RTEMS 5.2
threadimpl.h
1
12/*
13 * COPYRIGHT (c) 1989-2008.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Copyright (c) 2014, 2017 embedded brains GmbH.
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef _RTEMS_SCORE_THREADIMPL_H
24#define _RTEMS_SCORE_THREADIMPL_H
25
26#include <rtems/score/thread.h>
27#include <rtems/score/assert.h>
29#include <rtems/score/interr.h>
30#include <rtems/score/isr.h>
34#include <rtems/score/status.h>
38#include <rtems/score/todimpl.h>
40#include <rtems/config.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
55extern void *rtems_ada_self;
56
66
71#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
73#endif
74
75#if defined(RTEMS_SMP)
76#define THREAD_OF_SCHEDULER_HELP_NODE( node ) \
77 RTEMS_CONTAINER_OF( node, Thread_Control, Scheduler.Help_node )
78#endif
79
80typedef bool ( *Thread_Visitor )( Thread_Control *the_thread, void *arg );
81
91 Thread_Visitor visitor,
92 void *arg
93);
94
101
108
116void _Thread_Create_idle(void);
117
126
130typedef struct {
135
140
145
150
155
160
165
170
174 uint32_t isr_level;
175
179 bool is_fp;
180
186
208 Thread_Information *information,
209 Thread_Control *the_thread,
211);
212
223bool _Thread_Start(
224 Thread_Control *the_thread,
226 ISR_lock_Context *lock_context
227);
228
237 Thread_Control *executing,
239 ISR_lock_Context *lock_context
241
253 Thread_Control *the_thread,
255 ISR_lock_Context *lock_context
256);
257
263void _Thread_Yield( Thread_Control *executing );
264
275 Thread_Life_state clear,
277 Thread_Life_state ignore
278);
279
291
301void _Thread_Kill_zombies( void );
302
310void _Thread_Exit(
311 Thread_Control *executing,
313 void *exit_value
314);
315
325void _Thread_Join(
326 Thread_Control *the_thread,
327 States_Control waiting_for_join,
328 Thread_Control *executing,
329 Thread_queue_Context *queue_context
330);
331
339void _Thread_Cancel(
340 Thread_Control *the_thread,
341 Thread_Control *executing,
342 void *exit_value
343);
344
345typedef struct {
347 Thread_Control *cancel;
349
361void _Thread_Close(
362 Thread_Control *the_thread,
363 Thread_Control *executing,
365);
366
376{
377 return _States_Is_ready( the_thread->current_state );
378}
379
392 Thread_Control *the_thread,
393 States_Control state
394);
395
408 Thread_Control *the_thread,
409 States_Control state
410);
411
424 Thread_Control *the_thread,
425 States_Control state
426);
427
440 Thread_Control *the_thread,
441 States_Control state
442);
443
453 Thread_Control *the_thread
454);
455
462
469
478
494void _Thread_Handler( void );
495
503 Thread_Control *the_thread,
504 ISR_lock_Context *lock_context
505)
506{
507 _Thread_queue_Do_acquire_critical( &the_thread->Join_queue, lock_context );
508}
509
517 Thread_Control *the_thread,
518 ISR_lock_Context *lock_context
519)
520{
521 _ISR_lock_ISR_disable( lock_context );
522 _Thread_State_acquire_critical( the_thread, lock_context );
523}
524
534 ISR_lock_Context *lock_context
535)
536{
537 Thread_Control *executing;
538
539 _ISR_lock_ISR_disable( lock_context );
540 executing = _Thread_Executing;
541 _Thread_State_acquire_critical( executing, lock_context );
542
543 return executing;
544}
545
553 Thread_Control *the_thread,
554 ISR_lock_Context *lock_context
555)
556{
557 _Thread_queue_Do_release_critical( &the_thread->Join_queue, lock_context );
558}
559
567 Thread_Control *the_thread,
568 ISR_lock_Context *lock_context
569)
570{
571 _Thread_State_release_critical( the_thread, lock_context );
572 _ISR_lock_ISR_enable( lock_context );
573}
574
583#if defined(RTEMS_DEBUG)
584RTEMS_INLINE_ROUTINE bool _Thread_State_is_owner(
585 const Thread_Control *the_thread
586)
587{
588 return _Thread_queue_Is_lock_owner( &the_thread->Join_queue );
589}
590#endif
591
605 Thread_Control *start_of_path,
606 Thread_queue_Context *queue_context
607);
608
625 Thread_Control *the_thread,
626 Priority_Node *priority_node,
627 Thread_queue_Context *queue_context
628);
629
646 Thread_Control *the_thread,
647 Priority_Node *priority_node,
648 Thread_queue_Context *queue_context
649);
650
670 Thread_Control *the_thread,
671 Priority_Node *priority_node,
672 bool prepend_it,
673 Thread_queue_Context *queue_context
674);
675
697 Thread_Control *the_thread,
698 Priority_Node *priority_node,
699 Priority_Control new_priority,
700 bool prepend_it,
701 Thread_queue_Context *queue_context
702)
703{
704 _Priority_Node_set_priority( priority_node, new_priority );
706 the_thread,
707 priority_node,
708 prepend_it,
709 queue_context
710 );
711}
712
726 Thread_Control *the_thread,
727 Priority_Node *victim_node,
728 Priority_Node *replacement_node
729);
730
742void _Thread_Priority_update( Thread_queue_Context *queue_context );
743
750#if defined(RTEMS_SMP)
751void _Thread_Priority_and_sticky_update(
752 Thread_Control *the_thread,
753 int sticky_level_change
754);
755#endif
756
768 Priority_Control left,
769 Priority_Control right
770)
771{
772 return left > right;
773}
774
785 Priority_Control left,
786 Priority_Control right
787)
788{
789 return _Thread_Priority_less_than( left, right ) ? right : left;
790}
791
801 Objects_Id id
802)
803{
804 uint32_t the_api;
805
806 the_api = _Objects_Get_API( id );
807
808 if ( !_Objects_Is_api_valid( the_api ) ) {
809 return NULL;
810 }
811
812 /*
813 * Threads are always first class :)
814 *
815 * There is no need to validate the object class of the object identifier,
816 * since this will be done by the object get methods.
817 */
818 return _Objects_Information_table[ the_api ][ 1 ];
819}
820
830 Objects_Id id,
831 ISR_lock_Context *lock_context
832);
833
842 const Thread_Control *thread
843)
844{
845#if defined(RTEMS_SMP)
846 return thread->Scheduler.cpu;
847#else
848 (void) thread;
849
850 return _Per_CPU_Get();
851#endif
852}
853
861 Thread_Control *thread,
862 Per_CPU_Control *cpu
863)
864{
865#if defined(RTEMS_SMP)
866 thread->Scheduler.cpu = cpu;
867#else
868 (void) thread;
869 (void) cpu;
870#endif
871}
872
885 const Thread_Control *the_thread
886)
887{
888 return ( the_thread == _Thread_Executing );
889}
890
891#if defined(RTEMS_SMP)
904RTEMS_INLINE_ROUTINE bool _Thread_Is_executing_on_a_processor(
905 const Thread_Control *the_thread
906)
907{
908 return _CPU_Context_Get_is_executing( &the_thread->Registers );
909}
910#endif
911
924 const Thread_Control *the_thread
925)
926{
927 return ( the_thread == _Thread_Heir );
928}
929
940 Thread_Control *the_thread
941)
942{
943 _Thread_Clear_state( the_thread, STATES_BLOCKED );
944}
945
961#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
963 const Thread_Control *the_thread
964)
965{
966 return ( the_thread == _Thread_Allocated_fp );
967}
968#endif
969
970/*
971 * If the CPU has hardware floating point, then we must address saving
972 * and restoring it as part of the context switch.
973 *
974 * The second conditional compilation section selects the algorithm used
975 * to context switch between floating point tasks. The deferred algorithm
976 * can be significantly better in a system with few floating point tasks
977 * because it reduces the total number of save and restore FP context
978 * operations. However, this algorithm can not be used on all CPUs due
979 * to unpredictable use of FP registers by some compilers for integer
980 * operations.
