API Mutex Handler API. More...
| struct | API_Mutex_Control |
| Control block used to manage each API mutex. More... | |
| void | _API_Mutex_Initialization (uint32_t maximum_mutexes) |
| Initialization for the API Mutexe Handler. More... | |
| void | _API_Mutex_Allocate (API_Mutex_Control **mutex) |
| Allocates an API mutex from the inactive set and returns it in mutex. | |
| void | _API_Mutex_Lock (API_Mutex_Control *mutex) |
| Acquires the specified API mutex. More... | |
| void | _API_Mutex_Unlock (API_Mutex_Control *mutex) |
| Releases the specified API mutex. More... | |
| bool | _API_Mutex_Is_owner (const API_Mutex_Control *mutex) |
| Checks if the specified API mutex is owned by the executing thread. More... | |
| SCORE_EXTERN API_Mutex_Control * | _RTEMS_Allocator_Mutex |
| Memory allocation mutex. More... | |
| SCORE_EXTERN API_Mutex_Control * | _Once_Mutex |
