RTEMS 5.2
Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
todimpl.h File Reference
Time of Day Handler API. More...
#include <rtems/score/status.h>
#include <rtems/score/timestamp.h>
#include <rtems/score/timecounterimpl.h>
#include <sys/time.h>
#include <time.h>
struct  TOD_Control
 TOD control. More...
struct  TOD_Hook
 Structure to manage each TOD action hook. More...
#define TOD_SECONDS_PER_MINUTE   (uint32_t)60
#define TOD_MINUTES_PER_HOUR   (uint32_t)60
#define TOD_MONTHS_PER_YEAR   (uint32_t)12
#define TOD_DAYS_PER_YEAR   (uint32_t)365
#define TOD_HOURS_PER_DAY   (uint32_t)24
#define TOD_SECONDS_PER_DAY
#define TOD_SECONDS_PER_NON_LEAP_YEAR   (365 * TOD_SECONDS_PER_DAY)
#define TOD_MILLISECONDS_PER_SECOND   (uint32_t)1000
#define TOD_MICROSECONDS_PER_SECOND   (uint32_t)1000000
#define TOD_NANOSECONDS_PER_SECOND   (uint32_t)1000000000
#define TOD_NANOSECONDS_PER_MICROSECOND   (uint32_t)1000
#define TOD_SECONDS_1970_THROUGH_1988
#define TOD_BASE_YEAR   1988
 Earliest year to which an time of day can be initialized. More...
#define TOD_TICKS_PER_SECOND   TOD_TICKS_PER_SECOND_method()
 Gets number of ticks in a second. More...
typedef struct TOD_Hook TOD_Hook
enum  TOD_Action { TOD_ACTION_SET_CLOCK }
 Possible actions where a registered hook could be invoked. More...
void _TOD_Lock (void)
 Locks the time of day mutex.
void _TOD_Unlock (void)
 Unlocks the time of day mutex.
Status_Control _TOD_Set (const struct timespec *tod, ISR_lock_Context *lock_context)
 Sets the time of day. More...
uint32_t TOD_TICKS_PER_SECOND_method (void)
RTEMS_INLINE_ROUTINE void _TOD_Get_timeval (struct timeval *time)
 This routine returns a timeval based upon the internal timespec format TOD. More...
void _TOD_Adjust (const struct timespec *delta)
 Adjusts the Time of Time. More...
RTEMS_INLINE_ROUTINE bool _TOD_Is_set (void)
 Check if the TOD is Set. More...
void _TOD_Hook_Register (TOD_Hook *hook)
 Add a TOD Action Hook. More...
void _TOD_Hook_Unregister (TOD_Hook *hook)
 Remove a TOD Action Hook. More...
Status_Control _TOD_Hook_Run (TOD_Action action, const struct timespec *tod)
 Run the TOD Action Hooks. More...
TOD_Control _TOD
 TOD Management information.
Chain_Control _TOD_Hooks
 Set of registered methods for TOD Actions.
◆ TOD_BASE_YEAR
The following constant define the earliest year to which an time of day can be initialized. This is considered the epoch.
◆ TOD_SECONDS_1970_THROUGH_1988
Value:
(((1987 - 1970 + 1) * TOD_SECONDS_PER_NON_LEAP_YEAR) + \
Definition: todimpl.h:82
Definition: todimpl.h:75
Seconds from January 1, 1970 to January 1, 1988. Used to account for differences between POSIX API and RTEMS core. The timespec format time is kept in POSIX compliant form.
