RTEMS 5.2
Files | |
| file | object.h |
| Constants and Structures Associated with the Object Handler. | |
| file | objectdata.h |
| Object Handler Data Structures. | |
| file | objectimpl.h |
| Inlined Routines in the Object Handler. | |
| file | objectallocate.c |
| Allocate Object. | |
| file | objectallocatenone.c |
| file | objectallocatestatic.c |
| file | objectallocateunlimited.c |
| file | objectapimaximumclass.c |
| Object API Maximum Class. | |
| file | objectclose.c |
| Close Object. | |
| file | objectextendinformation.c |
| Extend Set of Objects. | |
| file | objectfree.c |
| Free Object. | |
| file | objectfreestatic.c |
| file | objectgetinfo.c |
| Get Object Information. | |
| file | objectgetlocal.c |
| Object Get Local. | |
| file | objectgetnext.c |
| Get Pointer to Next Object that is Active. | |
| file | objectgetnoprotection.c |
| Get Object without Dispatching Protection. | |
| file | objectinitializeinformation.c |
| Initialize Object Information. | |
| file | objectnametoidstring.c |
| Object ID to Name. | |
| file | objectsetname.c |
| Set Objects Name. | |
| union | Objects_Name |
| struct | Objects_Control |
| struct | Objects_Information |
| The information structure used to manage each API class of objects. More... | |
| #define | OBJECTS_INDEX_START_BIT 0U |
| #define | OBJECTS_NODE_START_BIT 16U |
| #define | OBJECTS_API_START_BIT 24U |
| #define | OBJECTS_CLASS_START_BIT 27U |
| #define | OBJECTS_INDEX_MASK (Objects_Id)0x0000ffffU |
| #define | OBJECTS_NODE_MASK (Objects_Id)0x00ff0000U |
| #define | OBJECTS_API_MASK (Objects_Id)0x07000000U |
| #define | OBJECTS_CLASS_MASK (Objects_Id)0xf8000000U |
| #define | OBJECTS_INDEX_VALID_BITS (Objects_Id)0x0000ffffU |
| #define | OBJECTS_NODE_VALID_BITS (Objects_Id)0x000000ffU |
| #define | OBJECTS_API_VALID_BITS (Objects_Id)0x00000007U |
| #define | OBJECTS_CLASS_VALID_BITS (Objects_Id)0x0000001fU |
| #define | OBJECTS_UNLIMITED_OBJECTS 0x80000000U |
| #define | OBJECTS_ID_INITIAL_INDEX (0) |
| #define | OBJECTS_ID_FINAL_INDEX (0xffffU) |
| #define | OBJECTS_APIS_LAST OBJECTS_POSIX_API |
| #define | OBJECTS_ID_NONE 0 |
| #define | OBJECTS_ID_OF_SELF ((Objects_Id) 0) |
| #define | OBJECTS_SEARCH_ALL_NODES 0 |
| #define | OBJECTS_SEARCH_OTHER_NODES 0x7FFFFFFE |
| #define | OBJECTS_SEARCH_LOCAL_NODE 0x7FFFFFFF |
| #define | OBJECTS_WHO_AM_I 0 |
| #define | OBJECTS_ID_INITIAL(_api, _class, _node) _Objects_Build_id( (_api), (_class), (_node), OBJECTS_ID_INITIAL_INDEX ) |
| #define | OBJECTS_ID_FINAL ((Objects_Id)~0) |
| #define | _Objects_Build_name(_C1, _C2, _C3, _C4) |
| #define | _Objects_Build_id(the_api, the_class, node, index) |
| Builds an object ID from its components. More... | |
| #define | _Objects_Is_unlimited(maximum) ( ( ( maximum ) & OBJECTS_UNLIMITED_OBJECTS ) != 0 ) |
| #define | _Objects_Maximum_per_allocation(maximum) ((Objects_Maximum) ((maximum) & ~OBJECTS_UNLIMITED_OBJECTS)) |
| #define | _Objects_Local_node ((uint16_t) 1) |
| The local MPCI node number. | |
| #define | OBJECTS_NO_STRING_NAME 0 |
| Constant for the object information string name length to indicate that this object class has no string names. | |
| #define | OBJECTS_INFORMATION_MP(name, extract) |
| #define | OBJECTS_INFORMATION_DEFINE_ZERO(name, api, cls, nl) |
| Statically initializes an objects information. More... | |
| #define | OBJECTS_INFORMATION_DEFINE(name, api, cls, type, max, nl, ex) |
| #define | OBJECTS_INTERNAL_CLASSES_LAST OBJECTS_INTERNAL_THREADS |
| #define | OBJECTS_RTEMS_CLASSES_LAST OBJECTS_RTEMS_BARRIERS |
| #define | OBJECTS_POSIX_CLASSES_LAST OBJECTS_POSIX_SHMS |
| #define | _Objects_Maximum_nodes 1 |
| #define | OBJECTS_INDEX_MINIMUM 1U |
| #define | OBJECTS_NAME_ERRORS_FIRST OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL |
| #define | OBJECTS_NAME_ERRORS_LAST OBJECTS_INVALID_NODE |
Typedefs | |
| typedef uint32_t | Objects_Id |
| typedef uint16_t | Objects_Maximum |
| typedef struct Objects_Information | Objects_Information |
| typedef bool(* | Objects_Name_comparators) (void *, void *, uint16_t) |
Enumerations | |
