File system operations. More...
Files | |
| file | default_are_nodes_equal.c |
| RTEMS Default File System has nodes equal. | |
| file | default_clone.c |
| RTEMS Default File System creates a child process. | |
| file | default_eval_path.c |
| RTEMS Default File System evaluates relative pathname to absolute. | |
| file | default_fstat.c |
| RTEMS Default File System gets file status. | |
| file | default_fsync.c |
| RTEMS Default File System Synchronises changes to a file. | |
| file | default_fsync_success.c |
| RTEMS Default Filesystem succeeds synchronizing file's in-core state. | |
| file | default_ftruncate.c |
| RTEMS Default File System Truncates a file to indicated length. | |
| file | default_ioctl.c |
| RTEMS Default File System controls a STREAMS device. | |
| file | default_lock_and_unlock.c |
| RTEMS Default File System locks and unlocks rtems filesystem. | |
| file | default_lseek.c |
| RTEMS Default File System reposits the read/write file offset. | |
| file | default_lseek_directory.c |
| RTEMS Default File System reposits read/write file offset directory. | |
| file | default_lseek_file.c |
| RTEMS Default File System reposits the offset of the open file fd. | |
| file | default_mknod.c |
| RTEMS Default File System creates a special or ordinary file. | |
| file | default_mount.c |
| RTEMS Default File System mounts a filesystem. | |
| file | default_rename.c |
| RTESM Default File System Rename Files. | |
| file | default_symlink.c |
| RTEMS Default File System creates a symbolic link to a file. | |
| file | default_unmount.c |
| RTEMS Default File System Unmounts. | |
| file | default_utime.c |
| RTEMS Default File System sets file access and modification times. | |
| file | default_write.c |
| RTEMS Default File System sends a message to another user. | |
| struct | rtems_filesystem_eval_path_context_t |
| Path evaluation context. More... | |
| struct | _rtems_filesystem_operations_table |
| File system operations table. More... | |
Typedefs | |
| typedef void(* | rtems_filesystem_mt_entry_lock_t) (const rtems_filesystem_mount_table_entry_t *mt_entry) |
| Locks a file system instance. More... | |
| typedef void(* | rtems_filesystem_mt_entry_unlock_t) (const rtems_filesystem_mount_table_entry_t *mt_entry) |
| Unlocks a file system instance. More... | |
| typedef void(* | rtems_filesystem_eval_path_t) (rtems_filesystem_eval_path_context_t *ctx) |
| Path evaluation. More... | |
| typedef int(* | rtems_filesystem_link_t) (const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen) |
| Creates a new link for the existing file. More... | |
| typedef int(* | rtems_filesystem_fchmod_t) (const rtems_filesystem_location_info_t *loc, mode_t mode) |
| Changes the mode of a node. More... | |
| typedef int(* | rtems_filesystem_chown_t) (const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group) |
| Changes owner and group of a node. More... | |
| typedef int(* | rtems_filesystem_clonenode_t) (rtems_filesystem_location_info_t *loc) |
| Clones a location. More... | |
| typedef void(* | rtems_filesystem_freenode_t) (const rtems_filesystem_location_info_t *loc) |
| Frees the location of a node. More... | |
| typedef int(* | rtems_filesystem_mount_t) (rtems_filesystem_mount_table_entry_t *mt_entry) |
| Mounts a file system instance in a mount point (directory). More... | |
| typedef int(* | rtems_filesystem_fsmount_me_t) (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data) |
| Initializes a file system instance. More... | |
| typedef int(* | rtems_filesystem_unmount_t) (rtems_filesystem_mount_table_entry_t *mt_entry) |
| Unmounts a file system instance in a mount point (directory). More... | |
| typedef void(* | rtems_filesystem_fsunmount_me_t) (rtems_filesystem_mount_table_entry_t *mt_entry) |
| Destroys a file system instance. More... | |
| typedef bool(* | rtems_filesystem_are_nodes_equal_t) (const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b) |
| Tests if the node of one location is equal to the node of the other location. More... | |
| typedef int(* | rtems_filesystem_mknod_t) (const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev) |
| Creates a new node. More... | |
| typedef int(* | rtems_filesystem_rmnod_t) (const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc) |
| Removes a node. More... | |
| typedef int(* | rtems_filesystem_utime_t) (const rtems_filesystem_location_info_t *loc, time_t actime, time_t modtime) |
| Set node access and modification times. More... | |
| typedef int(* | rtems_filesystem_symlink_t) (const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target) |
| Makes a symbolic link to a node. More... | |
| typedef ssize_t(* | rtems_filesystem_readlink_t) (const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize) |
| Reads the contents of a symbolic link. More... | |
| typedef int(* | rtems_filesystem_rename_t) (const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen) |
| Renames a node. More... | |
| typedef int(* | rtems_filesystem_statvfs_t) (const rtems_filesystem_location_info_t *loc, struct statvfs *buf) |
| Gets file system information. More... | |
| const rtems_filesystem_operations_table | rtems_filesystem_operations_default |
| File system operations table with default operations. | |
| typedef bool(* rtems_filesystem_are_nodes_equal_t) (const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b) |
The caller ensures that both nodes are within the same file system instance.