981 */
982
989{
990#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
991#if ( CPU_USE_DEFERRED_FP_SWITCH != TRUE )
992 if ( executing->fp_context != NULL )
993 _Context_Save_fp( &executing->fp_context );
994#endif
995#endif
996}
997
1004{
1005#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
1006#if ( CPU_USE_DEFERRED_FP_SWITCH == TRUE )
1007 if ( (executing->fp_context != NULL) &&
1008 !_Thread_Is_allocated_fp( executing ) ) {
1009 if ( _Thread_Allocated_fp != NULL )
1011 _Context_Restore_fp( &executing->fp_context );
1012 _Thread_Allocated_fp = executing;
1013 }
1014#else
1015 if ( executing->fp_context != NULL )
1016 _Context_Restore_fp( &executing->fp_context );
1017#endif
1018#endif
1019}
1020
1027#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
1029{
1031}
1032#endif
1033
1044{
1045 return ( _Thread_Dispatch_necessary );
1046}
1047
1057 const Thread_Control *the_thread
1058)
1059{
1060 return ( the_thread == NULL );
1061}
1062
1069{
1070 /* Idle threads */
1071 uint32_t maximum_internal_threads =
1073
1074 /* MPCI thread */
1075#if defined(RTEMS_MULTIPROCESSING)
1076 if ( _System_state_Is_multiprocessing ) {
1077 ++maximum_internal_threads;
1078 }
1079#endif
1080
1081 return maximum_internal_threads;
1082}
1083
1091{
1092 return (Thread_Control *)
1094}
1095
1110 Per_CPU_Control *cpu_self
1111)
1112{
1113 Thread_Control *heir;
1114
1115 heir = cpu_self->heir;
1116 cpu_self->dispatch_necessary = false;
1117 cpu_self->executing = heir;
1118
1119 return heir;
1120}
1121
1130 Thread_Control *the_thread,
1131 Per_CPU_Control *cpu
1132)
1133{
1134 Timestamp_Control last;
1136
1137 last = cpu->cpu_usage_timestamp;
1138 _TOD_Get_uptime( &cpu->cpu_usage_timestamp );
1139 _Timestamp_Subtract( &last, &cpu->cpu_usage_timestamp, &ran );
1140 _Timestamp_Add_to( &the_thread->cpu_time_used, &ran );
1141}
1142
1150#if defined( RTEMS_SMP )
1151RTEMS_INLINE_ROUTINE void _Thread_Dispatch_update_heir(
1152 Per_CPU_Control *cpu_self,
1153 Per_CPU_Control *cpu_for_heir,
1154 Thread_Control *heir
1155)
1156{
1157 _Thread_Update_CPU_time_used( cpu_for_heir->heir, cpu_for_heir );
1158
1159 cpu_for_heir->heir = heir;
1160
1161 _Thread_Dispatch_request( cpu_self, cpu_for_heir );
1162}
1163#endif
1164
1173 Thread_Control *the_thread,
1174 Timestamp_Control *cpu_time_used
1175);
1176
1183 Thread_Action_control *action_control
1184)
1185{
1186 _Chain_Initialize_empty( &action_control->Chain );
1187}
1188
1195 Thread_Action *action
1196)
1197{
1198 _Chain_Set_off_chain( &action->Node );
1199}
1200
1209 Thread_Control *the_thread,
1210 Thread_Action *action,
1211 Thread_Action_handler handler
1212)
1213{
1214 Per_CPU_Control *cpu_of_thread;
1215
1216 _Assert( _Thread_State_is_owner( the_thread ) );
1217
1218 cpu_of_thread = _Thread_Get_CPU( the_thread );
1219
1220 action->handler = handler;
1221
1222 _Thread_Dispatch_request( _Per_CPU_Get(), cpu_of_thread );
1223
1225 &the_thread->Post_switch_actions.Chain,
1226 &action->Node
1227 );
1228}
1229
1239 Thread_Life_state life_state
1240)
1241{
1242 return ( life_state & THREAD_LIFE_RESTARTING ) != 0;
1243}
1244
1254 Thread_Life_state life_state
1255)
1256{
1257 return ( life_state & THREAD_LIFE_TERMINATING ) != 0;
1258}
1259
1269 Thread_Life_state life_state
1270)
1271{
1272 return ( life_state
1273 & ( THREAD_LIFE_PROTECTED | THREAD_LIFE_CHANGE_DEFERRED ) ) == 0;
1274}
1275
1285 Thread_Life_state life_state
1286)
1287{
1288 return ( life_state
1289 & ( THREAD_LIFE_RESTARTING | THREAD_LIFE_TERMINATING ) ) != 0;
1290}
1291
1301 const Thread_Control *the_thread
1302)
1303{
1304 _Assert( _Thread_State_is_owner( the_thread ) );
1305 return ( the_thread->Life.state & THREAD_LIFE_DETACHED ) == 0;
1306}
1307
1314 Thread_Control *the_thread
1315)
1316{
1317#if defined(RTEMS_SCORE_THREAD_ENABLE_RESOURCE_COUNT)
1318 ++the_thread->resource_count;
1319#else
1320 (void) the_thread;
1321#endif
1322}
1323
1330 Thread_Control *the_thread
1331)
1332{
1333#if defined(RTEMS_SCORE_THREAD_ENABLE_RESOURCE_COUNT)
1334 --the_thread->resource_count;
1335#else
1336 (void) the_thread;
1337#endif
1338}
1339
1340#if defined(RTEMS_SCORE_THREAD_ENABLE_RESOURCE_COUNT)
1352RTEMS_INLINE_ROUTINE bool _Thread_Owns_resources(
1353 const Thread_Control *the_thread
1354)
1355{
1356 return the_thread->resource_count != 0;
1357}
1358#endif
1359
1360#if defined(RTEMS_SMP)
1368RTEMS_INLINE_ROUTINE void _Thread_Scheduler_cancel_need_for_help(
1369 Thread_Control *the_thread,
1370 Per_CPU_Control *cpu
1371)
1372{
1373 ISR_lock_Context lock_context;
1374
1375 _Per_CPU_Acquire( cpu, &lock_context );
1376
1377 if ( !_Chain_Is_node_off_chain( &the_thread->Scheduler.Help_node ) ) {
1378 _Chain_Extract_unprotected( &the_thread->Scheduler.Help_node );
1379 _Chain_Set_off_chain( &the_thread->Scheduler.Help_node );
1380 }
1381
1382 _Per_CPU_Release( cpu, &lock_context );
1383}
1384#endif
1385
1394 const Thread_Control *the_thread
1395)
1396{
1397#if defined(RTEMS_SMP)
1398 return the_thread->Scheduler.home_scheduler;
1399#else
1400 (void) the_thread;
1401 return &_Scheduler_Table[ 0 ];
1402#endif
1403}
1404
1413 const Thread_Control *the_thread
1414)
1415{
1416#if defined(RTEMS_SMP)
1417 _Assert( !_Chain_Is_empty( &the_thread->Scheduler.Wait_nodes ) );
1418 return SCHEDULER_NODE_OF_THREAD_WAIT_NODE(
1419 _Chain_First( &the_thread->Scheduler.Wait_nodes )
1420 );
1421#else
1422 return the_thread->Scheduler.nodes;
1423#endif
1424}
1425
1435 const Thread_Control *the_thread,
1436 size_t scheduler_index
1437)
1438{
1439#if defined(RTEMS_SMP)
1440 return (Scheduler_Node *)
1441 ( (uintptr_t) the_thread->Scheduler.nodes
1442 + scheduler_index * _Scheduler_Node_size );
1443#else
1444 _Assert( scheduler_index == 0 );
1445 (void) scheduler_index;
1446 return the_thread->Scheduler.nodes;
1447#endif
1448}
1449
1450#if defined(RTEMS_SMP)
1457RTEMS_INLINE_ROUTINE void _Thread_Scheduler_acquire_critical(
1458 Thread_Control *the_thread,
1459 ISR_lock_Context *lock_context
1460)
1461{
1462 _ISR_lock_Acquire( &the_thread->Scheduler.Lock, lock_context );
1463}
1464
1471RTEMS_INLINE_ROUTINE void _Thread_Scheduler_release_critical(
1472 Thread_Control *the_thread,
1473 ISR_lock_Context *lock_context
1474)
1475{
1476 _ISR_lock_Release( &the_thread->Scheduler.Lock, lock_context );
1477}
1478
1484void _Thread_Scheduler_process_requests( Thread_Control *the_thread );
1485
1493RTEMS_INLINE_ROUTINE void _Thread_Scheduler_add_request(
1494 Thread_Control *the_thread,
1495 Scheduler_Node *scheduler_node,
1496 Scheduler_Node_request request
1497)
1498{
1499 ISR_lock_Context lock_context;
1500 Scheduler_Node_request current_request;
1501
1502 _Thread_Scheduler_acquire_critical( the_thread, &lock_context );
1503
1504 current_request = scheduler_node->Thread.request;
1505
1506 if ( current_request == SCHEDULER_NODE_REQUEST_NOT_PENDING ) {
1507 _Assert(
1508 request == SCHEDULER_NODE_REQUEST_ADD
1509 || request == SCHEDULER_NODE_REQUEST_REMOVE
1510 );
1511 _Assert( scheduler_node->Thread.next_request == NULL );
1512 scheduler_node->Thread.next_request = the_thread->Scheduler.requests;
1513 the_thread->Scheduler.requests = scheduler_node;
1514 } else if ( current_request != SCHEDULER_NODE_REQUEST_NOTHING ) {
1515 _Assert(
1516 ( current_request == SCHEDULER_NODE_REQUEST_ADD
1517 && request == SCHEDULER_NODE_REQUEST_REMOVE )
1518 || ( current_request == SCHEDULER_NODE_REQUEST_REMOVE
1519 && request == SCHEDULER_NODE_REQUEST_ADD )
1520 );
1521 request = SCHEDULER_NODE_REQUEST_NOTHING;
1522 }
1523
1524 scheduler_node->Thread.request = request;
1525