| enum | Objects_APIs { OBJECTS_NO_API = 0 , OBJECTS_INTERNAL_API = 1 , OBJECTS_CLASSIC_API = 2 , OBJECTS_POSIX_API = 3 , OBJECTS_FAKE_OBJECTS_API = 7 } |
| enum | Objects_Internal_API { OBJECTS_INTERNAL_NO_CLASS = 0 , OBJECTS_INTERNAL_THREADS = 1 } |
| enum | Objects_Classic_API { OBJECTS_CLASSIC_NO_CLASS = 0 , OBJECTS_RTEMS_TASKS = 1 , OBJECTS_RTEMS_TIMERS , OBJECTS_RTEMS_SEMAPHORES , OBJECTS_RTEMS_MESSAGE_QUEUES , OBJECTS_RTEMS_PARTITIONS , OBJECTS_RTEMS_REGIONS , OBJECTS_RTEMS_PORTS , OBJECTS_RTEMS_PERIODS , OBJECTS_RTEMS_EXTENSIONS , OBJECTS_RTEMS_BARRIERS } |
| enum | Objects_POSIX_API { OBJECTS_POSIX_NO_CLASS = 0 , OBJECTS_POSIX_THREADS = 1 , OBJECTS_POSIX_KEYS , OBJECTS_POSIX_MESSAGE_QUEUES , OBJECTS_POSIX_SEMAPHORES , OBJECTS_POSIX_TIMERS , OBJECTS_POSIX_SHMS } |
| enum | Objects_Fake_objects_API { OBJECTS_FAKE_OBJECTS_NO_CLASS = 0 , OBJECTS_FAKE_OBJECTS_SCHEDULERS = 1 } |
| enum | Objects_Name_or_id_lookup_errors { OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL , OBJECTS_INVALID_NAME , OBJECTS_INVALID_ADDRESS , OBJECTS_INVALID_ID , OBJECTS_INVALID_NODE } |
| enum | Objects_Get_by_name_error { OBJECTS_GET_BY_NAME_INVALID_NAME , OBJECTS_GET_BY_NAME_NAME_TOO_LONG , OBJECTS_GET_BY_NAME_NO_OBJECT } |
| RTEMS_INLINE_ROUTINE Objects_APIs | _Objects_Get_API (Objects_Id id) |
| Returns the API portion of the ID. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | _Objects_Get_class (Objects_Id id) |
| Returns the class portion of the ID. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | _Objects_Get_node (Objects_Id id) |
| Returns the node portion of the ID. More... | |
| RTEMS_INLINE_ROUTINE Objects_Maximum | _Objects_Get_index (Objects_Id id) |
| Returns the index portion of the ID. More... | |
| Objects_Control * | _Objects_Allocate_none (Objects_Information *information) |
| Always return NULL. More... | |
| Objects_Control * | _Objects_Allocate_static (Objects_Information *information) |
| Return an inactive object or NULL. More... | |
| Objects_Control * | _Objects_Allocate_unlimited (Objects_Information *information) |
| void | _Objects_Free_static (Objects_Information *information, Objects_Control *the_object) |
| Free the object. More... | |
| void | _Objects_Free_unlimited (Objects_Information *information, Objects_Control *the_object) |
| Objects_Maximum | _Objects_Extend_information (Objects_Information *information) |
| Extends an object class information record. More... | |
| void | _Objects_Free_objects_block (Objects_Information *information, Objects_Maximum block) |
| Free the objects block with the specified index. More... | |
| void | _Objects_Shrink_information (Objects_Information *information) |
| Shrinks an object class information record. More... | |
| void | _Objects_Initialize_information (Objects_Information *information) |
| Initializes the specified objects information. More... | |
| unsigned int | _Objects_API_maximum_class (uint32_t api) |
| Returns highest numeric value of a valid API for the specified API. More... | |
| Objects_Control * | _Objects_Allocate (Objects_Information *information) |
| Allocates an object. More... | |
| Objects_Name_or_id_lookup_errors | _Objects_Name_to_id_u32 (Objects_Information *information, uint32_t name, uint32_t node, Objects_Id *id) |
| Converts an object name to an Id. More... | |
| Objects_Control * | _Objects_Get_by_name (const Objects_Information *information, const char *name, size_t *name_length_p, Objects_Get_by_name_error *error) |
| Gets an object control block identified by its name. More... | |
| Objects_Name_or_id_lookup_errors | _Objects_Id_to_name (Objects_Id id, Objects_Name *name) |
| Returns the name associated with object id. More... | |
| Objects_Control * | _Objects_Get (Objects_Id id, ISR_lock_Context *lock_context, const Objects_Information *information) |
| Maps the specified object identifier to the associated local object control block. More... | |
| Objects_Control * | _Objects_Get_no_protection (Objects_Id id, const Objects_Information *information) |
| Maps object ids to object control blocks. More... | |
| Objects_Control * | _Objects_Get_next (Objects_Id id, const Objects_Information *information, Objects_Id *next_id_p) |
