Buffering configuration definition. More...
#include <bdbuf.h>
Data Fields | |
| uint32_t | max_read_ahead_blocks |
| Number of blocks to read ahead. More... | |
| uint32_t | max_write_blocks |
| Number of blocks to write at once. More... | |
| rtems_task_priority | swapout_priority |
| Priority of the swap out task. More... | |
| uint32_t | swapout_period |
| Period swap-out checks buf timers. More... | |
| uint32_t | swap_block_hold |
| Period a buffer is held. More... | |
| size_t | swapout_workers |
| The number of worker threads for the swap-out task. More... | |
| rtems_task_priority | swapout_worker_priority |
| size_t | task_stack_size |
| Task stack size for swap-out task and worker threads. More... | |
| size_t | size |
| Size of memory in the cache. | |
| uint32_t | buffer_min |
| Minimum buffer size. More... | |
| uint32_t | buffer_max |
| Maximum buffer size supported. More... | |
| rtems_task_priority | read_ahead_priority |
| Priority of the read-ahead task. More... | |
See confdefs.h for support on using this structure.
| uint32_t rtems_bdbuf_config::buffer_max |
It is also the allocation size.
| uint32_t rtems_bdbuf_config::buffer_min |
| uint32_t rtems_bdbuf_config::max_read_ahead_blocks |
| uint32_t rtems_bdbuf_config::max_write_blocks |
| rtems_task_priority rtems_bdbuf_config::read_ahead_priority |
| uint32_t rtems_bdbuf_config::swap_block_hold |
| uint32_t rtems_bdbuf_config::swapout_period |
| rtems_task_priority rtems_bdbuf_config::swapout_priority |
| rtems_task_priority rtems_bdbuf_config::swapout_worker_priority |
| size_t rtems_bdbuf_config::swapout_workers |
| size_t rtems_bdbuf_config::task_stack_size |
