Data Structures | Macros | Typedefs | Variables
config.h File Reference
Table of User Defined Configuration Parameters. More...
#include <rtems/rtems/config.h>
#include <rtems/extension.h>
Include dependency graph for config.h:
struct  rtems_configuration_table
#define RTEMS_UNLIMITED_OBJECTS   OBJECTS_UNLIMITED_OBJECTS
#define rtems_resource_unlimited(resource)   ( resource | RTEMS_UNLIMITED_OBJECTS )
#define rtems_resource_is_unlimited(resource)   _Objects_Is_unlimited(resource)
#define rtems_resource_maximum_per_allocation(resource)   _Objects_Maximum_per_allocation(resource)
#define rtems_configuration_get_unified_work_area()   (Configuration.unified_work_area)
#define rtems_configuration_get_stack_allocator_avoids_work_space()   (Configuration.stack_allocator_avoids_work_space)
#define rtems_configuration_get_stack_space_size()   (Configuration.stack_space_size)
#define rtems_configuration_get_work_space_size()
#define rtems_configuration_get_maximum_extensions()   (Configuration.maximum_extensions)
#define rtems_configuration_get_microseconds_per_tick()   (Configuration.microseconds_per_tick)
#define rtems_configuration_get_milliseconds_per_tick()   (Configuration.microseconds_per_tick / 1000)
#define rtems_configuration_get_nanoseconds_per_tick()   (Configuration.nanoseconds_per_tick)
#define rtems_configuration_get_ticks_per_timeslice()   (Configuration.ticks_per_timeslice)
#define rtems_configuration_get_idle_task()   (Configuration.idle_task)
#define rtems_configuration_get_idle_task_stack_size()   (Configuration.idle_task_stack_size)
#define rtems_configuration_get_interrupt_stack_size()   (Configuration.interrupt_stack_size)
#define rtems_configuration_get_stack_allocate_init_hook()   (Configuration.stack_allocate_init_hook)
#define rtems_configuration_get_stack_allocate_hook()   (Configuration.stack_allocate_hook)
#define rtems_configuration_get_stack_free_hook()   (Configuration.stack_free_hook)
#define rtems_configuration_get_do_zero_of_workspace()   (Configuration.do_zero_of_workspace)
 This macro assists in accessing the field which indicates whether RTEMS is responsible for zeroing the Executive Workspace.
#define rtems_configuration_get_number_of_initial_extensions()   (Configuration.number_of_initial_extensions)
#define rtems_configuration_get_user_extension_table()   (Configuration.User_extension_table)
#define rtems_configuration_get_user_multiprocessing_table()   NULL
#define rtems_configuration_is_smp_enabled()   false
 Returns true if the SMP mode of operation is enabled, and false otherwise. More...
#define rtems_configuration_get_maximum_processors()   1
 Returns the configured maximum count of processors. More...
#define rtems_configuration_get_rtems_api_configuration()   (&Configuration_RTEMS_API)
#define rtems_configuration_get_posix_api_configuration()   (&Configuration_POSIX_API)
typedef void * posix_api_configuration_table
typedef void(* rtems_stack_allocate_init_hook) (size_t stack_space_size)
 Task stack allocator initialization hook. More...
typedef void *(* rtems_stack_allocate_hook) (size_t stack_size)
 Task stack allocator hook. More...
typedef void(* rtems_stack_free_hook) (void *addr)
 Task stack deallocator hook. More...
const rtems_configuration_table Configuration
 This is the configuration table generated by confdefs.h.
This include file contains the table of user defined configuration parameters.
◆ rtems_configuration_get_maximum_processors
#define rtems_configuration_get_maximum_processors ( )    1
The actual number of processors available for the application will be less than or equal to the configured maximum count of processors.
On single-processor configurations this is a compile time constant which evaluates to one.
Returns
The configured maximum count of processors.
◆ rtems_configuration_get_work_space_size
#define rtems_configuration_get_work_space_size ( )
Value:
(rtems_configuration_get_stack_allocator_avoids_work_space() ? \
0 : rtems_configuration_get_stack_space_size()))
uintptr_t work_space_size
This field specifies the size in bytes of the RTEMS Workspace.
Definition: config.h:132
◆ rtems_configuration_is_smp_enabled
#define rtems_configuration_is_smp_enabled ( )    false
On single-processor configurations this is a compile time constant which evaluates to false.
Return values
trueSMP mode of operation is enabled.
falseOtherwise.
Referenced by rtems_task_variable_add(), rtems_task_variable_delete(), and rtems_task_variable_get().
Typedef Documentation
◆ rtems_stack_allocate_hook
typedef void*(* rtems_stack_allocate_hook) (size_t stack_size)
Parameters
[in]stack_sizeis the Size of the task stack in bytes.
Return values
NULLNot enough memory.
otherPointer to task stack.
◆ rtems_stack_allocate_init_hook
Parameters
[in]stack_space_sizeis the size of the stack space in bytes.
◆ rtems_stack_free_hook
Parameters
[in]addris a pointer to previously allocated task stack.