| Gets the next open object after the specified object identifier. More... | |
| Objects_Information * | _Objects_Get_information (Objects_APIs the_api, uint16_t the_class) |
| Gets object information. More... | |
| Objects_Information * | _Objects_Get_information_id (Objects_Id id) |
| Gets information of an object from an ID. More... | |
| RTEMS_INLINE_ROUTINE bool | _Objects_Has_string_name (const Objects_Information *information) |
| Returns if the object has a string name. More... | |
| char * | _Objects_Get_name_as_string (Objects_Id id, size_t length, char *name) |
| Gets object name in the form of a C string. More... | |
| size_t | _Objects_Name_to_string (Objects_Name name, bool is_string, char *buffer, size_t buffer_size) |
| Converts the specified object name to a text representation. More... | |
| bool | _Objects_Set_name (const Objects_Information *information, Objects_Control *the_object, const char *name) |
| Sets objects name. More... | |
| RTEMS_INLINE_ROUTINE void | _Objects_Namespace_remove_u32 (const Objects_Information *information, Objects_Control *the_object) |
| Removes object with a 32-bit integer name from its namespace. More... | |
| void | _Objects_Namespace_remove_string (const Objects_Information *information, Objects_Control *the_object) |
| Removes object with a string name from its namespace. More... | |
| void | _Objects_Close (const Objects_Information *information, Objects_Control *the_object) |
| Closes object. More... | |
| Objects_Maximum | _Objects_Active_count (const Objects_Information *information) |
| Returns the count of active objects. More... | |
| RTEMS_INLINE_ROUTINE Objects_Maximum | _Objects_Extend_size (const Objects_Information *information) |
| Returns the object's objects per block. More... | |
| RTEMS_INLINE_ROUTINE bool | _Objects_Is_api_valid (uint32_t the_api) |
| Checks if the api is valid. More... | |
| RTEMS_INLINE_ROUTINE bool | _Objects_Is_local_node (uint32_t node) |
| Checks if the node is of the local object. More... | |
| RTEMS_INLINE_ROUTINE bool | _Objects_Is_local_id (Objects_Id id RTEMS_UNUSED) |
| Checks if the id is of a local object. More... | |
| RTEMS_INLINE_ROUTINE bool | _Objects_Are_ids_equal (Objects_Id left, Objects_Id right) |
| Checks if two object IDs are equal. More... | |
| RTEMS_INLINE_ROUTINE Objects_Id | _Objects_Get_minimum_id (Objects_Id id) |
| Returns the identifier with the minimum index for the specified identifier. More... | |
| RTEMS_INLINE_ROUTINE Objects_Maximum | _Objects_Get_maximum_index (const Objects_Information *information) |
| Returns the maximum index of the specified object class. More... | |
| RTEMS_INLINE_ROUTINE Objects_Control * | _Objects_Get_inactive (Objects_Information *information) |
| Get an inactive object or NULL. More... | |
| RTEMS_INLINE_ROUTINE Objects_Maximum | _Objects_Is_auto_extend (const Objects_Information *information) |
| Checks if the automatic object extension (unlimited objects) is enabled. More... | |
| RTEMS_INLINE_ROUTINE void | _Objects_Set_local_object (const Objects_Information *information, uint32_t index, Objects_Control *the_object) |
| Sets the pointer to the local_table object referenced by the index. More... | |
| RTEMS_INLINE_ROUTINE void | _Objects_Invalidate_Id (const Objects_Information *information, Objects_Control *the_object) |
| Invalidates an object Id. More... | |
| RTEMS_INLINE_ROUTINE void | _Objects_Open (Objects_Information *information, Objects_Control *the_object, Objects_Name name) |
| Places the_object control pointer and object name in the Local Pointer and Local Name Tables, respectively. More... | |
| RTEMS_INLINE_ROUTINE void | _Objects_Open_u32 (const Objects_Information *information, Objects_Control *the_object, uint32_t name) |
| RTEMS_INLINE_ROUTINE void | _Objects_Open_string (const Objects_Information *information, Objects_Control *the_object, const char *name) |
| RTEMS_INLINE_ROUTINE void | _Objects_Allocator_lock (void) |
| Locks the object allocator mutex. More... | |
| RTEMS_INLINE_ROUTINE void | _Objects_Allocator_unlock (void) |
