This module contains the parameters related to configuration of the POSIX API services. More...
| #define | CONFIGURE_MAXIMUM_POSIX_KEYS 0 |
| This configuration parameter specifies the maximum number of POSIX API keys. More... | |
| #define | CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS |
| This macro is calculated to specify the memory required for POSIX API key/value pairs. More... | |
| #define | CONFIGURE_POSIX_KEYS (CONFIGURE_MAXIMUM_POSIX_KEYS + CONFIGURE_LIBIO_POSIX_KEYS) |
| This macro is calculated to specify the total number of POSIX API keys required by the application and configured system capabilities. More... | |
| #define | CONFIGURE_MEMORY_FOR_POSIX_KEYS(_keys, _key_value_pairs) |
| This macro is calculated to specify the memory required for POSIX API keys. More... | |
| #define | CONFIGURE_MAXIMUM_POSIX_THREADS 0 |
| This configuration parameter specifies the maximum number of POSIX API threads. | |
| #define | CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE 0 |
| This configuration parameter specifies the stack size of the POSIX API Initialization thread (if used). | |
| #define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS |
This is an internal parameter.
| #define CONFIGURE_MAXIMUM_POSIX_KEYS 0 |
POSIX Keys are available whether or not the POSIX API is enabled.
| #define CONFIGURE_MEMORY_FOR_POSIX_KEYS | ( | _keys, | |
| _key_value_pairs | |||
| #define CONFIGURE_POSIX_KEYS (CONFIGURE_MAXIMUM_POSIX_KEYS + CONFIGURE_LIBIO_POSIX_KEYS) |
