RTEMS 5.2
object.h
1
13/*
14 * COPYRIGHT (c) 1989-2011.
15 * On-Line Applications Research Corporation (OAR).
16 *
17 * The license and distribution terms for this file may be
18 * found in the file LICENSE in this distribution or at
19 * http://www.rtems.org/license/LICENSE.
20 */
21
22#ifndef _RTEMS_SCORE_OBJECT_H
23#define _RTEMS_SCORE_OBJECT_H
24
26#include <rtems/score/cpu.h>
27
28#ifdef __cplusplus
29extern "C" {
30#endif
31
64typedef union {
66 const char *name_p;
68 uint32_t name_u32;
70
80typedef uint32_t Objects_Id;
81
86typedef uint16_t Objects_Maximum;
87
92#define OBJECTS_INDEX_START_BIT 0U
97#define OBJECTS_NODE_START_BIT 16U
98
103#define OBJECTS_API_START_BIT 24U
104
109#define OBJECTS_CLASS_START_BIT 27U
110
114#define OBJECTS_INDEX_MASK (Objects_Id)0x0000ffffU
115
119#define OBJECTS_NODE_MASK (Objects_Id)0x00ff0000U
120
124#define OBJECTS_API_MASK (Objects_Id)0x07000000U
125
129#define OBJECTS_CLASS_MASK (Objects_Id)0xf8000000U
130
135#define OBJECTS_INDEX_VALID_BITS (Objects_Id)0x0000ffffU
136
141#define OBJECTS_NODE_VALID_BITS (Objects_Id)0x000000ffU
142
147#define OBJECTS_API_VALID_BITS (Objects_Id)0x00000007U
148
153#define OBJECTS_CLASS_VALID_BITS (Objects_Id)0x0000001fU
154
159#define OBJECTS_UNLIMITED_OBJECTS 0x80000000U
160
164#define OBJECTS_ID_INITIAL_INDEX (0)
165
169#define OBJECTS_ID_FINAL_INDEX (0xffffU)
170
174typedef enum {
175 OBJECTS_NO_API = 0,
176 OBJECTS_INTERNAL_API = 1,
177 OBJECTS_CLASSIC_API = 2,
178 OBJECTS_POSIX_API = 3,
179 OBJECTS_FAKE_OBJECTS_API = 7
181
183#define OBJECTS_APIS_LAST OBJECTS_POSIX_API
184
188#define OBJECTS_ID_NONE 0
189
194#define OBJECTS_ID_OF_SELF ((Objects_Id) 0)
195
200#define OBJECTS_SEARCH_ALL_NODES 0
201
206#define OBJECTS_SEARCH_OTHER_NODES 0x7FFFFFFE
207
212#define OBJECTS_SEARCH_LOCAL_NODE 0x7FFFFFFF
213
218#define OBJECTS_WHO_AM_I 0
219
224#define OBJECTS_ID_INITIAL(_api, _class, _node) \
225 _Objects_Build_id( (_api), (_class), (_node), OBJECTS_ID_INITIAL_INDEX )
226
230#define OBJECTS_ID_FINAL ((Objects_Id)~0)
231
242#define _Objects_Build_name( _C1, _C2, _C3, _C4 ) \
243 ( (uint32_t)(_C1) << 24 | \
244 (uint32_t)(_C2) << 16 | \
245 (uint32_t)(_C3) << 8 | \
246 (uint32_t)(_C4) )
247
256 Objects_Id id
257)
258{
260}
261
270 Objects_Id id
271)
272{
273 return (uint32_t)
275}
276
285 Objects_Id id
286)
287{
289}
290
299 Objects_Id id
300)
301{
302 return
305}
306
317#define _Objects_Build_id( the_api, the_class, node, index ) \
318 ( (Objects_Id) ( (Objects_Id) the_api << OBJECTS_API_START_BIT ) | \
319 ( (Objects_Id) the_class << OBJECTS_CLASS_START_BIT ) | \
320 ( (Objects_Id) node << OBJECTS_NODE_START_BIT ) | \
321 ( (Objects_Id) index << OBJECTS_INDEX_START_BIT ) )
322
331#define _Objects_Is_unlimited( maximum ) \
332 ( ( ( maximum ) & OBJECTS_UNLIMITED_OBJECTS ) != 0 )
333
334/*
335 * We cannot use an inline function for this since it may be evaluated at
336 * compile time.
337 */
338#define _Objects_Maximum_per_allocation( maximum ) \
339 ((Objects_Maximum) ((maximum) & ~OBJECTS_UNLIMITED_OBJECTS))
340
344#if defined(RTEMS_MULTIPROCESSING)
345extern uint16_t _Objects_Local_node;
346#else
347#define _Objects_Local_node ((uint16_t) 1)
348#endif
349
354#ifdef __cplusplus
355}
356#endif
357
358#endif
359/* end of include file */
Basic Definitions.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Get_index(Objects_Id id)
Returns the index portion of the ID.
Definition: object.h:298
RTEMS_INLINE_ROUTINE uint32_t _Objects_Get_node(Objects_Id id)
Returns the node portion of the ID.
Definition: object.h:284
Objects_APIs
Definition: object.h:174
Definition: object.h:97
RTEMS_INLINE_ROUTINE uint32_t _Objects_Get_class(Objects_Id id)
Returns the class portion of the ID.
Definition: object.h:269
uint32_t Objects_Id
Definition: object.h:80
Definition: object.h:147
Definition: object.h:153
Definition: object.h:92
Definition: object.h:103
RTEMS_INLINE_ROUTINE Objects_APIs _Objects_Get_API(Objects_Id id)
Returns the API portion of the ID.
Definition: object.h:255
Definition: object.h:135
Definition: object.h:86
Definition: object.h:109
Definition: object.h:141
The local MPCI node number.
Definition: object.h:347
Definition: object.h:64
const char * name_p
Definition: object.h:66
uint32_t name_u32
Definition: object.h:68
