This handler encapsulates functionality which provides the foundation Message Queue services used in all of the APIs supported by RTEMS. More...
Files | |
| file | coremsg.c |
| Initialize a Message Queue. | |
| file | coremsgbroadcast.c |
| Broadcast a Message to the Message Queue. | |
| file | coremsgclose.c |
| Close a Message Queue. | |
| file | coremsgflush.c |
| Flush Messages Routine. | |
| file | coremsgflushwait.c |
| Flush Waiting Threads. | |
| file | coremsginsert.c |
| Insert a Message into the Message Queue. | |
| file | coremsgseize.c |
| Size a Message from the Message Queue. | |
| file | coremsgsubmit.c |
| CORE Message Queue Submit. | |
| struct | CORE_message_queue_Buffer |
| Data types needed to manipulate the contents of message buffers. More... | |
| struct | CORE_message_queue_Buffer_control |
| The organization of a message buffer. More... | |
| struct | CORE_message_queue_Attributes |
| Control block used to manage the attributes of each message queue. More... | |
| struct | CORE_message_queue_Control |
| Control block used to manage each message queue. More... | |
| #define | CORE_MESSAGE_QUEUE_SEND_REQUEST INT_MAX |
| Used when appending messages onto a message queue. More... | |
| #define | CORE_MESSAGE_QUEUE_URGENT_REQUEST INT_MIN |
| Used when prepending messages onto a message queue. More... | |
| #define | CORE_MESSAGE_QUEUE_STATUS_LAST CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED_WAIT |
| Core message queue last status value. More... | |
| #define | _CORE_message_queue_Set_notify(the_message_queue, the_handler, the_argument) |
| This routine initializes the notification information for the_message_queue. | |
Typedefs | |
| typedef int | CORE_message_queue_Submit_types |
| The modes in which a message may be submitted to a message queue. More... | |
| typedef void(* | CORE_message_queue_API_mp_support_callout) (Thread_Control *, Objects_Id) |
| Callout provides to support global/multiprocessor operations. More... | |
Enumerations | |
| enum | CORE_message_queue_Disciplines { CORE_MESSAGE_QUEUE_DISCIPLINES_FIFO, CORE_MESSAGE_QUEUE_DISCIPLINES_PRIORITY } |
| The possible blocking disciplines for a message queue. More... | |
| enum | CORE_message_queue_Status { CORE_MESSAGE_QUEUE_STATUS_SUCCESSFUL, CORE_MESSAGE_QUEUE_STATUS_INVALID_SIZE, CORE_MESSAGE_QUEUE_STATUS_TOO_MANY, CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED, CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED_NOWAIT, CORE_MESSAGE_QUEUE_STATUS_WAS_DELETED, CORE_MESSAGE_QUEUE_STATUS_TIMEOUT, CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED_WAIT } |
| The possible set of Core Message Queue handler return statuses. More... | |
| bool | _CORE_message_queue_Initialize (CORE_message_queue_Control *the_message_queue, CORE_message_queue_Attributes *the_message_queue_attributes, uint32_t maximum_pending_messages, size_t maximum_message_size) |
| Initialize a message queue. More... | |
| void | _CORE_message_queue_Close (CORE_message_queue_Control *the_message_queue, Thread_queue_Flush_callout remote_extract_callout, uint32_t status) |
| Close a message queue. More... | |
| uint32_t | _CORE_message_queue_Flush (CORE_message_queue_Control *the_message_queue, ISR_lock_Context *lock_context) |
| Flush pending messages. More... | |
| CORE_message_queue_Status | _CORE_message_queue_Broadcast (CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, Objects_Id id, CORE_message_queue_API_mp_support_callout api_message_queue_mp_support, uint32_t *count, ISR_lock_Context *lock_context) |
| Broadcast a message to the message queue. More... | |
| CORE_message_queue_Status | _CORE_message_queue_Submit (CORE_message_queue_Control *the_message_queue, Thread_Control *executing, const void *buffer, size_t size, Objects_Id id, CORE_message_queue_API_mp_support_callout api_message_queue_mp_support, CORE_message_queue_Submit_types submit_type, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context) |
| Submit a message to the message queue. More... | |
| void | _CORE_message_queue_Seize (CORE_message_queue_Control *the_message_queue, Thread_Control *executing, Objects_Id id, void *buffer, size_t *size_p, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context) |
| Size a message from the message queue. More... | |
| void | _CORE_message_queue_Insert_message (CORE_message_queue_Control *the_message_queue, CORE_message_queue_Buffer_control *the_message, CORE_message_queue_Submit_types submit_type) |
| Insert a message into the message queue. More... | |
