This handler provides the capability to have threads block in ordered sets. More...
| struct | Thread_queue_Operations |
| Thread queue operations. More... | |
| struct | Thread_queue_Control |
| This is the structure used to manage sets of tasks which are blocked waiting to acquire a resource. More... | |
| #define | THREAD_QUEUE_FIFO_INITIALIZER(designator, name) |
| #define | THREAD_QUEUE_PRIORITY_INITIALIZER(designator, name) |
Typedefs | |
| typedef struct Thread_Control | Thread_Control |
| typedef struct Thread_queue_Control | Thread_queue_Control |
| typedef void(* | Thread_queue_Priority_change_operation) (Thread_Control *the_thread, Priority_Control new_priority, Thread_queue_Control *the_thread_queue) |
| Thread queue priority change operation. More... | |
| typedef void(* | Thread_queue_Initialize_operation) (Thread_queue_Control *the_thread_queue) |
| Thread queue initialize operation. More... | |
| typedef void(* | Thread_queue_Enqueue_operation) (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread) |
| Thread queue enqueue operation. More... | |
| typedef void(* | Thread_queue_Extract_operation) (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread) |
| Thread queue extract operation. More... | |
| typedef Thread_Control *(* | Thread_queue_First_operation) (Thread_queue_Control *the_thread_queue) |
| Thread queue first operation. More... | |
| typedef void(* | Thread_queue_Flush_callout) (Thread_Control *) |
| The following type defines the callout used when a remote task is extracted from a local thread queue. | |
Enumerations | |
| enum | Thread_queue_Disciplines { THREAD_QUEUE_DISCIPLINE_FIFO, THREAD_QUEUE_DISCIPLINE_PRIORITY } |
| The following enumerated type details all of the disciplines supported by the Thread Queue Handler. | |
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Acquire_critical (Thread_queue_Control *the_thread_queue, ISR_lock_Context *lock_context) |
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Acquire (Thread_queue_Control *the_thread_queue, ISR_lock_Context *lock_context) |
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Release (Thread_queue_Control *the_thread_queue, ISR_lock_Context *lock_context) |
| Thread_Control * | _Thread_queue_Dequeue (Thread_queue_Control *the_thread_queue) |
| Gets a pointer to a thread waiting on the_thread_queue. More... | |
| void | _Thread_queue_Enqueue_critical (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread, States_Control state, Watchdog_Interval timeout, uint32_t timeout_code, ISR_lock_Context *lock_context) |
| Blocks the thread and places it on the thread queue. More... | |
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Enqueue (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread, States_Control state, Watchdog_Interval timeout, uint32_t timeout_code) |
| Acquires the thread queue lock and calls _Thread_queue_Enqueue_critical(). | |
| void | _Thread_queue_Extract_locked (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread) |
| Extracts the thread from the thread queue, restores the default wait operations and restores the default thread lock. More... | |
| void | _Thread_queue_Unblock_critical (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread, ISR_lock_Context *lock_context) |
| Unblocks the thread which was on the thread queue before. More... | |
| void | _Thread_queue_Extract_critical (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread, ISR_lock_Context *lock_context) |
| Extracts the thread from the thread queue and unblocks it. More... | |
| void | _Thread_queue_Extract (Thread_Control *the_thread) |
| Extracts thread from thread queue. More... | |
| void | _Thread_queue_Extract_with_proxy (Thread_Control *the_thread) |
| Extracts the_thread from the_thread_queue. More... | |
| RTEMS_INLINE_ROUTINE Thread_Control * | _Thread_queue_First_locked (Thread_queue_Control *the_thread_queue) |
Returns the first thread on the thread queue if it exists, otherwise NULL. More... | |
| Thread_Control * | _Thread_queue_First (Thread_queue_Control *the_thread_queue) |
| void | _Thread_queue_Flush (Thread_queue_Control *the_thread_queue, Thread_queue_Flush_callout remote_extract_callout, uint32_t status) |
| Unblocks all threads blocked on the_thread_queue. More... | |
| void | _Thread_queue_Initialize (Thread_queue_Control *the_thread_queue, Thread_queue_Disciplines the_discipline) |
| Initialize the_thread_queue. More... | |
| RTEMS_INLINE_ROUTINE void | _Thread_queue_Destroy (Thread_queue_Control *the_thread_queue) |
| RBTree_Compare_result | _Thread_queue_Compare_priority (const RBTree_Node *left, const RBTree_Node *right) |
| Compare two thread's priority for RBTree Insertion. More... | |
| const Thread_queue_Operations | _Thread_queue_Operations_default |
| const Thread_queue_Operations | _Thread_queue_Operations_FIFO |
| const Thread_queue_Operations | _Thread_queue_Operations_priority |
The sets may be ordered using the FIFO or priority discipline.
