This driver interface provides support to read and set the real-time clock and to initialize the time of day for the system. More...
| #define | RTC_DEVICE_NAME "/dev/rtc" |
| Device file name path. | |
| #define | RTC_DRIVER_TABLE_ENTRY |
| Device driver table entry. More... | |
| rtems_device_driver | rtc_initialize (rtems_device_major_number, rtems_device_minor_number, void *) |
| Initializes the real-time clock device and sets the time of day for the system. More... | |
| rtems_device_driver | rtc_open (rtems_device_major_number, rtems_device_minor_number, void *) |
| Opens the real-time clock device. | |
| rtems_device_driver | rtc_close (rtems_device_major_number, rtems_device_minor_number, void *) |
| Closes the real-time clock device. | |
| rtems_device_driver | rtc_read (rtems_device_major_number, rtems_device_minor_number, void *) |
| Reads the real-time clock value. More... | |
| rtems_device_driver | rtc_write (rtems_device_major_number, rtems_device_minor_number, void *) |
| Sets the real-time clock value. More... | |
| rtems_device_driver | rtc_control (rtems_device_major_number, rtems_device_minor_number, void *) |
| Controls the real-time clock. | |
| #define RTC_DRIVER_TABLE_ENTRY |
| rtems_device_driver rtc_initialize | ( | rtems_device_major_number | , |
| rtems_device_minor_number | , | ||
| void * | |||
If the real-time clock provides an invalid time of day value the system time of day must remain untouched.
| rtems_device_driver rtc_read | ( | rtems_device_major_number | , |
| void * | |||
The value will be returned in a rtems_time_of_day structure.
| rtems_device_driver rtc_write | ( | rtems_device_major_number | , |
| void * | |||
The value will be set from a rtems_time_of_day structure.
