ARM Architecture Support.
More...
| file | cpu.c |
| | ARM architecture support implementation.
| file | cpu_asm.h |
| | ARM Assembler Support API.
#define | CPU_MODEL_NAME "ARMv4" |
#define | ARM_MULTILIB_ARCH_V4 |
#define | CPU_NAME "ARM" |
#define | CPU_SIMPLE_VECTORED_INTERRUPTS FALSE |
#define | CPU_ISR_PASSES_FRAME_POINTER FALSE |
#define | CPU_HARDWARE_FP FALSE |
#define | CPU_SOFTWARE_FP FALSE |
#define | CPU_ALL_TASKS_ARE_FP FALSE |
#define | CPU_IDLE_TASK_IS_FP FALSE |
#define | CPU_USE_DEFERRED_FP_SWITCH FALSE |
#define | CPU_ENABLE_ROBUST_THREAD_DISPATCH TRUE |
#define | CPU_STACK_GROWS_UP FALSE |
#define | CPU_CACHE_LINE_BYTES 32 |
#define | CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES ) |
#define | CPU_MODES_INTERRUPT_MASK 0x1 |
#define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
#define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
#define | CPU_STACK_MINIMUM_SIZE (1024 * 4) |
#define | CPU_SIZEOF_POINTER 4 |
#define | CPU_ALIGNMENT 8 |
#define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_STACK_ALIGNMENT 8 |
#define | CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES |
#define | CPU_USE_GENERIC_BITFIELD_CODE TRUE |
#define | CPU_MAXIMUM_PROCESSORS 32 |
#define | ARM_EXCEPTION_FRAME_SIZE 80 |
#define | ARM_EXCEPTION_FRAME_REGISTER_SP_OFFSET 52 |
#define | ARM_EXCEPTION_FRAME_VFP_CONTEXT_OFFSET 72 |
#define | ARM_VFP_CONTEXT_SIZE 264 |
| #define | _CPU_ISR_Disable(_isr_cookie) |
#define | _CPU_ISR_Enable(_isr_cookie) arm_interrupt_enable( _isr_cookie ) |
#define | _CPU_ISR_Flash(_isr_cookie) arm_interrupt_flash( _isr_cookie ) |
#define | _CPU_Context_Get_SP(_context) (_context)->register_sp |
#define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
| #define | _CPU_Context_Initialize_fp(_destination) |
| #define | _CPU_Fatal_halt(_source, _err) |
#define | CPU_PER_CPU_CONTROL_SIZE 0 |
typedef void(* | CPU_ISR_handler) (void) |
typedef uint32_t | CPU_Counter_ticks |
| typedef uintptr_t | CPU_Uint32ptr |
RTEMS_INLINE_ROUTINE bool | _CPU_ISR_Is_enabled (uint32_t level) |
| void | _CPU_ISR_Set_level (uint32_t level) |
| | Sets the hardware interrupt level by the level value. More...
uint32_t | _CPU_ISR_Get_level (void) |
void | _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area) |
| void | _CPU_Initialize (void) |
| | CPU initialization. More...
void | _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler) |
void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
| | CPU switch context.
void | _CPU_Context_restore (Context_Control *new_context) RTEMS_NO_RETURN |
uint32_t | _CPU_Counter_frequency (void) |
CPU_Counter_ticks | _CPU_Counter_read (void) |
void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
void | _ARM_Exception_default (CPU_Exception_frame *frame) |
void | _CPU_Context_volatile_clobber (uintptr_t pattern) |
void | _CPU_Context_validate (uintptr_t pattern) |
RTEMS_INLINE_ROUTINE void | _CPU_Instruction_illegal (void) |
RTEMS_INLINE_ROUTINE void | _CPU_Instruction_no_operation (void) |
◆ _CPU_Context_Initialize_fp
| #define _CPU_Context_Initialize_fp |
_destination | ) |
Value: do { \
} while (0)
Context_Control_fp _CPU_Null_fp_context
◆ _CPU_Fatal_halt
| #define _CPU_Fatal_halt |
_source, |
_err |
Value: do { \
uint32_t _level; \
uint32_t _error = _err; \
_CPU_ISR_Disable( _level ); \
(void) _level; \
__asm__ volatile ("mov r0, %0\n" \
: "=r" (_error) \
: "0" (_error) \
: "r0" ); \
while (1); \
} while (0);
◆ _CPU_ISR_Disable
| #define _CPU_ISR_Disable |
_isr_cookie | ) |
Value: do { \
_isr_cookie = arm_interrupt_disable(); \
} while (0)
◆ CPU_Uint32ptr
Type that can store a 32-bit integer or a pointer.
◆ _CPU_Initialize()
| void _CPU_Initialize |
void |
CPU initialization.
CPU initialization.
◆ _CPU_ISR_Set_level()
| void _CPU_ISR_Set_level |
uint32_t |
level | ) |
- Parameters
| [in] | level | for or1k can only range over two values: 0 (enable interrupts) and 1 (disable interrupts). In future implementations if fast context switch is implemented, the level can range from 0 to 15. |
- See also
- OpenRISC architecture manual.