| Unlocks the object allocator mutex. More... | |
| RTEMS_INLINE_ROUTINE bool | _Objects_Allocator_is_owner (void) |
| Checks if the allocator is the owner of the object allocator mutex. More... | |
| RTEMS_INLINE_ROUTINE Objects_Control * | _Objects_Allocate_unprotected (Objects_Information *information) |
| Allocates an object without locking the allocator mutex. More... | |
| RTEMS_INLINE_ROUTINE void | _Objects_Free (Objects_Information *information, Objects_Control *the_object) |
| Frees an object. More... | |
| RTEMS_INLINE_ROUTINE bool | _Objects_Is_in_allocated_block (Objects_Maximum index, Objects_Maximum objects_per_block) |
| Returns true, if the object associated with the zero-based index is contained in an allocated block of objects, otherwise false. More... | |
| RTEMS_INLINE_ROUTINE void | _Objects_Activate_unlimited (Objects_Information *information, Objects_Control *the_object) |
| Activate the object. More... | |
| RTEMS_INLINE_ROUTINE Objects_Control * | _Objects_Allocate_with_extend (Objects_Information *information, void(*extend)(Objects_Information *)) |
| Allocate an object and extend the objects information on demand. More... | |
| Objects_Information **const | _Objects_Information_table [OBJECTS_APIS_LAST+1] |
| #define _Objects_Build_id | ( | the_api, | |
| the_class, | |||
| node, | |||
| index | |||
| the_api | The object API. |
| the_class | The object API class. |
| node | The object node. |
| index | The object index. |
| #define _Objects_Build_name | ( | _C1, | |
| _C2, | |||
| _C3, | |||
| _C4 | |||
This macro is used to build a thirty-two bit style name from four characters. The most significant byte will be the character _C1.
| [in] | _C1 | is the first character of the name |
| [in] | _C2 | is the second character of the name |
| [in] | _C3 | is the third character of the name |
| [in] | _C4 | is the fourth character of the name |
| #define _Objects_Is_unlimited | ( | maximum | ) | ( ( ( maximum ) & OBJECTS_UNLIMITED_OBJECTS ) != 0 ) |
Returns if the object maximum specifies unlimited objects.
| [in] | maximum | The object maximum specification. |
| true | Unlimited objects are available. |
| false | The object count is fixed. |
| #define _Objects_Maximum_nodes 1 |
The following is referenced to the number of nodes in the system.
| #define OBJECTS_API_MASK (Objects_Id)0x07000000U |
This mask is used to extract the API portion of an object Id.
| #define OBJECTS_API_START_BIT 24U |
This is the bit position of the starting bit of the API portion of the object Id.
| #define OBJECTS_API_VALID_BITS (Objects_Id)0x00000007U |
This mask represents the bits that is used to ensure no extra bits are set after shifting to extract the API portion of an object Id.
| #define OBJECTS_APIS_LAST OBJECTS_POSIX_API |
This macro is used to generically specify the last API index.
| #define OBJECTS_CLASS_MASK (Objects_Id)0xf8000000U |
This mask is used to extract the class portion of an object Id.
| #define OBJECTS_CLASS_START_BIT 27U |
This is the bit position of the starting bit of the class portion of the object Id.
| #define OBJECTS_CLASS_VALID_BITS (Objects_Id)0x0000001fU |
This mask represents the bits that is used to ensure no extra bits are set after shifting to extract the class portion of an object Id.
| #define OBJECTS_ID_FINAL ((Objects_Id)~0) |
This macro specifies the highest object ID value
| #define OBJECTS_ID_FINAL_INDEX (0xffffU) |
This is the highest value for the index portion of an object Id.
| #define OBJECTS_ID_INITIAL | ( | _api, | |
| _class, | |||
| _node | |||
| ) | _Objects_Build_id( (_api), (_class), (_node), OBJECTS_ID_INITIAL_INDEX ) |
This macros calculates the lowest ID for the specified api, class, and node.
| #define OBJECTS_ID_INITIAL_INDEX (0) |
This is the lowest value for the index portion of an object Id.
| #define OBJECTS_ID_NONE 0 |
No object can have this ID.
| #define OBJECTS_ID_OF_SELF ((Objects_Id) 0) |
The following defines the constant which may be used to manipulate the calling task.
| #define OBJECTS_INDEX_MASK (Objects_Id)0x0000ffffU |
This mask is used to extract the index portion of an object Id.
