RTEMS 5.2
Objects_Control Struct Reference
#include <objectdata.h>
Chain_Node Node
Objects_Id id
Objects_Name name
The following defines the Object Control Block used to manage each object local to this node.
Field Documentation
◆ id
Objects_Id Objects_Control::id
This is the object's ID.
◆ name
Objects_Name Objects_Control::name
This is the object's name.
◆ Node
Chain_Node Objects_Control::Node
This is the chain node portion of an object.