| [in] | a | The one location. |
| [in] | b | The other location. |
| true | The nodes of the locations are equal. |
| false | Otherwise. |
| typedef int(* rtems_filesystem_chown_t) (const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group) |
| [in] | loc | The location of the node. |
| [in] | owner | User ID for the node. |
| [in] | group | Group ID for the node. |
| 0 | Successful operation. |
| -1 | An error occurred. The errno is set to indicate the error. |
| typedef int(* rtems_filesystem_clonenode_t) (rtems_filesystem_location_info_t *loc) |
Clones a location.
The location is initialized with a bitwise copy of an existing location. The caller must ensure that this location is protected from a release during the clone operation. After a successful clone operation the clone will be added to the location chain of the corresponding mount table entry.
| [in,out] | loc | Location to clone. |
| typedef void(* rtems_filesystem_eval_path_t) (rtems_filesystem_eval_path_context_t *ctx) |
Path evaluation.
| [in,out] | ctx | The path evaluation context. |
| typedef int(* rtems_filesystem_fchmod_t) (const rtems_filesystem_location_info_t *loc, mode_t mode) |
| [in] | mode | The new mode of the node |
| typedef void(* rtems_filesystem_freenode_t) (const rtems_filesystem_location_info_t *loc) |
| typedef int(* rtems_filesystem_fsmount_me_t) (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data) |
This function must initialize the file system root node in the mount table entry.
| [in] | mt_entry | The mount table entry. |
| [in] | data | The data provided by the user. |
| typedef void(* rtems_filesystem_fsunmount_me_t) (rtems_filesystem_mount_table_entry_t *mt_entry) |
The mount point node location of the mount table entry is invalid. This handler must free the file system root location and all remaining resources of the file system instance.
| typedef int(* rtems_filesystem_link_t) (const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen) |
| [in] | parentloc | The location of the parent of the new link. |
| [in] | targetloc | The location of the target file. |
| [in] | name | Name for the new link. |
| [in] | namelen | Length of the name for the new link in characters. |
| typedef int(* rtems_filesystem_mknod_t) (const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev) |
Creates a new node.
This handler should create a new node according to the parameters.
| [in] | parentloc | The location of the parent of the new node. |
| [in] | name | Name for the new node. |
| [in] | namelen | Length of the name for the new node in characters. |
| [in] | mode | Mode for the new node. |
| [in] | dev | Optional device identifier for the new node. |
| typedef int(* rtems_filesystem_mount_t) (rtems_filesystem_mount_table_entry_t *mt_entry) |
The mount point belongs to the file system instance of the handler and is specified by a field of the mount table entry. The handler must check that the mount point is capable of mounting a file system instance. This is the last step during the mount process. The file system instance is fully initialized at this point.
| typedef void(* rtems_filesystem_mt_entry_lock_t) (const rtems_filesystem_mount_table_entry_t *mt_entry) |
This lock must allow nesting.
| [in,out] | mt_entry | The mount table entry of the file system instance. |
| typedef void(* rtems_filesystem_mt_entry_unlock_t) (const rtems_filesystem_mount_table_entry_t *mt_entry) |
| typedef ssize_t(* rtems_filesystem_readlink_t) (const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize) |
| [in] | loc | The location of the symbolic link. |
| [out] | buf | The buffer for the contents. |
| [in] | bufsize | The size of the buffer in characters. |
| non-negative | Size of the actual contents in characters. |
| typedef int(* rtems_filesystem_rename_t) (const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen) |
Renames a node.
| [in] | oldparentloc | The location of the parent of the old node. |
| [in] | oldloc | The location of the old node. |
| [in] | newparentloc | The location of the parent of the new node. |
| typedef int(* rtems_filesystem_rmnod_t) (const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc) |
Removes a node.