| #define OBJECTS_INDEX_MINIMUM 1U |
This is the minimum object ID index associated with an object.
| #define OBJECTS_INDEX_START_BIT 0U |
This is the bit position of the starting bit of the index portion of the object Id.
| #define OBJECTS_INDEX_VALID_BITS (Objects_Id)0x0000ffffU |
This mask represents the bits that is used to ensure no extra bits are set after shifting to extract the index portion of an object Id.
| #define OBJECTS_INFORMATION_DEFINE | ( | name, | |
| api, | |||
| cls, | |||
| type, | |||
| max, | |||
| nl, | |||
| ex | |||
The initialized objects information references a table with statically allocated objects as specified by the object maximum parameter. These objects must be registered via a call to _Objects_Information().
| name | The object class C designator namespace prefix, e.g. _Semaphore. |
| api | The object API number, e.g. OBJECTS_CLASSIC_API. |
| cls | The object class number, e.g. OBJECTS_RTEMS_SEMAPHORES. |
| type | The object class type. |
| max | The configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set). |
| nl | The object name string length, use OBJECTS_NO_STRING_NAME for objects without a string name. |
| ex | The optional object extraction method. Used only if multiprocessing (RTEMS_MULTIPROCESSING) is enabled. |
| #define OBJECTS_INFORMATION_DEFINE_ZERO | ( | name, | |
| api, | |||
| cls, | |||
| nl | |||
The initialized objects information contains no objects.
| #define OBJECTS_INTERNAL_CLASSES_LAST OBJECTS_INTERNAL_THREADS |
| #define OBJECTS_NAME_ERRORS_FIRST OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL |
This macro defines the first entry in the Objects_Name_or_id_lookup_errors enumerated list.
| #define OBJECTS_NAME_ERRORS_LAST OBJECTS_INVALID_NODE |
This macro defines the last entry in the Objects_Name_or_id_lookup_errors enumerated list.
| #define OBJECTS_NODE_MASK (Objects_Id)0x00ff0000U |
This mask is used to extract the node portion of an object Id.
| #define OBJECTS_NODE_START_BIT 16U |
This is the bit position of the starting bit of the node portion of the object Id.
| #define OBJECTS_NODE_VALID_BITS (Objects_Id)0x000000ffU |
This mask represents the bits that is used to ensure no extra bits are set after shifting to extract the node portion of an object Id.
| #define OBJECTS_POSIX_CLASSES_LAST OBJECTS_POSIX_SHMS |
| #define OBJECTS_RTEMS_CLASSES_LAST OBJECTS_RTEMS_BARRIERS |
| #define OBJECTS_SEARCH_ALL_NODES 0 |
The following constant is used to specify that a name to ID search should search through all nodes.
| #define OBJECTS_SEARCH_LOCAL_NODE 0x7FFFFFFF |
The following constant is used to specify that a name to ID search should search only on this node.
| #define OBJECTS_SEARCH_OTHER_NODES 0x7FFFFFFE |
The following constant is used to specify that a name to ID search should search through all nodes except the current node.
| #define OBJECTS_UNLIMITED_OBJECTS 0x80000000U |
Mask to enable unlimited objects. This is used in the configuration table when specifying the number of configured objects.
| #define OBJECTS_WHO_AM_I 0 |
The following constant is used to specify that a name to ID search is being asked for the ID of the currently executing task.
| typedef uint32_t Objects_Id |
The following type defines the control block used to manage object IDs. The format is as follows (0=LSB):
Bits 0 .. 15 = index (up to 65535 objects of a type) Bits 16 .. 23 = node (up to 255 nodes) Bits 24 .. 26 = API (up to 7 API classes) Bits 27 .. 31 = class (up to 31 object types per API)
| typedef uint16_t Objects_Maximum |
This type is used to store the maximum number of allowed objects of each type.
| typedef bool(* Objects_Name_comparators) (void *, void *, uint16_t) |
Functions which compare names are prototyped like this.
| enum Objects_APIs |
This enumerated type is used in the class field of the object ID.
| enum Objects_Classic_API |
This enumerated type is used in the class field of the object ID for the RTEMS Classic API.
| enum Objects_Internal_API |
This enumerated type is used in the class field of the object ID for RTEMS internal object classes.
