Data Fields | |
| uintptr_t | work_space_size |
| This field specifies the size in bytes of the RTEMS Workspace. | |
| uintptr_t | stack_space_size |
| This field specifies the size in bytes of the RTEMS thread stack space. | |
| uint32_t | maximum_extensions |
| This field specifies the maximum number of dynamically installed used extensions. | |
| uint32_t | maximum_keys |
| This field contains the maximum number of POSIX API keys which are configured for this application. | |
| uint32_t | maximum_key_value_pairs |
| This field contains the maximum number of POSIX API key value pairs which are configured for this application. More... | |
| uint32_t | microseconds_per_tick |
| This field specifies the number of microseconds which elapse between clock ticks. More... | |
| uint32_t | nanoseconds_per_tick |
| This field specifies the number of nanoseconds which elapse between clock ticks. More... | |
| uint32_t | ticks_per_timeslice |
| This field specifies the number of ticks in each task's timeslice. | |
| Thread(* | idle_task )(uintptr_t) |
| This element points to the BSP's optional idle task which may override the default one provided with RTEMS. | |
| uint32_t | idle_task_stack_size |
| This field specifies the size of the IDLE task's stack. More... | |
| uint32_t | interrupt_stack_size |
| This field specifies the size of the interrupt stack. More... | |
| rtems_stack_allocate_init_hook | stack_allocate_init_hook |
| Optional task stack allocator initialization hook. | |
| rtems_stack_allocate_hook | stack_allocate_hook |
| Optional task stack allocator hook. | |
| rtems_stack_free_hook | stack_free_hook |
| Optional task stack free hook. | |
| bool | do_zero_of_workspace |
| If this element is TRUE, then RTEMS will zero the Executive Workspace. More... | |
| bool | unified_work_area |
| Specifies if a unified work area is used or not. More... | |
| bool | stack_allocator_avoids_work_space |
| Specifies if the stack allocator avoids the work space. More... | |
| uint32_t | number_of_initial_extensions |
| const rtems_extensions_table * | User_extension_table |
| bool rtems_configuration_table::do_zero_of_workspace |
When this element is FALSE, it is assumed that the BSP or invoking environment has ensured that memory was cleared before RTEMS was invoked.
| uint32_t rtems_configuration_table::idle_task_stack_size |
If less than or equal to the minimum stack size, then the IDLE task will have the minimum stack size.
| uint32_t rtems_configuration_table::interrupt_stack_size |
If less than or equal to the minimum stack size, then the interrupt stack will be of minimum stack size.
| uint32_t rtems_configuration_table::maximum_key_value_pairs |
| uint32_t rtems_configuration_table::microseconds_per_tick |
This is the basis for RTEMS timing.
| uint32_t rtems_configuration_table::nanoseconds_per_tick |
This value is derived from the microseconds_per_tick field and provided to avoid calculation at run-time.
| bool rtems_configuration_table::stack_allocator_avoids_work_space |
If this element is true, then the stack allocator must not allocate the thread stacks from the RTEMS Workspace, otherwise it should allocate the thread stacks from the RTEMS Workspace.
| bool rtems_configuration_table::unified_work_area |
If this element is true, then the RTEMS Workspace and the C Program Heap use the same heap, otherwise they use separate heaps.
