| CPU CPU |
| Provides CPU architecture dependent services.
| RTEMS no cpu Build Information |
| MIPS Processor Family Type Definitions |
| SPARC Context Structures |
| Generally there are 2 types of context to save.
| Debug Information |
| Address Handler |
| This handler encapsulates functionality which abstracts address manipulation in a portable manner.
| API Extension Handler |
| This handler encapsulates functionality which provides mechanisms for the SuperCore to perform API specific actions without there beingg "up-references" from the SuperCore to APIs.
| API Mutex Handler |
| Provides routines to ensure mutual exclusion on API level.
| Atomic Operations |
| Support for atomic operations.
| Basic Definitions |
| Chain Handler |
| The Chain Handler is used to manage sets of entities.
| Context Handler |
| This handler encapsulates functionality which abstracts thread context management in a portable manner.
| RTEMS Copyright Notice |
| Barrier Handler |
| This handler encapsulates functionality which provides the foundation Barrier services used in all of the APIs supported by RTEMS.
| Message Queue Handler |
| This handler encapsulates functionality which provides the foundation Message Queue services used in all of the APIs supported by RTEMS.
| Mutex Handler |
| This handler encapsulates functionality which provides the foundation Mutex services used in all of the APIs supported by RTEMS.
| RWLock Handler |
| This handler encapsulates functionality which provides the foundation RWLock services used in all of the APIs supported by RTEMS.
| Semaphore Handler |
| This handler encapsulates functionality which provides the foundation Semaphore services used in all of the APIs supported by RTEMS.
| Spinlock Handler |
| This handler encapsulates functionality which provides the foundation Spinlock services used in all of the APIs supported by RTEMS.
| Freechain Handler |
| The Freechain Handler is used to manage a chain of nodes, of which size can automatically increase when there is no free node left.
| Heap Handler |
| The Heap Handler provides a heap.
| Internal Error Handler |
| ISR Handler |
| This handler encapsulates functionality which provides the foundation ISR services used in all of the APIs supported by RTEMS.
| MPCI Handler |
| The MPCI Handler encapsulates functionality which is related to the generation, receipt, and processing of remote operations in a multiprocessor system.
| MP Packet Handler |
| This handler encapsulates the primary definition of MPCI packets.
| Object Handler |
| Object Handler Multiprocessing Support |
| This handler encapsulates functionality which is used to manage objects which have been declared to be globally visible.
| Once Functions. |
| The _Once() function for pthread_once() and rtems_gxx_once().
| RTEMS Per CPU Information |
| This defines the per CPU state information required by RTEMS and the BSP.
| Priority Handler |
| This handler encapsulates functionality which is used to manage thread priorities.
| Bitmap Priority Thread Routines |
| Red-Black Tree Handler |
| The Red-Black Tree Handler is used to manage sets of entities.
| Resource Handler |
| Support for resource dependency management.
| Scheduler Handler |
| This handler encapsulates functionality related to managing sets of threads that are ready for execution.
| SMP Support |
| This defines the interface of the SuperCore SMP support.
| SMP Barriers |
| The SMP barrier provides barrier synchronization for SMP systems at the lowest level.
| Stack Handler |
| This handler encapsulates functionality which is used in the management of thread stacks.
| SuperCore Thread States |
| This handler encapsulates functionality which relates to the management of the state bitmap associated with each thread.
| System State Handler |
| Management of the internal system state of RTEMS.
| Thread Handler |
| This handler encapsulates functionality related to the management of threads.
| Thread Handler Multiprocessing Support |
| This handler encapsulates functionality which is related to managing threads in a multiprocessor system configuration.
| Thread Queue Handler |
| This handler provides the capability to have threads block in ordered sets.
| Timecounter Handler |
| Helpers |
| This handler encapsulates functionality related to manipulating POSIX struct timespecs.
| Score Timestamp |
| This handler encapsulates functionality related to manipulating SuperCore Timestamps.
| Thread-Local Storage (TLS) |
| Thread-local storage (TLS) support.
| Time of Day Handler |
| The following constants are related to the time of day and are independent of RTEMS.
| User Extension Handler |
| The User Extension Handler provides invocation of application dependent routines at critical points in the life of each thread and the system as a whole.
| Watchdog Handler |
| This handler encapsulates functionality related to the scheduling of watchdog functions to be called at specific times in the future.
| Workspace Handler |
| This handler encapsulates functionality related to the management of the RTEMS Executive Workspace.
| Set Errno |
| System Information |