1526 _Thread_Scheduler_release_critical( the_thread, &lock_context );
1527}
1528
1536RTEMS_INLINE_ROUTINE void _Thread_Scheduler_add_wait_node(
1537 Thread_Control *the_thread,
1538 Scheduler_Node *scheduler_node
1539)
1540{
1542 &the_thread->Scheduler.Wait_nodes,
1543 &scheduler_node->Thread.Wait_node
1544 );
1545 _Thread_Scheduler_add_request(
1546 the_thread,
1547 scheduler_node,
1548 SCHEDULER_NODE_REQUEST_ADD
1549 );
1550}
1551
1559RTEMS_INLINE_ROUTINE void _Thread_Scheduler_remove_wait_node(
1560 Thread_Control *the_thread,
1561 Scheduler_Node *scheduler_node
1562)
1563{
1564 _Chain_Extract_unprotected( &scheduler_node->Thread.Wait_node );
1565 _Thread_Scheduler_add_request(
1566 the_thread,
1567 scheduler_node,
1568 SCHEDULER_NODE_REQUEST_REMOVE
1569 );
1570}
1571#endif
1572
1585 const Thread_Control *the_thread
1586)
1587{
1588 Scheduler_Node *scheduler_node;
1589
1590 scheduler_node = _Thread_Scheduler_get_home_node( the_thread );
1591 return _Priority_Get_priority( &scheduler_node->Wait.Priority );
1592}
1593
1602 const Thread_Control *the_thread
1603)
1604{
1605 return SCHEDULER_PRIORITY_UNMAP( _Thread_Get_priority( the_thread ) );
1606}
1607
1616 const Thread_Control *the_thread
1617)
1618{
1619 return SCHEDULER_PRIORITY_UNMAP( the_thread->Real_priority.priority );
1620}
1621
1633 Thread_Control *the_thread,
1634 ISR_lock_Context *lock_context
1635)
1636{
1637 _ISR_lock_Acquire( &the_thread->Wait.Lock.Default, lock_context );
1638}
1639
1652 ISR_lock_Context *lock_context
1653)
1654{
1655 Thread_Control *executing;
1656
1657 _ISR_lock_ISR_disable( lock_context );
1658 executing = _Thread_Executing;
1659 _Thread_Wait_acquire_default_critical( executing, lock_context );
1660
1661 return executing;
1662}
1663
1674 Thread_Control *the_thread,
1675 ISR_lock_Context *lock_context
1676)
1677{
1678 _ISR_lock_ISR_disable( lock_context );
1679 _Thread_Wait_acquire_default_critical( the_thread, lock_context );
1680}
1681
1693 Thread_Control *the_thread,
1694 ISR_lock_Context *lock_context
1695)
1696{
1697 _ISR_lock_Release( &the_thread->Wait.Lock.Default, lock_context );
1698}
1699
1709 Thread_Control *the_thread,
1710 ISR_lock_Context *lock_context
1711)
1712{
1713 _Thread_Wait_release_default_critical( the_thread, lock_context );
1714 _ISR_lock_ISR_enable( lock_context );
1715}
1716
1717#if defined(RTEMS_SMP)
1718#define THREAD_QUEUE_CONTEXT_OF_REQUEST( node ) \
1719 RTEMS_CONTAINER_OF( node, Thread_queue_Context, Lock_context.Wait.Gate.Node )
1720
1727RTEMS_INLINE_ROUTINE void _Thread_Wait_remove_request_locked(
1728 Thread_Control *the_thread,
1729 Thread_queue_Lock_context *queue_lock_context
1730)
1731{
1732 Chain_Node *first;
1733
1734 _Chain_Extract_unprotected( &queue_lock_context->Wait.Gate.Node );
1735 first = _Chain_First( &the_thread->Wait.Lock.Pending_requests );
1736
1737 if ( first != _Chain_Tail( &the_thread->Wait.Lock.Pending_requests ) ) {
1738 _Thread_queue_Gate_open( (Thread_queue_Gate *) first );
1739 }
1740}
1741
1748RTEMS_INLINE_ROUTINE void _Thread_Wait_acquire_queue_critical(
1749 Thread_queue_Queue *queue,
1750 Thread_queue_Lock_context *queue_lock_context
1751)
1752{
1753 _Thread_queue_Queue_acquire_critical(
1754 queue,
1755 &_Thread_Executing->Potpourri_stats,
1756 &queue_lock_context->Lock_context
1757 );
1758}
1759
1766RTEMS_INLINE_ROUTINE void _Thread_Wait_release_queue_critical(
1767 Thread_queue_Queue *queue,
1768 Thread_queue_Lock_context *queue_lock_context
1769)
1770{
1772 queue,
1773 &queue_lock_context->Lock_context
1774 );
1775}
1776#endif
1777
1787 Thread_Control *the_thread,
1788 Thread_queue_Context *queue_context
1789)
1790{
1791#if defined(RTEMS_SMP)
1792 Thread_queue_Queue *queue;
1793
1795 the_thread,
1796 &queue_context->Lock_context.Lock_context
1797 );
1798
1799 queue = the_thread->Wait.queue;
1800 queue_context->Lock_context.Wait.queue = queue;
1801
1802 if ( queue != NULL ) {
1803 _Thread_queue_Gate_add(
1804 &the_thread->Wait.Lock.Pending_requests,
1805 &queue_context->Lock_context.Wait.Gate
1806 );
1808 the_thread,
1809 &queue_context->Lock_context.Lock_context
1810 );
1811 _Thread_Wait_acquire_queue_critical( queue, &queue_context->Lock_context );
1812
1813 if ( queue_context->Lock_context.Wait.queue == NULL ) {
1814 _Thread_Wait_release_queue_critical(
1815 queue,
1816 &queue_context->Lock_context
1817 );
1819 the_thread,
1820 &queue_context->Lock_context.Lock_context
1821 );
1822 _Thread_Wait_remove_request_locked(
1823 the_thread,
1824 &queue_context->Lock_context
1825 );
1826 _Assert( the_thread->Wait.queue == NULL );
1827 }
1828 }
1829#else
1830 (void) the_thread;
1831 (void) queue_context;
1832#endif
1833}
1834
1843 Thread_Control *the_thread,
1844 Thread_queue_Context *queue_context
1845)
1846{
1848 _Thread_Wait_acquire_critical( the_thread, queue_context );
1849}
1850
1862 Thread_Control *the_thread,
1863 Thread_queue_Context *queue_context
1864)
1865{
1866#if defined(RTEMS_SMP)
1867 Thread_queue_Queue *queue;
1868
1869 queue = queue_context->Lock_context.Wait.queue;
1870
1871 if ( queue != NULL ) {
1872 _Thread_Wait_release_queue_critical(
1873 queue, &queue_context->Lock_context
1874 );
1876 the_thread,
1877 &queue_context->Lock_context.Lock_context
1878 );
1879 _Thread_Wait_remove_request_locked(
1880 the_thread,
1881 &queue_context->Lock_context
1882 );
1883 }
1884
1886 the_thread,
1887 &queue_context->Lock_context.Lock_context
1888 );
1889#else
1890 (void) the_thread;
1891 (void) queue_context;
1892#endif
1893}
1894
1904 Thread_Control *the_thread,
1905 Thread_queue_Context *queue_context
1906)
1907{
1908 _Thread_Wait_release_critical( the_thread, queue_context );
1910}
1911
1927 Thread_Control *the_thread,
1928 Thread_queue_Queue *queue
1929)
1930{
1931 ISR_lock_Context lock_context;
1932
1933 _Thread_Wait_acquire_default_critical( the_thread, &lock_context );
1934
1935 _Assert( the_thread->Wait.queue == NULL );
1936
1937#if defined(RTEMS_SMP)
1938 _Chain_Initialize_empty( &the_thread->Wait.Lock.Pending_requests );
1939 _Chain_Initialize_node( &the_thread->Wait.Lock.Tranquilizer.Node );
1940 _Thread_queue_Gate_close( &the_thread->Wait.Lock.Tranquilizer );
1941#endif
1942
1943 the_thread->Wait.queue = queue;
1944
1945 _Thread_Wait_release_default_critical( the_thread, &lock_context );
1946}
1947
1956 Thread_Control *the_thread,
1957 const Thread_queue_Operations *operations
1958)
1959{
1960 the_thread->Wait.operations = operations;
1961}
1962
1975 Thread_Control *the_thread,
1976 Thread_queue_Lock_context *queue_lock_context
1977)
1978{
1979#if defined(RTEMS_SMP)
1980 ISR_lock_Context lock_context;
1981
1982 _Thread_Wait_acquire_default( the_thread, &lock_context );
1983 _Thread_Wait_remove_request_locked( the_thread, queue_lock_context );
1984 _Thread_Wait_release_default( the_thread, &lock_context );
1985#else
1986 (void) the_thread;
1987 (void) queue_lock_context;
1988#endif
1989}
1990
2004 Thread_Control *the_thread
2005)
2006{
2007#if defined(RTEMS_SMP)
2008 ISR_lock_Context lock_context;
2009 Chain_Node *node;
2010 const Chain_Node *tail;
2011
2012 _Thread_Wait_acquire_default_critical( the_thread, &lock_context );
2013
2014 node = _Chain_First( &the_thread->Wait.Lock.Pending_requests );
2015 tail = _Chain_Immutable_tail( &the_thread->Wait.Lock.Pending_requests );
2016
2017 if ( node != tail ) {
2018 do {
2019 Thread_queue_Context *queue_context;
2020
2021 queue_context = THREAD_QUEUE_CONTEXT_OF_REQUEST( node );
2022 queue_context->Lock_context.Wait.queue = NULL;
2023
2024 node = _Chain_Next( node );
2025 } while ( node != tail );
2026
2027 _Thread_queue_Gate_add(
