This handler encapsulates functionality related to the management of the RTEMS Executive Workspace.
More...
◆ _Workspace_Allocate()
| void* _Workspace_Allocate |
size_t |
size | ) |
Allocate memory from workspace.
This routine returns the address of a block of memory of size bytes. If a block of the appropriate size cannot be allocated from the workspace, then NULL is returned.
- Parameters
| size | is the requested size |
- Return values
| a | pointer to the requested memory or NULL. |
◆ _Workspace_Allocate_aligned()
| void* _Workspace_Allocate_aligned |
size_t |
size, |
size_t |
alignment |
Allocate aligned memory from workspace.
- Parameters
| [in] | size | The size of the requested memory. |
| [in] | alignment | The alignment of the requested memory. |
- Return values
| NULL | Not enough resources. |
| other | The memory area begin. |
◆ _Workspace_Allocate_or_fatal_error()
| void* _Workspace_Allocate_or_fatal_error |
size_t |
size | ) |
Workspace allocate or fail with fatal error.
This routine returns the address of a block of memory of size bytes. If a block of the appropriate size cannot be allocated from the workspace, then the internal error handler is invoked.
- Parameters
| [in] | size | is the desired number of bytes to allocate |
- Return values
| If | successful, the starting address of the allocated memory |
Referenced by _Objects_MP_Handler_initialization(), and _Thread_MP_Handler_initialization().
◆ _Workspace_Free()
| void _Workspace_Free |
void * |
block | ) |
◆ _Workspace_Handler_initialization()
Initilize workspace handler.
This routine performs the initialization necessary for this handler.
References _Heap_Initialize().
◆ _Workspace_String_duplicate()
| char* _Workspace_String_duplicate |
const char * |
string, |
size_t |
len |
Duplicates string with memory from the workspace.
- Parameters
| [in] | string | is the pointer to a zero terminated string. |
| [in] | len | is the length of the string (equal to strlen(string)). |
- Return values
| NULL | Not enough memory. |
| other | Duplicated string. |
◆ _Workspace_Area