This function implements the common portion of the object identification directives. This directive returns the object id associated with name. If more than one object of this class is named name, then the object to which the id belongs is arbitrary. Node indicates the extent of the search for the id of the object named name. If the object class supports global objects, then the search can be limited to a particular node or allowed to encompass all nodes.
| enum Objects_POSIX_API |
This enumerated type is used in the class field of the object ID for the POSIX API.
| RTEMS_INLINE_ROUTINE void _Objects_Activate_unlimited | ( | Objects_Information * | information, |
| Objects_Control * | the_object | ||
This function must be only used in case this objects information supports unlimited objects.
| information | The object information block. |
| the_object | The object to activate. |
| Objects_Maximum _Objects_Active_count | ( | const Objects_Information * | information | ) |
| information | The object information table. |
| Objects_Control * _Objects_Allocate | ( | Objects_Information * | information | ) |
This function locks the object allocator mutex via _Objects_Allocator_lock(). The caller must later unlock the object allocator mutex via _Objects_Allocator_unlock(). The caller must unlock the mutex in any case, even if the allocation failed due to resource shortage.
A typical object allocation code looks like this:
| [in,out] | information | The object information block. |
| object | The allocated object. |
| NULL | No object available. |
| Objects_Control * _Objects_Allocate_none | ( | Objects_Information * | information | ) |
Always return NULL.
| information | The objects information. |
| NULL | Always. |
| Objects_Control * _Objects_Allocate_static | ( | Objects_Information * | information | ) |
| NULL | No inactive object is available. |
| object | An inactive object. |
| Objects_Control * _Objects_Allocate_unlimited | ( | Objects_Information * | information | ) |
Try to extend the objects information if necessary.
| RTEMS_INLINE_ROUTINE Objects_Control * _Objects_Allocate_unprotected | ( | Objects_Information * | information | ) |
This function can be called in two contexts
| RTEMS_INLINE_ROUTINE Objects_Control * _Objects_Allocate_with_extend | ( | Objects_Information * | information, |
| void(*)(Objects_Information *) | extend | ||
| extend | The object information extend handler. |
| RTEMS_INLINE_ROUTINE bool _Objects_Allocator_is_owner | ( | void | ) |
| true | The allocator is the owner of the object allocator mutex. |
| false | The allocato is not the owner of the object allocator mutex. |
| RTEMS_INLINE_ROUTINE void _Objects_Allocator_lock | ( | void | ) |
While holding the allocator mutex the executing thread is protected from asynchronous thread restart and deletion.
The usage of the object allocator mutex with the thread life protection makes it possible to allocate and free objects without thread dispatching disabled. The usage of a unified workspace and unlimited objects may lead to heap fragmentation. Thus the execution time of the _Objects_Allocate() function may increase during system run-time.
| RTEMS_INLINE_ROUTINE void _Objects_Allocator_unlock | ( | void | ) |
In case the mutex is fully unlocked, then this function restores the previous thread life protection state and thus may not return if the executing thread was restarted or deleted in the mean-time.
| unsigned int _Objects_API_maximum_class | ( | uint32_t | api | ) |
This function returns the highest numeric value of a valid API for the specified api.
| api | The API of interest. |
| some_value | Positive integer on success. |
| 0 | The method failed. |
| RTEMS_INLINE_ROUTINE bool _Objects_Are_ids_equal | ( | Objects_Id | left, |
| Objects_Id | right | ||
| left | The Id on the left hand side of the comparison. |
| right | The Id on the right hand side of the comparison. |
| true | The specified object IDs are equal. |
| false | The specified object IDs are not equal. |
| void _Objects_Close | ( | const Objects_Information * | information, |
Closes object.
This function removes the_object control pointer and object name in the Local Pointer and Local Name Tables.
| information | Points to an Object Information Table. | |
| [out] | the_object | A pointer to an object. |
| Objects_Maximum _Objects_Extend_information | ( | Objects_Information * | information | ) |
| information | Points to an object class information block. |
| 0 | The extend operation failed. |
| block | The block index of the new objects block. |
| RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Extend_size | ( | const Objects_Information * | information | ) |
| RTEMS_INLINE_ROUTINE void _Objects_Free | ( | Objects_Information * | information, |
Frees an object.
Appends the object to the chain of inactive objects.
| information | The object information block. | |
| [out] | the_object | The object to free. |
A typical object deletion code looks like this:
| void _Objects_Free_objects_block | ( | Objects_Information * | information, |
| Objects_Maximum | block | ||
| block | The block index. |
| void _Objects_Free_static | ( | Objects_Information * | information, |
Free the object.
Append the object to the inactive chain of the objects information.
| void _Objects_Free_unlimited | ( | Objects_Information * | information, |
Free the object.
