File system types and mount.
More...
enum | rtems_filesystem_options_t { RTEMS_FILESYSTEM_READ_ONLY,
RTEMS_FILESYSTEM_READ_WRITE,
RTEMS_FILESYSTEM_BAD_OPTIONS
| File system options.
int | rtems_filesystem_register (const char *type, rtems_filesystem_fsmount_me_t mount_h) |
| Registers a file system type. More...
int | rtems_filesystem_unregister (const char *type) |
| Unregisters a file system type. More...
int | unmount (const char *mount_path) |
| Unmounts the file system instance at the specified mount path. More...
int | mount (const char *source, const char *target, const char *filesystemtype, rtems_filesystem_options_t options, const void *data) |
| Mounts a file system instance at the specified target path. More...
int | mount_and_make_target_path (const char *source, const char *target, const char *filesystemtype, rtems_filesystem_options_t options, const void *data) |
| Mounts a file system and makes the target path. More...
bool | rtems_filesystem_iterate (rtems_per_filesystem_routine routine, void *routine_arg) |
| Iterates over all file system types. More...
bool | rtems_filesystem_mount_iterate (rtems_filesystem_mt_entry_visitor visitor, void *visitor_arg) |
| Iterates over all file system mount entries. More...
#define | RTEMS_FILESYSTEM_TYPE_IMFS "imfs" |
#define | RTEMS_FILESYSTEM_TYPE_MINIIMFS "mimfs" |
#define | RTEMS_FILESYSTEM_TYPE_DEVFS "devfs" |
#define | RTEMS_FILESYSTEM_TYPE_FTPFS "ftpfs" |
#define | RTEMS_FILESYSTEM_TYPE_TFTPFS "tftpfs" |
#define | RTEMS_FILESYSTEM_TYPE_NFS "nfs" |
#define | RTEMS_FILESYSTEM_TYPE_DOSFS "dosfs" |
#define | RTEMS_FILESYSTEM_TYPE_RFS "rfs" |
#define | RTEMS_FILESYSTEM_TYPE_JFFS2 "jffs2" |
◆ rtems_filesystem_mt_entry_visitor
◆ rtems_per_filesystem_routine
Per file system type routine.
- See also
- rtems_filesystem_iterate().
- Return values
true | Stop the iteration. |
false | Continue the iteration. |
◆ mount()
int mount |
const char * |
source, |
const char * |
target, |
const char * |
filesystemtype, |
rtems_filesystem_options_t |
options, |
const void * |
data |
To mount a standard file system instance one of the following defines should be used to select the file system type
- RTEMS_FILESYSTEM_TYPE_DEVFS,
- RTEMS_FILESYSTEM_TYPE_DOSFS,
- RTEMS_FILESYSTEM_TYPE_FTPFS,
- RTEMS_FILESYSTEM_TYPE_IMFS,
- RTEMS_FILESYSTEM_TYPE_JFFS2,
- RTEMS_FILESYSTEM_TYPE_MINIIMFS,
- RTEMS_FILESYSTEM_TYPE_NFS,
- RTEMS_FILESYSTEM_TYPE_RFS, or
- RTEMS_FILESYSTEM_TYPE_TFTPFS.
Only configured or registered file system types are available. You can add file system types to your application configuration with the following configuration options
- CONFIGURE_FILESYSTEM_DEVFS,
- CONFIGURE_FILESYSTEM_DOSFS,
- CONFIGURE_FILESYSTEM_FTPFS,
- CONFIGURE_FILESYSTEM_IMFS,
- CONFIGURE_FILESYSTEM_JFFS2,
- CONFIGURE_FILESYSTEM_MINIIMFS,
- CONFIGURE_FILESYSTEM_NFS,
- CONFIGURE_FILESYSTEM_RFS, and
- CONFIGURE_FILESYSTEM_TFTPFS.
In addition to these configuration options file system types can be registered with rtems_filesystem_register().
- Parameters
[in] | source | The source parameter will be forwarded to the file system initialization handler. Usually the source is a path to the corresponding device file, or NULL in case the file system does not use a device file. |
[in] | target | The target path must lead to an existing directory, or must be NULL . In case the target is NULL , the root file system will be mounted. |
[in] | filesystemtype | This string selects the file system type. |
[in] | options | The options specify if the file system instance allows read-write or read-only access. |
[in] | data | The data parameter will be forwarded to the file system initialization handler. It can be used to pass file system specific mount options. The data structure for mount options is file system specific. See also in the corresponding file system documentation. |
- Return values
0 | Successful operation. |
-1 | An error occurred. The errno indicates the error. |
- See also
- rtems_filesystem_register(), mount_and_make_target_path(), FAT Filesystem Support and Journalling Flash File System Version 2 (JFFS2) Support.
◆ mount_and_make_target_path()
int mount_and_make_target_path |
const char * |
source, |
const char * |
target, |
const char * |
filesystemtype, |
options, |
const void * |
data |
The target path will be created with rtems_mkdir() and must not be NULL
- See also
- mount().
- Return values
◆ rtems_filesystem_iterate()
For each file system type the routine will be called with the entry and the routine_arg parameter.
Do not register or unregister file system types in routine.
The iteration is protected by the IO library mutex.
- Return values
true | Iteration stopped due to routine return status. |
false | Iteration through all entries. |
References rtems_filesystem_table.
◆ rtems_filesystem_mount_iterate()
The iteration is protected by the IO library mutex. Do not mount or unmount file systems in the visitor function.
- Parameters
[in] | visitor | For each file system mount entry the visitor function will be called with the entry and the visitor argument as parameters. |
[in] | visitor_arg | The second parameter for the visitor function. |
- Return values
true | Iteration stopped due to visitor function return status. |
◆ rtems_filesystem_register()
The mount_h handler will be used to mount a file system of this type.
- Return values
◆ rtems_filesystem_unregister()
int rtems_filesystem_unregister |
const char * |
type | ) |
- Return values
◆ unmount()
int unmount |
const char * |
path | ) |
The function waits for the unmount process completion. In case the calling thread uses resources of the unmounted file system the function may never return. In case the calling thread has its root or current directory in the unmounted file system the function returns with an error status and errno is set to EBUSY.
The unmount process completion notification uses the transient event. It is a fatal error to terminate the calling thread while waiting for this event.
A concurrent unmount request for the same file system instance has unpredictable effects.
- Parameters
[in] | mount_path | The path to the file system instance mount point. |
- Return values
- See also
- Transient Event.
This routine is necessary to mount instantiations of a file system into the file system name space.
◆ rtems_filesystem_table