2028 &the_thread->Wait.Lock.Pending_requests,
2029 &the_thread->Wait.Lock.Tranquilizer
2030 );
2031 } else {
2032 _Thread_queue_Gate_open( &the_thread->Wait.Lock.Tranquilizer );
2033 }
2034#endif
2035
2036 the_thread->Wait.queue = NULL;
2037 the_thread->Wait.operations = &_Thread_queue_Operations_default;
2038
2039#if defined(RTEMS_SMP)
2040 _Thread_Wait_release_default_critical( the_thread, &lock_context );
2041#endif
2042}
2043
2063 Thread_Control *the_thread
2064)
2065{
2066#if defined(RTEMS_SMP)
2067 _Thread_queue_Gate_wait( &the_thread->Wait.Lock.Tranquilizer );
2068#else
2069 (void) the_thread;
2070#endif
2071}
2072
2081 Thread_Control *the_thread,
2082 Thread_queue_Context *queue_context
2083)
2084{
2085 Thread_queue_Queue *queue;
2086
2087 queue = the_thread->Wait.queue;
2088
2089#if defined(RTEMS_SMP)
2090 if ( queue != NULL ) {
2091 _Assert( queue_context->Lock_context.Wait.queue == queue );
2092#endif
2093
2094 ( *the_thread->Wait.operations->extract )(
2095 queue,
2096 the_thread,
2097 queue_context
2098 );
2099 _Thread_Wait_restore_default( the_thread );
2100
2101#if defined(RTEMS_SMP)
2102 _Assert( queue_context->Lock_context.Wait.queue == NULL );
2103 queue_context->Lock_context.Wait.queue = queue;
2104 }
2105#endif
2106}
2107
2111#define THREAD_WAIT_FLAGS_INITIAL 0x0U
2112
2116#define THREAD_WAIT_STATE_MASK 0xffU
2117
2125#define THREAD_WAIT_STATE_INTEND_TO_BLOCK 0x1U
2126
2130#define THREAD_WAIT_STATE_BLOCKED 0x2U
2131
2137#define THREAD_WAIT_STATE_READY_AGAIN 0x4U
2138
2142#define THREAD_WAIT_CLASS_MASK 0xff00U
2143
2147#define THREAD_WAIT_CLASS_EVENT 0x100U
2148
2152#define THREAD_WAIT_CLASS_SYSTEM_EVENT 0x200U
2153
2157#define THREAD_WAIT_CLASS_OBJECT 0x400U
2158
2162#define THREAD_WAIT_CLASS_PERIOD 0x800U
2163
2171 Thread_Control *the_thread,
2172 Thread_Wait_flags flags
2173)
2174{
2175#if defined(RTEMS_SMP)
2176 _Atomic_Store_uint( &the_thread->Wait.flags, flags, ATOMIC_ORDER_RELAXED );
2177#else
2178 the_thread->Wait.flags = flags;
2179#endif
2180}
2181
2190 const Thread_Control *the_thread
2191)
2192{
2193#if defined(RTEMS_SMP)
2194 return _Atomic_Load_uint( &the_thread->Wait.flags, ATOMIC_ORDER_RELAXED );
2195#else
2196 return the_thread->Wait.flags;
2197#endif
2198}
2199
2208 const Thread_Control *the_thread
2209)
2210{
2211#if defined(RTEMS_SMP)
2212 return _Atomic_Load_uint( &the_thread->Wait.flags, ATOMIC_ORDER_ACQUIRE );
2213#else
2214 return the_thread->Wait.flags;
2215#endif
2216}
2217
2235 Thread_Control *the_thread,
2236 Thread_Wait_flags expected_flags,
2237 Thread_Wait_flags desired_flags
2238)
2239{
2240 _Assert( _ISR_Get_level() != 0 );
2241
2242#if defined(RTEMS_SMP)
2243 return _Atomic_Compare_exchange_uint(
2244 &the_thread->Wait.flags,
2245 &expected_flags,
2246 desired_flags,
2247 ATOMIC_ORDER_RELEASE,
2248 ATOMIC_ORDER_RELAXED
2249 );
2250#else
2251 bool success = ( the_thread->Wait.flags == expected_flags );
2252
2253 if ( success ) {
2254 the_thread->Wait.flags = desired_flags;
2255 }
2256
2257 return success;
2258#endif
2259}
2260
2275 Thread_Control *the_thread,
2276 Thread_Wait_flags expected_flags,
2277 Thread_Wait_flags desired_flags
2278)
2279{
2280#if defined(RTEMS_SMP)
2281 return _Atomic_Compare_exchange_uint(
2282 &the_thread->Wait.flags,
2283 &expected_flags,
2284 desired_flags,
2285 ATOMIC_ORDER_ACQUIRE,
2286 ATOMIC_ORDER_ACQUIRE
2287 );
2288#else
2289 bool success;
2290 ISR_Level level;
2291
2292 _ISR_Local_disable( level );
2293
2295 the_thread,
2296 expected_flags,
2297 desired_flags
2298 );
2299
2300 _ISR_Local_enable( level );
2301 return success;
2302#endif
2303}
2304
2321Objects_Id _Thread_Wait_get_id( const Thread_Control *the_thread );
2322
2329 const Thread_Control *the_thread
2330)
2331{
2332 return (Status_Control) the_thread->Wait.return_code;
2333}
2334
2347void _Thread_Continue( Thread_Control *the_thread, Status_Control status );
2348
2354void _Thread_Timeout( Watchdog_Control *the_watchdog );
2355
2364 Per_CPU_Control *cpu
2365)
2366{
2367 _ISR_lock_Initialize( &timer->Lock, "Thread Timer" );
2368 timer->header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_TICKS ];
2369 _Watchdog_Preinitialize( &timer->Watchdog, cpu );
2370}
2371
2380 Thread_Control *the_thread,
2381 Per_CPU_Control *cpu,
2382 Watchdog_Interval ticks
2383)
2384{
2385 ISR_lock_Context lock_context;
2386
2387 _ISR_lock_ISR_disable_and_acquire( &the_thread->Timer.Lock, &lock_context );
2388
2389 the_thread->Timer.header =
2391 the_thread->Timer.Watchdog.routine = _Thread_Timeout;
2392 _Watchdog_Per_CPU_insert_ticks( &the_thread->Timer.Watchdog, cpu, ticks );
2393
2394 _ISR_lock_Release_and_ISR_enable( &the_thread->Timer.Lock, &lock_context );
2395}
2396
2406 Thread_Control *the_thread,
2407 Per_CPU_Control *cpu,
2409 uint64_t expire
2410)
2411{
2412 ISR_lock_Context lock_context;
2413 Watchdog_Header *header;
2414
2415 _ISR_lock_ISR_disable_and_acquire( &the_thread->Timer.Lock, &lock_context );
2416
2417 header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_REALTIME ];
2418 the_thread->Timer.header = header;
2419 the_thread->Timer.Watchdog.routine = routine;
2420 _Watchdog_Per_CPU_insert( &the_thread->Timer.Watchdog, cpu, header, expire );
2421
2422 _ISR_lock_Release_and_ISR_enable( &the_thread->Timer.Lock, &lock_context );
2423}
2424
2431{
2432 ISR_lock_Context lock_context;
2433
2434 _ISR_lock_ISR_disable_and_acquire( &the_thread->Timer.Lock, &lock_context );
2435
2437 &the_thread->Timer.Watchdog,
2438#if defined(RTEMS_SMP)
2439 the_thread->Timer.Watchdog.cpu,
2440#else
2441 _Per_CPU_Get(),
2442#endif
2443 the_thread->Timer.header
2444 );
2445
2446 _ISR_lock_Release_and_ISR_enable( &the_thread->Timer.Lock, &lock_context );
2447}
2448
2457 Thread_Control *the_thread,
2458 Thread_queue_Queue *queue
2459)
2460{
2461 _Thread_Wait_tranquilize( the_thread );
2462 _Thread_Timer_remove( the_thread );
2463
2464#if defined(RTEMS_MULTIPROCESSING)
2465 if ( _Objects_Is_local_id( the_thread->Object.id ) ) {
2466 _Thread_Unblock( the_thread );
2467 } else {
2468 _Thread_queue_Unblock_proxy( queue, the_thread );
2469 }
2470#else
2471 (void) queue;
2472 _Thread_Unblock( the_thread );
2473#endif
2474}
2475
2485Status_Control _Thread_Set_name(
2486 Thread_Control *the_thread,
2487 const char *name
2488);
2489
2499size_t _Thread_Get_name(
2500 const Thread_Control *the_thread,
2501 char *buffer,
2502 size_t buffer_size
2503);
2504
2505#if defined(RTEMS_SMP)
2506#define THREAD_PIN_STEP 2
2507
2508#define THREAD_PIN_PREEMPTION 1
2509
2516void _Thread_Do_unpin(
2517 Thread_Control *executing,
2518 Per_CPU_Control *cpu_self
2519);
2520#endif
2521
2528{
2529#if defined(RTEMS_SMP)
2530 _Assert( executing == _Thread_Executing );
2531
2532 executing->Scheduler.pin_level += THREAD_PIN_STEP;
2533#else
2534 (void) executing;
2535#endif
2536}
2537
2545 Thread_Control *executing,
2546 Per_CPU_Control *cpu_self
2547)
2548{
2549#if defined(RTEMS_SMP)
2550 unsigned int pin_level;
2551
2552 _Assert( executing == _Thread_Executing );
2553
2554 pin_level = executing->Scheduler.pin_level;
2555 _Assert( pin_level > 0 );
2556
2557 if (
2559 pin_level != ( THREAD_PIN_STEP | THREAD_PIN_PREEMPTION )
2560 )
2561 ) {
2562 executing->Scheduler.pin_level = pin_level - THREAD_PIN_STEP;
2563 } else {
2564 _Thread_Do_unpin( executing, cpu_self );
2565 }
2566#else
2567 (void) executing;
2568 (void) cpu_self;
2569#endif
2570}
2571
2574#ifdef __cplusplus
2575}
2576#endif
2577
2578#if defined(RTEMS_MULTIPROCESSING)
2579#include <rtems/score/threadmp.h>
2580#endif
2581
2582#endif
2583/* end of include file */
Information for the Assert Handler.