Append the object to the inactive chain of the objects information and shrink the objects information if necessary.
| Objects_Control * _Objects_Get | ( | Objects_Id | id, |
| ISR_lock_Context * | lock_context, | ||
| const Objects_Information * | information | ||
In this function interrupts are disabled during the object lookup. In case an associated object exists, then interrupts remain disabled, otherwise the previous interrupt state is restored.
| id | The object identifier. This is the first parameter since usual callers get the object identifier as the first parameter themself. |
| lock_context | The interrupt lock context. This is the second parameter since usual callers get the interrupt lock context as the second parameter themself. |
| information | The object class information block. |
| pointer | The pointer to the associated object control block. Interrupts are now disabled and must be restored using the specified lock context via _ISR_lock_ISR_enable() or _ISR_lock_Release_and_ISR_enable(). |
| NULL | No associated object exists. |
| RTEMS_INLINE_ROUTINE Objects_APIs _Objects_Get_API | ( | Objects_Id | id | ) |
| id | The object Id to be processed. |
| Objects_Control * _Objects_Get_by_name | ( | const Objects_Information * | information, |
| const char * | name, | ||
| size_t * | name_length_p, | ||
| Objects_Get_by_name_error * | error | ||
The object information must use string names.
| information | The object information. Must not be NULL. | |
| name | The object name. | |
| [out] | name_length_p | Optional parameter to return the name length. |
| [out] | error | The error indication in case of failure. Must not be NULL. |
| pointer | The first object according to object index associated with this name. |
| NULL | No object exists for this name or invalid parameters. |
| RTEMS_INLINE_ROUTINE uint32_t _Objects_Get_class | ( | Objects_Id | id | ) |
| RTEMS_INLINE_ROUTINE Objects_Control * _Objects_Get_inactive | ( | Objects_Information * | information | ) |
| RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Get_index | ( | Objects_Id | id | ) |
| id | is the Id to be processed. |
| Objects_Information * _Objects_Get_information | ( | Objects_APIs | the_api, |
| uint16_t | the_class | ||
This function returns the information structure given an API and Class. This can be done independent of the existence of any objects created by the API.
| the_api | Indicates the API for the information we want |
| the_class | Indicates the Class for the information we want |
| pointer | Pointer to the Object Information Table for the class of objects which corresponds to this object ID. |
| NULL | An error occured. |
| Objects_Information * _Objects_Get_information_id | ( | Objects_Id | id | ) |
This function returns the information structure given an id of an object.
| id | The object ID to get the information from. |
| RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Get_maximum_index | ( | const Objects_Information * | information | ) |
| information | The object information. |
| RTEMS_INLINE_ROUTINE Objects_Id _Objects_Get_minimum_id | ( | Objects_Id | id | ) |
The specified identifier must have valid API, class and node fields.
| id | The identifier to be processed. |
| char * _Objects_Get_name_as_string | ( | Objects_Id | id, |
| size_t | length, | ||
| char * | name | ||
This method gets the name of an object and returns its name in the form of a C string. It attempts to be careful about overflowing the user's string and about returning unprintable characters.
| id | The object to obtain the name of. | |
| length | Indicates the length of the caller's buffer. | |
| [out] | name | A string which will be filled in. |
a name The operation was succeeded and the string was correctly filled in.
| Objects_Control * _Objects_Get_next | ( | Objects_Id | id, |
| const Objects_Information * | information, | ||
| Objects_Id * | next_id_p | ||
Locks the object allocator mutex in case a next object exists.
| id | The Id of the object whose name we are locating. This is the first parameter since usual callers get the object identifier as the first parameter themself. | |
| information | Points to an object class information block. | |
| [in,out] | next_id_p | The Id of the next object we will look at. |
| pointer | Pointer to the located object. |
| Objects_Control * _Objects_Get_no_protection | ( | Objects_Id | id, |
This function maps object ids to object control blocks. If id corresponds to a local object, then it returns the_object control pointer which maps to id and location is set to OBJECTS_LOCAL. If the object class supports global objects and the object id is global and resides on a remote node, then location is set to OBJECTS_REMOTE, and the_object is undefined. Otherwise, location is set to OBJECTS_ERROR and the_object is undefined.
| pointer | The local object corresponding to the given id. |
| NULL | The object to the given id was not found locally. |
| RTEMS_INLINE_ROUTINE uint32_t _Objects_Get_node | ( | Objects_Id | id | ) |
| RTEMS_INLINE_ROUTINE bool _Objects_Has_string_name | ( | const Objects_Information * | information | ) |
| true | The object has a string name. |
| false | The object does not have a string name. |
| Objects_Name_or_id_lookup_errors _Objects_Id_to_name | ( | Objects_Id | id, |
| Objects_Name * | name | ||
This function implements the common portion of the object Id to name directives. This function returns the name associated with object id.
| id | is the Id of the object whose name we are locating. | |
| [out] | name | will contain the name of the object, if found. |
| OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL | The operation succeeded. name contains the name of the object. |
| OBJECTS_INVALID_ID | The id is invalid, the operation failed. |
| void _Objects_Initialize_information | ( | Objects_Information * | information | ) |
The objects information must be statically pre-initialized with the OBJECTS_INFORMATION_DEFINE() macro before this function is called.
