Provides system call and file system interface definitions. More...
Modules | |
| User Environment | |
| Provides a POSIX like user environment for tasks. | |
| File System Operations | |
| File system operations. | |
| File System Node Handler | |
| File system node handler. | |
| File System Types and Mount | |
| File system types and mount. | |
| Termios | |
| Termios. | |
| IMFS Generic Nodes | |
| Generic nodes are an alternative to standard drivers in RTEMS. | |
Files | |
| file | libio.h |
| Basic IO API. | |
| file | base_fs.c |
| Base File System Initialization. | |
| file | libio_exit.c |
| file | libio_helper_null.c |
| file | libio_init.c |
| RTEMS LibIO Initialization. | |
| file | mount-mktgt.c |
| mount_and_make_target_path() implementation. | |
| file | rtems_mkdir.c |
| rtems_mkdir() implementation. | |
| file | default_handlers.c |
| rtems_filesystem_handlers_default definition. | |
| file | default_ops.c |
| rtems_filesystem_operations_default definition. | |
| struct | rtems_filesystem_location_info_tt |
| File system location. More... | |
| struct | rtems_filesystem_global_location_t |
| Global file system location. More... | |
| struct | rtems_filesystem_limits_and_options_t |
| Contain file system specific information which is required to support fpathconf(). More... | |
| struct | rtems_libio_tt |
| An open file data structure. More... | |
| struct | rtems_libio_rw_args_t |
| Paramameter block for read/write. More... | |
| struct | rtems_libio_open_close_args_t |
| Parameter block for open/close. More... | |
| struct | rtems_libio_ioctl_args_t |
| Parameter block for ioctl. More... | |
| union | __rtems_dev_t |
| #define | rtems_filesystem_split_dev_t(_dev, _major, _minor) |
Typedefs | |
| typedef struct rtems_filesystem_location_info_tt | rtems_filesystem_location_info_t |
| File system location. | |
| typedef struct rtems_filesystem_global_location_t | rtems_filesystem_global_location_t |
| typedef off_t | rtems_off64_t |
| typedef void(* | rtems_libio_helper) (void) |
| rtems_filesystem_fsmount_me_t | rtems_filesystem_get_mount_handler (const char *type) |
| Gets the mount handler for the file system type. More... | |
| void | rtems_libio_init (void) |
| RTEMS LibIO Initialization. More... | |
| void | rtems_filesystem_initialize (void) |
| Base File System Initialization. More... | |
| void | rtems_libio_helper_null (void) |
| void | rtems_libio_post_driver (void) |
| void | rtems_libio_exit (void) |
| int | rtems_mkdir (const char *path, mode_t mode) |
| Creates a directory and all its parent directories according to path. More... | |
| const rtems_filesystem_limits_and_options_t | rtems_filesystem_default_pathconf |
| Default pathconf settings. More... | |
| const rtems_libio_helper | rtems_libio_init_helper |
| const rtems_libio_helper | rtems_libio_post_driver_helper |
| const rtems_libio_helper | rtems_libio_exit_helper |
| const rtems_libio_helper | rtems_fs_init_helper |
General purpose communication channel for RTEMS to allow UNIX/POSIX system call behavior under RTEMS. Initially this supported only IO to devices but has since been enhanced to support networking and support for mounted file systems.
| #define rtems_filesystem_split_dev_t | ( | _dev, | |
| _major, | |||
| _minor | |||
The global file system locations are used for
During the path evaluation global start locations are obtained to ensure that the current file system will be not unmounted in the meantime.
To support a release within critical sections of the operating system a deferred release is supported. This is similar to malloc() and free().
| rtems_filesystem_fsmount_me_t rtems_filesystem_get_mount_handler | ( | const char * | type | ) |
NULL if no such association exists. | void rtems_filesystem_initialize | ( | void | ) |
Initialize the foundation of the file system. This is specified by the structure rtems_filesystem_mount_table. The usual configuration is a single instantiation of the IMFS or miniIMFS with a single "/dev" directory in it.
| void rtems_libio_init | ( | void | ) |
Called by BSP startup code to initialize the libio subsystem.
| int rtems_mkdir | ( | const char * | path, |
| mode_t | mode | ||
The mode value selects the access permissions of the directory.
| 0 | Successful operation. |
| -1 | An error occurred. The errno indicates the error. |
| const rtems_filesystem_limits_and_options_t rtems_filesystem_default_pathconf |
Override in a filesystem.
