_MAXIMUM_DEVICES 40 #undef BSP_ZERO_WORKSPACE_AUTOMATICALLY 41 #undef CONFIGURE_BSP_PREREQUISITE_DRIVERS 42 #undef CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK 48 #include <sys/reent.h> 84 #if defined(RTEMS_MULTIPROCESSING) 88 extern rtems_multiprocessing_table Multiprocessing_configuration;
91 #ifdef RTEMS_POSIX_API 102 #ifdef RTEMS_SCHEDSIM 106 #if (defined(RTEMS_NEWLIB) && !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY)) 107 #define CONFIGURE_NEWLIB_EXTENSION 1 109 #define CONFIGURE_NEWLIB_EXTENSION 0 112 #ifndef RTEMS_SCHEDSIM 115 #ifdef CONFIGURE_INIT 116 const rtems_libio_helper rtems_libio_init_helper =
117 #ifdef CONFIGURE_APPLICATION_DISABLE_FILESYSTEM 118 rtems_libio_helper_null;
123 const rtems_libio_helper rtems_libio_post_driver_helper =
124 #ifdef CONFIGURE_APPLICATION_DISABLE_FILESYSTEM 125 rtems_libio_helper_null;
127 rtems_libio_post_driver;
130 const rtems_libio_helper rtems_libio_exit_helper =
131 #ifdef CONFIGURE_APPLICATION_DISABLE_FILESYSTEM 132 rtems_libio_helper_null;
137 const rtems_libio_helper rtems_fs_init_helper =
138 #ifdef CONFIGURE_APPLICATION_DISABLE_FILESYSTEM 139 rtems_libio_helper_null;
151 #ifndef CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 152 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 3 158 #define CONFIGURE_LIBIO_SEMAPHORES 1 163 #define CONFIGURE_LIBIO_POSIX_KEYS 1 168 #ifdef RTEMS_DRVMGR_STARTUP 169 #define CONFIGURE_DRVMGR_SEMAPHORES 1 171 #define CONFIGURE_DRVMGR_SEMAPHORES 0 174 #ifdef CONFIGURE_INIT 181 const uint32_t rtems_libio_number_iops = RTEMS_ARRAY_SIZE(rtems_libio_iops);
189 #ifdef CONFIGURE_TERMIOS_DISABLED 190 #define CONFIGURE_TERMIOS_SEMAPHORES 0 196 #ifndef CONFIGURE_NUMBER_OF_TERMIOS_PORTS 197 #define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 1 204 #define CONFIGURE_TERMIOS_SEMAPHORES \ 205 ((CONFIGURE_NUMBER_OF_TERMIOS_PORTS * 4) + 1) 212 #ifndef CONFIGURE_MAXIMUM_PTYS 213 #define CONFIGURE_MAXIMUM_PTYS 0 220 #ifdef CONFIGURE_INIT 226 #if defined(RTEMS_SMP) 230 #if !defined(CONFIGURE_SMP_APPLICATION) 231 #if !defined(CONFIGURE_SMP_MAXIMUM_PROCESSORS) 232 #define CONFIGURE_SMP_MAXIMUM_PROCESSORS 1 235 #if !defined(CONFIGURE_SMP_MAXIMUM_PROCESSORS) 236 #error "CONFIGURE_SMP_MAXIMUM_PROCESSORS not specified for SMP Application" 248 #if !defined(CONFIGURE_MAXIMUM_FIFOS) 249 #define CONFIGURE_MAXIMUM_FIFOS 0 255 #if !defined(CONFIGURE_MAXIMUM_PIPES) 256 #define CONFIGURE_MAXIMUM_PIPES 0 265 #if CONFIGURE_MAXIMUM_FIFOS > 0 || CONFIGURE_MAXIMUM_PIPES > 0 266 #define CONFIGURE_BARRIERS_FOR_FIFOS \ 267 (2 * (CONFIGURE_MAXIMUM_FIFOS + CONFIGURE_MAXIMUM_PIPES)) 269 #define CONFIGURE_BARRIERS_FOR_FIFOS 0 278 #if CONFIGURE_MAXIMUM_FIFOS > 0 || CONFIGURE_MAXIMUM_PIPES > 0 279 #define CONFIGURE_SEMAPHORES_FOR_FIFOS \ 280 (1 + (CONFIGURE_MAXIMUM_FIFOS + CONFIGURE_MAXIMUM_PIPES)) 282 #define CONFIGURE_SEMAPHORES_FOR_FIFOS 0 324 #ifdef CONFIGURE_INIT 330 #ifdef CONFIGURE_FILESYSTEM_ALL 331 #define CONFIGURE_FILESYSTEM_IMFS 332 #define CONFIGURE_FILESYSTEM_DEVFS 333 #define CONFIGURE_FILESYSTEM_TFTPFS 334 #define CONFIGURE_FILESYSTEM_FTPFS 335 #define CONFIGURE_FILESYSTEM_NFS 336 #define CONFIGURE_FILESYSTEM_DOSFS 337 #define CONFIGURE_FILESYSTEM_RFS 338 #define CONFIGURE_FILESYSTEM_JFFS2 345 #if defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM) 346 #if defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM) 347 #error "Filesystem disabled and a base filesystem configured." 350 #if defined(CONFIGURE_FILESYSTEM_IMFS) || \ 351 defined(CONFIGURE_FILESYSTEM_DEVFS) || \ 352 defined(CONFIGURE_FILESYSTEM_TFTPFS) || \ 353 defined(CONFIGURE_FILESYSTEM_FTPFS) || \ 354 defined(CONFIGURE_FILESYSTEM_NFS) || \ 355 defined(CONFIGURE_FILESYSTEM_DOSFS) || \ 356 defined(CONFIGURE_FILESYSTEM_RFS) || \ 357 defined(CONFIGURE_FILESYSTEM_JFFS2) 358 #error "Filesystem disabled and a filesystem configured." 366 #if !defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM) 367 #if defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM) 368 #define CONFIGURE_FILESYSTEM_DEVFS 374 #ifndef RTEMS_SCHEDSIM 378 #include <rtems/imfs.h> 386 #ifndef CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK 387 #define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK \ 388 IMFS_MEMFILE_DEFAULT_BYTES_PER_BLOCK 394 #if !defined(CONFIGURE_FILESYSTEM_ENTRY_IMFS) && \ 395 defined(CONFIGURE_FILESYSTEM_IMFS) 396 #define CONFIGURE_FILESYSTEM_ENTRY_IMFS \ 397 { RTEMS_FILESYSTEM_TYPE_IMFS, IMFS_initialize } 401 #ifdef CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM 402 #define CONFIGURE_IMFS_DISABLE_CHMOD 403 #define CONFIGURE_IMFS_DISABLE_CHOWN 404 #define CONFIGURE_IMFS_DISABLE_UTIME 405 #define CONFIGURE_IMFS_DISABLE_LINK 406 #define CONFIGURE_IMFS_DISABLE_SYMLINK 407 #define CONFIGURE_IMFS_DISABLE_READLINK 408 #define CONFIGURE_IMFS_DISABLE_RENAME 409 #define CONFIGURE_IMFS_DISABLE_UNMOUNT 415 #if !defined(CONFIGURE_FILESYSTEM_ENTRY_DEVFS) && \ 416 defined(CONFIGURE_FILESYSTEM_DEVFS) 417 #include <rtems/devfs.h> 418 #define CONFIGURE_FILESYSTEM_ENTRY_DEVFS \ 419 { RTEMS_FILESYSTEM_TYPE_DEVFS, devFS_initialize } 422 #ifdef RTEMS_NETWORKING 426 #if !defined(CONFIGURE_FILESYSTEM_ENTRY_FTPFS) && \ 427 defined(CONFIGURE_FILESYSTEM_FTPFS) 429 #define CONFIGURE_FILESYSTEM_ENTRY_FTPFS \ 430 { RTEMS_FILESYSTEM_TYPE_FTPFS, rtems_ftpfs_initialize } 436 #if !defined(CONFIGURE_FILESYSTEM_ENTRY_TFTPFS) && \ 437 defined(CONFIGURE_FILESYSTEM_TFTPFS) 439 #define CONFIGURE_FILESYSTEM_ENTRY_TFTPFS \ 440 { RTEMS_FILESYSTEM_TYPE_TFTPFS, rtems_tftpfs_initialize } 446 #if !defined(CONFIGURE_FILESYSTEM_ENTRY_NFS) && \ 447 defined(CONFIGURE_FILESYSTEM_NFS) 449 #if !defined(CONFIGURE_MAXIMUM_NFS_MOUNTS) 450 #define CONFIGURE_MAXIMUM_NFS_MOUNTS 1 452 #define CONFIGURE_FILESYSTEM_ENTRY_NFS \ 453 { RTEMS_FILESYSTEM_TYPE_NFS, rtems_nfs_initialize } 454 #define CONFIGURE_SEMAPHORES_FOR_NFS ((CONFIGURE_MAXIMUM_NFS_MOUNTS * 2) + 1) 456 #define CONFIGURE_SEMAPHORES_FOR_NFS 0 459 #define CONFIGURE_SEMAPHORES_FOR_NFS 0 465 #if !defined(CONFIGURE_FILESYSTEM_ENTRY_DOSFS) && \ 466 defined(CONFIGURE_FILESYSTEM_DOSFS) 467 #include <rtems/dosfs.h> 468 #if !defined(CONFIGURE_MAXIMUM_DOSFS_MOUNTS) 469 #define CONFIGURE_MAXIMUM_DOSFS_MOUNTS 1 471 #define CONFIGURE_FILESYSTEM_ENTRY_DOSFS \ 472 { RTEMS_FILESYSTEM_TYPE_DOSFS, rtems_dosfs_initialize } 473 #define CONFIGURE_SEMAPHORES_FOR_DOSFS CONFIGURE_MAXIMUM_DOSFS_MOUNTS 475 #define CONFIGURE_SEMAPHORES_FOR_DOSFS 0 481 #if !defined(CONFIGURE_FILESYSTEM_ENTRY_RFS) && \ 482 defined(CONFIGURE_FILESYSTEM_RFS) 483 #include <rtems/rtems-rfs.h> 484 #if !defined(CONFIGURE_MAXIMUM_RFS_MOUNTS) 485 #define CONFIGURE_MAXIMUM_RFS_MOUNTS 1 487 #define CONFIGURE_FILESYSTEM_ENTRY_RFS \ 488 { RTEMS_FILESYSTEM_TYPE_RFS, rtems_rfs_rtems_initialise } 489 #define CONFIGURE_SEMAPHORES_FOR_RFS CONFIGURE_MAXIMUM_RFS_MOUNTS 491 #define CONFIGURE_SEMAPHORES_FOR_RFS 0 497 #if !defined(CONFIGURE_FILESYSTEM_ENTRY_JFFS2) && \ 498 defined(CONFIGURE_FILESYSTEM_JFFS2) 500 #if !defined(CONFIGURE_MAXIMUM_JFFS2_MOUNTS) 501 #define CONFIGURE_MAXIMUM_JFFS2_MOUNTS 1 503 #define CONFIGURE_FILESYSTEM_ENTRY_JFFS2 \ 504 { RTEMS_FILESYSTEM_TYPE_JFFS2, rtems_jffs2_initialize } 505 #define CONFIGURE_SEMAPHORES_FOR_JFFS2 CONFIGURE_MAXIMUM_JFFS2_MOUNTS 507 #define CONFIGURE_SEMAPHORES_FOR_JFFS2 0 516 #define CONFIGURE_SEMAPHORES_FOR_FILE_SYSTEMS \ 517 (CONFIGURE_SEMAPHORES_FOR_FIFOS + \ 518 CONFIGURE_SEMAPHORES_FOR_NFS + \ 519 CONFIGURE_SEMAPHORES_FOR_DOSFS + \ 520 CONFIGURE_SEMAPHORES_FOR_RFS + \ 521 CONFIGURE_SEMAPHORES_FOR_JFFS2) 523 #ifdef CONFIGURE_INIT 534 #ifdef CONFIGURE_FILESYSTEM_DEVFS 535 #ifndef CONFIGURE_MAXIMUM_DEVICES 536 #if defined(BSP_MAXIMUM_DEVICES) 537 #define CONFIGURE_MAXIMUM_DEVICES BSP_MAXIMUM_DEVICES 539 #define CONFIGURE_MAXIMUM_DEVICES 4 542 #include <rtems/devfs.h> 548 #define CONFIGURE_FILESYSTEM_NULL { NULL, NULL } 550 #ifndef RTEMS_SCHEDSIM 551 #if !defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM) && \ 552 !defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM) 553 int imfs_rq_memfile_bytes_per_block =
561 #if !defined(CONFIGURE_HAS_OWN_FILESYSTEM_TABLE) && \ 562 !defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM) 564 #if !defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM) 565 {
"/", IMFS_initialize_support },
567 #if defined(CONFIGURE_FILESYSTEM_IMFS) && \ 568 defined(CONFIGURE_FILESYSTEM_ENTRY_IMFS) 569 CONFIGURE_FILESYSTEM_ENTRY_IMFS,
571 #if defined(CONFIGURE_FILESYSTEM_DEVFS) && \ 572 defined(CONFIGURE_FILESYSTEM_ENTRY_DEVFS) 573 CONFIGURE_FILESYSTEM_ENTRY_DEVFS,
575 #if defined(CONFIGURE_FILESYSTEM_TFTPFS) && \ 576 defined(CONFIGURE_FILESYSTEM_ENTRY_TFTPFS) 577 CONFIGURE_FILESYSTEM_ENTRY_TFTPFS,
579 #if defined(CONFIGURE_FILESYSTEM_FTPFS) && \ 580 defined(CONFIGURE_FILESYSTEM_ENTRY_FTPFS) 581 CONFIGURE_FILESYSTEM_ENTRY_FTPFS,
583 #if defined(CONFIGURE_FILESYSTEM_NFS) && \ 584 defined(CONFIGURE_FILESYSTEM_ENTRY_NFS) 585 CONFIGURE_FILESYSTEM_ENTRY_NFS,
587 #if defined(CONFIGURE_FILESYSTEM_DOSFS) && \ 588 defined(CONFIGURE_FILESYSTEM_ENTRY_DOSFS) 589 CONFIGURE_FILESYSTEM_ENTRY_DOSFS,
591 #if defined(CONFIGURE_FILESYSTEM_RFS) && \ 592 defined(CONFIGURE_FILESYSTEM_ENTRY_RFS) 593 CONFIGURE_FILESYSTEM_ENTRY_RFS,
595 #if defined(CONFIGURE_FILESYSTEM_JFFS2) && \ 596 defined(CONFIGURE_FILESYSTEM_ENTRY_JFFS2) 597 CONFIGURE_FILESYSTEM_ENTRY_JFFS2,
599 CONFIGURE_FILESYSTEM_NULL
603 #if !defined(CONFIGURE_HAS_OWN_MOUNT_TABLE) && \ 604 !defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM) 605 #if defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM) 606 static devFS_node devFS_root_filesystem_nodes [CONFIGURE_MAXIMUM_DEVICES];
607 static const devFS_data devFS_root_filesystem_data = {
608 devFS_root_filesystem_nodes,
609 CONFIGURE_MAXIMUM_DEVICES
618 #ifdef CONFIGURE_IMFS_DISABLE_LINK 624 #ifdef CONFIGURE_IMFS_DISABLE_MKNOD 629 #ifdef CONFIGURE_IMFS_DISABLE_RMNOD 634 #ifdef CONFIGURE_IMFS_DISABLE_CHMOD 639 #ifdef CONFIGURE_IMFS_DISABLE_CHOWN 646 #ifdef CONFIGURE_IMFS_DISABLE_MOUNT 651 #ifdef CONFIGURE_IMFS_DISABLE_UNMOUNT 657 #ifdef CONFIGURE_IMFS_DISABLE_UTIME 662 #ifdef CONFIGURE_IMFS_DISABLE_SYMLINK 667 #ifdef CONFIGURE_IMFS_DISABLE_READLINK 672 #ifdef CONFIGURE_IMFS_DISABLE_RENAME 681 #ifdef CONFIGURE_IMFS_DISABLE_READDIR 682 &IMFS_mknod_control_dir_minimal,
684 &IMFS_mknod_control_dir_default,
686 &IMFS_mknod_control_device,
687 #ifdef CONFIGURE_IMFS_DISABLE_MKNOD_FILE 688 &IMFS_mknod_control_enosys,
690 &IMFS_mknod_control_memfile,
