RTEMS 5.2
Thread_Configuration Struct Reference
The configuration of a new thread to initialize. More...
#include <threadimpl.h>
const struct _Scheduler_Controlscheduler
 The scheduler control instance for the thread.
void * stack_area
 The starting address of the stack area.
size_t stack_size
 The size of the stack area in bytes.
void * allocated_stack
 The address of the allocated stack area or NULL.
Priority_Control priority
 The new thread's priority.
Thread_CPU_budget_algorithms budget_algorithm
 The thread's budget algorithm.
Thread_CPU_budget_algorithm_callout budget_callout
 The thread's initial budget callout.
Objects_Name name
 Name of the object for the thread.
uint32_t isr_level
 The thread's initial ISR level.
bool is_fp
 Indicates whether the thread needs a floating-point area.
bool is_preemptible
 Indicates whether the new thread is preemptible.