| RTEMS_INLINE_ROUTINE CORE_message_queue_Status | _CORE_message_queue_Send (CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, Objects_Id id, CORE_message_queue_API_mp_support_callout api_message_queue_mp_support, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context) |
| This routine sends a message to the end of the specified message queue. | |
| RTEMS_INLINE_ROUTINE CORE_message_queue_Status | _CORE_message_queue_Urgent (CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, Objects_Id id, CORE_message_queue_API_mp_support_callout api_message_queue_mp_support, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context) |
| This routine sends a message to the front of the specified message queue. | |
| RTEMS_INLINE_ROUTINE void | _CORE_message_queue_Acquire (CORE_message_queue_Control *the_message_queue, ISR_lock_Context *lock_context) |
| RTEMS_INLINE_ROUTINE void | _CORE_message_queue_Acquire_critical (CORE_message_queue_Control *the_message_queue, ISR_lock_Context *lock_context) |
| RTEMS_INLINE_ROUTINE void | _CORE_message_queue_Release (CORE_message_queue_Control *the_message_queue, ISR_lock_Context *lock_context) |
| RTEMS_INLINE_ROUTINE void | _CORE_message_queue_Copy_buffer (const void *source, void *destination, size_t size) |
| This routine copies the contents of the source message buffer to the destination message buffer. | |
| RTEMS_INLINE_ROUTINE CORE_message_queue_Buffer_control * | _CORE_message_queue_Allocate_message_buffer (CORE_message_queue_Control *the_message_queue) |
| This function allocates a message buffer from the inactive message buffer chain. | |
| RTEMS_INLINE_ROUTINE void | _CORE_message_queue_Free_message_buffer (CORE_message_queue_Control *the_message_queue, CORE_message_queue_Buffer_control *the_message) |
| This routine frees a message buffer to the inactive message buffer chain. | |
| RTEMS_INLINE_ROUTINE int | _CORE_message_queue_Get_message_priority (const CORE_message_queue_Buffer_control *the_message) |
| This function returns the priority of the_message. More... | |
| RTEMS_INLINE_ROUTINE void | _CORE_message_queue_Set_message_priority (CORE_message_queue_Buffer_control *the_message, int priority) |
| This function sets the priority of the_message. More... | |
| RTEMS_INLINE_ROUTINE CORE_message_queue_Buffer_control * | _CORE_message_queue_Get_pending_message (CORE_message_queue_Control *the_message_queue) |
| This function removes the first message from the_message_queue and returns a pointer to it. | |
| RTEMS_INLINE_ROUTINE bool | _CORE_message_queue_Is_priority (CORE_message_queue_Attributes *the_attribute) |
| This function returns true if the priority attribute is enabled in the attribute_set and false otherwise. | |
| RTEMS_INLINE_ROUTINE Thread_Control * | _CORE_message_queue_Dequeue_receiver (CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, CORE_message_queue_Submit_types submit_type, ISR_lock_Context *lock_context) |
| #define CORE_MESSAGE_QUEUE_SEND_REQUEST INT_MAX |
This is the priority constant used when appending messages onto a message queue.
| #define CORE_MESSAGE_QUEUE_STATUS_LAST CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED_WAIT |
This is the last status value.
Referenced by _POSIX_Message_queue_Translate_core_message_queue_return_code().
| #define CORE_MESSAGE_QUEUE_URGENT_REQUEST INT_MIN |
This is the priority constant used when prepending messages onto a message queue.
| typedef void( * CORE_message_queue_API_mp_support_callout) (Thread_Control *, Objects_Id) |
The following type defines the callout which the API provides to support global/multiprocessor operations on message_queues.
| typedef int CORE_message_queue_Submit_types |
The following type details the modes in which a message may be submitted to a message queue. The message may be posted in a send or urgent fashion.
This enumerated types defines the possible blocking disciplines for a message queue.
This enumerated type defines the possible set of Core Message Queue handler return statuses.
| CORE_message_queue_Status _CORE_message_queue_Broadcast | ( | CORE_message_queue_Control * | the_message_queue, |
| const void * | buffer, | ||
| size_t | size, | ||
| Objects_Id | id, | ||
| CORE_message_queue_API_mp_support_callout | api_message_queue_mp_support, | ||
| uint32_t * | count, | ||
| ISR_lock_Context * | lock_context | ||
This package is the implementation of the CORE Message Queue Handler. This core object provides task synchronization and communication functions via messages passed to queue objects.