692 #if CONFIGURE_MAXIMUM_FIFOS > 0 || CONFIGURE_MAXIMUM_PIPES > 0 693 &IMFS_mknod_control_fifo
695 &IMFS_mknod_control_enosys
700 &_Configure_IMFS_fs_info,
701 &_Configure_IMFS_ops,
702 &_Configure_IMFS_mknod_controls
707 rtems_filesystem_root_configuration = {
710 #if defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM) 711 RTEMS_FILESYSTEM_TYPE_DEVFS,
715 RTEMS_FILESYSTEM_READ_WRITE,
716 #if defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM) 717 &devFS_root_filesystem_data
719 &_Configure_IMFS_mount_data
731 #if defined(STACK_CHECKER_ON) 732 #define CONFIGURE_STACK_CHECKER_ENABLED 733 #warning "STACK_CHECKER_ON deprecated -- use CONFIGURE_STACK_CHECKER_ENABLED" 739 #ifdef CONFIGURE_STACK_CHECKER_ENABLED 740 #define CONFIGURE_STACK_CHECKER_EXTENSION 1 742 #define CONFIGURE_STACK_CHECKER_EXTENSION 0 775 #ifndef CONFIGURE_MAXIMUM_PRIORITY 776 #define CONFIGURE_MAXIMUM_PRIORITY PRIORITY_DEFAULT_MAXIMUM 811 #if !defined(CONFIGURE_SCHEDULER_USER) && \ 812 !defined(CONFIGURE_SCHEDULER_PRIORITY) && \ 813 !defined(CONFIGURE_SCHEDULER_PRIORITY_SMP) && \ 814 !defined(CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP) && \ 815 !defined(CONFIGURE_SCHEDULER_SIMPLE) && \ 816 !defined(CONFIGURE_SCHEDULER_SIMPLE_SMP) && \ 817 !defined(CONFIGURE_SCHEDULER_EDF) && \ 818 !defined(CONFIGURE_SCHEDULER_CBS) 819 #if defined(RTEMS_SMP) && defined(CONFIGURE_SMP_APPLICATION) 824 #define CONFIGURE_SCHEDULER_PRIORITY_SMP 830 #define CONFIGURE_SCHEDULER_PRIORITY 839 #if defined(CONFIGURE_SCHEDULER_PRIORITY) 840 #if !defined(CONFIGURE_SCHEDULER_NAME) 842 #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'P', 'D', ' ') 845 #if !defined(CONFIGURE_SCHEDULER_CONTROLS) 847 #define CONFIGURE_SCHEDULER_CONTEXT \ 848 RTEMS_SCHEDULER_CONTEXT_PRIORITY( \ 850 CONFIGURE_MAXIMUM_PRIORITY + 1 \ 854 #define CONFIGURE_SCHEDULER_CONTROLS \ 855 RTEMS_SCHEDULER_CONTROL_PRIORITY(dflt, CONFIGURE_SCHEDULER_NAME) 863 #if defined(CONFIGURE_SCHEDULER_PRIORITY_SMP) 864 #if !defined(CONFIGURE_SCHEDULER_NAME) 866 #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'P', 'D', ' ') 869 #if !defined(CONFIGURE_SCHEDULER_CONTROLS) 871 #define CONFIGURE_SCHEDULER_CONTEXT \ 872 RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP( \ 874 CONFIGURE_MAXIMUM_PRIORITY + 1 \ 878 #define CONFIGURE_SCHEDULER_CONTROLS \ 879 RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP(dflt, CONFIGURE_SCHEDULER_NAME) 887 #if defined(CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP) 888 #if !defined(CONFIGURE_SCHEDULER_NAME) 890 #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'P', 'A', ' ') 893 #if !defined(CONFIGURE_SCHEDULER_CONTROLS) 895 #define CONFIGURE_SCHEDULER_CONTEXT \ 896 RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP( \ 898 CONFIGURE_MAXIMUM_PRIORITY + 1 \ 901 #define CONFIGURE_SCHEDULER_CONTROLS \ 902 RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP( \ 904 CONFIGURE_SCHEDULER_NAME \ 912 #if defined(CONFIGURE_SCHEDULER_SIMPLE) 913 #if !defined(CONFIGURE_SCHEDULER_NAME) 915 #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'P', 'S', ' ') 918 #if !defined(CONFIGURE_SCHEDULER_CONTROLS) 920 #define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_SIMPLE(dflt) 923 #define CONFIGURE_SCHEDULER_CONTROLS \ 924 RTEMS_SCHEDULER_CONTROL_SIMPLE(dflt, CONFIGURE_SCHEDULER_NAME) 931 #if defined(CONFIGURE_SCHEDULER_SIMPLE_SMP) 932 #if !defined(CONFIGURE_SCHEDULER_NAME) 934 #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'P', 'S', ' ') 937 #if !defined(CONFIGURE_SCHEDULER_CONTROLS) 939 #define CONFIGURE_SCHEDULER_CONTEXT \ 940 RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(dflt) 943 #define CONFIGURE_SCHEDULER_CONTROLS \ 944 RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(dflt, CONFIGURE_SCHEDULER_NAME) 951 #if defined(CONFIGURE_SCHEDULER_EDF) 952 #if !defined(CONFIGURE_SCHEDULER_NAME) 954 #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'E', 'D', 'F') 957 #if !defined(CONFIGURE_SCHEDULER_CONTROLS) 959 #define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_EDF(dflt) 962 #define CONFIGURE_SCHEDULER_CONTROLS \ 963 RTEMS_SCHEDULER_CONTROL_EDF(dflt, CONFIGURE_SCHEDULER_NAME) 970 #if defined(CONFIGURE_SCHEDULER_CBS) 971 #if !defined(CONFIGURE_SCHEDULER_NAME) 973 #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'C', 'B', 'S') 976 #if !defined(CONFIGURE_SCHEDULER_CONTROLS) 978 #define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_CBS(dflt) 981 #define CONFIGURE_SCHEDULER_CONTROLS \ 982 RTEMS_SCHEDULER_CONTROL_CBS(dflt, CONFIGURE_SCHEDULER_NAME) 985 #ifndef CONFIGURE_CBS_MAXIMUM_SERVERS 986 #define CONFIGURE_CBS_MAXIMUM_SERVERS CONFIGURE_MAXIMUM_TASKS 989 #ifdef CONFIGURE_INIT 991 CONFIGURE_CBS_MAXIMUM_SERVERS;
1002 #ifdef CONFIGURE_INIT 1003 #if defined(CONFIGURE_SCHEDULER_CONTEXT) 1011 #if defined(RTEMS_SMP) 1013 RTEMS_ARRAY_SIZE( _Scheduler_Table );
1015 const Scheduler_Assignment _Scheduler_Assignments[] = {
1016 #if defined(CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS) 1017 CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
1019 #define CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT \ 1020 RTEMS_SCHEDULER_ASSIGN( \ 1022 RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL \ 1024 CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1025 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 2 1026 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1028 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 3 1029 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1031 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 4 1032 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1034 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 5 1035 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1037 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 6 1038 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1040 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 7 1041 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1043 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 8 1044 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1046 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 9 1047 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1049 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 10 1050 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1052 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 11 1053 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1055 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 12 1056 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1058 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 13 1059 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1061 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 14 1062 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1064 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 15 1065 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1067 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 16 1068 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1070 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 17 1071 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1073 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 18 1074 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1076 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 19 1077 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1079 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 20 1080 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1082 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 21 1083 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1085 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 22 1086 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1088 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 23 1089 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1091 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 24 1092 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1094 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 25 1095 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1097 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 26 1098 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1100 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 27 1101 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1103 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 28 1104 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1106 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 29 1107 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1109 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 30 1110 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1112 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 31 1113 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1115 #if CONFIGURE_SMP_MAXIMUM_PROCESSORS >= 32 1116 , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
1118 #undef CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT 1122 RTEMS_STATIC_ASSERT(
1123 CONFIGURE_SMP_MAXIMUM_PROCESSORS
1124 == RTEMS_ARRAY_SIZE( _Scheduler_Assignments ),
1125 _Scheduler_Assignments
