16 #ifndef _RTEMS_EXTENSION_H 17 #define _RTEMS_EXTENSION_H 33 typedef User_extensions_routine
176 typedef Internal_errors_t rtems_fatal_code;
199 const rtems_extensions_table *extension_table,
Constants and Structures Associated with the Object Handler.
void(* User_extensions_thread_begin_extension)(Thread_Control *executing)
Task begin extension.
Definition: userext.h:171
The following defines the Object Control Block used to manage each object local to this node...
Definition: object.h:232
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:80
rtems_status_code rtems_extension_delete(rtems_id id)
Deletes an extension set object specified by the identifier id.
Definition: extensiondelete.c:26
void(* User_extensions_thread_delete_extension)(Thread_Control *executing, Thread_Control *deleted)
Task delete extension.
Definition: userext.h:91
void(* User_extensions_thread_exitted_extension)(Thread_Control *executing)
Task exitted extension.
Definition: userext.h:185
void(* User_extensions_thread_restart_extension)(Thread_Control *executing, Thread_Control *restarted)
Task restart extension.
Definition: userext.h:133
rtems_status_code rtems_extension_create(rtems_name name, const rtems_extensions_table *extension_table, rtems_id *id)
Creates an extension set object.
Definition: extensioncreate.c:28
void(* User_extensions_thread_start_extension)(Thread_Control *executing, Thread_Control *started)
Task start extension.
Definition: userext.h:111
rtems_status_code
Classic API Status.
Definition: status.h:46
uint32_t rtems_name
Classic API object name type.
Definition: types.h:74
rtems_status_code rtems_extension_ident(rtems_name name, rtems_id *id)
Identifies an extension set object by a name.
Definition: extensionident.c:28
void(* User_extensions_fatal_extension)(Internal_errors_Source source, bool is_internal, Internal_errors_t code)
Fatal error extension.
Definition: userext.h:203
void(* User_extensions_thread_switch_extension)(Thread_Control *executing, Thread_Control *heir)
Task switch extension.
Definition: userext.h:156
#define RTEMS_COMPILER_DEPRECATED_ATTRIBUTE
Instructs the compiler to issue a warning whenever a variable or function with this attribute will be...
Definition: basedefs.h:186
bool(* User_extensions_thread_create_extension)(Thread_Control *executing, Thread_Control *created)
Task create extension.
Definition: userext.h:71
Definition: extension.h:28
User extension table.
Definition: userext.h:232
Manages each user extension set.
Definition: userext.h:260
This type lists the possible sources from which an error can be reported.
Definition: interr.h:45
User Extension Handler API.
