Provides CPU architecture dependent services. More...
Modules | |
ARM Assembler Support | |
ARM Assembler Support. | |
Object Handler | |
Files | |
file | arm_exc_handler_high.c |
ARM exception support implementation. | |
file | cpu.c |
ARM architecture support implementation. | |
file | cpu_asm.h |
ARM Assembler Support API. | |
file | epiphany-utility.h |
This include file contains macros pertaining to the Epiphany processor family. | |
file | objectshrinkinformation.c |
Shrink an Object Class Information Record. | |
struct | Context_Control |
This defines the minimal set of integer and processor state registers that must be saved during a voluntary context switch from one thread to another. More... | |
struct | Context_Control_fp |
This defines the complete set of floating point registers that must be saved during any context switch from one thread to another. More... | |
struct | CPU_Interrupt_frame |
This defines the set of integer and processor state registers that must be saved during an interrupt. More... | |
union | Objects_Name |
The following type defines the control block used to manage object names. More... | |
#define | CPU_MODEL_NAME "ARMv4" |
#define | ARM_MULTILIB_ARCH_V4 |
#define | CPU_NAME "ARM" |
#define | CPU_INLINE_ENABLE_DISPATCH TRUE |
#define | CPU_SIMPLE_VECTORED_INTERRUPTS FALSE |
#define | CPU_HAS_SOFTWARE_INTERRUPT_STACK FALSE |
#define | CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE |
#define | CPU_ALLOCATE_INTERRUPT_STACK FALSE |
#define | CPU_ISR_PASSES_FRAME_POINTER 0 |
#define | CPU_HARDWARE_FP FALSE |
#define | CPU_SOFTWARE_FP FALSE |
#define | CPU_ALL_TASKS_ARE_FP FALSE |
#define | CPU_IDLE_TASK_IS_FP FALSE |
#define | CPU_USE_DEFERRED_FP_SWITCH FALSE |
#define | CPU_PROVIDES_IDLE_THREAD_BODY FALSE |
#define | CPU_STACK_GROWS_UP FALSE |
#define | CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned ( 32 ))) |
#define | CPU_TIMESTAMP_USE_STRUCT_TIMESPEC TRUE |
#define | CPU_MODES_INTERRUPT_MASK 0x1 |
#define | CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) |
#define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
#define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
#define | CPU_STACK_MINIMUM_SIZE (1024 * 4) |
#define | CPU_SIZEOF_POINTER 4 |
#define | CPU_ALIGNMENT 8 |
#define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_PARTITION_ALIGNMENT 4 |
#define | CPU_STACK_ALIGNMENT 8 |
#define | CPU_USE_GENERIC_BITFIELD_CODE TRUE |
#define | CPU_USE_GENERIC_BITFIELD_DATA TRUE |
#define | CPU_PER_CPU_CONTROL_SIZE 0 |
#define | _CPU_ISR_Disable(_isr_cookie) |
#define | _CPU_ISR_Enable(_isr_cookie) arm_interrupt_enable( _isr_cookie ) |
#define | _CPU_ISR_Flash(_isr_cookie) arm_interrupt_flash( _isr_cookie ) |
#define | _CPU_Context_Get_SP(_context) (_context)->register_sp |
#define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
#define | _CPU_Context_Fp_start(_base, _offset) ( (void *) _Addresses_Add_offset( (_base), (_offset) ) ) |
#define | _CPU_Context_Initialize_fp(_destination) |
#define | _CPU_Fatal_halt(_source, _err) |
#define | CPU_INLINE_ENABLE_DISPATCH FALSE |
#define | CPU_ISR_PASSES_FRAME_POINTER 1 |
#define | CPU_ALL_TASKS_ARE_FP CPU_HARDWARE_FP |
#define | CPU_USE_DEFERRED_FP_SWITCH TRUE |
#define | CPU_PROVIDES_IDLE_THREAD_BODY TRUE |
#define | CPU_STRUCTURE_ALIGNMENT |
#define | CPU_TIMESTAMP_USE_INT64_INLINE TRUE |
#define | CPU_MODES_INTERRUPT_MASK 0x000000ff |
#define | _CPU_Context_Get_SP(_context) (uintptr_t) (_context)->sp |
#define | CPU_STACK_MINIMUM_SIZE (8 * 1024) |
#define | CPU_PARTITION_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_STACK_ALIGNMENT CPU_ALIGNMENT |
#define | _CPU_ISR_Disable(_level) |
#define | _CPU_ISR_Enable(_level) |
#define | _CPU_ISR_Flash(_xlevel) |
#define | _CPU_Fatal_halt(_source, _error) |
#define | _CPU_Bitfield_Find_first_bit(_value, _output) |
#define | _CPU_Priority_Mask(_bit_number) ( 1 << (_bit_number) ) |