1145 #if (defined(CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION) && \ 1146 !defined(CONFIGURE_IDLE_TASK_BODY)) 1147 #error "CONFIGURE_ERROR: You did not override the IDLE task body." 1158 #ifndef CONFIGURE_IDLE_TASK_BODY 1159 #if defined(BSP_IDLE_TASK_BODY) 1160 #define CONFIGURE_IDLE_TASK_BODY BSP_IDLE_TASK_BODY 1161 #elif (CPU_PROVIDES_IDLE_THREAD_BODY == TRUE) 1162 #define CONFIGURE_IDLE_TASK_BODY _CPU_Thread_Idle_body 1165 #ifdef CONFIGURE_INIT 1172 #define CONFIGURE_IDLE_TASK_BODY _Thread_Idle_body 1188 #ifndef CONFIGURE_MINIMUM_TASK_STACK_SIZE 1189 #define CONFIGURE_MINIMUM_TASK_STACK_SIZE CPU_STACK_MINIMUM_SIZE 1196 #define CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE \ 1197 (2 * CONFIGURE_MINIMUM_TASK_STACK_SIZE) 1205 #ifndef CONFIGURE_IDLE_TASK_STACK_SIZE 1206 #ifdef BSP_IDLE_TASK_STACK_SIZE 1207 #define CONFIGURE_IDLE_TASK_STACK_SIZE BSP_IDLE_TASK_STACK_SIZE 1209 #define CONFIGURE_IDLE_TASK_STACK_SIZE CONFIGURE_MINIMUM_TASK_STACK_SIZE 1212 #if CONFIGURE_IDLE_TASK_STACK_SIZE < CONFIGURE_MINIMUM_TASK_STACK_SIZE 1213 #error "CONFIGURE_IDLE_TASK_STACK_SIZE less than CONFIGURE_MINIMUM_TASK_STACK_SIZE" 1222 #ifndef CONFIGURE_INTERRUPT_STACK_SIZE 1223 #ifdef BSP_INTERRUPT_STACK_SIZE 1224 #define CONFIGURE_INTERRUPT_STACK_SIZE BSP_INTERRUPT_STACK_SIZE 1226 #define CONFIGURE_INTERRUPT_STACK_SIZE CONFIGURE_MINIMUM_TASK_STACK_SIZE 1237 #if (CPU_ALLOCATE_INTERRUPT_STACK == 0) 1238 #define CONFIGURE_INTERRUPT_STACK_MEMORY 0 1240 #define CONFIGURE_INTERRUPT_STACK_MEMORY \ 1241 _Configure_From_workspace( CONFIGURE_INTERRUPT_STACK_SIZE ) 1247 #ifndef CONFIGURE_TASK_STACK_ALLOCATOR_INIT 1248 #define CONFIGURE_TASK_STACK_ALLOCATOR_INIT NULL 1254 #if !defined(CONFIGURE_TASK_STACK_ALLOCATOR) \ 1255 && !defined(CONFIGURE_TASK_STACK_DEALLOCATOR) 1259 #define CONFIGURE_TASK_STACK_ALLOCATOR _Workspace_Allocate 1263 #define CONFIGURE_TASK_STACK_DEALLOCATOR _Workspace_Free 1264 #elif (defined(CONFIGURE_TASK_STACK_ALLOCATOR) \ 1265 && !defined(CONFIGURE_TASK_STACK_DEALLOCATOR)) \ 1266 || (!defined(CONFIGURE_TASK_STACK_ALLOCATOR) \ 1267 && defined(CONFIGURE_TASK_STACK_DEALLOCATOR)) 1268 #error "CONFIGURE_TASK_STACK_ALLOCATOR and CONFIGURE_TASK_STACK_DEALLOCATOR must be both defined or both undefined" 1281 #ifndef CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY 1282 #ifdef BSP_ZERO_WORKSPACE_AUTOMATICALLY 1283 #define CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY \ 1284 BSP_ZERO_WORKSPACE_AUTOMATICALLY 1286 #define CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY FALSE 1300 #ifdef CONFIGURE_INIT 1307 #ifdef CONFIGURE_UNIFIED_WORK_AREAS 1315 #ifdef CONFIGURE_INIT 1322 const rtems_heap_extend_handler rtems_malloc_extend_handler =
1323 #ifdef CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK 1326 rtems_heap_null_extend;
1330 #ifdef CONFIGURE_INIT 1336 rtems_malloc_dirtier_t rtems_malloc_dirty_helper =
1337 #if defined(CONFIGURE_MALLOC_DIRTY) 1358 #define _Configure_Zero_or_One(_number) ((_number) ? 1 : 0) 1363 #define _Configure_Align_up(_val, _align) \ 1364 (((_val) + (_align) - 1) & ~((_align) - 1)) 1372 #define _Configure_From_workspace(_size) \ 1373 (ssize_t) (_Configure_Zero_or_One(_size) * \ 1374 _Configure_Align_up((_size) + HEAP_BLOCK_HEADER_SIZE, CPU_HEAP_ALIGNMENT)) 1381 #ifdef CONFIGURE_TASK_STACK_FROM_ALLOCATOR 1382 #define _Configure_From_stackspace(_stack_size) \ 1383 CONFIGURE_TASK_STACK_FROM_ALLOCATOR(_stack_size) 1385 #define _Configure_From_stackspace(_stack_size) \ 1386 _Configure_From_workspace(_stack_size) 1393 #define _Configure_Max_Objects(_max) \ 1394 (_Configure_Zero_or_One(_max) * rtems_resource_maximum_per_allocation(_max)) 1403 #define _Configure_Object_RAM(_number, _size) ( \ 1404 _Configure_From_workspace(_Configure_Max_Objects(_number) * (_size)) + \ 1405 _Configure_From_workspace( \ 1406 _Configure_Zero_or_One(_number) * ( \ 1407 (_Configure_Max_Objects(_number) + 1) * sizeof(Objects_Control *) + \ 1408 _Configure_Align_up(sizeof(void *), CPU_ALIGNMENT) + \ 1409 _Configure_Align_up(sizeof(uint32_t), CPU_ALIGNMENT) \ 1426 #ifdef CONFIGURE_RTEMS_INIT_TASKS_TABLE 1428 #ifdef CONFIGURE_HAS_OWN_INIT_TASK_TABLE 1441 #ifndef CONFIGURE_INIT_TASK_NAME 1442 #define CONFIGURE_INIT_TASK_NAME rtems_build_name('U', 'I', '1', ' ') 1449 #ifndef CONFIGURE_INIT_TASK_STACK_SIZE 1450 #define CONFIGURE_INIT_TASK_STACK_SIZE CONFIGURE_MINIMUM_TASK_STACK_SIZE 1457 #ifndef CONFIGURE_INIT_TASK_PRIORITY 1458 #define CONFIGURE_INIT_TASK_PRIORITY 1 1465 #ifndef CONFIGURE_INIT_TASK_ATTRIBUTES 1466 #define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES 1473 #ifndef CONFIGURE_INIT_TASK_ENTRY_POINT 1481 #define CONFIGURE_INIT_TASK_ENTRY_POINT Init 1482 extern const char* bsp_boot_cmdline;
1483 #define CONFIGURE_INIT_TASK_ARGUMENTS ((rtems_task_argument) &bsp_boot_cmdline) 1490 #ifndef CONFIGURE_INIT_TASK_INITIAL_MODES 1491 #if defined(RTEMS_SMP) && defined(CONFIGURE_SMP_APPLICATION) 1492 #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES 1494 #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_NO_PREEMPT 1502 #ifndef CONFIGURE_INIT_TASK_ARGUMENTS 1503 #define CONFIGURE_INIT_TASK_ARGUMENTS 0 1506 #ifdef CONFIGURE_INIT 1508 { CONFIGURE_INIT_TASK_NAME,
1510 CONFIGURE_INIT_TASK_PRIORITY,
1511 CONFIGURE_INIT_TASK_ATTRIBUTES,
1512 CONFIGURE_INIT_TASK_ENTRY_POINT,
1513 CONFIGURE_INIT_TASK_INITIAL_MODES,
1514 CONFIGURE_INIT_TASK_ARGUMENTS
1524 #define CONFIGURE_INIT_TASK_TABLE Initialization_tasks 1531 #define CONFIGURE_INIT_TASK_TABLE_SIZE \ 1532 RTEMS_ARRAY_SIZE(CONFIGURE_INIT_TASK_TABLE) 1543 #define CONFIGURE_INIT_TASK_TABLE NULL 1550 #define CONFIGURE_INIT_TASK_TABLE_SIZE 0 1557 #define CONFIGURE_INIT_TASK_STACK_SIZE 0 1578 #define NULL_DRIVER_TABLE_ENTRY \ 1579 { NULL, NULL, NULL, NULL, NULL, NULL } 1581 #ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER 1582 #include <rtems/console.h> 1585 #ifdef CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER 1586 #include <rtems/clockdrv.h> 1589 #ifdef CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER 1593 #ifdef CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER 1594 #include <rtems/rtc.h> 1597 #ifdef CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER 1601 #ifdef CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER 1605 #ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER 1606 #include <rtems/devnull.h> 1609 #ifdef CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER 1610 #include <rtems/devzero.h> 1613 #ifdef CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER 1615 #ifndef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER 1616 #define CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER 1618 #include <libchip/ide_ctrl.h> 1621 #ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER 1622 #include <libchip/ata.h> 1625 #ifndef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE 1632 #ifndef CONFIGURE_MAXIMUM_DRIVERS 1633 #define CONFIGURE_MAXIMUM_DRIVERS 1636 #ifdef CONFIGURE_INIT 1639 #ifdef CONFIGURE_BSP_PREREQUISITE_DRIVERS 1640 CONFIGURE_BSP_PREREQUISITE_DRIVERS,
1642 #ifdef CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS 1643 CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS,
1645 #ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER 1648 #ifdef CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER 1649 CLOCK_DRIVER_TABLE_ENTRY,
1651 #ifdef CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER 1654 #ifdef CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER 1657 #ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER 1658 DEVNULL_DRIVER_TABLE_ENTRY,
1660 #ifdef CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER 1661 DEVZERO_DRIVER_TABLE_ENTRY,
1663 #ifdef CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER 1664 IDE_CONTROLLER_DRIVER_TABLE_ENTRY,
1666 #ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER 1667 ATA_DRIVER_TABLE_ENTRY,
1669 #ifdef CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER 1672 #ifdef CONFIGURE_APPLICATION_EXTRA_DRIVERS 1673 CONFIGURE_APPLICATION_EXTRA_DRIVERS,
1675 #ifdef CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER 1677 #elif !defined(CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER) && \ 1678 !defined(CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER) && \ 1679 !defined(CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER) && \ 1680 !defined(CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER) && \ 1681 !defined(CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER) && \ 1682 !defined(CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER) && \ 1683 !defined(CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER) && \ 1684 !defined(CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER) && \ 1685 !defined(CONFIGURE_APPLICATION_EXTRA_DRIVERS) 1690 const size_t _IO_Number_of_drivers =
1691 RTEMS_ARRAY_SIZE( _IO_Driver_address_table );
1696 #ifdef CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER 1700 #ifndef CONFIGURE_ATA_DRIVER_TASK_PRIORITY 1701 #define CONFIGURE_ATA_DRIVER_TASK_PRIORITY ATA_DRIVER_TASK_DEFAULT_PRIORITY 1703 #ifdef CONFIGURE_INIT 1705 = CONFIGURE_ATA_DRIVER_TASK_PRIORITY;
1720 #ifdef CONFIGURE_APPLICATION_NEEDS_LIBBLOCK 1725 #ifndef CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS 1726 #define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS \ 1727 RTEMS_BDBUF_MAX_READ_AHEAD_BLOCKS_DEFAULT 1729 #ifndef CONFIGURE_BDBUF_MAX_WRITE_BLOCKS 1730 #define CONFIGURE_BDBUF_MAX_WRITE_BLOCKS \ 1731 RTEMS_BDBUF_MAX_WRITE_BLOCKS_DEFAULT 1733 #ifndef CONFIGURE_SWAPOUT_TASK_PRIORITY 1734 #define CONFIGURE_SWAPOUT_TASK_PRIORITY \ 1735 RTEMS_BDBUF_SWAPOUT_TASK_PRIORITY_DEFAULT 1737 #ifndef CONFIGURE_SWAPOUT_SWAP_PERIOD 1738 #define CONFIGURE_SWAPOUT_SWAP_PERIOD \ 1739 RTEMS_BDBUF_SWAPOUT_TASK_SWAP_PERIOD_DEFAULT 1741 #ifndef CONFIGURE_SWAPOUT_BLOCK_HOLD 1742 #define CONFIGURE_SWAPOUT_BLOCK_HOLD \ 1743 RTEMS_BDBUF_SWAPOUT_TASK_BLOCK_HOLD_DEFAULT 1745 #ifndef CONFIGURE_SWAPOUT_WORKER_TASKS 1746 #define CONFIGURE_SWAPOUT_WORKER_TASKS \ 1747 RTEMS_BDBUF_SWAPOUT_WORKER_TASKS_DEFAULT 1749 #ifndef CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY 1750 #define CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY \ 1751 RTEMS_BDBUF_SWAPOUT_WORKER_TASK_PRIORITY_DEFAULT 1753 #ifndef CONFIGURE_BDBUF_TASK_STACK_SIZE 1754 #define CONFIGURE_BDBUF_TASK_STACK_SIZE \ 1755 RTEMS_BDBUF_TASK_STACK_SIZE_DEFAULT 1757 #ifndef CONFIGURE_BDBUF_CACHE_MEMORY_SIZE 1758 #define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE \ 1759 RTEMS_BDBUF_CACHE_MEMORY_SIZE_DEFAULT 1761 #ifndef CONFIGURE_BDBUF_BUFFER_MIN_SIZE 1762 #define CONFIGURE_BDBUF_BUFFER_MIN_SIZE \ 1763 RTEMS_BDBUF_BUFFER_MIN_SIZE_DEFAULT 1765 #ifndef CONFIGURE_BDBUF_BUFFER_MAX_SIZE 1766 #define CONFIGURE_BDBUF_BUFFER_MAX_SIZE \ 1767 RTEMS_BDBUF_BUFFER_MAX_SIZE_DEFAULT 1769 #ifndef CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY 1770 #define CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY \ 1771 RTEMS_BDBUF_READ_AHEAD_TASK_PRIORITY_DEFAULT 1773 #ifdef CONFIGURE_INIT 1775 CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS,
1776 CONFIGURE_BDBUF_MAX_WRITE_BLOCKS,
1777 CONFIGURE_SWAPOUT_TASK_PRIORITY,
1778 CONFIGURE_SWAPOUT_SWAP_PERIOD,
1779 CONFIGURE_SWAPOUT_BLOCK_HOLD,
1780 CONFIGURE_SWAPOUT_WORKER_TASKS,
1781 CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY,
1782 CONFIGURE_BDBUF_TASK_STACK_SIZE,
1783 CONFIGURE_BDBUF_CACHE_MEMORY_SIZE,
1784 CONFIGURE_BDBUF_BUFFER_MIN_SIZE,
1785 CONFIGURE_BDBUF_BUFFER_MAX_SIZE,
1786 CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
