| struct | Scheduler_simple_Context |
| Simple scheduler context. More... | |
| #define | SCHEDULER_SIMPLE_ENTRY_POINTS |
| Entry points for Scheduler Simple. More... | |
| void | _Scheduler_simple_Initialize (const Scheduler_Control *scheduler) |
| Initialize simple scheduler. More... | |
| void | _Scheduler_simple_Schedule (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| This routine sets the heir thread to be the next ready thread on the ready queue by getting the first node in the scheduler information. More... | |
| Scheduler_Void_or_thread | _Scheduler_simple_Yield (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| Invoked when a thread wishes to voluntarily transfer control of the processor to another thread in the queue. More... | |
| void | _Scheduler_simple_Block (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| Remove a simple-priority-based thread from the queue. More... | |
| Scheduler_Void_or_thread | _Scheduler_simple_Unblock (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| Unblock a simple-priority-based thread. More... | |
| Scheduler_Void_or_thread | _Scheduler_simple_Change_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Control new_priority, bool prepend_it) |
| RTEMS_INLINE_ROUTINE Scheduler_simple_Context * | _Scheduler_simple_Get_context (const Scheduler_Control *scheduler) |
| RTEMS_INLINE_ROUTINE bool | _Scheduler_simple_Insert_priority_lifo_order (const Chain_Node *to_insert, const Chain_Node *next) |
| RTEMS_INLINE_ROUTINE bool | _Scheduler_simple_Insert_priority_fifo_order (const Chain_Node *to_insert, const Chain_Node *next) |
| RTEMS_INLINE_ROUTINE void | _Scheduler_simple_Insert_priority_lifo (Chain_Control *chain, Thread_Control *to_insert) |
| RTEMS_INLINE_ROUTINE void | _Scheduler_simple_Insert_priority_fifo (Chain_Control *chain, Thread_Control *to_insert) |
| RTEMS_INLINE_ROUTINE void | _Scheduler_simple_Extract (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| RTEMS_INLINE_ROUTINE void | _Scheduler_simple_Schedule_body (const Scheduler_Control *scheduler, Thread_Control *the_thread, bool force_dispatch) |
| #define SCHEDULER_SIMPLE_ENTRY_POINTS |
| void _Scheduler_simple_Block | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | the_thread | ||
This routine removes the_thread from the scheduling decision, that is, removes it from the ready queue. It performs any necessary scheduling operations including the selection of a new heir thread.
| [in] | scheduler | The scheduler instance. |
| [in] | the_thread | is the thread that is to be blocked |
| void _Scheduler_simple_Initialize | ( | const Scheduler_Control * | scheduler | ) |
This routine initializes the simple scheduler.
| void _Scheduler_simple_Schedule | ( | const Scheduler_Control * | scheduler, |
| [in] | the_thread | causing the scheduling operation. |
| Scheduler_Void_or_thread _Scheduler_simple_Unblock | ( | const Scheduler_Control * | scheduler, |
This routine adds the_thread to the scheduling decision, that is, adds it to the ready queue and updates any appropriate scheduling variables, for example the heir thread.
| [in] | the_thread | is the thread that is to be unblocked |
| Scheduler_Void_or_thread _Scheduler_simple_Yield | ( | const Scheduler_Control * | scheduler, |
This routine is invoked when a thread wishes to voluntarily transfer control of the processor to another thread in the queue. It will remove the specified THREAD from the scheduler.informaiton (where the ready queue is stored) and place it immediately at the between the last entry of its priority and the next priority thread. Reset timeslice and yield the processor functions both use this routine, therefore if reset is true and this is the only thread on the queue then the timeslice counter is reset. The heir THREAD will be updated if the running is also the currently the heir.
| [in,out] | the_thread | The yielding thread. |