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
Chain Handler API.
@ PER_CPU_WATCHDOG_REALTIME
Index for realtime clock per-CPU watchdog header.
Definition: percpu.h:325
@ PER_CPU_WATCHDOG_TICKS
Index for tick clock per-CPU watchdog header.
Definition: percpu.h:316
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG.
Definition: assert.h:100
#define RTEMS_PREDICT_TRUE(_exp)
Returns the value of the specified integral expression and tells the compiler that the predicted valu...
Definition: basedefs.h:374
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE void _Chain_Initialize_empty(Chain_Control *the_chain)
Initializes this chain as empty.
Definition: chainimpl.h:505
RTEMS_INLINE_ROUTINE void _Chain_Append_if_is_off_chain_unprotected(Chain_Control *the_chain, Chain_Node *the_node)
Appends a node on the end of a chain if the node is in the off chain state (unprotected).
Definition: chainimpl.h:711
RTEMS_INLINE_ROUTINE void _Chain_Extract_unprotected(Chain_Node *the_node)
Extracts this node (unprotected).
Definition: chainimpl.h:558
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Tail(Chain_Control *the_chain)
Returns pointer to chain tail.
Definition: chainimpl.h:227
RTEMS_INLINE_ROUTINE bool _Chain_Is_empty(const Chain_Control *the_chain)
Checks if the chain is empty.
Definition: chainimpl.h:393
RTEMS_INLINE_ROUTINE const Chain_Node * _Chain_Immutable_tail(const Chain_Control *the_chain)
Returns pointer to immutable chain tail.
Definition: chainimpl.h:243
RTEMS_INLINE_ROUTINE void _Chain_Append_unprotected(Chain_Control *the_chain, Chain_Node *the_node)
Appends a node (unprotected).
Definition: chainimpl.h:680
RTEMS_INLINE_ROUTINE void _Chain_Initialize_node(Chain_Node *the_node)
Initializes a chain node.
Definition: chainimpl.h:122
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Next(const Chain_Node *the_node)
Returns pointer to the next node from this node.
Definition: chainimpl.h:327
RTEMS_INLINE_ROUTINE bool _Chain_Is_node_off_chain(const Chain_Node *node)
Checks if the node is off chain.
Definition: chainimpl.h:142
RTEMS_INLINE_ROUTINE void _Chain_Set_off_chain(Chain_Node *node)
Sets off chain.
Definition: chainimpl.h:104
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_First(const Chain_Control *the_chain)
Returns pointer to chain's first node.
Definition: chainimpl.h:260
#define _Context_Restore_fp(_fp)
Restore floating point context area.
Definition: context.h:142
#define _Context_Save_fp(_fp)
Save floating point context area.
Definition: context.h:153
#define _ISR_lock_ISR_enable(_context)
Restores the saved interrupt state of the ISR lock context.
Definition: isrlock.h:419
#define _ISR_lock_Release(_lock, _context)
Releases an ISR lock inside an ISR disabled section.
Definition: isrlock.h:316
#define _ISR_lock_ISR_disable(_context)
Disables interrupts and saves the previous interrupt state in the ISR lock context.
Definition: isrlock.h:398
#define _ISR_lock_Acquire(_lock, _context)
Acquires an ISR lock inside an ISR disabled section.
Definition: isrlock.h:293
#define _ISR_lock_Release_and_ISR_enable(_lock, _context)
Releases an ISR lock.
Definition: isrlock.h:263
#define _ISR_lock_ISR_disable_and_acquire(_lock, _context)
Acquires an ISR lock.
Definition: isrlock.h:238
#define _ISR_lock_Initialize(_lock, _name)
Initializes an ISR lock.
Definition: isrlock.h:185
#define _ISR_Local_disable(_level)
Disables interrupts on this processor.
Definition: isrlevel.h:57
#define _ISR_Local_enable(_level)
Enables interrupts on this processor.
Definition: isrlevel.h:74
#define _ISR_Get_level()
Return current interrupt level.
Definition: isrlevel.h:128
uint32_t ISR_Level
Definition: isrlevel.h:41
RTEMS_INLINE_ROUTINE Objects_Control * _Objects_Allocate_unprotected(Objects_Information *information)
Allocates an object without locking the allocator mutex.
Definition: objectimpl.h:874
Objects_Information **const _Objects_Information_table[OBJECTS_APIS_LAST+1]
uint32_t Objects_Id
Definition: object.h:80
RTEMS_INLINE_ROUTINE bool _Objects_Is_api_valid(uint32_t the_api)
Checks if the api is valid.
Definition: objectimpl.h:549
RTEMS_INLINE_ROUTINE Objects_APIs _Objects_Get_API(Objects_Id id)
Returns the API portion of the ID.
Definition: object.h:255
RTEMS_INLINE_ROUTINE bool _Objects_Is_local_id(Objects_Id id RTEMS_UNUSED)
Checks if the id is of a local object.
Definition: objectimpl.h:584
uint64_t Priority_Control
The thread priority control.
Definition: priority.h:70
RTEMS_INLINE_ROUTINE void _Priority_Node_set_priority(Priority_Node *node, Priority_Control priority)
Sets the priority of the priority node to the given priority.
Definition: priorityimpl.h:171
RTEMS_INLINE_ROUTINE Priority_Control _Priority_Get_priority(const Priority_Aggregation *aggregation)
Gets the priority aggregation's priority.
Definition: priorityimpl.h:270
const Scheduler_Control _Scheduler_Table[]
Registered schedulers.
#define SCHEDULER_PRIORITY_UNMAP(priority)
Returns the plain priority value.
Definition: schedulernodeimpl.h:61
RTEMS_INLINE_ROUTINE bool _States_Is_ready(States_Control the_states)
Checks if the state is ready.
Definition: statesimpl.h:195
#define STATES_BLOCKED
Definition: statesimpl.h:135
uint32_t States_Control
Definition: states.h:46
RTEMS_INLINE_ROUTINE void _Thread_queue_Do_release_critical(Thread_queue_Control *the_thread_queue, ISR_lock_Context *lock_context)
Checks if the thread queue control is the owner of the lock.
Definition: threadqimpl.h:747
RTEMS_INLINE_ROUTINE void _Thread_queue_Do_acquire_critical(Thread_queue_Control *the_thread_queue, ISR_lock_Context *lock_context)
Acquires the thread queue control in a critical section.
Definition: threadqimpl.h:665
RTEMS_INLINE_ROUTINE void _Thread_queue_Queue_release_critical(Thread_queue_Queue *queue, ISR_lock_Context *lock_context)
Releases the thread queue queue in a critical section.
Definition: threadqimpl.h:603
RTEMS_INLINE_ROUTINE void _Thread_Update_CPU_time_used(Thread_Control *the_thread, Per_CPU_Control *cpu)
Updates the cpu time used of the thread.
Definition: threadimpl.h:1129
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_restarting(Thread_Life_state life_state)
Checks if the thread life state is restarting.
Definition: threadimpl.h:1238
RTEMS_INLINE_ROUTINE void _Thread_Remove_timer_and_unblock(Thread_Control *the_thread, Thread_queue_Queue *queue)
Remove the watchdog timer from the thread and unblock if necessary.
Definition: threadimpl.h:2456
RTEMS_INLINE_ROUTINE void _Thread_Wait_claim(Thread_Control *the_thread, Thread_queue_Queue *queue)
Claims the thread wait queue.
Definition: threadimpl.h:1926
bool _Thread_Start(Thread_Control *the_thread, const Thread_Entry_information *entry, ISR_lock_Context *lock_context)
Initializes thread and executes it.
Definition: threadstart.c:26
RTEMS_INLINE_ROUTINE Scheduler_Node * _Thread_Scheduler_get_home_node(const Thread_Control *the_thread)
Gets the scheduler's home node.