| #define THREAD_QUEUE_FIFO_INITIALIZER | ( | designator, | |
| name | |||
| #define THREAD_QUEUE_PRIORITY_INITIALIZER | ( | designator, | |
| name | |||
| typedef void( * Thread_queue_Enqueue_operation) (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread) |
| [in] | the_thread_queue | The thread queue. |
| [in] | the_thread | The thread to enqueue on the queue. |
| typedef void( * Thread_queue_Extract_operation) (Thread_queue_Control *the_thread_queue, Thread_Control *the_thread) |
| [in] | the_thread | The thread to extract from the thread queue. |
| typedef Thread_Control*( * Thread_queue_First_operation) (Thread_queue_Control *the_thread_queue) |
| NULL | No thread is present on the thread queue. |
| first | The first thread of the thread queue according to the insert order. This thread remains on the thread queue. |
| typedef void( * Thread_queue_Initialize_operation) (Thread_queue_Control *the_thread_queue) |
| typedef void( * Thread_queue_Priority_change_operation) (Thread_Control *the_thread, Priority_Control new_priority, Thread_queue_Control *the_thread_queue) |
| [in] | the_thread | The thread. |
| [in] | new_priority | The new priority value. |
| RBTree_Compare_result _Thread_queue_Compare_priority | ( | const RBTree_Node * | left, |
| const RBTree_Node * | right | ||
| [in] | left | points to the left thread's RBnode |
| [in] | right | points to the right thread's RBnode |
| 1 | The left node is more important than right node. |
| 0 | The left node is of equal importance with right node. |
| 1 | The left node is less important than right node. |
| Thread_Control* _Thread_queue_Dequeue | ( | Thread_queue_Control * | the_thread_queue | ) |
This function returns a pointer to a thread waiting on the_thread_queue. The selection of this thread is based on the discipline of the_thread_queue. If no threads are waiting on the_thread_queue, then NULL is returned.
Referenced by _CORE_barrier_Release().
| void _Thread_queue_Enqueue_critical | ( | Thread_queue_Control * | the_thread_queue, |
| Thread_Control * | the_thread, | ||
| States_Control | state, | ||
| Watchdog_Interval | timeout, | ||
| uint32_t | timeout_code, | ||
| ISR_lock_Context * | lock_context | ||
This enqueues the thread on the thread queue, blocks the thread, and optionally starts the thread timer in case the timeout interval is not WATCHDOG_NO_TIMEOUT.
The caller must be the owner of the thread queue lock. This function will release the thread queue lock and register it as the new thread lock. Thread dispatching is disabled before the thread queue lock is released. Thread dispatching is enabled once the sequence to block the thread is complete. The operation to enqueue the thread on the queue is protected by the thread queue lock. This makes it possible to use the thread queue lock to protect the state of objects embedding the thread queue and directly enter _Thread_queue_Enqueue_critical() in case the thread must block.