| information | The object information to be initialized. |
| RTEMS_INLINE_ROUTINE void _Objects_Invalidate_Id | ( | const Objects_Information * | information, |
This function sets the pointer to the local_table object referenced by the index to NULL so the object Id is invalid after this call.
| [in,out] | information | points to an Object Information Table. |
| the_object | The local object pointer. |
| RTEMS_INLINE_ROUTINE bool _Objects_Is_api_valid | ( | uint32_t | the_api | ) |
| the_api | is the api portion of an object ID. |
| true | The specified api value is valid. |
| false | The specified api value is not valid. |
| RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Is_auto_extend | ( | const Objects_Information * | information | ) |
| true | The automatic object extension (unlimited objects) is enabled. |
| false | The automatic object extension (unlimited objects) is not enabled. |
| RTEMS_INLINE_ROUTINE bool _Objects_Is_in_allocated_block | ( | Objects_Maximum | index, |
| Objects_Maximum | objects_per_block | ||
| index | is the zero-based object index. |
| objects_per_block | is the object count per block. |
| true | The object associated with the zero-based index is in an allocated block of objects. |
| false | Otherwise. |
| RTEMS_INLINE_ROUTINE bool _Objects_Is_local_id | ( | Objects_Id id | RTEMS_UNUSED | ) |
| id | The object ID. |
| true | The specified object Id is local. |
| false | The specified object Id is not local. |
| RTEMS_INLINE_ROUTINE bool _Objects_Is_local_node | ( | uint32_t | node | ) |
| node | The node number and corresponds to the node number portion of an object ID. |
| true | The specified node is the local node. |
| false | The specified node is not the local node. |
| Objects_Name_or_id_lookup_errors _Objects_Name_to_id_u32 | ( | Objects_Information * | information, |
| uint32_t | name, | ||
| uint32_t | node, | ||
| Objects_Id * | id | ||
This method converts an object name to an Id. It performs a look up using the object information block for this object class.
| information | points to an object class information block. | |
| name | is the name of the object to find. | |
| node | is the set of nodes to search. | |
| [out] | id | will contain the Id if the search is successful. |
| OBJECTS_NAME_OR_ID_LOOKUP_SUCCESSFUL | The operations was successful id contains the ID. |
| OBJECTS_INVALID_NAME | The name was invalid. |
| OBJECTS_INVALID_ID | The id is not 0 before the operation. |
| size_t _Objects_Name_to_string | ( | Objects_Name | name, |
| bool | is_string, | ||
| char * | buffer, | ||
| size_t | buffer_size | ||
Non-printable characters according to isprint() are converted to '*'.
| is_string | Indicates if the object name is a string or a four character array (32-bit unsigned integer). | |
| [out] | buffer | The string buffer for the text representation. |
| buffer_size | The buffer size in characters. |
| void _Objects_Namespace_remove_string | ( | const Objects_Information * | information, |
| information | The corresponding object information table. | |
| [out] | the_object | The object the object to operate upon. |
| RTEMS_INLINE_ROUTINE void _Objects_Namespace_remove_u32 | ( | const Objects_Information * | information, |
| [out] | the_object | The object to operate upon. |
| RTEMS_INLINE_ROUTINE void _Objects_Open | ( | Objects_Information * | information, |
| Objects_Control * | the_object, | ||
| Objects_Name | name | ||
This method uses Objects_Name for the object name.
| [in,out] | information | Points to an Object Information Table. |
| the_object | Pointer to an object. | |
| name | The name of the object to make accessible. |
| RTEMS_INLINE_ROUTINE void _Objects_Open_string | ( | const Objects_Information * | information, |
| const char * | name | ||
This method uses a String for the object name.
| RTEMS_INLINE_ROUTINE void _Objects_Open_u32 | ( | const Objects_Information * | information, |
| uint32_t | name | ||
This method uses uint32_t for the object name.
| RTEMS_INLINE_ROUTINE void _Objects_Set_local_object | ( | const Objects_Information * | information, |
| uint32_t | index, | ||
| index | The index of the object the caller wants to access. | |
| bool _Objects_Set_name | ( | const Objects_Information * | information, |
Sets objects name.
This method sets the object name to either a copy of a string or up to the first four characters of the string based upon whether this object class uses strings for names.
| information | points to the object information structure | |
| [out] | the_object | is the object to operate upon |
| name | is a pointer to the name to use |
| true | The operation succeeded. |
| false | The operation failed. |
| void _Objects_Shrink_information | ( | Objects_Information * | information | ) |
This function shrinks an object class information record. The object's name and object space are released. The local_table etc block does not shrink. The InActive list needs to be scanned to find the objects are remove them.
extern |
The following is the list of information blocks per API for each object class. From the ID, we can go to one of these information blocks, and obtain a pointer to the appropriate object control block.