| [in] | parentloc | The location of the parent of the node. |
| typedef int(* rtems_filesystem_statvfs_t) (const rtems_filesystem_location_info_t *loc, struct statvfs *buf) |
| [in] | loc | The location of a node. |
| [out] | buf | Buffer for file system information. |
| typedef int(* rtems_filesystem_symlink_t) (const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target) |
| [in] | parentloc | The location of the parent of the new symbolic link. |
| [in] | name | Name for the new symbolic link. |
| [in] | namelen | Length of the name for the new symbolic link in characters. |
| [in] | target | Contents for the symbolic link. |
| typedef int(* rtems_filesystem_unmount_t) (rtems_filesystem_mount_table_entry_t *mt_entry) |
In case this function is successful the file system instance will be marked as unmounted. The file system instance will be destroyed when the last reference to it vanishes.
| typedef int(* rtems_filesystem_utime_t) (const rtems_filesystem_location_info_t *loc, time_t actime, time_t modtime) |
| [in] | actime | Access time for the node. |
| [in] | modtime | Modification for the node. |
| bool rtems_filesystem_default_are_nodes_equal | ( | const rtems_filesystem_location_info_t * | a, |
| const rtems_filesystem_location_info_t * | b | ||
Tests if the node access pointer of one location is equal to the node access pointer of the other location.
| true | The node access pointers of the locations are equal. |
| int rtems_filesystem_default_chown | ( | const rtems_filesystem_location_info_t * | loc, |
| uid_t | owner, | ||
| gid_t | group | ||
| -1 | Always. The errno is set to ENOTSUP. |
References rtems_set_errno_and_return_minus_one.
| int rtems_filesystem_default_clonenode | ( | rtems_filesystem_location_info_t * | loc | ) |
| 0 | Always. |
| void rtems_filesystem_default_eval_path | ( | rtems_filesystem_eval_path_context_t * | ctx | ) |
Terminates the path evaluation and replaces the current location with the null location.
References rtems_filesystem_eval_path_context_t::pathlen.
| int rtems_filesystem_default_fchmod | ( | const rtems_filesystem_location_info_t * | loc, |
| mode_t | mode | ||
| void rtems_filesystem_default_freenode | ( | const rtems_filesystem_location_info_t * | loc | ) |
| void rtems_filesystem_default_fsunmount | ( | rtems_filesystem_mount_table_entry_t * | mt_entry | ) |
| int rtems_filesystem_default_link | ( | const rtems_filesystem_location_info_t * | parentloc, |
| const rtems_filesystem_location_info_t * | targetloc, | ||
| const char * | name, | ||
| size_t | namelen | ||
| void rtems_filesystem_default_lock | ( | const rtems_filesystem_mount_table_entry_t * | mt_entry | ) |
Obtains the IO library mutex.
| int rtems_filesystem_default_mknod | ( | const rtems_filesystem_location_info_t * | parentloc, |
| size_t | namelen, | ||
| mode_t | mode, | ||
| dev_t | dev | ||
| int rtems_filesystem_default_mount | ( | rtems_filesystem_mount_table_entry_t * | mt_entry | ) |
| ssize_t rtems_filesystem_default_readlink | ( | const rtems_filesystem_location_info_t * | loc, |
| char * | buf, | ||
| size_t | bufsize | ||
| int rtems_filesystem_default_rename | ( | const rtems_filesystem_location_info_t * | oldparentloc, |
| const rtems_filesystem_location_info_t * | oldloc, | ||
| const rtems_filesystem_location_info_t * | newparentloc, | ||
| int rtems_filesystem_default_rmnod | ( | const rtems_filesystem_location_info_t * | parentloc, |
| const rtems_filesystem_location_info_t * | loc | ||
| int rtems_filesystem_default_statvfs | ( | const rtems_filesystem_location_info_t * | loc, |
| struct statvfs * | buf | ||
| int rtems_filesystem_default_symlink | ( | const rtems_filesystem_location_info_t * | parentloc, |
| const char * | target | ||
| void rtems_filesystem_default_unlock | ( | const rtems_filesystem_mount_table_entry_t * | mt_entry | ) |
Releases the IO library mutex.
| int rtems_filesystem_default_unmount | ( | rtems_filesystem_mount_table_entry_t * | mt_entry | ) |
| int rtems_filesystem_default_utime | ( | const rtems_filesystem_location_info_t * | loc, |
| time_t | actime, | ||
| time_t | modtime | ||