| [in] | the_thread | The thread to enqueue. |
| [in] | state | The new state of the thread. |
| [in] | timeout | Interval to wait. Use WATCHDOG_NO_TIMEOUT to block potentially forever. |
| [in] | timeout_code | The return code in case a timeout occurs. |
| [in] | lock_context | The lock context of the lock acquire. |
| void _Thread_queue_Extract | ( | Thread_Control * | the_thread | ) |
This routine removes the_thread its thread queue and cancels any timeouts associated with this blocking.
| [in] | the_thread | is the pointer to a thread control block that is to be removed |
| void _Thread_queue_Extract_critical | ( | Thread_queue_Control * | the_thread_queue, |
The caller must be the owner of the thread queue lock. This function will release the thread queue lock and restore the default thread lock. Thread dispatching is disabled before the thread queue lock is released and an unblock is necessary. Thread dispatching is enabled once the sequence to unblock the thread is complete. This makes it possible to use the thread queue lock to protect the state of objects embedding the thread queue and directly enter _Thread_queue_Extract_critical() to finalize an operation in case a waiting thread exists.
| [in] | the_thread | The thread to extract. |
References _Thread_queue_Extract_locked(), and _Thread_queue_Unblock_critical().
| void _Thread_queue_Extract_locked | ( | Thread_queue_Control * | the_thread_queue, |
| Thread_Control * | the_thread | ||
The caller must be the owner of the thread queue lock. The thread queue lock is not released.
References _Thread_Lock_restore_default, _Thread_Wait_restore_default_operations(), _Thread_Wait_set_queue(), Thread_queue_Operations::extract, and Thread_queue_Control::operations.
Referenced by _Thread_queue_Extract_critical().
| void _Thread_queue_Extract_with_proxy | ( | Thread_Control * | the_thread | ) |
This routine extracts the_thread from the_thread_queue and ensures that if there is a proxy for this task on another node, it is also dealt with.
This routine extracts the_thread from the_thread_queue and ensures that if there is a proxy for this task on another node, it is also dealt with. A proxy is a data data that is on the thread queue on the remote node and acts as a proxy for the local thread. If the local thread was waiting on a remote operation, then the remote side of the operation must be cleaned up.
| Thread_Control* _Thread_queue_First | ( | Thread_queue_Control * | the_thread_queue | ) |
| first | The first thread on the thread queue according to the enqueue order. |
Referenced by _Thread_queue_First_locked().
| RTEMS_INLINE_ROUTINE Thread_Control* _Thread_queue_First_locked | ( | Thread_queue_Control * | the_thread_queue | ) |
References _Thread_queue_First(), _Thread_queue_Flush(), Thread_queue_Operations::first, and Thread_queue_Control::operations.
| void _Thread_queue_Flush | ( | Thread_queue_Control * | the_thread_queue, |
| Thread_queue_Flush_callout | remote_extract_callout, | ||
| uint32_t | status | ||
This routine unblocks all threads blocked on the_thread_queue and cancels any associated timeouts.
| [in] | the_thread_queue | is the pointer to a threadq header |
| [in] | remote_extract_callout | points to a method to invoke to invoke when a remote thread is unblocked |
| [in] | status | is the status which will be returned to all unblocked threads |
| void _Thread_queue_Initialize | ( | Thread_queue_Control * | the_thread_queue, |
| Thread_queue_Disciplines | the_discipline | ||
This routine initializes the_thread_queue based on the discipline indicated in attribute_set. The state set on threads which block on the_thread_queue is state.
| [in] | the_discipline | is the queueing discipline |
References _ISR_lock_Initialize.
Referenced by _CORE_barrier_Initialize(), _CORE_mutex_Initialize(), _CORE_RWLock_Initialize(), _CORE_semaphore_Initialize(), and pthread_cond_init().
| void _Thread_queue_Unblock_critical | ( | Thread_queue_Control * | the_thread_queue, |
The caller must be the owner of the thread queue lock. This function will release the thread queue lock. Thread dispatching is disabled before the thread queue lock is released and an unblock is necessary. Thread dispatching is enabled once the sequence to unblock the thread is complete.
