Stack Checker Information. More...
Files | |
| file | check.c |
| Stack Overflow Check User Extension SetNOTE: This extension set automatically determines at initialization time whether the stack for this CPU grows up or down and installs the correct extension routines for that direction. | |
| #define | RTEMS_STACK_CHECKER_EXTENSION |
| Stack Checker Extension Set Definition. More... | |
| bool | rtems_stack_checker_is_blown (void) |
| Checks if current task is blown its stack. More... | |
| void | rtems_stack_checker_report_usage (void) |
| Print the stack usage report using printk. More... | |
| void | rtems_stack_checker_report_usage_with_plugin (void *context, rtems_printk_plugin_t print) |
| Print the stack usage report using caller's routine. More... | |
| bool | rtems_stack_checker_create_extension (Thread_Control *running, Thread_Control *the_thread) |
| Stack Checker Task Create Extension. More... | |
| void | rtems_stack_checker_begin_extension (Thread_Control *the_thread) |
| Stack Checker Task Begin Extension. More... | |
| void | rtems_stack_checker_switch_extension (Thread_Control *running, Thread_Control *heir) |
| Stack Checker Task Context Switch Extension. More... | |
This include file contains information necessary to utilize and install the stack checker mechanism.
| #define RTEMS_STACK_CHECKER_EXTENSION |
This macro defines the user extension handler set for the stack checker. This macro is normally only used by confdefs.h.
| void rtems_stack_checker_begin_extension | ( | Thread_Control * | the_thread | ) |
This method is the task begin extension for the stack checker.
| [in] | the_thread | points to task starting to execute |
References Objects_Control::id, and Thread_Control::Object.
| bool rtems_stack_checker_create_extension | ( | Thread_Control * | running, |
| Thread_Control * | the_thread | ||
This method is the task create extension for the stack checker.
| [in] | running | points to the currently executing task |
| [in] | the_thread | points to the newly created task |
| bool rtems_stack_checker_is_blown | ( | void | ) |
This method is used to determine if the current stack pointer of the currently executing task is within bounds.
| This | method returns true if the currently executing task has blown its stack. |
References _Thread_Get_executing(), Thread_Start_information::Initial_stack, and Thread_Control::Start.
| void rtems_stack_checker_report_usage | ( | void | ) |
This method prints a stack usage report for the curently executing task.
References printk_plugin(), and rtems_stack_checker_report_usage_with_plugin().
| void rtems_stack_checker_report_usage_with_plugin | ( | void * | context, |
| rtems_printk_plugin_t | |||
| [in] | context | is the context to pass to the print handler |
| [in] | is the print handler |
Referenced by rtems_stack_checker_report_usage().
| void rtems_stack_checker_switch_extension | ( | Thread_Control * | running, |
| Thread_Control * | heir | ||
This method is the task context switch extension for the stack checker.
| [in] | running | points to the currently executing task which is being context switched out |
| [in] | running | points to the heir task which we are switching to |
References Thread_Start_information::Initial_stack, and Thread_Control::Start.