1790 #define CONFIGURE_LIBBLOCK_TASKS \ 1791 (1 + CONFIGURE_SWAPOUT_WORKER_TASKS + \ 1792 (CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS != 0)) 1794 #define CONFIGURE_LIBBLOCK_TASK_EXTRA_STACKS \ 1795 (CONFIGURE_LIBBLOCK_TASKS * \ 1796 (CONFIGURE_BDBUF_TASK_STACK_SIZE <= CONFIGURE_MINIMUM_TASK_STACK_SIZE ? \ 1797 0 : CONFIGURE_BDBUF_TASK_STACK_SIZE - CONFIGURE_MINIMUM_TASK_STACK_SIZE)) 1799 #ifdef RTEMS_BDBUF_USE_PTHREAD 1804 #define CONFIGURE_LIBBLOCK_SEMAPHORES 1 1811 #define CONFIGURE_LIBBLOCK_POSIX_MUTEXES 2 1819 #define CONFIGURE_LIBBLOCK_POSIX_CONDITION_VARIABLES 3 1830 #define CONFIGURE_LIBBLOCK_SEMAPHORES 6 1832 #define CONFIGURE_LIBBLOCK_POSIX_MUTEXES 0 1833 #define CONFIGURE_LIBBLOCK_POSIX_CONDITION_VARIABLES 0 1836 #if defined(CONFIGURE_HAS_OWN_BDBUF_TABLE) || \ 1837 defined(CONFIGURE_BDBUF_BUFFER_SIZE) || \ 1838 defined(CONFIGURE_BDBUF_BUFFER_COUNT) 1839 #error BDBUF Cache does not use a buffer configuration table. Please remove. 1843 #define CONFIGURE_LIBBLOCK_TASKS 0 1845 #define CONFIGURE_LIBBLOCK_TASK_EXTRA_STACKS 0 1847 #define CONFIGURE_LIBBLOCK_SEMAPHORES 0 1849 #define CONFIGURE_LIBBLOCK_POSIX_MUTEXES 0 1854 #define CONFIGURE_LIBBLOCK_POSIX_CONDITION_VARIABLES 0 1875 #ifndef CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK 1876 #define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK 0 1883 #ifndef CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER 1884 #define CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER 0 1888 #if defined(RTEMS_MULTIPROCESSING) 1895 #ifdef CONFIGURE_MP_APPLICATION 1896 #define CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER 1 1898 #ifndef CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE 1900 #ifndef CONFIGURE_MP_NODE_NUMBER 1901 #define CONFIGURE_MP_NODE_NUMBER NODE_NUMBER 1904 #ifndef CONFIGURE_MP_MAXIMUM_NODES 1905 #define CONFIGURE_MP_MAXIMUM_NODES 2 1908 #ifndef CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS 1909 #define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS 32 1911 #define CONFIGURE_MEMORY_FOR_GLOBAL_OBJECTS(_global_objects) \ 1912 _Configure_Object_RAM((_global_objects), sizeof(Objects_MP_Control)) 1914 #ifndef CONFIGURE_MP_MAXIMUM_PROXIES 1915 #define CONFIGURE_MP_MAXIMUM_PROXIES 32 1917 #define CONFIGURE_MEMORY_FOR_PROXIES(_proxies) \ 1918 _Configure_Object_RAM((_proxies) + 1, sizeof(Thread_Proxy_control) ) 1920 #ifndef CONFIGURE_MP_MPCI_TABLE_POINTER 1922 #define CONFIGURE_MP_MPCI_TABLE_POINTER &MPCI_table 1925 #ifdef CONFIGURE_INIT 1926 rtems_multiprocessing_table Multiprocessing_configuration = {
1927 CONFIGURE_MP_NODE_NUMBER,
1928 CONFIGURE_MP_MAXIMUM_NODES,
1929 CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS,
1930 CONFIGURE_MP_MAXIMUM_PROXIES,
1932 CONFIGURE_MP_MPCI_TABLE_POINTER
1936 #define CONFIGURE_MULTIPROCESSING_TABLE &Multiprocessing_configuration 1942 #define CONFIGURE_MULTIPROCESSING_TABLE NULL 1952 #if defined(CONFIGURE_UNLIMITED_OBJECTS) 1953 #if !defined(CONFIGURE_UNIFIED_WORK_AREAS) && \ 1954 !defined(CONFIGURE_EXECUTIVE_RAM_SIZE) && \ 1955 !defined(CONFIGURE_MEMORY_OVERHEAD) 1956 #error "CONFIGURE_UNLIMITED_OBJECTS requires a unified work area, an executive RAM size, or a defined workspace memory overhead" 1959 #if !defined(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 1964 #define CONFIGURE_UNLIMITED_ALLOCATION_SIZE 8 1966 #if !defined(CONFIGURE_MAXIMUM_TASKS) 1967 #define CONFIGURE_MAXIMUM_TASKS \ 1968 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 1970 #if !defined(CONFIGURE_MAXIMUM_TIMERS) 1971 #define CONFIGURE_MAXIMUM_TIMERS \ 1972 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 1974 #if !defined(CONFIGURE_MAXIMUM_SEMAPHORES) 1975 #define CONFIGURE_MAXIMUM_SEMAPHORES \ 1976 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 1978 #if !defined(CONFIGURE_MAXIMUM_MESSAGE_QUEUES) 1979 #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES \ 1980 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 1982 #if !defined(CONFIGURE_MAXIMUM_PARTITIONS) 1983 #define CONFIGURE_MAXIMUM_PARTITIONS \ 1984 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 1986 #if !defined(CONFIGURE_MAXIMUM_REGIONS) 1987 #define CONFIGURE_MAXIMUM_REGIONS \ 1988 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 1990 #if !defined(CONFIGURE_MAXIMUM_PORTS) 1991 #define CONFIGURE_MAXIMUM_PORTS \ 1992 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 1994 #if !defined(CONFIGURE_MAXIMUM_PERIODS) 1995 #define CONFIGURE_MAXIMUM_PERIODS \ 1996 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 1998 #if !defined(CONFIGURE_MAXIMUM_BARRIERS) 1999 #define CONFIGURE_MAXIMUM_BARRIERS \ 2000 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 2002 #if !defined(CONFIGURE_MAXIMUM_POSIX_KEYS) 2003 #define CONFIGURE_MAXIMUM_POSIX_KEYS \ 2004 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 2006 #if !defined(CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS) 2007 #define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS \ 2008 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 2011 #ifdef RTEMS_POSIX_API 2012 #if !defined(CONFIGURE_MAXIMUM_POSIX_THREADS) 2013 #define CONFIGURE_MAXIMUM_POSIX_THREADS \ 2014 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 2016 #if !defined(CONFIGURE_MAXIMUM_POSIX_MUTEXES) 2017 #define CONFIGURE_MAXIMUM_POSIX_MUTEXES \ 2018 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 2020 #if !defined(CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES) 2021 #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES \ 2022 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 2024 #if !defined(CONFIGURE_MAXIMUM_POSIX_TIMERS) 2025 #define CONFIGURE_MAXIMUM_POSIX_TIMERS \ 2026 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 2034 #if !defined(CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES) 2035 #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES \ 2036 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 2038 #if !defined(CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS) 2039 #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS \ 2040 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 2042 #if !defined(CONFIGURE_MAXIMUM_POSIX_SEMAPHORES) 2043 #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES \ 2044 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 2046 #if !defined(CONFIGURE_MAXIMUM_POSIX_BARRIERS) 2047 #define CONFIGURE_MAXIMUM_POSIX_BARRIERS \ 2048 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 2050 #if !defined(CONFIGURE_MAXIMUM_POSIX_RWLOCKS) 2051 #define CONFIGURE_MAXIMUM_POSIX_RWLOCKS \ 2052 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 2054 #if !defined(CONFIGURE_MAXIMUM_POSIX_SPINLOCKS) 2055 #define CONFIGURE_MAXIMUM_POSIX_SPINLOCKS \ 2056 rtems_resource_unlimited(CONFIGURE_UNLIMITED_ALLOCATION_SIZE) 2071 #ifndef CONFIGURE_HAS_OWN_CONFIGURATION_TABLE 2074 #ifndef CONFIGURE_MAXIMUM_TASKS 2075 #define CONFIGURE_MAXIMUM_TASKS 0 2084 #define CONFIGURE_TASKS \ 2085 (CONFIGURE_MAXIMUM_TASKS + CONFIGURE_LIBBLOCK_TASKS) 2091 #if defined(CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS) 2092 #warning "Classic API Notepads are deprecated and will be removed." 2094 #if defined(CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS) 2095 #warning "Classic API Notepads are deprecated and will be removed." 2099 #ifdef CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS 2100 #define CONFIGURE_NOTEPADS_ENABLED TRUE 2102 #define CONFIGURE_NOTEPADS_ENABLED FALSE 2115 #if defined(RTEMS_SMP) 2116 #ifdef CONFIGURE_MAXIMUM_TASK_VARIABLES 2117 #warning "Per-Task Variables are deprecated and will be removed." 2118 #error "Per-Task Variables are not safe for SMP systems and disabled." 2120 #define CONFIGURE_MAXIMUM_TASK_VARIABLES 0 2121 #define CONFIGURE_MEMORY_FOR_TASK_VARIABLES(_task_variables) 0 2123 #ifndef CONFIGURE_MAXIMUM_TASK_VARIABLES 2125 #define CONFIGURE_MAXIMUM_TASK_VARIABLES 0 2132 #define CONFIGURE_MEMORY_FOR_TASK_VARIABLES(_task_variables) 0 2134 #warning "Per-Task Variables are deprecated and will be removed." 2135 #define CONFIGURE_MEMORY_FOR_TASK_VARIABLES(_task_variables) \ 2136 (_task_variables) * \ 2137 _Configure_From_workspace(sizeof(rtems_task_variable_t)) 2141 #ifndef CONFIGURE_MAXIMUM_TIMERS 2143 #define CONFIGURE_MAXIMUM_TIMERS 0 2150 #define CONFIGURE_MEMORY_FOR_TIMERS(_timers) 0 2152 #define CONFIGURE_MEMORY_FOR_TIMERS(_timers) \ 2153 _Configure_Object_RAM(_timers, sizeof(Timer_Control) ) 2156 #ifndef CONFIGURE_MAXIMUM_SEMAPHORES 2158 #define CONFIGURE_MAXIMUM_SEMAPHORES 0 2166 #ifdef RTEMS_NETWORKING 2167 #define CONFIGURE_NETWORKING_SEMAPHORES 1 2169 #define CONFIGURE_NETWORKING_SEMAPHORES 0 2179 #define CONFIGURE_SEMAPHORES \ 2180 (CONFIGURE_MAXIMUM_SEMAPHORES + CONFIGURE_LIBIO_SEMAPHORES + \ 2181 CONFIGURE_TERMIOS_SEMAPHORES + CONFIGURE_LIBBLOCK_SEMAPHORES + \ 2182 CONFIGURE_SEMAPHORES_FOR_FILE_SYSTEMS + \ 2183 CONFIGURE_NETWORKING_SEMAPHORES + CONFIGURE_DRVMGR_SEMAPHORES) 2192 #if !defined(RTEMS_SMP) || \ 2193 !defined(CONFIGURE_MAXIMUM_MRSP_SEMAPHORES) 2194 #define CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES 0 2196 #define CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES \ 2197 CONFIGURE_MAXIMUM_MRSP_SEMAPHORES * \ 2198 _Configure_From_workspace( \ 2199 RTEMS_ARRAY_SIZE(_Scheduler_Table) * sizeof(Priority_Control) \ 2212 #if CONFIGURE_SEMAPHORES == 0 2213 #define CONFIGURE_MEMORY_FOR_SEMAPHORES(_semaphores) 0 2215 #define CONFIGURE_MEMORY_FOR_SEMAPHORES(_semaphores) \ 2216 _Configure_Object_RAM(_semaphores, sizeof(Semaphore_Control) ) + \ 2217 CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES 2220 #ifndef CONFIGURE_MAXIMUM_MESSAGE_QUEUES 2225 #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 0 2232 #define CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(_queues) 0 2234 #define CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(_queues) \ 2235 _Configure_Object_RAM(_queues, sizeof(Message_queue_Control) ) 2238 #ifndef CONFIGURE_MAXIMUM_PARTITIONS 2243 #define CONFIGURE_MAXIMUM_PARTITIONS 0 2250 #define CONFIGURE_MEMORY_FOR_PARTITIONS(_partitions) 0 2252 #define CONFIGURE_MEMORY_FOR_PARTITIONS(_partitions) \ 2253 _Configure_Object_RAM(_partitions, sizeof(Partition_Control) ) 2256 #ifndef CONFIGURE_MAXIMUM_REGIONS 2261 #define CONFIGURE_MAXIMUM_REGIONS 0 2268 #define CONFIGURE_MEMORY_FOR_REGIONS(_regions) 0 2270 #define CONFIGURE_MEMORY_FOR_REGIONS(_regions) \ 2271 _Configure_Object_RAM(_regions, sizeof(Region_Control) ) 2274 #ifndef CONFIGURE_MAXIMUM_PORTS 2279 #define CONFIGURE_MAXIMUM_PORTS 0 2286 #define CONFIGURE_MEMORY_FOR_PORTS(_ports) 0 2288 #define CONFIGURE_MEMORY_FOR_PORTS(_ports) \ 2289 _Configure_Object_RAM(_ports, sizeof(Dual_ported_memory_Control) ) 2292 #ifndef CONFIGURE_MAXIMUM_PERIODS 2297 #define CONFIGURE_MAXIMUM_PERIODS 0 2304 #define CONFIGURE_MEMORY_FOR_PERIODS(_periods) 0 2306 #define CONFIGURE_MEMORY_FOR_PERIODS(_periods) \ 2307 _Configure_Object_RAM(_periods, sizeof(Rate_monotonic_Control) ) 2314 #ifndef CONFIGURE_MAXIMUM_BARRIERS 2315 #define CONFIGURE_MAXIMUM_BARRIERS 0 2324 #define CONFIGURE_BARRIERS \ 2325 (CONFIGURE_MAXIMUM_BARRIERS + CONFIGURE_BARRIERS_FOR_FIFOS) 2333 #if CONFIGURE_BARRIERS == 0 2334 #define CONFIGURE_MEMORY_FOR_BARRIERS(_barriers) 0 2336 #define CONFIGURE_MEMORY_FOR_BARRIERS(_barriers) \ 2337 _Configure_Object_RAM(_barriers, sizeof(Barrier_Control) ) 2340 #ifndef CONFIGURE_MAXIMUM_USER_EXTENSIONS 2345 #define CONFIGURE_MAXIMUM_USER_EXTENSIONS 0 2352 #define CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(_extensions) 0 2354 #define CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(_extensions) \ 2355 _Configure_Object_RAM(_extensions, sizeof(Extension_Control) ) 2370 #ifndef CONFIGURE_MICROSECONDS_PER_TICK 2371 #define CONFIGURE_MICROSECONDS_PER_TICK \ 2372 RTEMS_MILLISECONDS_TO_MICROSECONDS(10) 2376 #ifndef CONFIGURE_TICKS_PER_TIMESLICE 2377 #define CONFIGURE_TICKS_PER_TIMESLICE 50 2386 #ifdef CONFIGURE_INIT 2387 #ifdef CONFIGURE_STACK_CHECKER_ENABLED 2388 #include <rtems/stackchk.h> 2392 #if defined(BSP_INITIAL_EXTENSION) || \ 2393 defined(CONFIGURE_INITIAL_EXTENSIONS) || \ 2394 defined(CONFIGURE_STACK_CHECKER_ENABLED) || \ 2395 (defined(RTEMS_NEWLIB) && !