This function sends a message for every thread waiting on the queue and returns the number of threads made ready by the message.
| [in] | the_message_queue | points to the message queue |
| [in] | buffer | is the starting address of the message to broadcast |
| [in] | size | is the size of the message being broadcast |
| [in] | id | is the RTEMS object Id associated with this message queue. It is used when unblocking a remote thread. |
| [in] | api_message_queue_mp_support | is the routine to invoke if a thread that is unblocked is actually a remote thread. |
| [out] | count | points to the variable that will contain the number of tasks that are sent this message |
| [in] | lock_context | The lock context of the interrupt disable. |
| void _CORE_message_queue_Close | ( | CORE_message_queue_Control * | the_message_queue, |
| Thread_queue_Flush_callout | remote_extract_callout, | ||
| uint32_t | status | ||
This function closes a message by returning all allocated space and flushing the_message_queue's task wait queue.
| [in] | the_message_queue | points to the message queue to close |
| [in] | remote_extract_callout | is the routine to call for each thread that is extracted from the set of waiting threads |
| [in] | status | is the status that each waiting thread will return from it's blocking service |
Referenced by _POSIX_Message_queue_Delete().
| uint32_t _CORE_message_queue_Flush | ( | CORE_message_queue_Control * | the_message_queue, |
This function flushes the_message_queue's pending message queue. The number of messages flushed from the queue is returned.
| [in] | the_message_queue | points to the message queue to flush |
| This | method returns the number of message pending messages flushed. |
| RTEMS_INLINE_ROUTINE int _CORE_message_queue_Get_message_priority | ( | const CORE_message_queue_Buffer_control * | the_message | ) |
| bool _CORE_message_queue_Initialize | ( | CORE_message_queue_Control * | the_message_queue, |
| CORE_message_queue_Attributes * | the_message_queue_attributes, | ||
| uint32_t | maximum_pending_messages, | ||
| size_t | maximum_message_size | ||
This routine initializes the_message_queue based on the parameters passed.
| [in] | the_message_queue | points to the message queue to initialize |
| [in] | the_message_queue_attributes | points to the attributes that will be used with this message queue instance |
| [in] | maximum_pending_messages | is the maximum number of messages that will be allowed to pend at any given time |
| [in] | maximum_message_size | is the size of largest message that may be sent to this message queue instance |
| true | if the message queue can be initialized. In general, false will only be returned if memory for the pending messages cannot be allocated. |
References _CORE_message_queue_Set_notify, CORE_message_queue_Control::maximum_message_size, CORE_message_queue_Control::maximum_pending_messages, and CORE_message_queue_Control::number_of_pending_messages.
| void _CORE_message_queue_Insert_message | ( | CORE_message_queue_Control * | the_message_queue, |
| CORE_message_queue_Buffer_control * | the_message, | ||
| CORE_message_queue_Submit_types | submit_type | ||
This kernel routine inserts the specified message into the message queue. It is assumed that the message has been filled in before this routine is called.
| [in] | the_message | is the message to enqueue |
| [in] | submit_type | determines whether the message is prepended, appended, or enqueued in priority order. |
| void _CORE_message_queue_Seize | ( | CORE_message_queue_Control * | the_message_queue, |
| Thread_Control * | executing, | ||
| size_t * | size_p, | ||
| bool | wait, | ||
| Watchdog_Interval | timeout, | ||
This kernel routine dequeues a message, copies the message buffer to a given destination buffer, and frees the message buffer to the inactive message pool. The thread will be blocked if wait is true, otherwise an error will be given to the thread if no messages are available.
| [in] | buffer | is the starting address of the message buffer to to be filled in with a message |
| [in] | size_p | is a pointer to the size of the buffer and indicates the maximum size message that the caller can receive. |
| [in] | wait | indicates whether the calling thread is willing to block if the message queue is empty. |
| [in] | timeout | is the maximum number of clock ticks that the calling thread is willing to block if the message queue is empty. |
| indication | of the successful completion or reason for failure. On success, the location pointed to size_p will contain the size of the received message. |
| RTEMS_INLINE_ROUTINE void _CORE_message_queue_Set_message_priority | ( | CORE_message_queue_Buffer_control * | the_message, |
| int | priority | ||
References RTEMS_INLINE_ROUTINE.
| CORE_message_queue_Status _CORE_message_queue_Submit | ( | CORE_message_queue_Control * | the_message_queue, |
| size_t | size, | ||
| CORE_message_queue_Submit_types | submit_type, | ||
| bool | wait, | ||
This routine implements the send and urgent message functions. It processes a message that is to be submitted to the designated message queue. The message will either be processed as a send message which it will be inserted at the rear of the queue or it will be processed as an urgent message which will be inserted at the front of the queue.
| [in] | buffer | is the starting address of the message to send |
| [in] | size | is the size of the message being send |
| [in] | wait | indicates whether the calling thread is willing to block if the message queue is full. |
| [in] | timeout | is the maximum number of clock ticks that the calling thread is willing to block if the message queue is full. |
| indication | of the successful completion or reason for failure |
