Here is a list of all documented functions, variables, defines, enums, and typedefs with links to the documentation:
- s -
SAPI_EXTERN :
basedefs.h
sched_get_priority_min() :
sched_getprioritymin.c
sched_getparam() :
sched_getparam.c
Scheduler_CBS_Budget_overrun :
schedulercbs.h
SCHEDULER_CBS_ENTRY_POINTS :
schedulercbs.h
Scheduler_CBS_Server_id :
schedulercbs.h
Scheduler_Context :
scheduler.h
SCHEDULER_EDF_ENTRY_POINTS :
scheduleredf.h
SCHEDULER_EDF_PRIO_MSB :
scheduleredf.h
Scheduler_EDF_Queue_state :
scheduleredf.h
SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS :
schedulerpriorityaffinitysmp.h
SCHEDULER_PRIORITY_ENTRY_POINTS :
schedulerpriority.h
SCHEDULER_PRIORITY_SMP_ENTRY_POINTS :
schedulerprioritysmp.h
SCHEDULER_SIMPLE_ENTRY_POINTS :
schedulersimple.h
SCHEDULER_SIMPLE_SMP_ENTRY_POINTS :
schedulersimplesmp.h
SCHEDULER_SMP_NODE_BLOCKED :
schedulersmp.h
SCHEDULER_SMP_NODE_READY :
schedulersmp.h
SCHEDULER_SMP_NODE_SCHEDULED :
schedulersmp.h
Scheduler_SMP_Node_state :
schedulersmp.h
SCORE_EXTERN :
basedefs.h
Semaphore_MP_Remote_operations :
semmp.h
serial_mouse_close() :
serial_mouse.c
serial_mouse.h
serial_mouse_control() :
serial_mouse.c
serial_mouse.h
SERIAL_MOUSE_DEVICE_PS2 :
serial_mouse.h
SERIAL_MOUSE_DRIVER_TABLE_ENTRY :
serial_mouse.h
serial_mouse_initialize() :
serial_mouse.c
serial_mouse.h
serial_mouse_open() :
serial_mouse.c
serial_mouse.h
serial_mouse_read() :
serial_mouse.c
serial_mouse.h
serial_mouse_write() :
serial_mouse.c
serial_mouse.h
setegid() :
setegid.c
setpgid() :
setpgid.c
setsid() :
setsid.c
Signal_MP_Remote_operations :
signalmp.h
sigprocmask() :
sigprocmask.c
sigtimedwait() :
sigtimedwait.c
sleep_cpu :
sleep.h
sleep_enable :
sleep.h
SMP_BARRIER_CONTROL_INITIALIZER :
smpbarrier.h
SMP_BARRIER_STATE_INITIALIZER :
smpbarrier.h
SMP_Fatal_code :
smpimpl.h
SMP_MESSAGE_MULTICAST_ACTION :
smpimpl.h
SMP_MESSAGE_SHUTDOWN :
smpimpl.h
SMP_MESSAGE_TEST :
smpimpl.h
SPARC_ASYNCHRONOUS_TRAP :
cpu.h
sparc_flash_interrupts :
sparc.h
sparc_get_interrupt_level :
sparc.h
sparc_get_psr :
sparc.h
sparc_get_tbr :
sparc.h
sparc_get_wim :
sparc.h
sparc_get_y :
sparc.h
SPARC_HAS_BITSCAN :
sparc.h
SPARC_HAS_FPU :
sparc.h
sparc_isr :
types.h
sparc_isr_entry :
types.h
SPARC_NUMBER_OF_REGISTER_WINDOWS :
sparc.h
SPARC_PER_CPU_ISR_DISPATCH_DISABLE :
cpu.h