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY)) 2397 #if !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY) 2398 RTEMS_NEWLIB_EXTENSION,
2400 #if defined(CONFIGURE_STACK_CHECKER_ENABLED) 2403 #if defined(CONFIGURE_INITIAL_EXTENSIONS) 2404 CONFIGURE_INITIAL_EXTENSIONS,
2406 #if defined(BSP_INITIAL_EXTENSION) 2407 BSP_INITIAL_EXTENSION
2411 #define CONFIGURE_INITIAL_EXTENSION_TABLE Configuration_Initial_Extensions 2412 #define CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS \ 2413 RTEMS_ARRAY_SIZE(Configuration_Initial_Extensions) 2415 #define CONFIGURE_INITIAL_EXTENSION_TABLE NULL 2416 #define CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS 0 2419 #if defined(RTEMS_NEWLIB) && defined(__DYNAMIC_REENT__) 2420 struct _reent *__getreent(
void)
2422 #ifdef CONFIGURE_DISABLE_NEWLIB_REENTRANCY 2423 return _GLOBAL_REENT;
2448 #ifndef CONFIGURE_MAXIMUM_POSIX_KEYS 2449 #define CONFIGURE_MAXIMUM_POSIX_KEYS 0 2458 #ifndef CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 2459 #define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS \ 2460 (CONFIGURE_MAXIMUM_POSIX_KEYS * \ 2461 (CONFIGURE_MAXIMUM_POSIX_THREADS + CONFIGURE_MAXIMUM_TASKS)) 2471 #define CONFIGURE_POSIX_KEYS \ 2472 (CONFIGURE_MAXIMUM_POSIX_KEYS + CONFIGURE_LIBIO_POSIX_KEYS) 2480 #define CONFIGURE_MEMORY_FOR_POSIX_KEYS(_keys, _key_value_pairs) \ 2481 (_Configure_Object_RAM(_keys, sizeof(POSIX_Keys_Control) ) \ 2482 + _Configure_From_workspace( \ 2483 _Configure_Max_Objects(_key_value_pairs) \ 2484 * sizeof(POSIX_Keys_Key_value_pair))) 2490 #ifdef RTEMS_POSIX_API 2491 #include <sys/types.h> 2513 #define _Configure_POSIX_Named_Object_RAM(_number, _size) \ 2514 _Configure_Object_RAM( (_number), _size ) + \ 2515 (_Configure_Max_Objects(_number) * _Configure_From_workspace(NAME_MAX) ) 2521 #ifndef CONFIGURE_MAXIMUM_POSIX_THREADS 2522 #define CONFIGURE_MAXIMUM_POSIX_THREADS 0 2529 #ifndef CONFIGURE_MAXIMUM_POSIX_MUTEXES 2530 #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 0 2539 #define CONFIGURE_MEMORY_FOR_POSIX_MUTEXES(_mutexes) \ 2540 _Configure_Object_RAM(_mutexes, sizeof(POSIX_Mutex_Control) ) 2546 #ifndef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 2547 #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 0 2556 #define CONFIGURE_MEMORY_FOR_POSIX_CONDITION_VARIABLES(_condvars) \ 2557 _Configure_Object_RAM(_condvars, \ 2558 sizeof(POSIX_Condition_variables_Control) ) 2564 #ifndef CONFIGURE_MAXIMUM_POSIX_TIMERS 2565 #define CONFIGURE_MAXIMUM_POSIX_TIMERS 0 2574 #define CONFIGURE_MEMORY_FOR_POSIX_TIMERS(_timers) \ 2575 _Configure_Object_RAM(_timers, sizeof(POSIX_Timer_Control) ) 2581 #ifndef CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 2582 #define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 0 2591 #define CONFIGURE_MEMORY_FOR_POSIX_QUEUED_SIGNALS(_queued_signals) \ 2592 _Configure_From_workspace( \ 2593 (_queued_signals) * (sizeof(POSIX_signals_Siginfo_node)) ) 2599 #ifndef CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 2600 #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 0 2609 #ifndef CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS 2610 #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS \ 2611 CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 2620 #define CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUES(_message_queues) \ 2621 _Configure_POSIX_Named_Object_RAM( \ 2622 _message_queues, sizeof(POSIX_Message_queue_Control) ) 2630 #define CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUE_DESCRIPTORS(_mqueue_fds) \ 2631 _Configure_Object_RAM( \ 2632 _mqueue_fds, sizeof(POSIX_Message_queue_Control_fd) ) 2638 #ifndef CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 2639 #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 0 2648 #define CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES(_semaphores) \ 2649 _Configure_POSIX_Named_Object_RAM( \ 2650 _semaphores, sizeof(POSIX_Semaphore_Control) ) 2656 #ifndef CONFIGURE_MAXIMUM_POSIX_BARRIERS 2657 #define CONFIGURE_MAXIMUM_POSIX_BARRIERS 0 2666 #define CONFIGURE_MEMORY_FOR_POSIX_BARRIERS(_barriers) \ 2667 _Configure_Object_RAM(_barriers, sizeof(POSIX_Barrier_Control) ) 2673 #ifndef CONFIGURE_MAXIMUM_POSIX_SPINLOCKS 2674 #define CONFIGURE_MAXIMUM_POSIX_SPINLOCKS 0 2683 #define CONFIGURE_MEMORY_FOR_POSIX_SPINLOCKS(_spinlocks) \ 2684 _Configure_Object_RAM(_spinlocks, sizeof(POSIX_Spinlock_Control) ) 2690 #ifndef CONFIGURE_MAXIMUM_POSIX_RWLOCKS 2691 #define CONFIGURE_MAXIMUM_POSIX_RWLOCKS 0 2700 #define CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS(_rwlocks) \ 2701 _Configure_Object_RAM(_rwlocks, sizeof(POSIX_RWLock_Control) ) 2703 #ifdef CONFIGURE_POSIX_INIT_THREAD_TABLE 2705 #ifdef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE 2714 #ifndef CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT 2715 #define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT POSIX_Init 2718 #ifndef CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE 2719 #define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE \ 2720 CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE 2723 #ifdef CONFIGURE_INIT 2725 { CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT, \
2726 CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE }
2730 #define CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME \ 2731 POSIX_Initialization_threads 2733 #define CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE \ 2734 RTEMS_ARRAY_SIZE(CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME) 2740 #define CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME NULL 2741 #define CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE 0 2751 #define CONFIGURE_MAXIMUM_POSIX_THREADS 0 2759 #ifndef CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE 2760 #define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE 0 2773 #ifdef CONFIGURE_GNAT_RTEMS 2779 #define CONFIGURE_GNAT_MUTEXES 10 2786 #ifndef CONFIGURE_MAXIMUM_ADA_TASKS 2787 #define CONFIGURE_MAXIMUM_ADA_TASKS 20 2793 #ifndef CONFIGURE_MAXIMUM_FAKE_ADA_TASKS 2794 #define CONFIGURE_MAXIMUM_FAKE_ADA_TASKS 0 2799 #define CONFIGURE_GNAT_MUTEXES 0 2801 #define CONFIGURE_MAXIMUM_ADA_TASKS 0 2806 #define CONFIGURE_MAXIMUM_FAKE_ADA_TASKS 0 2819 #ifdef CONFIGURE_ENABLE_GO 2821 #ifndef CONFIGURE_MAXIMUM_POSIX_THREADS 2822 #define CONFIGURE_MAXIMUM_POSIX_THREADS 1 2824 #ifndef CONFIGURE_MAXIMUM_POSIX_MUTEXES 2825 #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 1 2827 #ifndef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 2828 #define CONFIGURE_MAXIMUM_CONDITION_VARIABLES 1 2831 #define CONFIGURE_GO_INIT_MUTEXES 77 2832 #define CONFIGURE_GO_INIT_CONDITION_VARIABLES 4 2834 #ifndef CONFIGURE_MAXIMUM_GOROUTINES 2835 #define CONFIGURE_MAXIMUM_GOROUTINES 400 2838 #define CONFIGURE_GOROUTINES_TASK_VARIABLES \ 2839 (2 * CONFIGURE_MAXIMUM_GOROUTINES) 2841 #ifndef CONFIGURE_MAXIMUM_GO_CHANNELS 2842 #define CONFIGURE_MAXIMUM_GO_CHANNELS 500 2852 #define CONFIGURE_GO_INIT_MUTEXES 0 2860 #define CONFIGURE_GO_INIT_CONDITION_VARIABLES 0 2863 #define CONFIGURE_MAXIMUM_GOROUTINES 0 2866 #define CONFIGURE_GOROUTINES_TASK_VARIABLES 0 2869 #define CONFIGURE_MAXIMUM_GO_CHANNELS 0 2877 #ifndef CONFIGURE_EXTRA_TASK_STACKS 2878 #define CONFIGURE_EXTRA_TASK_STACKS 0 2884 #define CONFIGURE_POSIX_THREADS \ 2885 (CONFIGURE_MAXIMUM_POSIX_THREADS + \ 2886 CONFIGURE_MAXIMUM_ADA_TASKS + \ 2887 CONFIGURE_MAXIMUM_GOROUTINES) 2889 #ifdef RTEMS_POSIX_API 2893 #define CONFIGURE_POSIX_MUTEXES \ 2894 (CONFIGURE_MAXIMUM_POSIX_MUTEXES + \ 2895 CONFIGURE_LIBBLOCK_POSIX_MUTEXES + \ 2896 CONFIGURE_GNAT_MUTEXES + \ 2897 CONFIGURE_MAXIMUM_ADA_TASKS + \ 2898 CONFIGURE_MAXIMUM_FAKE_ADA_TASKS + \ 2899 CONFIGURE_GO_INIT_MUTEXES + \ 2900 CONFIGURE_MAXIMUM_GO_CHANNELS) 2907 #define CONFIGURE_POSIX_CONDITION_VARIABLES \ 2908 (CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES + \ 2909 CONFIGURE_LIBBLOCK_POSIX_CONDITION_VARIABLES + \ 2910 CONFIGURE_MAXIMUM_ADA_TASKS + \ 2911 CONFIGURE_MAXIMUM_FAKE_ADA_TASKS + \ 2912 CONFIGURE_GO_INIT_CONDITION_VARIABLES + \ 2913 CONFIGURE_MAXIMUM_GO_CHANNELS) 2921 #define CONFIGURE_MEMORY_FOR_POSIX \ 2922 (CONFIGURE_MEMORY_FOR_POSIX_MUTEXES(CONFIGURE_POSIX_MUTEXES) + \ 2923 CONFIGURE_MEMORY_FOR_POSIX_CONDITION_VARIABLES( \ 2924 CONFIGURE_POSIX_CONDITION_VARIABLES) + \ 2925 CONFIGURE_MEMORY_FOR_POSIX_QUEUED_SIGNALS( \ 2926 CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS) + \ 2927 CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUES( \ 2928 CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES) + \ 2929 CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUE_DESCRIPTORS( \ 2930 CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS) + \ 2931 CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( \ 2932 CONFIGURE_MAXIMUM_POSIX_SEMAPHORES) + \ 2933 CONFIGURE_MEMORY_FOR_POSIX_BARRIERS(CONFIGURE_MAXIMUM_POSIX_BARRIERS) + \ 2934 CONFIGURE_MEMORY_FOR_POSIX_SPINLOCKS( \ 2935 CONFIGURE_MAXIMUM_POSIX_SPINLOCKS) + \ 