#define | _CPU_Priority_bits_index(_priority) (_priority) |
#define | CPU_swap_u16(value) (((value&0xff) << 8) | ((value >> 8)&0xff)) |
Typedefs | |
typedef uint32_t | CPU_Counter_ticks |
typedef uintptr_t | CPU_Uint32ptr |
Type that can store a 32-bit integer or a pointer. More... | |
typedef uint16_t | Priority_bit_map_Word |
typedef void | epiphany_isr |
typedef void(* | epiphany_isr_entry) (void) |
typedef CPU_Interrupt_frame | CPU_Exception_frame |
typedef void | or1k_isr |
typedef void(* | or1k_isr_entry) (void) |
void | _CPU_ISR_Set_level (uint32_t level) |
Sets the hardware interrupt level by the level value. More... | |
void | _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area) |
void | _CPU_Initialize (void) |
CPU initialization. More... | |
CPU_Counter_ticks | _CPU_Counter_read (void) |
CPU_Counter_ticks | _CPU_Counter_difference (CPU_Counter_ticks second, CPU_Counter_ticks first) |
Returns the difference between the second and first CPU counter value. More... | |
void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
void | mips_vector_exceptions (CPU_Interrupt_frame *frame) |
uint32_t | mips_interrupt_mask (void) |
void | _CPU_Context_Initialize (Context_Control *the_context, uintptr_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area) |
void | mips_break (int error) |
void | _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
This routine installs a "raw" interrupt handler directly into the processor's vector table. More... | |
void | _CPU_Install_interrupt_stack (void) |
This routine installs the hardware interrupt stack pointer. More... | |
void | _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr) |
This routine saves the floating point context passed to it. More... | |
void | _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr) |
This routine restores the floating point context passed to it. More... | |
void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
Prints the exception frame via printk(). More... | |
uint32_t | arm_cpu_mode |
SCORE_EXTERN Context_Control_fp | _CPU_Null_fp_context |
#define _CPU_Bitfield_Find_first_bit | ( | _value, | |
_output | |||
#define _CPU_Context_Initialize_fp | ( | _destination | ) |
#define _CPU_Fatal_halt | ( | _source, | |
_err | |||
_error | |||
#define _CPU_ISR_Disable | ( | _isr_cookie | ) |
#define _CPU_ISR_Disable | ( | _level | ) |
#define _CPU_ISR_Enable | ( | _level | ) |
#define _CPU_ISR_Flash | ( | _xlevel | ) |
typedef uintptr_t CPU_Uint32ptr |
void _CPU_Context_restore_fp | ( | Context_Control_fp ** | fp_context_ptr | ) |
[in] | fp_context_ptr | is a pointer to a pointer to a floating point context area to restore |
Port Specific Information:
XXX document implementation including references if appropriate
void _CPU_Context_save_fp | ( | Context_Control_fp ** | fp_context_ptr | ) |
[in] | fp_context_ptr | is a pointer to a pointer to a floating point context area |
inline |
This operation may be carried out as a modulo operation depending on the range of the CPU counter device.
[in] | second | The second CPU counter value. |
[in] | first | The first CPU counter value. |
void _CPU_Exception_frame_print | ( | const CPU_Exception_frame * | frame | ) |
This method prints the CPU exception frame.
void _CPU_Initialize | ( | void | ) |
CPU initialization.
CPU initialization.
void _CPU_Install_interrupt_stack | ( | void | ) |
NOTE: It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK is TRUE.
[in] | vector | is the vector number |
[in] | new_handler | is the raw ISR handler to install |
[in] | old_handler | is the previously installed ISR Handler |
void _CPU_ISR_Set_level | ( | uint32_t | level | ) |
[in] | level | for or1k can only range over two values: 0 (enable interrupts) and 1 (disable interrupts). In future implementations if fast context switch is implemented, the level can range from 0 to 15. |