SPARC_PSR_CWP_BIT_POSITION :
sparc.h
SPARC_PSR_CWP_MASK :
sparc.h
SPARC_PSR_EC_BIT_POSITION :
sparc.h
SPARC_PSR_EC_MASK :
sparc.h
SPARC_PSR_EF_BIT_POSITION :
sparc.h
SPARC_PSR_EF_MASK :
sparc.h
SPARC_PSR_ET_BIT_POSITION :
sparc.h
SPARC_PSR_ET_MASK :
sparc.h
SPARC_PSR_ICC_BIT_POSITION :
sparc.h
SPARC_PSR_ICC_MASK :
sparc.h
SPARC_PSR_IMPL_BIT_POSITION :
sparc.h
SPARC_PSR_IMPL_MASK :
sparc.h
SPARC_PSR_PIL_BIT_POSITION :
sparc.h
SPARC_PSR_PIL_MASK :
sparc.h
SPARC_PSR_PS_BIT_POSITION :
sparc.h
SPARC_PSR_PS_MASK :
sparc.h
SPARC_PSR_S_BIT_POSITION :
sparc.h
SPARC_PSR_S_MASK :
sparc.h
SPARC_PSR_VER_BIT_POSITION :
sparc.h
SPARC_PSR_VER_MASK :
sparc.h
SPARC_REAL_TRAP_NUMBER :
cpu.h
sparc_set_psr :
sparc.h
sparc_set_tbr :
sparc.h
sparc_set_wim :
sparc.h
sparc_set_y :
sparc.h
SPARC_SYNCHRONOUS_TRAP :
cpu.h
SPARC_SYNCHRONOUS_TRAP_BIT_MASK :
cpu.h
sparc_syscall_exit() :
sparc.h
STACK_MINIMUM_SIZE :
stack.h
STATES_ALL_SET :
statesimpl.h
STATES_BLOCKED :
statesimpl.h
States_Control :
states.h
STATES_DELAYING :
statesimpl.h
STATES_DORMANT :
statesimpl.h
STATES_INTERRUPTIBLE_BY_SIGNAL :
statesimpl.h
STATES_LOCALLY_BLOCKED :
statesimpl.h
STATES_MIGRATING :
statesimpl.h
STATES_READY :
statesimpl.h
STATES_RESTARTING :
statesimpl.h
STATES_SUSPENDED :
statesimpl.h
STATES_WAITING_FOR_BARRIER :
statesimpl.h
STATES_WAITING_FOR_BSD_WAKEUP :
statesimpl.h
STATES_WAITING_FOR_BUFFER :
statesimpl.h
STATES_WAITING_FOR_CONDITION_VARIABLE :
statesimpl.h
STATES_WAITING_FOR_EVENT :
statesimpl.h
STATES_WAITING_FOR_JOIN :
statesimpl.h
STATES_WAITING_FOR_JOIN_AT_EXIT :
statesimpl.h
STATES_WAITING_FOR_MESSAGE :
statesimpl.h
STATES_WAITING_FOR_MUTEX :
statesimpl.h
STATES_WAITING_FOR_PERIOD :
statesimpl.h
STATES_WAITING_FOR_RPC_REPLY :
statesimpl.h
STATES_WAITING_FOR_RWLOCK :
statesimpl.h
STATES_WAITING_FOR_SEGMENT :
statesimpl.h
STATES_WAITING_FOR_SEMAPHORE :
statesimpl.h
STATES_WAITING_FOR_SIGNAL :
statesimpl.h
STATES_WAITING_FOR_SYSTEM_EVENT :
statesimpl.h
STATES_WAITING_FOR_TERMINATION :
statesimpl.h
STATES_WAITING_FOR_TIME :
statesimpl.h
STATES_ZOMBIE :
statesimpl.h
strlcat() :
pppd.h
strlcat.c
SYM :
asm.h
sync() :
sync.c
SYSTEM_STATE_BEFORE_INITIALIZATION :
sysstate.h
SYSTEM_STATE_BEFORE_MULTITASKING :
sysstate.h
System_state_Codes :
sysstate.h
SYSTEM_STATE_TERMINATED :
sysstate.h
SYSTEM_STATE_UP :
sysstate.h