2936 CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS( \ 2937 CONFIGURE_MAXIMUM_POSIX_RWLOCKS) + \ 2938 CONFIGURE_MEMORY_FOR_POSIX_TIMERS(CONFIGURE_MAXIMUM_POSIX_TIMERS)) 2946 #define CONFIGURE_MEMORY_FOR_POSIX 0 2954 #define CONFIGURE_HEAP_HANDLER_OVERHEAD \ 2955 _Configure_Align_up( HEAP_BLOCK_HEADER_SIZE, CPU_HEAP_ALIGNMENT ) 2960 #ifndef CONFIGURE_EXECUTIVE_RAM_SIZE 2970 #define CONFIGURE_MEMORY_FOR_TASKS(_tasks, _number_FP_tasks) \ 2972 _Configure_Object_RAM(_tasks, sizeof(Configuration_Thread_control)) \ 2973 + _Configure_Max_Objects(_number_FP_tasks) \ 2974 * _Configure_From_workspace(CONTEXT_FP_SIZE) \ 2983 #ifdef CONFIGURE_MP_APPLICATION 2984 #define CONFIGURE_MEMORY_FOR_MP \ 2985 (CONFIGURE_MEMORY_FOR_PROXIES(CONFIGURE_MP_MAXIMUM_PROXIES) + \ 2986 CONFIGURE_MEMORY_FOR_GLOBAL_OBJECTS( \ 2987 CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS) + \ 2988 CONFIGURE_MEMORY_FOR_TASKS(1, 1) \ 2991 #define CONFIGURE_MEMORY_FOR_MP 0 2999 #define CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(_messages, _size) \ 3000 _Configure_From_workspace( \ 3001 (_messages) * ((_size) + sizeof(CORE_message_queue_Buffer_control))) 3010 #ifndef CONFIGURE_MESSAGE_BUFFER_MEMORY 3011 #define CONFIGURE_MESSAGE_BUFFER_MEMORY 0 3026 #ifndef CONFIGURE_MEMORY_OVERHEAD 3027 #define CONFIGURE_MEMORY_OVERHEAD 0 3034 #define CONFIGURE_API_MUTEX_MEMORY \ 3035 _Configure_Object_RAM(2, sizeof(API_Mutex_Control)) 3041 #if defined(RTEMS_SMP) 3042 #define CONFIGURE_IDLE_TASKS_COUNT CONFIGURE_SMP_MAXIMUM_PROCESSORS 3044 #define CONFIGURE_IDLE_TASKS_COUNT 1 3051 #if CPU_IDLE_TASK_IS_FP == TRUE 3052 #define CONFIGURE_MEMORY_FOR_IDLE_TASK \ 3053 CONFIGURE_MEMORY_FOR_TASKS( \ 3054 CONFIGURE_IDLE_TASKS_COUNT, CONFIGURE_IDLE_TASKS_COUNT) 3056 #define CONFIGURE_MEMORY_FOR_IDLE_TASK \ 3057 CONFIGURE_MEMORY_FOR_TASKS(CONFIGURE_IDLE_TASKS_COUNT, 0) 3063 #define CONFIGURE_MEMORY_FOR_SYSTEM_OVERHEAD \ 3064 ( CONFIGURE_MEMORY_FOR_IDLE_TASK + \ 3065 CONFIGURE_INTERRUPT_STACK_MEMORY + \ 3066 CONFIGURE_API_MUTEX_MEMORY \ 3073 #define CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS \ 3074 (CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS == 0 ? 0 : \ 3075 _Configure_From_workspace( \ 3076 CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS \ 3077 * sizeof(User_extensions_Switch_control) \ 3084 #define CONFIGURE_MEMORY_FOR_CLASSIC \ 3085 (CONFIGURE_MEMORY_FOR_TASK_VARIABLES(CONFIGURE_MAXIMUM_TASK_VARIABLES + \ 3086 CONFIGURE_GOROUTINES_TASK_VARIABLES) + \ 3087 CONFIGURE_MEMORY_FOR_TIMERS(CONFIGURE_MAXIMUM_TIMERS + \ 3088 CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER ) + \ 3089 CONFIGURE_MEMORY_FOR_SEMAPHORES(CONFIGURE_SEMAPHORES) + \ 3090 CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(CONFIGURE_MAXIMUM_MESSAGE_QUEUES) + \ 3091 CONFIGURE_MEMORY_FOR_PARTITIONS(CONFIGURE_MAXIMUM_PARTITIONS) + \ 3092 CONFIGURE_MEMORY_FOR_REGIONS( CONFIGURE_MAXIMUM_REGIONS ) + \ 3093 CONFIGURE_MEMORY_FOR_PORTS(CONFIGURE_MAXIMUM_PORTS) + \ 3094 CONFIGURE_MEMORY_FOR_PERIODS(CONFIGURE_MAXIMUM_PERIODS) + \ 3095 CONFIGURE_MEMORY_FOR_BARRIERS(CONFIGURE_BARRIERS) + \ 3096 CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(CONFIGURE_MAXIMUM_USER_EXTENSIONS) \ 3104 #if defined(RTEMS_SMP) 3105 #define CONFIGURE_MEMORY_FOR_SMP \ 3106 (CONFIGURE_SMP_MAXIMUM_PROCESSORS * \ 3107 _Configure_From_workspace( CONFIGURE_INTERRUPT_STACK_SIZE ) \ 3110 #define CONFIGURE_MEMORY_FOR_SMP 0 3118 #define CONFIGURE_EXECUTIVE_RAM_SIZE \ 3120 CONFIGURE_MEMORY_FOR_SYSTEM_OVERHEAD + \ 3121 CONFIGURE_MEMORY_FOR_TASKS( \ 3122 CONFIGURE_TASKS, CONFIGURE_TASKS) + \ 3123 CONFIGURE_MEMORY_FOR_TASKS( \ 3124 CONFIGURE_POSIX_THREADS, CONFIGURE_POSIX_THREADS) + \ 3125 CONFIGURE_MEMORY_FOR_CLASSIC + \ 3126 CONFIGURE_MEMORY_FOR_POSIX_KEYS( \ 3127 CONFIGURE_POSIX_KEYS, \ 3128 CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS ) + \ 3129 CONFIGURE_MEMORY_FOR_POSIX + \ 3130 CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS + \ 3131 CONFIGURE_MEMORY_FOR_MP + \ 3132 CONFIGURE_MEMORY_FOR_SMP + \ 3133 CONFIGURE_MESSAGE_BUFFER_MEMORY + \ 3134 (CONFIGURE_MEMORY_OVERHEAD * 1024) + \ 3135 CONFIGURE_HEAP_HANDLER_OVERHEAD \ 3149 #if (CONFIGURE_INIT_TASK_STACK_SIZE > CONFIGURE_MINIMUM_TASK_STACK_SIZE) 3150 #define CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART \ 3151 (CONFIGURE_INIT_TASK_STACK_SIZE - CONFIGURE_MINIMUM_TASK_STACK_SIZE) 3153 #define CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART 0 3162 #if defined(RTEMS_POSIX_API) && \ 3163 (CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE > \ 3164 CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE) 3165 #define CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART \ 3166 (CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE - \ 3167 CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE) 3169 #define CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART 0 3178 #define CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS \ 3179 (CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART + \ 3180 CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART) 3188 #define CONFIGURE_IDLE_TASKS_STACK \ 3189 (CONFIGURE_IDLE_TASKS_COUNT * \ 3190 _Configure_From_stackspace( CONFIGURE_IDLE_TASK_STACK_SIZE ) ) 3198 #define CONFIGURE_TASKS_STACK \ 3199 (_Configure_Max_Objects( CONFIGURE_TASKS ) * \ 3200 _Configure_From_stackspace( CONFIGURE_MINIMUM_TASK_STACK_SIZE ) ) 3208 #define CONFIGURE_POSIX_THREADS_STACK \ 3209 (_Configure_Max_Objects( CONFIGURE_MAXIMUM_POSIX_THREADS ) * \ 3210 _Configure_From_stackspace( CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE ) ) 3218 #define CONFIGURE_ADA_TASKS_STACK \ 3219 (_Configure_Max_Objects( CONFIGURE_MAXIMUM_ADA_TASKS ) * \ 3220 _Configure_From_stackspace( CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE ) ) 3228 #define CONFIGURE_GOROUTINES_STACK \ 3229 (_Configure_Max_Objects( CONFIGURE_MAXIMUM_GOROUTINES ) * \ 3230 _Configure_From_stackspace( CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE ) ) 3234 #define CONFIGURE_IDLE_TASKS_STACK 0 3235 #define CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS 0 3236 #define CONFIGURE_TASKS_STACK 0 3237 #define CONFIGURE_POSIX_THREADS_STACK 0 3238 #define CONFIGURE_GOROUTINES_STACK 0 3239 #define CONFIGURE_ADA_TASKS_STACK 0 3241 #if CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK != 0 3242 #error "CONFIGURE_EXECUTIVE_RAM_SIZE defined with request for CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK" 3245 #if CONFIGURE_EXTRA_TASK_STACKS != 0 3246 #error "CONFIGURE_EXECUTIVE_RAM_SIZE defined with request for CONFIGURE_EXTRA_TASK_STACKS" 3257 #define CONFIGURE_STACK_SPACE_SIZE \ 3259 CONFIGURE_IDLE_TASKS_STACK + \ 3260 CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS + \ 3261 CONFIGURE_TASKS_STACK + \ 3262 CONFIGURE_POSIX_THREADS_STACK + \ 3263 CONFIGURE_GOROUTINES_STACK + \ 3264 CONFIGURE_ADA_TASKS_STACK + \ 3265 CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK + \ 3266 CONFIGURE_LIBBLOCK_TASK_EXTRA_STACKS + \ 3267 CONFIGURE_EXTRA_TASK_STACKS + \ 3268 CONFIGURE_HEAP_HANDLER_OVERHEAD \ 3271 #ifdef CONFIGURE_INIT 3274 #if CONFIGURE_MAXIMUM_USER_EXTENSIONS > 0 3279 #ifdef CONFIGURE_SCHEDULER_CBS 3282 #ifdef CONFIGURE_SCHEDULER_EDF 3285 #ifdef CONFIGURE_SCHEDULER_PRIORITY 3288 #ifdef CONFIGURE_SCHEDULER_SIMPLE_SMP 3291 #ifdef CONFIGURE_SCHEDULER_PRIORITY_SMP 3294 #ifdef CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP 3297 #ifdef CONFIGURE_SCHEDULER_USER_PER_THREAD 3298 CONFIGURE_SCHEDULER_USER_PER_THREAD User;
3302 #if defined(CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS) 3305 #ifdef RTEMS_POSIX_API 3308 #if !defined(RTEMS_SCHEDSIM) \ 3309 && defined(RTEMS_NEWLIB) \ 3310 && !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY) 3311 struct _reent Newlib;
3315 } Configuration_Thread_control;
3321 offsetof( Configuration_Thread_control, Control.Scheduler.node ),
3322 offsetof( Configuration_Thread_control, Scheduler )
3325 Configuration_Thread_control,
3328 offsetof( Configuration_Thread_control, API_RTEMS )
3331 Configuration_Thread_control,
3334 offsetof( Configuration_Thread_control, Newlib )
3336 #ifdef RTEMS_POSIX_API 3339 Configuration_Thread_control,
3342 offsetof( Configuration_Thread_control, API_POSIX )
3348 RTEMS_ARRAY_SIZE( _Thread_Control_add_ons );
3368 #ifdef RTEMS_POSIX_API 3374 CONFIGURE_POSIX_MUTEXES,
3375 CONFIGURE_POSIX_CONDITION_VARIABLES,
3376 CONFIGURE_MAXIMUM_POSIX_TIMERS,
3377 CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS,
3378 CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES,
3379 CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS,
3380 CONFIGURE_MAXIMUM_POSIX_SEMAPHORES,
3381 CONFIGURE_MAXIMUM_POSIX_BARRIERS,
3382 CONFIGURE_MAXIMUM_POSIX_RWLOCKS,
3383 CONFIGURE_MAXIMUM_POSIX_SPINLOCKS,
3384 CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE,
3385 CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME
3431 #ifdef CONFIGURE_UNIFIED_WORK_AREAS 3436 #ifdef CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE 3444 #ifdef CONFIGURE_SMP_APPLICATION 3450 CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS,
3451 CONFIGURE_INITIAL_EXTENSION_TABLE,
3452 #if defined(RTEMS_MULTIPROCESSING) 3453 CONFIGURE_MULTIPROCESSING_TABLE,
3456 CONFIGURE_SMP_MAXIMUM_PROCESSORS,
3463 #if defined(RTEMS_SMP) 3467 #if defined(CONFIGURE_INIT) 3477 #ifdef CONFIGURE_INIT 3478 #if defined(CONFIGURE_RTEMS_INIT_TASKS_TABLE) || \ 3479 defined(CONFIGURE_HAS_OWN_INIT_TASK_TABLE) 3491 #ifdef RTEMS_POSIX_API 3492 #ifdef CONFIGURE_INIT 3493 #if defined(CONFIGURE_POSIX_INIT_THREAD_TABLE) || \ 3494 defined(CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE) 3506 #ifdef RTEMS_PCI_CONFIG_LIB 3507 #ifdef CONFIGURE_INIT 3508 #define PCI_LIB_NONE 0 3509 #define PCI_LIB_AUTO 1 3510 #define PCI_LIB_STATIC 2 3511 #define PCI_LIB_READ 3 3512 #define PCI_LIB_PERIPHERAL 4 3513 #if CONFIGURE_PCI_LIB == PCI_LIB_AUTO 3514 #define PCI_CFG_AUTO_LIB 3517 #define PCI_LIB_INIT pci_config_auto 3518 #define PCI_LIB_CONFIG pci_config_auto_register 3519 #elif CONFIGURE_PCI_LIB == PCI_LIB_STATIC 3520 #define PCI_CFG_STATIC_LIB 3522 #define PCI_LIB_INIT pci_config_static 3523 #define PCI_LIB_CONFIG NULL 3525 #elif CONFIGURE_PCI_LIB == PCI_LIB_READ 3526 #define PCI_CFG_READ_LIB 3528 #define PCI_LIB_INIT pci_config_read 3529 #define PCI_LIB_CONFIG NULL 3531 #elif CONFIGURE_PCI_LIB == PCI_LIB_PERIPHERAL 3532 #define PCI_LIB_INIT pci_config_peripheral 3533 #define PCI_LIB_CONFIG NULL 3535 #elif CONFIGURE_PCI_LIB == PCI_LIB_NONE 3536 #define PCI_LIB_INIT NULL 3537 #define PCI_LIB_CONFIG NULL 3540 #error NO PCI LIBRARY DEFINED 3543 const int pci_config_lib_type = CONFIGURE_PCI_LIB;
