RTEMS 5.2
The control block used to manage each watchdog timer. More...
#include <watchdog.h>
Data Fields | |
| union { | |
| RBTree_Node RBTree | |
| this field is a red-black tree node structure and allows this to be placed on a red-black tree used to manage the scheduled watchdogs. | |
| Chain_Node Chain | |
| this field is a chain node structure and allows this to be placed on a chain used to manage pending watchdogs by the timer server. | |
| } | Node |
| Nodes for the watchdog. | |
| Watchdog_Service_routine_entry | routine |
| This field is the function to invoke. | |
| uint64_t | expire |
| This field is the expiration time point. | |
The following record defines the control block used to manage each watchdog timer.