Definition: threadimpl.h:1412
Thread_Life_state
Thread life states.
Definition: thread.h:679
void _Thread_Continue(Thread_Control *the_thread, Status_Control status)
Cancels a blocking operation so that the thread can continue its execution.
Definition: threadtimeout.c:25
RTEMS_INLINE_ROUTINE void _Thread_Unblock(Thread_Control *the_thread)
Unblocks the thread.
Definition: threadimpl.h:939
RTEMS_INLINE_ROUTINE void _Thread_Wait_release_default_critical(Thread_Control *the_thread, ISR_lock_Context *lock_context)
Releases the thread wait default lock inside a critical section (interrupts disabled).
Definition: threadimpl.h:1692
void _Thread_Entry_adaptor_idle(Thread_Control *executing)
Calls the start kinds idle entry of the thread.
Definition: threadentryadaptoridle.c:21
Thread_Information _Thread_Information
The internal thread objects information.
void _Thread_Timeout(Watchdog_Control *the_watchdog)
General purpose thread wait timeout.
Definition: threadtimeout.c:83
RTEMS_INLINE_ROUTINE Status_Control _Thread_Wait_get_status(const Thread_Control *the_thread)
Get the status of the wait return code of the thread.
Definition: threadimpl.h:2328
RTEMS_INLINE_ROUTINE bool _Thread_Is_heir(const Thread_Control *the_thread)
Checks if the thread is the heir.
Definition: threadimpl.h:923
Thread_Control * _Thread_Get(Objects_Id id, ISR_lock_Context *lock_context)
Gets a thread by its identifier.
Definition: threadget.c:24
RTEMS_INLINE_ROUTINE void _Thread_Dispatch_request(Per_CPU_Control *cpu_self, Per_CPU_Control *cpu_target)
Requests a thread dispatch on the target processor.
Definition: threaddispatch.h:235
RTEMS_INLINE_ROUTINE void _Thread_Timer_insert_realtime(Thread_Control *the_thread, Per_CPU_Control *cpu, Watchdog_Service_routine_entry routine, uint64_t expire)
Inserts the cpu's watchdog realtime into the thread's timer.
Definition: threadimpl.h:2405
void * rtems_ada_self
void(* Thread_CPU_budget_algorithm_callout)(Thread_Control *)
Definition: thread.h:178
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Get_priority(const Thread_Control *the_thread)
Returns the priority of the thread.
Definition: threadimpl.h:1584
RTEMS_INLINE_ROUTINE void _Thread_Wait_acquire_critical(Thread_Control *the_thread, Thread_queue_Context *queue_context)
Acquires the thread wait lock inside a critical section (interrupts disabled).
Definition: threadimpl.h:1786
void _Thread_Priority_changed(Thread_Control *the_thread, Priority_Node *priority_node, bool prepend_it, Thread_queue_Context *queue_context)
Propagates a thread priority value change in the specified thread priority node to the corresponding ...
Definition: threadchangepriority.c:307
RTEMS_INLINE_ROUTINE void _Thread_Wait_restore_default(Thread_Control *the_thread)
Restores the default thread wait queue and operations.
Definition: threadimpl.h:2003
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Get_unmapped_real_priority(const Thread_Control *the_thread)
Returns the unmapped real priority of the thread.
Definition: threadimpl.h:1615
void _Thread_Priority_update(Thread_queue_Context *queue_context)
Updates the priority of all threads in the set.
Definition: threadchangepriority.c:339
void _Thread_Handler_initialization(void)
Initializes thread handler.
Definition: thread.c:59
RTEMS_INLINE_ROUTINE Thread_Control * _Thread_Get_heir_and_make_it_executing(Per_CPU_Control *cpu_self)
Gets the heir of the processor and makes it executing.
Definition: threadimpl.h:1109
RTEMS_INLINE_ROUTINE void _Thread_Set_CPU(Thread_Control *thread, Per_CPU_Control *cpu)
Sets the cpu of the thread's scheduler.
Definition: threadimpl.h:860
void _Thread_Priority_replace(Thread_Control *the_thread, Priority_Node *victim_node, Priority_Node *replacement_node)
Replaces the victim priority node with the replacement priority node in the corresponding thread prio...
Definition: threadchangepriority.c:323
bool _Thread_Restart_other(Thread_Control *the_thread, const Thread_Entry_information *entry, ISR_lock_Context *lock_context)
Restarts the thread.
Definition: threadrestart.c:559
RTEMS_INLINE_ROUTINE Thread_Wait_flags _Thread_Wait_flags_get_acquire(const Thread_Control *the_thread)
Gets the thread's wait flags according to the ATOMIC_ORDER_ACQUIRE.
Definition: threadimpl.h:2207
Objects_Id _Thread_Global_constructor
Object identifier of the global constructor thread.
Definition: threadhandler.c:49
RTEMS_INLINE_ROUTINE void _Thread_Restore_fp(Thread_Control *executing)
Restores the executing thread's floating point area.
Definition: threadimpl.h:1003
void _Thread_Priority_add(Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Adds the specified thread priority node to the corresponding thread priority aggregation.
Definition: threadchangepriority.c:277
size_t _Thread_Get_name(const Thread_Control *the_thread, char *buffer, size_t buffer_size)
Gets the name of the thread.
Definition: threadname.c:37
RTEMS_INLINE_ROUTINE Thread_Control * _Thread_Internal_allocate(void)
Allocates an internal thread and returns it.
Definition: threadimpl.h:1090
RTEMS_INLINE_ROUTINE void _Thread_Deallocate_fp(void)
Deallocates the currently loaded floating point context.
Definition: threadimpl.h:1028
void _Thread_Priority_perform_actions(Thread_Control *start_of_path, Thread_queue_Context *queue_context)
Checks if the thread is owner of the lock of the join queue.
Definition: threadchangepriority.c:182
States_Control _Thread_Set_state(Thread_Control *the_thread, States_Control state)
Sets the specified thread state.
Definition: threadsetstate.c:50
void _Thread_Join(Thread_Control *the_thread, States_Control waiting_for_join, Thread_Control *executing, Thread_queue_Context *queue_context)
Joins the currently executing thread with the given thread to wait for.
Definition: threadrestart.c:421
RTEMS_INLINE_ROUTINE void _Thread_Action_control_initialize(Thread_Action_control *action_control)
Initializes the control chain of the action control.
Definition: threadimpl.h:1182
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Get_unmapped_priority(const Thread_Control *the_thread)
Returns the unmapped priority of the thread.
Definition: threadimpl.h:1601
RTEMS_INLINE_ROUTINE void _Thread_Priority_change(Thread_Control *the_thread, Priority_Node *priority_node, Priority_Control new_priority, bool prepend_it, Thread_queue_Context *queue_context)
Changes the thread priority value of the specified thread priority node in the corresponding thread p...
Definition: threadimpl.h:696
RTEMS_INLINE_ROUTINE void _Thread_Wait_tranquilize(Thread_Control *the_thread)
Tranquilizes the thread after a wait on a thread queue.
Definition: threadimpl.h:2062
RTEMS_INLINE_ROUTINE void _Thread_Resource_count_decrement(Thread_Control *the_thread)
Decrements the thread's resource count.
Definition: threadimpl.h:1329
RTEMS_INLINE_ROUTINE bool _Thread_Is_allocated_fp(const Thread_Control *the_thread)
Checks if the floating point context of the thread is currently loaded in the floating point unit.
Definition: threadimpl.h:962
RTEMS_INLINE_ROUTINE uint32_t _Thread_Get_maximum_internal_threads(void)
Gets the maximum number of internal threads.
Definition: threadimpl.h:1068
RTEMS_INLINE_ROUTINE Thread_Wait_flags _Thread_Wait_flags_get(const Thread_Control *the_thread)
Gets the thread's wait flags according to the ATOMIC_ORDER_RELAXED.
Definition: threadimpl.h:2189
RTEMS_INLINE_ROUTINE bool _Thread_Is_joinable(const Thread_Control *the_thread)
Checks if the thread is joinable.
Definition: threadimpl.h:1300
Thread_Life_state _Thread_Change_life(Thread_Life_state clear, Thread_Life_state set, Thread_Life_state ignore)
Changes the currently executing thread to a new state with the sets.
Definition: threadrestart.c:649
States_Control _Thread_Clear_state(Thread_Control *the_thread, States_Control state)
Clears the specified thread state.
Definition: threadclearstate.c:51
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_change_allowed(Thread_Life_state life_state)
Checks if the thread life state allos life change.
Definition: threadimpl.h:1268
void _Thread_Yield(Thread_Control *executing)
Yields the currently executing thread.
Definition: threadyield.c:30
RTEMS_INLINE_ROUTINE void _Thread_Timer_remove(Thread_Control *the_thread)
Remove the watchdog timer from the thread.
Definition: threadimpl.h:2430
RTEMS_INLINE_ROUTINE Thread_Control * _Thread_State_acquire_for_executing(ISR_lock_Context *lock_context)
Disables interrupts and acquires the lock context for the currently executing thread.
Definition: threadimpl.h:533
Creates idle thread.