3544 int (*pci_config_lib_init)(void) = PCI_LIB_INIT;
3545 void (*pci_config_lib_register)(
void *
config) = PCI_LIB_CONFIG;
3562 #if defined(CONFIGURE_CONFDEFS_DEBUG) && defined(CONFIGURE_INIT) 3571 uint32_t SYSTEM_OVERHEAD;
3572 uint32_t STATIC_EXTENSIONS;
3573 uint32_t INITIALIZATION_THREADS_STACKS;
3575 uint32_t PER_INTEGER_TASK;
3576 uint32_t FP_OVERHEAD;
3581 uint32_t INTERRUPT_STACK_MEMORY;
3582 uint32_t MEMORY_FOR_IDLE_TASK;
3585 uint32_t CLASSIC_TASKS;
3586 uint32_t TASK_VARIABLES;
3588 uint32_t SEMAPHORES;
3589 uint32_t MESSAGE_QUEUES;
3590 uint32_t PARTITIONS;
3595 uint32_t USER_EXTENSIONS;
3598 uint32_t POSIX_KEYS;
3600 #ifdef RTEMS_POSIX_API 3602 uint32_t POSIX_MUTEXES;
3603 uint32_t POSIX_CONDITION_VARIABLES;
3604 uint32_t POSIX_TIMERS;
3605 uint32_t POSIX_QUEUED_SIGNALS;
3606 uint32_t POSIX_MESSAGE_QUEUES;
3607 uint32_t POSIX_SEMAPHORES;
3608 uint32_t POSIX_BARRIERS;
3609 uint32_t POSIX_SPINLOCKS;
3610 uint32_t POSIX_RWLOCKS;
3614 uint32_t IDLE_TASKS_STACK;
3615 uint32_t INITIALIZATION_THREADS_EXTRA_STACKS;
3616 uint32_t TASKS_STACK;
3617 uint32_t POSIX_THREADS_STACK;
3618 uint32_t GOROUTINES_STACK;
3619 uint32_t ADA_TASKS_STACK;
3620 uint32_t EXTRA_MPCI_RECEIVE_SERVER_STACK;
3621 uint32_t EXTRA_TASK_STACKS;
3622 } Configuration_Debug_t;
3624 Configuration_Debug_t Configuration_Memory_Debug = {
3654 #ifdef RTEMS_POSIX_API 3656 CONFIGURE_MEMORY_FOR_POSIX_MUTEXES( CONFIGURE_POSIX_MUTEXES ),
3657 CONFIGURE_MEMORY_FOR_POSIX_CONDITION_VARIABLES(
3658 CONFIGURE_POSIX_CONDITION_VARIABLES ),
3659 CONFIGURE_MEMORY_FOR_POSIX_QUEUED_SIGNALS(
3660 CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS ),
3661 CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUES(
3662 CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES ),
3663 CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( CONFIGURE_MAXIMUM_POSIX_SEMAPHORES ),
3664 CONFIGURE_MEMORY_FOR_POSIX_BARRIERS( CONFIGURE_MAXIMUM_POSIX_BARRIERS ),
3665 CONFIGURE_MEMORY_FOR_POSIX_SPINLOCKS( CONFIGURE_MAXIMUM_POSIX_SPINLOCKS ),
3666 CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS( CONFIGURE_MAXIMUM_POSIX_RWLOCKS ),
3667 CONFIGURE_MEMORY_FOR_POSIX_TIMERS( CONFIGURE_MAXIMUM_POSIX_TIMERS ),
3690 #if !defined(CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION) 3691 #if (CONFIGURE_MAXIMUM_TASKS == 0) && \ 3692 (CONFIGURE_MAXIMUM_POSIX_THREADS == 0) && \ 3693 (CONFIGURE_MAXIMUM_ADA_TASKS == 0) && \ 3694 (CONFIGURE_MAXIMUM_GOROUTINES == 0) 3695 #error "CONFIGURATION ERROR: No tasks or threads configured!!" 3699 #ifndef RTEMS_SCHEDSIM 3704 #if !defined(CONFIGURE_RTEMS_INIT_TASKS_TABLE) && \ 3705 !defined(CONFIGURE_POSIX_INIT_THREAD_TABLE) && \ 3706 !defined(CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION) 3707 #error "CONFIGURATION ERROR: No initialization tasks or threads configured!!" 3715 #if defined(CONFIGURE_MP_APPLICATION) && \ 3716 !defined(RTEMS_MULTIPROCESSING) 3717 #error "CONFIGURATION ERROR: RTEMS not configured for multiprocessing!!" 3728 #if !defined(RTEMS_POSIX_API) 3729 #if ((CONFIGURE_MAXIMUM_POSIX_THREADS != 0) || \ 3730 (CONFIGURE_MAXIMUM_POSIX_MUTEXES != 0) || \ 3731 (CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES != 0) || \ 3732 (CONFIGURE_MAXIMUM_POSIX_TIMERS != 0) || \ 3733 (CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS != 0) || \ 3734 (CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES != 0) || \ 3735 (CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS != 0) || \ 3736 (CONFIGURE_MAXIMUM_POSIX_SEMAPHORES != 0) || \ 3737 (CONFIGURE_MAXIMUM_POSIX_BARRIERS != 0) || \ 3738 (CONFIGURE_MAXIMUM_POSIX_SPINLOCKS != 0) || \ 3739 (CONFIGURE_MAXIMUM_POSIX_RWLOCKS != 0) || \ 3740 defined(CONFIGURE_POSIX_INIT_THREAD_TABLE)) 3741 #error "CONFIGURATION ERROR: POSIX API support not configured!!" 3745 #if !defined(RTEMS_SCHEDSIM) 3746 #if !defined(CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE) 3757 #if !defined(CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER) && \ 3758 !defined(CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER) && \ 3759 !defined(CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER) 3760 #error "CONFIGURATION ERROR: Do you want the clock driver or not?!?" 3767 #if ((defined(CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER) + \ 3768 defined(CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER) + \ 3769 defined(CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER)) > 1) 3770 #error "CONFIGURATION ERROR: More than one clock/timer driver configuration parameter specified?!?" 3778 #if defined(CONFIGURE_TEST_NEEDS_TIMER_DRIVER) || \ 3779 defined(CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER) || \ 3780 defined(CONFIGURE_TEST_NEEDS_CLOCK_DRIVER) || \ 3781 defined(CONFIGURE_TEST_NEEDS_RTC_DRIVER) || \ 3782 defined(CONFIGURE_TEST_NEEDS_STUB_DRIVER) 3783 #error "CONFIGURATION ERROR: CONFIGURE_TEST_XXX constants are obsolete" 3789 #if ((CONFIGURE_MAXIMUM_PRIORITY != 3) && \ 3790 (CONFIGURE_MAXIMUM_PRIORITY != 7) && \ 3791 (CONFIGURE_MAXIMUM_PRIORITY != 15) && \ 3792 (CONFIGURE_MAXIMUM_PRIORITY != 31) && \ 3793 (CONFIGURE_MAXIMUM_PRIORITY != 63) && \ 3794 (CONFIGURE_MAXIMUM_PRIORITY != 127) && \ 3795 (CONFIGURE_MAXIMUM_PRIORITY != 255)) 3796 #error "Maximum priority is not 1 less than a power of 2 between 4 and 256" 3799 #if (CONFIGURE_MAXIMUM_PRIORITY > PRIORITY_DEFAULT_MAXIMUM) 3800 #error "Maximum priority configured higher than supported by target." 3808 #if (CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS < \ 3809 CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES) 3810 #error "Fewer POSIX Message Queue descriptors than Queues!" 3817 #if (CONFIGURE_MAXIMUM_POSIX_KEYS != 0) && \ 3818 (CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS != 0) 3819 #if (CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS < CONFIGURE_MAXIMUM_POSIX_KEYS) 3820 #error "Fewer POSIX Key pairs than POSIX Key!" 3828 #if ((CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 16) && \ 3829 (CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 32) && \ 3830 (CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 64) && \ 3831 (CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 128) && \ 3832 (CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 256) && \ 3833 (CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK != 512)) 3834 #error "IMFS Memfile block size must be a power of 2 between 16 and 512" Frame Buffer Device Driver for all Boards.
const size_t _Thread_Control_add_on_count
Thread control add-on count.
void rtems_filesystem_initialize(void)
Base File System Initialization.
Definition: base_fs.c:32
void * _Thread_Idle_body(uintptr_t ignored)
This routine is the body of the system idle thread.
int rtems_filesystem_default_utime(const rtems_filesystem_location_info_t *loc, time_t actime, time_t modtime)
Definition: default_utime.c:24
Interrupt stack size configuration.
Definition: confdefs.h:1226
This file describes the Watchdog Driver for all boards.
The following records define the POSIX Configuration Table.
Definition: config.h:58
Idle task body configuration.
Definition: confdefs.h:1162
bool rtems_filesystem_default_are_nodes_equal(const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
Tests if the node access pointer of one location is equal to the node access pointer of the other loc...
Definition: default_are_nodes_equal.c:28
This macro is calculated to specify the memory required for the POSIX API in its entirety.
Definition: confdefs.h:2946
uint8_t rtems_maximum_priority
This variable contains the configured number of priorities.
Definition: deflate.c:116
This macro is calculated to specify the memory required for task variables.
Definition: confdefs.h:2132
This macro is calculated to specify the memory required for Classic API User Extensions.
Definition: confdefs.h:2352
This defines the formula used to compute the amount of memory reserved for IDLE task control structur...
Definition: confdefs.h:3052
int rtems_filesystem_default_link(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Definition: default_link.c:23
This specifies the maximum number of Classic API timers.
Definition: confdefs.h:2143
Idle task stack size configuration.
Definition: confdefs.h:1209
This macro is calculated to specify the memory required for the stacks of all POSIX threads...
Definition: confdefs.h:3208
SCORE_EXTERN Heap_Control _Workspace_Area
Executive workspace control.
Definition: wkspace.h:46
Scheduler control.
Definition: scheduler.h:192
int IMFS_link(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Create a new IMFS link node.
Definition: imfs_link.c:25
This is the stack size of the Initialization Task when none is configured.
Definition: confdefs.h:1557
This macro calculates the memory required for task variables.
Definition: confdefs.h:2125
This configuration parameter specifies the maximum number of Classic API Dual-Ported Memory Ports...
Definition: confdefs.h:2279
This is the API specific information required by each thread for the RTEMS API to function correctly...
Definition: tasks.h:661
This specifies the task stack allocator method.
Definition: confdefs.h:1259
This macro is calculated to specify the memory required for Classic API timers.
Definition: confdefs.h:2150
Scheduler node specialization for EDF schedulers.
Definition: scheduleredf.h:96
const rtems_filesystem_table_t rtems_filesystem_table[]
Static table of file systems.
int rtems_filesystem_default_unmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_unmount.c:21
int IMFS_mount(rtems_filesystem_mount_table_entry_t *mt_entry)
Mount an IMFS.
Definition: imfs_mount.c:26
This configuration parameter specifies the maximum number of Classic API Regions. ...
Definition: confdefs.h:2261
This macro is calculated to specify the memory required for the stacks of all Go routines.
Definition: confdefs.h:3228
void rtems_task
The following defines the "return type" of an RTEMS task.
Definition: tasks.h:161
This specifies the maximum number of device drivers that can be installed in the system at one time...
Definition: confdefs.h:1633
void IMFS_node_free(const rtems_filesystem_location_info_t *loc)
Free an IMFS node.
Definition: imfs_initsupp.c:157
This macro provides a summation of the various POSIX thread requirements.
