RTEMS 5.2
Modules | Files | Macros | Typedefs | Functions | Variables
ISR Handler
ISR Handler. More...
 ISR Locks
 Low-level lock to protect critical sections accessed by threads and interrupt service routines.
file  isr.h
 Data Related to the Management of Processor Interrupt Levels.
file  isrlevel.h
 ISR Level Type.
file  isr.c
 Initialize the ISR handler.
file  isrisinprogress.c
 ISR Is In Progress Default Implementation.
#define _ISR_Install_vector(_vector, _new_handler, _old_handler)    _CPU_ISR_install_vector( _vector, _new_handler, _old_handler )
 Install interrupt handler vector. More...
#define _ISR_Local_disable(_level)
 Disables interrupts on this processor. More...
#define _ISR_Local_enable(_level)
 Enables interrupts on this processor. More...
#define _ISR_Local_flash(_level)
 Temporarily enables interrupts on this processor. More...
#define _ISR_Is_enabled(_level)    _CPU_ISR_Is_enabled( _level )
 Returns true if interrupts are enabled in the specified interrupt level, otherwise returns false. More...
#define _ISR_Get_level()    _CPU_ISR_Get_level()
 Return current interrupt level. More...
#define _ISR_Set_level(_new_level)
 Set current interrupt level. More...
typedef uint32_t ISR_Vector_number
typedef void ISR_Handler
typedef void * ISR_Handler_entry
typedef uint32_t ISR_Level
 RTEMS_DECLARE_GLOBAL_SYMBOL (_ISR_Stack_size)
 Global symbol with a value equal to the configure interrupt stack size. More...
void _ISR_Handler_initialization (void)
 Initializes the ISR handler. More...
void _ISR_Handler (void)
 ISR interrupt dispatcher. More...
bool _ISR_Is_in_progress (void)
 Checks if an ISR in progress. More...
char _ISR_Stack_area_begin []
 The interrupt stack area begin. More...
const char _ISR_Stack_area_end []
 The interrupt stack area end. More...
ISR Handler.
This handler encapsulates functionality which provides the foundation ISR services used in all of the APIs supported by RTEMS.
The ISR Nest level counter variable is maintained as part of the per cpu data structure.
◆ _ISR_Get_level
#define _ISR_Get_level ( )     _CPU_ISR_Get_level()
This routine returns the current interrupt level.
LM32 Specific Information: XXX document implementation including references if appropriate
Return values
Thismethod returns the current level.
◆ _ISR_Install_vector
#define _ISR_Install_vector (   _vector,
  _new_handler,
  _old_handler
This routine installs new_handler as the interrupt service routine for the specified vector. The previous interrupt service routine is returned as old_handler.
Parameters
[in]_vectoris the vector number
[in]_new_handleris ISR handler to install
[in]_old_handleris a pointer to a variable which will be set to the old handler
Return values
*_old_handlerwill be set to the old ISR handler
◆ _ISR_Is_enabled
#define _ISR_Is_enabled (   _level)     _CPU_ISR_Is_enabled( _level )
Parameters
[in]_levelThe ISR level.
Return values
trueInterrupts are enabled in the interrupt level.
falseOtherwise.
◆ _ISR_Local_disable
#define _ISR_Local_disable (   _level)
Value:
do { \
_CPU_ISR_Disable( _level ); \
RTEMS_COMPILER_MEMORY_BARRIER(); \
} while (0)
This macro disables all interrupts on this processor so that a critical section of code is protected from concurrent access by interrupts of this processor. Disabling of interrupts disables thread dispatching on the processor as well.
On SMP configurations other processors can enter such sections if not protected by other means.
Parameters
[out]_levelThe argument _level will contain the previous interrupt mask level.
◆ _ISR_Local_enable
#define _ISR_Local_enable (   _level)
Value:
do { \
_CPU_ISR_Enable( _level ); \
} while (0)
This macro restores the interrupt status on the processor with the interrupt level value obtained by _ISR_Local_disable(). It is used at the end of a critical section of code to enable interrupts so they can be processed again.
Parameters
[in]_levelThe interrupt level previously obtained by _ISR_Local_disable().
◆ _ISR_Local_flash
#define _ISR_Local_flash (   _level)
Value:
do { \
_CPU_ISR_Flash( _level ); \
} while (0)
This macro temporarily enables interrupts to the previous interrupt mask level and then disables all interrupts so that the caller can continue into the second part of a critical section.
This routine is used to temporarily enable interrupts during a long critical section. It is used in long sections of critical code when a point is reached at which interrupts can be temporarily enabled. Deciding where to flash interrupts in a long critical section is often difficult and the point must be selected with care to ensure that the critical section properly protects itself.
Parameters
◆ _ISR_Set_level
#define _ISR_Set_level (   _new_level)
Value:
do { \
_CPU_ISR_Set_level( _new_level ); \
} while (0)
This routine sets the current interrupt level to that specified by _new_level. The new interrupt level is effective when the routine exits.
Parameters
[in]_new_levelcontains the desired interrupt level.
Typedef Documentation
◆ ISR_Handler
Return type for ISR Handler
◆ ISR_Level
The following type defines the control block used to manage the interrupt level portion of the status register.
◆ ISR_Vector_number
The following type defines the type used to manage the vectors.
◆ _ISR_Handler()
void _ISR_Handler ( void  )
This routine is the interrupt dispatcher. ALL interrupts are vectored to this routine so that minimal context can be saved and setup performed before the application's high-level language interrupt service routine is invoked. After the application's interrupt service routine returns control to this routine, it will determine if a thread dispatch is necessary. If so, it will ensure that the necessary thread scheduling operations are performed when the outermost interrupt service routine exits.
Note
Typically implemented in assembly language.
◆ _ISR_Handler_initialization()
void _ISR_Handler_initialization ( void  )
This routine performs the initialization necessary for the ISR handler.
◆ _ISR_Is_in_progress()
bool _ISR_Is_in_progress ( void  )
This function returns true if the processor is currently servicing and interrupt and false otherwise. A return value of true indicates that the caller is an interrupt service routine, NOT a thread.
Return values
trueReturns true when called from an ISR.
falseReturns false when not called from an ISR.
◆ RTEMS_DECLARE_GLOBAL_SYMBOL()
RTEMS_DECLARE_GLOBAL_SYMBOL ( _ISR_Stack_size  )
This global symbol is defined by the application configuration option CONFIGURE_INIT_TASK_STACK_SIZE via <rtems/confdefs.h>.
Variable Documentation
◆ _ISR_Stack_area_begin
char _ISR_Stack_area_begin[]
extern
The interrupt stack area is defined by the application configuration via <rtems/confdefs.h>. The size of the area depends on CONFIGURE_INIT_TASK_STACK_SIZE and CONFIGURE_MAXIMUM_PROCESSORS.
◆ _ISR_Stack_area_end
const char _ISR_Stack_area_end[]
extern