Definition: threadcreateidle.c:99
Thread_Control * _Thread_Allocated_fp
Definition: threaddispatch.c:35
void _Thread_Priority_remove(Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Removes the specified thread priority node from the corresponding thread priority aggregation.
Definition: threadchangepriority.c:292
RTEMS_INLINE_ROUTINE void _Thread_Wait_flags_set(Thread_Control *the_thread, Thread_Wait_flags flags)
Sets the thread's wait flags.
Definition: threadimpl.h:2170
void _Thread_Entry_adaptor_numeric(Thread_Control *executing)
Calls the start kinds numeric entry of the thread.
Definition: threadentryadaptornumeric.c:21
RTEMS_INLINE_ROUTINE void _Thread_State_release(Thread_Control *the_thread, ISR_lock_Context *lock_context)
Releases the lock context and enables interrupts.
Definition: threadimpl.h:566
RTEMS_INLINE_ROUTINE bool _Thread_Is_context_switch_necessary(void)
Checks if dispatching is disabled.
Definition: threadimpl.h:1043
void _Thread_Kill_zombies(void)
Kills all zombie threads in the system.
Definition: threadrestart.c:216
void _Thread_Exit(Thread_Control *executing, Thread_Life_state set, void *exit_value)
Exits the currently executing thread.
Definition: threadrestart.c:532
unsigned int Thread_Wait_flags
This type is able to contain several flags used to control the wait class and state of a thread.
Definition: thread.h:390
RTEMS_INLINE_ROUTINE void _Thread_State_acquire(Thread_Control *the_thread, ISR_lock_Context *lock_context)
Disables interrupts and acquires the lock_context.
Definition: threadimpl.h:516
RTEMS_INLINE_ROUTINE void _Thread_Add_timeout_ticks(Thread_Control *the_thread, Per_CPU_Control *cpu, Watchdog_Interval ticks)
Adds timeout ticks to the thread.
Definition: threadimpl.h:2379
RTEMS_INLINE_ROUTINE void _Thread_Save_fp(Thread_Control *executing)
Saves the executing thread's floating point area.
Definition: threadimpl.h:988
RTEMS_INLINE_ROUTINE void _Thread_Wait_acquire(Thread_Control *the_thread, Thread_queue_Context *queue_context)
Acquires the thread wait default lock and disables interrupts.
Definition: threadimpl.h:1842
void(* Thread_Action_handler)(Thread_Control *the_thread, Thread_Action *action, ISR_lock_Context *lock_context)
Thread action handler.
Definition: thread.h:620
RTEMS_INLINE_ROUTINE void _Thread_Action_initialize(Thread_Action *action)
Initializes the Thread action.
Definition: threadimpl.h:1194
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_changing(Thread_Life_state life_state)
Checks if the thread life state is life changing.
Definition: threadimpl.h:1284
void _Thread_Entry_adaptor_pointer(Thread_Control *executing)
Calls the start kinds pointer entry of the thread.
Definition: threadentryadaptorpointer.c:21
void _Thread_Get_CPU_time_used(Thread_Control *the_thread, Timestamp_Control *cpu_time_used)
Updates the used cpu time for the heir and dispatches a new heir.
Definition: threadgetcputimeused.c:31
RTEMS_INLINE_ROUTINE void _Thread_State_release_critical(Thread_Control *the_thread, ISR_lock_Context *lock_context)
Release the lock context in a critical section.
Definition: threadimpl.h:552
RTEMS_INLINE_ROUTINE void _Thread_Add_post_switch_action(Thread_Control *the_thread, Thread_Action *action, Thread_Action_handler handler)
Adds a post switch action to the thread with the given handler.
Definition: threadimpl.h:1208
void _Thread_Cancel(Thread_Control *the_thread, Thread_Control *executing, void *exit_value)
Cancels the thread.
Definition: threadrestart.c:450
void _Thread_Start_multitasking(void) RTEMS_NO_RETURN
Starts thread multitasking.
Definition: threadstartmultitasking.c:24
RTEMS_INLINE_ROUTINE bool _Thread_Is_ready(const Thread_Control *the_thread)
Checks if the thread is ready.
Definition: threadimpl.h:375
bool _Thread_Initialize(Thread_Information *information, Thread_Control *the_thread, const Thread_Configuration *config)
Initializes thread.
Definition: threadinitialize.c:29
Thread_CPU_budget_algorithms
Definition: thread.h:164
RTEMS_INLINE_ROUTINE void _Thread_Wait_cancel(Thread_Control *the_thread, Thread_queue_Context *queue_context)
Cancels a thread wait on a thread queue.
Definition: threadimpl.h:2080
RTEMS_INLINE_ROUTINE Per_CPU_Control * _Thread_Get_CPU(const Thread_Control *thread)
Gets the cpu of the thread's scheduler.
Definition: threadimpl.h:841
RTEMS_INLINE_ROUTINE bool _Thread_Priority_less_than(Priority_Control left, Priority_Control right)
Updates the priority of the thread and changes it sticky level.
Definition: threadimpl.h:767
RTEMS_INLINE_ROUTINE bool _Thread_Wait_flags_try_change_release(Thread_Control *the_thread, Thread_Wait_flags expected_flags, Thread_Wait_flags desired_flags)
Tries to change the thread wait flags with release semantics in case of success.
Definition: threadimpl.h:2234
RTEMS_INLINE_ROUTINE Scheduler_Node * _Thread_Scheduler_get_node_by_index(const Thread_Control *the_thread, size_t scheduler_index)
Gets the thread's scheduler node by index.
Definition: threadimpl.h:1434
RTEMS_INLINE_ROUTINE bool _Thread_Is_null(const Thread_Control *the_thread)
Checks if the thread is NULL.
Definition: threadimpl.h:1056
RTEMS_INLINE_ROUTINE Thread_Control * _Thread_Wait_acquire_default_for_executing(ISR_lock_Context *lock_context)
Acquires the thread wait default lock and returns the executing thread.
Definition: threadimpl.h:1651
RTEMS_INLINE_ROUTINE void _Thread_Wait_release(Thread_Control *the_thread, Thread_queue_Context *queue_context)
Releases the thread wait lock and restores the previous interrupt status.
Definition: threadimpl.h:1903
RTEMS_INLINE_ROUTINE void _Thread_Timer_initialize(Thread_Timer_information *timer, Per_CPU_Control *cpu)
Initializes the thread timer.
Definition: threadimpl.h:2362
void _Thread_Iterate(Thread_Visitor visitor, void *arg)
Calls the visitor with all threads and the given argument until it is done.
Definition: threaditerate.c:21
void _Thread_Initialize_information(Thread_Information *information)
Initializes the thread information.
Definition: thread.c:47
RTEMS_INLINE_ROUTINE void _Thread_Wait_release_default(Thread_Control *the_thread, ISR_lock_Context *lock_context)
Releases the thread wait default lock and restores the previous interrupt status.
Definition: threadimpl.h:1708
RTEMS_INLINE_ROUTINE bool _Thread_Is_executing(const Thread_Control *the_thread)
Checks if the thread is the currently executing thread.
Definition: threadimpl.h:884
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Priority_highest(Priority_Control left, Priority_Control right)
Returns the highest priority of the left and right thread priorities in the intuitive sense of priori...
Definition: threadimpl.h:784
Thread_Life_state _Thread_Set_life_protection(Thread_Life_state state)
Set the thread to life protected.
Definition: threadrestart.c:671
Objects_Id _Thread_Wait_get_id(const Thread_Control *the_thread)
Returns the object identifier of the object containing the current thread wait queue.
Definition: threadwaitgetid.c:21
States_Control _Thread_Set_state_locked(Thread_Control *the_thread, States_Control state)
Sets the specified thread state without locking the lock context.
Definition: threadsetstate.c:28
RTEMS_INLINE_ROUTINE void _Thread_Wait_remove_request(Thread_Control *the_thread, Thread_queue_Lock_context *queue_lock_context)
Removes a thread wait lock request.
Definition: threadimpl.h:1974
RTEMS_INLINE_ROUTINE void _Thread_Wait_claim_finalize(Thread_Control *the_thread, const Thread_queue_Operations *operations)
Finalizes the thread wait queue claim via registration of the corresponding thread queue operations.
Definition: threadimpl.h:1955
void _Thread_Load_environment(Thread_Control *the_thread)
Initializes enviroment for a thread.
Definition: threadloadenv.c:24
RTEMS_INLINE_ROUTINE void _Thread_Resource_count_increment(Thread_Control *the_thread)
Increments the thread's resource count.
Definition: threadimpl.h:1313
RTEMS_INLINE_ROUTINE void _Thread_Pin(Thread_Control *executing)
Pin the executing thread.
Definition: threadimpl.h:2527
RTEMS_INLINE_ROUTINE void _Thread_Wait_release_critical(Thread_Control *the_thread, Thread_queue_Context *queue_context)
Releases the thread wait lock inside a critical section (interrupts disabled).
Definition: threadimpl.h:1861
RTEMS_INLINE_ROUTINE Objects_Information * _Thread_Get_objects_information(Objects_Id id)
Gets object information for the object id.
Definition: threadimpl.h:800
Status_Control _Thread_Set_name(Thread_Control *the_thread, const char *name)
Sets the name of the thread.
