RTEMS 5.2
Data Structures | Macros | Typedefs | Enumerations | Functions
Constants and Structures Associated with the Object Handler. More...
#include <rtems/score/cpu.h>
union  Objects_Name
#define OBJECTS_INDEX_START_BIT   0U
#define OBJECTS_NODE_START_BIT   16U
#define OBJECTS_API_START_BIT   24U
#define OBJECTS_CLASS_START_BIT   27U
#define OBJECTS_INDEX_MASK   (Objects_Id)0x0000ffffU
#define OBJECTS_NODE_MASK   (Objects_Id)0x00ff0000U
#define OBJECTS_API_MASK   (Objects_Id)0x07000000U
#define OBJECTS_CLASS_MASK   (Objects_Id)0xf8000000U
#define OBJECTS_INDEX_VALID_BITS   (Objects_Id)0x0000ffffU
#define OBJECTS_NODE_VALID_BITS   (Objects_Id)0x000000ffU
#define OBJECTS_API_VALID_BITS   (Objects_Id)0x00000007U
#define OBJECTS_CLASS_VALID_BITS   (Objects_Id)0x0000001fU
#define OBJECTS_UNLIMITED_OBJECTS   0x80000000U
#define OBJECTS_ID_INITIAL_INDEX   (0)
#define OBJECTS_ID_FINAL_INDEX   (0xffffU)
#define OBJECTS_APIS_LAST   OBJECTS_POSIX_API
#define OBJECTS_ID_NONE   0
#define OBJECTS_ID_OF_SELF   ((Objects_Id) 0)
#define OBJECTS_SEARCH_ALL_NODES   0
#define OBJECTS_SEARCH_OTHER_NODES   0x7FFFFFFE
#define OBJECTS_SEARCH_LOCAL_NODE   0x7FFFFFFF
#define OBJECTS_WHO_AM_I   0
#define OBJECTS_ID_INITIAL(_api, _class, _node)    _Objects_Build_id( (_api), (_class), (_node), OBJECTS_ID_INITIAL_INDEX )
#define OBJECTS_ID_FINAL   ((Objects_Id)~0)
#define _Objects_Build_name(_C1, _C2, _C3, _C4)
#define _Objects_Build_id(the_api, the_class, node, index)
 Builds an object ID from its components. More...
#define _Objects_Is_unlimited(maximum)    ( ( ( maximum ) & OBJECTS_UNLIMITED_OBJECTS ) != 0 )
#define _Objects_Maximum_per_allocation(maximum)    ((Objects_Maximum) ((maximum) & ~OBJECTS_UNLIMITED_OBJECTS))
#define _Objects_Local_node   ((uint16_t) 1)
 The local MPCI node number.
typedef uint32_t Objects_Id
typedef uint16_t Objects_Maximum
enum  Objects_APIs {
  OBJECTS_NO_API = 0 , OBJECTS_INTERNAL_API = 1 , OBJECTS_CLASSIC_API = 2 , OBJECTS_POSIX_API = 3 ,
  OBJECTS_FAKE_OBJECTS_API = 7
RTEMS_INLINE_ROUTINE Objects_APIs _Objects_Get_API (Objects_Id id)
 Returns the API portion of the ID. More...
RTEMS_INLINE_ROUTINE uint32_t _Objects_Get_class (Objects_Id id)
 Returns the class portion of the ID. More...
RTEMS_INLINE_ROUTINE uint32_t _Objects_Get_node (Objects_Id id)
 Returns the node portion of the ID. More...
RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Get_index (Objects_Id id)
 Returns the index portion of the ID. More...
This include file contains all the constants and structures associated with the Object Handler. This Handler provides mechanisms which can be used to initialize and manipulate all objects which have ids.