Definition: confdefs.h:2884
void rtems_filesystem_default_unlock(const rtems_filesystem_mount_table_entry_t *mt_entry)
Releases the IO library mutex.
Definition: default_lock_and_unlock.c:35
#define CONFIGURE_MAXIMUM_PTYS
This macro specifies the number of PTYs that can be concurrently active.
int rtems_telnetd_maximum_ptys
This variable contains the maximum number of PTYs that can be concurrently active.
The following records define the Configuration Table.
Definition: config.h:49
Should the RTEMS Workspace and C Program Heap be cleared automatically at system start up...
Definition: confdefs.h:1286
Heap_Control * RTEMS_Malloc_Heap
C program heap control.
#define CONSOLE_DRIVER_TABLE_ENTRY
This macro defines the standard device driver table entry for a console device driver.
Definition: console.h:38
This calculates the memory required for the executive workspace.
Definition: confdefs.h:3118
This macro is calculated to specify the memory required for the stacks of all Ada tasks...
Definition: confdefs.h:3218
File system table entry.
Definition: libio.h:1594
POSIX Threads Private Support.
rtems_api_configuration_table Configuration_RTEMS_API
RTEMS API Configuration Table.
const rtems_configuration_table Configuration
This is the configuration table generated by confdefs.h.
void rtems_malloc_dirty_memory(void *start, size_t size)
Dirty Memory Function.
Definition: malloc_dirtier.c:28
Buffering configuration definition.
Definition: bdbuf.h:367
ssize_t rtems_filesystem_default_readlink(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Definition: default_readlink.c:24
Account for allocating the following per object.
Definition: confdefs.h:2970
This value is for the Classic RTEMS API.
Definition: thread.h:427
int rtems_filesystem_default_fchmod(const rtems_filesystem_location_info_t *loc, mode_t mode)
Definition: default_fchmod.c:23
The configures the number of microseconds per clock tick.
Definition: confdefs.h:2371
POSIX Thread API Support.
This configures the maximum number of Classic API tasks.
Definition: confdefs.h:2075
#define RTEMS_STACK_CHECKER_EXTENSION
Stack Checker Extension Set Definition.
Definition: stackchk.h:135
const uint32_t _Scheduler_CBS_Maximum_servers
Maximum number of simultaneous servers.
Internal Information about POSIX Signals.
This macro provides a summation of the memory required by the Classic API as configured.
Definition: confdefs.h:3084
This macro accounts for general RTEMS system overhead.
Definition: confdefs.h:3063
This macro is calculated to specify the memory required for the Idle tasks(s) stack.
Definition: confdefs.h:3188
void IMFS_eval_path(rtems_filesystem_eval_path_context_t *ctx)
IMFS evaluation node support.
Definition: imfs_eval.c:175
Configure the controls for this scheduler instance.
Definition: confdefs.h:854
POSIX Timers Internal Support.
int IMFS_node_clone(rtems_filesystem_location_info_t *loc)
Clone an IMFS node.
Definition: imfs_initsupp.c:141
This macro is calculated to specify the number of Classic API semaphores required by the application ...
Definition: confdefs.h:2179
This is an empty device driver slot.
Definition: confdefs.h:1578
#define WATCHDOG_DRIVER_TABLE_ENTRY
This macro defines the watchdog device driver entry points.
Definition: watchdogdrv.h:30
Configure the context needed by the scheduler instance.
Definition: confdefs.h:847
By default, use the minimum stack size requested by this port.
Definition: confdefs.h:1189
void _RTEMS_tasks_Initialize_user_tasks_body(void)
Definition: taskinitusers.c:44
Priority_Control rtems_task_priority
Define the type for an RTEMS API task priority.
Definition: tasks.h:79
This include file defines the per CPU information required by RTEMS.
Public Interface to the NFS Client Library for RTEMS.
This macro is calculated to specify the memory required for Classic API Barriers. ...
Definition: confdefs.h:2334
RTEMS Benchmark Timer API for all Boards.
This structure defines the Thread Control Block (TCB).
Definition: thread.h:671
void(* _POSIX_Threads_Initialize_user_threads_p)(void)
When the user configures a set of POSIX API initialization threads, This variable will point to the m...
This macro is calculated to specify the memory required for Classic API Rate Monotonic Periods...
Definition: confdefs.h:2304
This configuration parameter specifies the maximum number of Classic API Partitions.
Definition: confdefs.h:2243
This is the name of the Initialization Task when none is configured.
Definition: confdefs.h:1543
Information Related to the RAM Workspace.
This macro is calculated to specify the memory required for the stacks of all tasks.
Definition: confdefs.h:3198
Thread control add-on.
Definition: thread.h:857
This is calculated to account for the maximum number of Classic API tasks used by the application and...
Definition: confdefs.h:2084
Constants and Structures Associated with the POSIX Barrier Manager.
This reserves memory for the interrupt stack if it is to be allocated by RTEMS rather than the BSP...
Definition: confdefs.h:1238
struct _reent * libc_reent
This field points to the newlib reentrancy structure for this thread.
Definition: thread.h:795
This configuration parameter specifies the maximum number of Classic API User Extensions.
Definition: confdefs.h:2345
int rtems_filesystem_default_symlink(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Definition: default_symlink.c:24
void _POSIX_Threads_Initialize_user_threads_body(void)
POSIX threads initialize user threads body.
Definition: pthreadinitthreads.c:39
int IMFS_mknod(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Create an IMFS node.
Definition: imfs_mknod.c:43
int rtems_filesystem_default_rmnod(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
Definition: default_rmnod.c:24
This defines the timers required for the shared memory driver in a multiprocessing configuration...
Definition: confdefs.h:1884
int IMFS_fchmod(const rtems_filesystem_location_info_t *loc, mode_t mode)
Change the IMFS file mode.
Definition: imfs_fchmod.c:23
Control block used to manage a heap.
Definition: heap.h:342
Scheduler node specialization for SMP schedulers.
Definition: schedulersmp.h:98
This macro is calculated to specify the memory required for Classic API.
Definition: confdefs.h:2250
Scheduler node specialization for Deterministic Priority schedulers.
Definition: schedulerpriority.h:90
Scheduler_CBS_Server _Scheduler_CBS_Server_list[]
List of servers.
This macro is calculated to specify the RTEMS Workspace required for the Classic API Message Queues...
Definition: confdefs.h:2232
POSIX Message Queues Private Private Support.
int IMFS_chown(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Change the owner of IMFS.
Definition: imfs_chown.c:27
Per Device Node Control Structure.
Definition: devfs.h:33
int IMFS_symlink(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Create a new IMFS symbolic link node.
Definition: imfs_symlink.c:27
uint32_t rtems_minimum_stack_size
This variable contains the the minimum stack size;.
void rtems_libio_init(void)
RTEMS LibIO Initialization.
Definition: libio_init.c:43
This structure represents a time server.
Definition: schedulercbs.h:107
This is the size of the Initialization Task when none is configured.
Definition: confdefs.h:1550
Standard C Library Support.
void(* _RTEMS_tasks_Initialize_user_tasks_p)(void)
When the user configures a set of Classic API initialization tasks, This variable will point to the m...
#define RTEMS_COMPILER_DEPRECATED_ATTRIBUTE
Instructs the compiler to issue a warning whenever a variable or function with this attribute will be...
Definition: basedefs.h:186
This defines the extra stack space required for the MPCI server thread.
Definition: confdefs.h:1876
This macro is calculated to specify the memory required for Classic API Dual-Ported Memory Ports...
Definition: confdefs.h:2286
This specifies the task stack deallocator method.
Definition: confdefs.h:1263
int IMFS_unmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Unmount an IMFS.
Definition: imfs_unmount.c:26
const rtems_bdbuf_config rtems_bdbuf_configuration
External reference to the configuration.
Private Support Information for POSIX Semaphores.
File system operations table.
Definition: libio.h:471
This value is for the POSIX API.
Definition: thread.h:429
This macro is calculated to specify the number of Classic API Barriers required by the application an...
Definition: confdefs.h:2324
LibIO Internal Interface.
int IMFS_rmnod(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
IMFS node removal handler.
Definition: imfs_rmnod.c:26
int rtems_filesystem_default_mount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_mount.c:21
This defines the POSIX API support structure associated with each thread in a system with POSIX confi...
Definition: threadsup.h:44
ssize_t IMFS_readlink(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Put IMFS symbolic link into buffer.
Definition: imfs_symlink.c:56
File Transfer Protocol file system (FTP client).
int IMFS_utime(const rtems_filesystem_location_info_t *loc, time_t actime, time_t modtime)
Set IMFS file access and modification times.
Definition: imfs_utime.c:25
Configure the very much optional task stack allocator initialization.
Definition: confdefs.h:1248
void rtems_filesystem_default_fsunmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_fsunmount.c:20
#define RTEMS_NUMBER_NOTEPADS
This is used to indicate the number of notepads available.
Definition: tasks.h:151
This macro is calculated to specify the memory required for Classic API Regions.
Definition: confdefs.h:2268
This is so we can account for tasks with stacks greater than minimum size.
Definition: confdefs.h:2878
Thread_Entry_numeric_type rtems_task_argument
The following defines the argument to an RTEMS task.
Definition: tasks.h:166
rtems_initialization_tasks_table Initialization_tasks[]
This is the Classic API initialization tasks table.
int rtems_filesystem_default_statvfs(const rtems_filesystem_location_info_t *loc, struct statvfs *buf)
Definition: default_statvfs.c:23
Scheduler node for per-thread data.
Definition: scheduler.h:281
Scheduler node specialization for Deterministic Priority SMP schedulers.
Definition: schedulerprioritysmp.h:64
const Scheduler_Control _Scheduler_Table[]
Registered schedulers.
The configures the number of clock ticks per timeslice.
Definition: confdefs.h:2377
An open file data structure.
Definition: libio.h:1281
posix_api_configuration_table Configuration_POSIX_API
POSIX API configuration table.
User extension table.
Definition: userext.h:232
This macro is calculated to specify the memory required for POSIX API keys.
Definition: confdefs.h:2480
This macro is calculated to specify the memory required for POSIX API key/value pairs.
Definition: confdefs.h:2459
int rtems_filesystem_default_rename(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Definition: default_rename.c:24
const size_t _Thread_Control_size
Size of the thread control block of a particular application.
POSIX Condition Variables Private Support.
This file defines the interface to RTEMS extensions to the Malloc Family.
This specifies the maximum number of Go per-task variables required.
Definition: confdefs.h:2866
This structure handles CBS specific data of a thread.
Definition: schedulercbs.h:130
This configuration parameter specifies the maximum number of Classic API Rate Monotonic Periods...
Definition: confdefs.h:2297
void * rtems_heap_extend_via_sbrk(Heap_Control *heap, size_t alloc_size)
RTEMS Extend Heap via Sbrk.
Definition: rtems_heap_extend_via_sbrk.c:34
This macro provides a summation of the various initialization task and thread stack requirements...
Definition: confdefs.h:3178
POSIX Key Private Support.
#define RTC_DRIVER_TABLE_ENTRY
Device driver table entry.
Definition: rtc.h:43
The following records define the Initialization Tasks Table.
Definition: tasks.h:181
This macro is calculated to specify the memory required for Classic API Semaphores.
Definition: confdefs.h:2215
This macro is calculated to specify the memory required for all tasks and threads of all varieties...
Definition: confdefs.h:3257
Constants and Structures Associated with the POSIX RWLock Manager.
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
This macro defines the number of POSIX file descriptors allocated and managed by libio.
Definition: confdefs.h:152
int rtems_filesystem_default_mknod(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Definition: default_mknod.c:24
const Thread_Control_add_on _Thread_Control_add_ons[]
Thread control add-ons.
This configuration parameter enables/disables Classic API notepads.
Definition: confdefs.h:2102
This macro reserves the memory required by the statically configured user extensions.
Definition: confdefs.h:3073
int rtems_filesystem_default_chown(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Definition: default_chown.c:23
For now, we are only allowing the user to specify the entry point and stack size for POSIX initializa...
Definition: config.h:42
void rtems_filesystem_default_lock(const rtems_filesystem_mount_table_entry_t *mt_entry)
Obtains the IO library mutex.
Definition: default_lock_and_unlock.c:28
Scheduler Configuration API.
#define CONFIGURE_MAXIMUM_PRIORITY
Maximum priority configuration.
Definition: confdefs.h:776
Scheduler node specialization for Deterministic Priority Affinity SMP schedulers. ...
Definition: schedulerpriorityaffinitysmp.h:173
int IMFS_rename(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Rename the IMFS.
Definition: imfs_rename.c:26
Block Device Buffer Management.
#define FRAME_BUFFER_DRIVER_TABLE_ENTRY
This macro defines the standard device driver table entry for a frame buffer device driver...
Definition: framebuffer.h:45
This configuration parameter specifies the maximum number of Classic API Message Queues.
Definition: confdefs.h:2225
#define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
IMFS.
Definition: confdefs.h:387
RTEMS_INLINE_ROUTINE struct Thread_Control * _Thread_Get_executing(void)
Returns the thread control block of the executing thread.
Definition: percpu.h:614
This macro is calculated to specify the total number of POSIX API keys required by the application an...
Definition: confdefs.h:2471
#define _Scheduler_Count
Count of registered schedulers.
Definition: scheduler.h:352