Definition: threadname.c:17
void _Thread_Handler(void)
Wrapper function for all threads.
Definition: threadhandler.c:72
States_Control _Thread_Clear_state_locked(Thread_Control *the_thread, States_Control state)
Clears the specified thread state without locking the lock context.
Definition: threadclearstate.c:25
RTEMS_INLINE_ROUTINE bool _Thread_Wait_flags_try_change_acquire(Thread_Control *the_thread, Thread_Wait_flags expected_flags, Thread_Wait_flags desired_flags)
Tries to change the thread wait flags with acquire semantics.
Definition: threadimpl.h:2274
RTEMS_INLINE_ROUTINE const Scheduler_Control * _Thread_Scheduler_get_home(const Thread_Control *the_thread)
Gets the home scheduler of the thread.
Definition: threadimpl.h:1393
void _Thread_Restart_self(Thread_Control *executing, const Thread_Entry_information *entry, ISR_lock_Context *lock_context) RTEMS_NO_RETURN
Restarts the currently executing thread.
Definition: threadrestart.c:602
RTEMS_INLINE_ROUTINE bool _Thread_Is_life_terminating(Thread_Life_state life_state)
Checks if the thread life state is terminating.
Definition: threadimpl.h:1253
void _Thread_Close(Thread_Control *the_thread, Thread_Control *executing, Thread_Close_context *context)
Closes the thread.
Definition: threadrestart.c:509
RTEMS_INLINE_ROUTINE void _Thread_Wait_acquire_default_critical(Thread_Control *the_thread, ISR_lock_Context *lock_context)
Acquires the thread wait default lock inside a critical section (interrupts disabled).
Definition: threadimpl.h:1632
RTEMS_INLINE_ROUTINE void _Thread_Unpin(Thread_Control *executing, Per_CPU_Control *cpu_self)
Unpins the thread.
Definition: threadimpl.h:2544
RTEMS_INLINE_ROUTINE void _Thread_State_acquire_critical(Thread_Control *the_thread, ISR_lock_Context *lock_context)
Acquires the lock context in a critical section.
Definition: threadimpl.h:502
RTEMS_INLINE_ROUTINE void _Thread_Wait_acquire_default(Thread_Control *the_thread, ISR_lock_Context *lock_context)
Definition: threadimpl.h:1673
RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove(Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Header *header)
Removes the watchdog from the cpu and the scheduled watchdogs.
Definition: watchdogimpl.h:649
uint32_t Watchdog_Interval
Type is used to specify the length of intervals.
Definition: watchdogticks.h:38
RTEMS_INLINE_ROUTINE void _Watchdog_Preinitialize(Watchdog_Control *the_watchdog, Per_CPU_Control *cpu)
Pre-initializes a watchdog.
Definition: watchdogimpl.h:214
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_ticks(Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Interval ticks)
Sets the watchdog's cpu to the given instance and sets its expiration time to the watchdog expiration...
Definition: watchdogimpl.h:593
Watchdog_Service_routine(* Watchdog_Service_routine_entry)(Watchdog_Control *)
Pointer to a watchdog service routine.
Definition: watchdog.h:66
RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert(Watchdog_Control *the_watchdog, Per_CPU_Control *cpu, Watchdog_Header *header, uint64_t expire)
Sets the watchdog's cpu and inserts it with the given expiration time in the scheduled watchdogs.
Definition: watchdogimpl.h:625
int64_t Timestamp_Control
Definition: timestamp.h:57
RTEMS_INLINE_ROUTINE void _Timestamp_Add_to(Timestamp_Control *_time, const Timestamp_Control *_add)
Adds two timestamps.
Definition: timestampimpl.h:147
RTEMS_INLINE_ROUTINE void _Timestamp_Subtract(const Timestamp_Control *_start, const Timestamp_Control *_end, Timestamp_Control *_result)
Subtracts two timestamps.
Definition: timestampimpl.h:166
#define rtems_configuration_get_maximum_processors()
Returns the configured maximum count of processors.
Definition: config.h:167
Constants and Prototypes Related to the Internal Error Handler.
Data Related to the Management of Processor Interrupt Levels.
Inlined Routines in the Object Handler.
Scheduler Node Implementation.
Constants and Structures Related with the Thread Control Block.
Inlined Routines Associated with Thread State Information.
Definition: chain.h:68
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:65
Objects_Id id
Definition: objectdata.h:43
The information structure used to manage each API class of objects.
Definition: objectdata.h:176
Per CPU Core Structure.
Definition: percpu.h:347
struct _Thread_Control * heir
This is the heir thread for this processor.
Definition: percpu.h:436
Watchdog_Header Header[PER_CPU_WATCHDOG_COUNT]
Header for watchdogs.
Definition: percpu.h:474
volatile bool dispatch_necessary
This is set to true when this processor needs to run the thread dispatcher.
Definition: percpu.h:400
Timestamp_Control cpu_usage_timestamp
The CPU usage timestamp contains the time point of the last heir thread change or last CPU usage upda...
Definition: percpu.h:452
struct _Thread_Control * executing
This is the thread executing on this processor.
Definition: percpu.h:420
struct Per_CPU_Control::@3978 Watchdog
Watchdog state for this processor.
The priority node to build up a priority aggregation.
Definition: priority.h:98
The priority value of this node.
Definition: priority.h:110
Scheduler node for per-thread data.
Definition: schedulernode.h:79
struct Scheduler_Node::@3981 Wait
Thread wait support block.
Control block to manage thread actions.
Definition: thread.h:665
Thread action.
Definition: thread.h:640
Definition: threadimpl.h:345
The configuration of a new thread to initialize.
Thread_CPU_budget_algorithm_callout budget_callout
The thread's initial budget callout.
Definition: threadimpl.h:164
The new thread's priority.
Definition: threadimpl.h:154
Objects_Name name
Name of the object for the thread.
const struct _Scheduler_Control * scheduler
The scheduler control instance for the thread.
Definition: threadimpl.h:134
void * stack_area
The starting address of the stack area.
size_t stack_size
The size of the stack area in bytes.
Definition: threadimpl.h:144
bool is_preemptible
Indicates whether the new thread is preemptible.
Thread_CPU_budget_algorithms budget_algorithm
The thread's budget algorithm.
Definition: threadimpl.h:159
void * allocated_stack
The address of the allocated stack area or NULL.
Definition: threadimpl.h:149
uint32_t isr_level
The thread's initial ISR level.
Definition: threadimpl.h:174
bool is_fp
Indicates whether the thread needs a floating-point area.
Definition: threadimpl.h:179
Thread entry information.
Definition: thread.h:136
The thread object information.
Definition: thread.h:997
Objects_Information Objects
The object information.
Definition: thread.h:1001
The current thread life state.
Definition: thread.h:700
Scheduler_Node * nodes
The scheduler nodes of this thread.
Definition: thread.h:358
Information required to manage a thread timer.
Definition: thread.h:506
Thread_queue_Queue * queue
The current thread queue.
Definition: thread.h:489
This field contains several flags used to control the wait class and state of a thread in case fine-g...
Definition: thread.h:429
const Thread_queue_Operations * operations
The current thread queue operations.
Definition: thread.h:498
uint32_t return_code
Definition: thread.h:420
Thread queue context for the thread queue methods.
Definition: threadq.h:198
Thread_queue_Lock_context Lock_context
The lock context for the thread queue acquire and release operations.
Definition: threadq.h:203
Definition: threadq.h:125
ISR_lock_Context Lock_context
Definition: threadq.h:130
Thread queue operations.
Definition: threadq.h:518
Thread_queue_Extract_operation extract
Thread queue extract operation.
Definition: threadq.h:536
Definition: threadq.h:402
The control block used to manage each watchdog timer.
Definition: watchdog.h:90
This field is the function to invoke.
Definition: watchdog.h:114
The watchdog header to manage scheduled watchdogs.
Definition: watchdog.h:71
Scheduler control.
Definition: scheduler.h:269
Definition: thread.h:732
Context_Control Registers
Definition: thread.h:837
Objects_Control Object
Definition: thread.h:734
Timestamp_Control cpu_time_used
Definition: thread.h:827
Thread_Wait_information Wait
Definition: thread.h:774
Context_Control_fp * fp_context
Definition: thread.h:842
Priority_Node Real_priority
The base priority of this thread in its home scheduler instance.
Definition: thread.h:761
States_Control current_state
Definition: thread.h:756
Thread_Scheduler_control Scheduler
Scheduler related control.
Definition: thread.h:771
Thread_queue_Control Join_queue
Thread queue for thread join operations and multi-purpose lock.
Definition: thread.h:753
Thread_Timer_information Timer
Definition: thread.h:776
Thread_Life_control Life
Thread life-cycle control.
Definition: thread.h:859
Definition: deflate.c:115
Definition: mmu-config.c:40
unsigned context
Definition: tlb.h:1
System State Handler API.
Multiprocessing Portion of the Thread Package.
Constants and Structures Associated with the Manipulation of Objects.
Helpers for Manipulating Timestamps.
Time of Day Handler API.
Definition: object.h:64
Inlined Routines in the Watchdog Handler.
