This handler encapsulates functionality which is used to manage objects which have been declared to be globally visible. More...
Files | |
| file | objectmp.c |
| Objects MP Support. | |
| void | _Objects_MP_Handler_initialization (void) |
| Intializes the inactive global object chain based on the maximum number of global objects configured. More... | |
| void | _Objects_MP_Handler_early_initialization (void) |
| Intializes the global object node number used in the ID field of all objects. More... | |
| void | _Objects_MP_Open (Objects_Information *information, Objects_MP_Control *the_global_object, uint32_t the_name, Objects_Id the_id) |
| Place the specified global object in the specified information table. More... | |
| bool | _Objects_MP_Allocate_and_open (Objects_Information *information, uint32_t the_name, Objects_Id the_id, bool is_fatal_error) |
| Allocates a global object control block and places it in the specified information table. More... | |
| void | _Objects_MP_Close (Objects_Information *information, Objects_Id the_id) |
| Removes a global object from the specified information table. More... | |
| Objects_Name_or_id_lookup_errors | _Objects_MP_Global_name_search (Objects_Information *information, Objects_Name the_name, uint32_t nodes_to_search, Objects_Id *the_id) |
| Look for the object with the_name in the global object tables indicated by information. More... | |
| void | _Objects_MP_Is_remote (Objects_Information *information, Objects_Id the_id, Objects_Locations *location, Objects_Control **the_object) |
| Searches the Global Object Table managed by information for the object indicated by ID. More... | |
| RTEMS_INLINE_ROUTINE Objects_MP_Control * | _Objects_MP_Allocate_global_object (void) |
| This function allocates a Global Object control block. | |
| RTEMS_INLINE_ROUTINE void | _Objects_MP_Free_global_object (Objects_MP_Control *the_object) |
| This routine deallocates a Global Object control block. | |
| RTEMS_INLINE_ROUTINE bool | _Objects_MP_Is_null_global_object (Objects_MP_Control *the_object) |
| This function returns whether the global object is NULL or not. | |
| SCORE_EXTERN uint32_t | _Objects_MP_Maximum_global_objects |
| This is the maximum number of global objects configured. | |
| SCORE_EXTERN Chain_Control | _Objects_MP_Inactive_global_objects |
| The following chain header is used to manage the set of inactive global object control blocks. | |
This handler knows objects from all of the nodes in the system.
| bool _Objects_MP_Allocate_and_open | ( | Objects_Information * | information, |
| uint32_t | the_name, | ||
| Objects_Id | the_id, | ||
| bool | is_fatal_error | ||
This routine allocates a global object control block and places it in the specified information table. If the allocation fails, then is_fatal_error determines the error processing actions taken.
| [in] | information | points to the object information table for this object class. |
| [in] | the_name | is the name of the object being opened. |
| [in] | the_id | is the Id of the object being opened. |
| [in] | is_fatal_error | is true if not being able to allocate the object is considered a fatal error. |
References _Objects_MP_Allocate_global_object(), _Objects_MP_Is_null_global_object(), _Terminate(), and INTERNAL_ERROR_CORE.
Referenced by rtems_semaphore_create().
| void _Objects_MP_Close | ( | Objects_Information * | information, |
| Objects_Id | the_id | ||
This routine removes a global object from the specified information table and deallocates the global object control block.
References _Chain_Extract(), _Chain_First(), _Chain_Is_tail(), _Chain_Next(), _Objects_Are_ids_equal(), _Objects_Get_node(), _Objects_MP_Free_global_object(), _Terminate(), and INTERNAL_ERROR_CORE.
| Objects_Name_or_id_lookup_errors _Objects_MP_Global_name_search | ( | Objects_Information * | information, |
| Objects_Name | the_name, | ||
| uint32_t | nodes_to_search, | ||
| Objects_Id * | the_id | ||
This routine looks for the object with the_name in the global object tables indicated by information. It returns the ID of the object with that name if one is found.
| [in] | the_name | is the name of the object being searched for. |
| [in] | nodes_to_search | indicates the set of nodes to search. |
| [in] | the_id | will contain the Id of the object if found. |
| This | method returns one of the Objects_Name_or_id_lookup_errors. If successful, the_id will contain the Id of the object. |
References _Objects_Maximum_nodes, and Objects_Name::name_u32.
| void _Objects_MP_Handler_early_initialization | ( | void | ) |
This routine intializes the global object node number used in the ID field of all objects.
References _Terminate(), and INTERNAL_ERROR_CORE.
| void _Objects_MP_Handler_initialization | ( | void | ) |
This routine intializes the inactive global object chain based on the maximum number of global objects configured.
References _Chain_Initialize(), _Chain_Initialize_empty(), _Objects_MP_Inactive_global_objects, _Objects_MP_Maximum_global_objects, and _Workspace_Allocate_or_fatal_error().
| void _Objects_MP_Is_remote | ( | Objects_Information * | information, |
| Objects_Locations * | location, | ||
| Objects_Control ** | the_object | ||
This function searches the Global Object Table managed by information for the object indicated by ID. If the object is found, then location is set to objects_remote, otherwise location is set to objects_error. In both cases, the_object is undefined.
| [in] | location | will contain the location of the object. |
| [in] | the_object | will contain a pointer to the object. |
| This | method fills in location to indicate successful location of the object or error. On success, the_object will be filled in. |
References _Objects_Get_node(), _Objects_Is_local_node(), and _Objects_Maximum_nodes.
| void _Objects_MP_Open | ( | Objects_Information * | information, |
| Objects_MP_Control * | the_global_object, | ||
This routine place the specified global object in the specified information table.
| [in] | the_global_object | points to the object being opened. |
References _Chain_Prepend(), and _Objects_Get_node().
