Here is a list of all documented functions, variables, defines, enums, and typedefs with links to the documentation:
- o -
O6_SP_OFFSET :
cpu.h
O7_OFFSET :
cpu.h
OBJECTS_API_MASK :
object.h
OBJECTS_API_START_BIT :
object.h
OBJECTS_API_VALID_BITS :
object.h
Objects_APIs :
object.h
OBJECTS_APIS_LAST :
object.h
OBJECTS_CLASS_MASK :
object.h
OBJECTS_CLASS_START_BIT :
object.h
OBJECTS_CLASS_VALID_BITS :
object.h
Objects_Classic_API :
objectimpl.h
Objects_Id :
object.h
OBJECTS_ID_FINAL :
object.h
OBJECTS_ID_FINAL_INDEX :
object.h
OBJECTS_ID_INITIAL :
object.h
OBJECTS_ID_INITIAL_INDEX :
object.h
OBJECTS_ID_NONE :
object.h
OBJECTS_ID_OF_SELF :
object.h
OBJECTS_INDEX_MASK :
object.h
OBJECTS_INDEX_START_BIT :
object.h
OBJECTS_INDEX_VALID_BITS :
object.h
Objects_Internal_API :
objectimpl.h
OBJECTS_INTERNAL_CLASSES_LAST :
objectimpl.h
Objects_Locations :
objectimpl.h
Objects_Maximum :
object.h
Objects_Name_comparators :
objectimpl.h
OBJECTS_NAME_ERRORS_FIRST :
objectimpl.h
OBJECTS_NAME_ERRORS_LAST :
objectimpl.h
Objects_Name_or_id_lookup_errors :
objectimpl.h
OBJECTS_NODE_MASK :
object.h
OBJECTS_NODE_START_BIT :
object.h
OBJECTS_NODE_VALID_BITS :
object.h
Objects_POSIX_API :
objectimpl.h
OBJECTS_POSIX_CLASSES_LAST :
objectimpl.h
OBJECTS_RTEMS_CLASSES_LAST :
objectimpl.h
OBJECTS_SEARCH_ALL_NODES :
object.h
OBJECTS_SEARCH_LOCAL_NODE :
object.h
OBJECTS_SEARCH_OTHER_NODES :
object.h
Objects_Thread_queue_Extract_callout :
objectimpl.h
OBJECTS_UNLIMITED_OBJECTS :
object.h
OBJECTS_WHO_AM_I :
object.h
open() :
open.c
OR1K_Symbolic_exception_name :
or1k-utility.h
