This handler encapsulates functionality which provides the foundation Semaphore services used in all of the APIs supported by RTEMS. More...
Files | |
| file | coresem.c |
| Core Semaphore Initialize. | |
| struct | CORE_semaphore_Attributes |
| The following defines the control block used to manage the attributes of each semaphore. More... | |
| struct | CORE_semaphore_Control |
| The following defines the control block used to manage each counting semaphore. More... | |
| #define | CORE_SEMAPHORE_STATUS_LAST CORE_SEMAPHORE_MAXIMUM_COUNT_EXCEEDED |
| Core semaphore last status value. More... | |
Typedefs | |
| typedef void(* | CORE_semaphore_API_mp_support_callout) (Thread_Control *, Objects_Id) |
| The following type defines the callout which the API provides to support global/multiprocessor operations on semaphores. | |
Enumerations | |
| enum | CORE_semaphore_Disciplines { CORE_SEMAPHORE_DISCIPLINES_FIFO, CORE_SEMAPHORE_DISCIPLINES_PRIORITY } |
| Blocking disciplines for a semaphore. More... | |
| enum | CORE_semaphore_Status { CORE_SEMAPHORE_STATUS_SUCCESSFUL, CORE_SEMAPHORE_STATUS_UNSATISFIED_NOWAIT, CORE_SEMAPHORE_WAS_DELETED, CORE_SEMAPHORE_TIMEOUT, CORE_SEMAPHORE_MAXIMUM_COUNT_EXCEEDED } |
| Core Semaphore handler return statuses. More... | |
| void | _CORE_semaphore_Initialize (CORE_semaphore_Control *the_semaphore, const CORE_semaphore_Attributes *the_semaphore_attributes, uint32_t initial_value) |
| Initialize the semaphore based on the parameters passed. More... | |
| RTEMS_INLINE_ROUTINE void | _CORE_semaphore_Destroy (CORE_semaphore_Control *the_semaphore) |
| RTEMS_INLINE_ROUTINE CORE_semaphore_Status | _CORE_semaphore_Surrender (CORE_semaphore_Control *the_semaphore, Objects_Id id, CORE_semaphore_API_mp_support_callout api_semaphore_mp_support, ISR_lock_Context *lock_context) |
| Surrender a unit to a semaphore. More... | |
| RTEMS_INLINE_ROUTINE void | _CORE_semaphore_Flush (CORE_semaphore_Control *the_semaphore, Thread_queue_Flush_callout remote_extract_callout, uint32_t status) |
| Core semaphore flush. More... | |
| RTEMS_INLINE_ROUTINE bool | _CORE_semaphore_Is_priority (const CORE_semaphore_Attributes *the_attribute) |
| This function returns true if the priority attribute is enabled in the attribute_set and false otherwise. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | _CORE_semaphore_Get_count (CORE_semaphore_Control *the_semaphore) |
| This routine returns the current count associated with the semaphore. More... | |
| RTEMS_INLINE_ROUTINE void | _CORE_semaphore_Seize (CORE_semaphore_Control *the_semaphore, Thread_Control *executing, Objects_Id id, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context) |
| This routine attempts to receive a unit from the_semaphore. More... | |
| #define CORE_SEMAPHORE_STATUS_LAST CORE_SEMAPHORE_MAXIMUM_COUNT_EXCEEDED |
This is the last status value.
Referenced by _POSIX_Semaphore_Translate_core_semaphore_return_code().
| RTEMS_INLINE_ROUTINE void _CORE_semaphore_Flush | ( | CORE_semaphore_Control * | the_semaphore, |
| Thread_queue_Flush_callout | remote_extract_callout, | ||
| uint32_t | status | ||
This package is the implementation of the CORE Semaphore Handler. This core object utilizes standard Dijkstra counting semaphores to provide synchronization and mutual exclusion capabilities.
This routine assists in the deletion of a semaphore by flushing the associated wait queue.
| [in] | the_semaphore | is the semaphore to flush |
| [in] | remote_extract_callout | is the routine to invoke if the thread unblocked is remote |
| [in] | status | is the status to be returned to the unblocked thread |
Referenced by _POSIX_Semaphore_Delete().
| RTEMS_INLINE_ROUTINE uint32_t _CORE_semaphore_Get_count | ( | CORE_semaphore_Control * | the_semaphore | ) |
| [in] | the_semaphore | is the semaphore to obtain the count of |
References CORE_semaphore_Control::count.
| void _CORE_semaphore_Initialize | ( | CORE_semaphore_Control * | the_semaphore, |
| const CORE_semaphore_Attributes * | the_semaphore_attributes, | ||
| uint32_t | initial_value | ||
This routine initializes the semaphore based on the parameters passed.
| [in] | the_semaphore | is the semaphore to initialize |
| [in] | the_semaphore_attributes | define the behavior of this instance |
| [in] | initial_value | is the initial count of the semaphore |
References _CORE_semaphore_Is_priority(), _Thread_queue_Initialize(), CORE_semaphore_Control::Attributes, CORE_semaphore_Control::count, and CORE_semaphore_Control::Wait_queue.
Referenced by rtems_semaphore_create().
| RTEMS_INLINE_ROUTINE bool _CORE_semaphore_Is_priority | ( | const CORE_semaphore_Attributes * | the_attribute | ) |
| [in] | the_attribute | is the attribute set to test |
References CORE_SEMAPHORE_DISCIPLINES_PRIORITY, and CORE_semaphore_Attributes::discipline.
Referenced by _CORE_semaphore_Initialize().
| RTEMS_INLINE_ROUTINE void _CORE_semaphore_Seize | ( | CORE_semaphore_Control * | the_semaphore, |
| Thread_Control * | executing, | ||
| Objects_Id | id, | ||
| bool | wait, | ||
| Watchdog_Interval | timeout, | ||
| ISR_lock_Context * | lock_context | ||
If a unit is available or if the wait flag is false, then the routine returns. Otherwise, the calling task is blocked until a unit becomes available.
| [in] | the_semaphore | is the semaphore to obtain |
| [in,out] | executing | The currently executing thread. |
| [in] | id | is the Id of the owning API level Semaphore object |
| [in] | wait | is true if the thread is willing to wait |
| [in] | timeout | is the maximum number of ticks to block |
| [in] | lock_context | is a temporary variable used to contain the ISR disable level cookie |
Referenced by _MPCI_Receive_server().
| RTEMS_INLINE_ROUTINE CORE_semaphore_Status _CORE_semaphore_Surrender | ( | CORE_semaphore_Control * | the_semaphore, |
| CORE_semaphore_API_mp_support_callout | api_semaphore_mp_support, | ||
This routine frees a unit to the semaphore. If a task was blocked waiting for a unit from this semaphore, then that task will be readied and the unit given to that task. Otherwise, the unit will be returned to the semaphore.
| [in] | the_semaphore | is the semaphore to surrender |
| [in] | id | is the Id of the API level Semaphore object associated with this instance of a SuperCore Semaphore |
| [in] | api_semaphore_mp_support | is the routine to invoke if the thread unblocked is remote |
| an | indication of whether the routine succeeded or failed |
Referenced by _MPCI_Announce().
