Time of Day Handler.
More...
The following constants are related to the time of day and are independent of RTEMS.
This handler encapsulates functionality used to manage time of day.
◆ TOD_DAYS_PER_YEAR
| #define TOD_DAYS_PER_YEAR (uint32_t)365 |
This constant represents the number of days in a non-leap year.
◆ TOD_HOURS_PER_DAY
| #define TOD_HOURS_PER_DAY (uint32_t)24 |
This constant represents the number of hours per day.
◆ TOD_MICROSECONDS_PER_SECOND
| #define TOD_MICROSECONDS_PER_SECOND (uint32_t)1000000 |
This constant represents the number of microseconds in a second.
◆ TOD_MILLISECONDS_PER_SECOND
| #define TOD_MILLISECONDS_PER_SECOND (uint32_t)1000 |
This constant represents the number of millisecond in a second.
◆ TOD_MINUTES_PER_HOUR
| #define TOD_MINUTES_PER_HOUR (uint32_t)60 |
This constant represents the number of minutes per hour.
◆ TOD_MONTHS_PER_YEAR
| #define TOD_MONTHS_PER_YEAR (uint32_t)12 |
This constant represents the number of months in a year.
◆ TOD_NANOSECONDS_PER_MICROSECOND
| #define TOD_NANOSECONDS_PER_MICROSECOND (uint32_t)1000 |
This constant represents the number of nanoseconds in a mircosecond.
◆ TOD_NANOSECONDS_PER_SECOND
| #define TOD_NANOSECONDS_PER_SECOND (uint32_t)1000000000 |
This constant represents the number of nanoseconds in a second.
◆ TOD_SECONDS_PER_DAY
| #define TOD_SECONDS_PER_DAY |
Value:
Definition: todimpl.h:54
#define TOD_SECONDS_PER_MINUTE
Definition: todimpl.h:49
Definition: todimpl.h:69
This constant represents the number of seconds in a day which does not include a leap second.
◆ TOD_SECONDS_PER_MINUTE
| #define TOD_SECONDS_PER_MINUTE (uint32_t)60 |
This constant represents the number of seconds in a minute.
◆ TOD_SECONDS_PER_NON_LEAP_YEAR
This constant represents the number of seconds in a non-leap year.
◆ TOD_TICKS_PER_SECOND
Gets number of ticks in a second.
This method exists to hide the fact that TOD_TICKS_PER_SECOND can not be implemented as a macro in a .h file due to visibility issues. The Configuration Table is not available to SuperCore .h files but is available to their .c files.
◆ _TOD_Adjust()
| void _TOD_Adjust |
const struct timespec * |
delta | ) |
Adjusts the Time of Time.
This method is used to adjust the current time of day by the specified amount.
- Parameters
| delta | is the amount to adjust. |
◆ _TOD_Get_timeval()
This routine returns a timeval based upon the internal timespec format TOD.
- Parameters
| [out] | time | The timeval to be filled in by the method. |
◆ _TOD_Is_set()
Check if the TOD is Set.
- Return values
| true | The time is set. |
| false | The time is not set. |
◆ _TOD_Set()
| Status_Control _TOD_Set |
tod, |
ISR_lock_Context * |
lock_context |
Sets the time of day.
The caller must be the owner of the TOD lock.
- Parameters
| tod | The new time of day in timespec format representing the time since UNIX Epoch. |
| lock_context | The ISR lock context used for the corresponding _TOD_Acquire(). The caller must be the owner of the TOD lock. This function will release the TOD lock. |
- Return values
| STATUS_SUCCESSFUL | Successful operation. |
| other | Some error occurred. |
◆ TOD_TICKS_PER_SECOND_method()
| uint32_t TOD_TICKS_PER_SECOND_method |
void |
This method returns the number of ticks in a second.
- Note
- If the clock tick value does not multiply evenly into a second then this number of ticks will be slightly shorter than a second.
- Returns
- The number of ticks in a second.
