RTEMS 5.2
watchdog.h
1
13/*
14 * COPYRIGHT (c) 1989-2009.
15 * On-Line Applications Research Corporation (OAR).
16 *
17 * The license and distribution terms for this file may be
18 * found in the file LICENSE in this distribution or at
19 * http://www.rtems.org/license/LICENSE.
20 */
21
22#ifndef _RTEMS_SCORE_WATCHDOG_H
23#define _RTEMS_SCORE_WATCHDOG_H
24
26#include <rtems/score/chain.h>
27#include <rtems/score/rbtree.h>
28
29struct Per_CPU_Control;
30
31#ifdef __cplusplus
32extern "C" {
33#endif
34
52
59
67
71typedef struct {
75 RBTree_Control Watchdogs;
76
83
94 union {
100
107
108#if defined(RTEMS_SMP)
110 struct Per_CPU_Control *cpu;
111#endif
112
115
117 uint64_t expire;
118};
119
122#ifdef __cplusplus
123}
124#endif
125
126#endif
127/* end of include file */
Basic Definitions.
void Watchdog_Service_routine
Return type from a Watchdog Service Routine.
Definition: watchdog.h:58
Watchdog_Service_routine(* Watchdog_Service_routine_entry)(Watchdog_Control *)
Pointer to a watchdog service routine.
Definition: watchdog.h:66
Constants and Structures Associated with the Red-Black Tree Handler.
Chain Handler API.
Definition: chain.h:68
Per CPU Core Structure.
Definition: percpu.h:347
Red-black tree node.
Definition: rbtree.h:55
The control block used to manage each watchdog timer.
Definition: watchdog.h:90
RBTree_Node RBTree
this field is a red-black tree node structure and allows this to be placed on a red-black tree used t...
Definition: watchdog.h:99
uint64_t expire
This field is the expiration time point.
Definition: watchdog.h:117
union Watchdog_Control::@3988 Node
Nodes for the watchdog.
Watchdog_Service_routine_entry routine
This field is the function to invoke.
Definition: watchdog.h:114
Chain_Node Chain
this field is a chain node structure and allows this to be placed on a chain used to manage pending w...
Definition: watchdog.h:105
The watchdog header to manage scheduled watchdogs.
Definition: watchdog.h:71
RBTree_Node * first
The scheduled watchdog with the earliest expiration time or NULL in case no watchdog is scheduled.
Definition: watchdog.h:81
Red-black tree of scheduled watchdogs sorted by expiration time.
Definition: watchdog.h:75
