RTEMS 5.2
The set of registers that specifies the complete processor state. More...
#include <cpu.h>
uint32_t register_r0
uint32_t register_r1
uint32_t register_r2
uint32_t register_r3
uint32_t register_r4
uint32_t register_r5
uint32_t register_r6
uint32_t register_r7
uint32_t register_r8
uint32_t register_r9
uint32_t register_r10
uint32_t register_r11
uint32_t register_r12
uint32_t register_sp
void * register_lr
void * register_pc
const ARM_VFP_contextvfp_context
uint32_t reserved_for_stack_alignment
uint32_t r [62]
uint32_t status
uint32_t config
uint32_t iret
struct Context_Control_ssefp_ctxt
uint32_t edi
uint32_t esi
uint32_t ebp
uint32_t esp0
uint32_t ebx
uint32_t edx
uint32_t ecx
uint32_t eax
uint32_t idtIndex
uint32_t faultCode
uint32_t eip
uint32_t cs
uint32_t eflags
uint32_t vecnum
uint32_t sr
uint32_t pc
uint32_t d0
uint32_t d1
uint32_t d2
uint32_t d3
uint32_t d4
uint32_t d5
uint32_t d6
uint32_t d7
uint32_t a0
uint32_t a1
uint32_t a2
uint32_t a3
uint32_t a4
uint32_t a5
uint32_t a6
uint32_t a7
uint32_t integer_registers [16]
uint32_t r1
uint32_t r2
uint32_t r3
uint32_t r4
uint32_t r5
uint32_t r6
uint32_t r7
uint32_t r8
uint32_t r9
uint32_t r10
uint32_t r11
uint32_t r12
uint32_t r13
uint32_t r14
uint32_t r15
uint32_t r16
uint32_t r17
uint32_t r18
uint32_t r19
uint32_t r20
uint32_t r21
uint32_t r22
uint32_t r23
uint32_t gp
uint32_t fp
uint32_t sp
uint32_t ra
uint32_t et
uint32_t ea
uint32_t ienable
uint32_t ipending
uint32_t processor_state_register
double float_registers [1]
uint32_t epcr
uint32_t eear
uint32_t esr
uintptr_t EXC_SRR0
uintptr_t EXC_SRR1
uint32_t _EXC_number
uint32_t RESERVED_FOR_ALIGNMENT_0
uint32_t EXC_CR
uint32_t EXC_XER
uintptr_t EXC_CTR
uintptr_t EXC_LR
uintptr_t RESERVED_FOR_ALIGNMENT_1
PPC_GPR_TYPE GPR0
PPC_GPR_TYPE GPR1
PPC_GPR_TYPE GPR2
PPC_GPR_TYPE GPR3
PPC_GPR_TYPE GPR4
PPC_GPR_TYPE GPR5
PPC_GPR_TYPE GPR6
PPC_GPR_TYPE GPR7
PPC_GPR_TYPE GPR8
PPC_GPR_TYPE GPR9
PPC_GPR_TYPE GPR10
PPC_GPR_TYPE GPR11
PPC_GPR_TYPE GPR12
PPC_GPR_TYPE GPR13
PPC_GPR_TYPE GPR14
PPC_GPR_TYPE GPR15
PPC_GPR_TYPE GPR16
PPC_GPR_TYPE GPR17
PPC_GPR_TYPE GPR18
PPC_GPR_TYPE GPR19
PPC_GPR_TYPE GPR20
PPC_GPR_TYPE GPR21
PPC_GPR_TYPE GPR22
PPC_GPR_TYPE GPR23
PPC_GPR_TYPE GPR24
PPC_GPR_TYPE GPR25
PPC_GPR_TYPE GPR26
PPC_GPR_TYPE GPR27
PPC_GPR_TYPE GPR28
PPC_GPR_TYPE GPR29
PPC_GPR_TYPE GPR30
PPC_GPR_TYPE GPR31
uintptr_t RESERVED_FOR_ALIGNMENT_2
CPU_Interrupt_frame Interrupt_frame
uintptr_t mcause
uintptr_t sp
uintptr_t gp
uintptr_t tp
uintptr_t s2
uintptr_t s3
uintptr_t s4
uintptr_t s5
uintptr_t s6
uintptr_t s7
uintptr_t s8
uintptr_t s9
uintptr_t s10
uintptr_t s11
uint32_t trap
CPU_Interrupt_frameisf
The CPU exception frame may be available in fatal error conditions like for example illegal opcodes, instruction fetch errors, or data access errors.
See also
rtems_fatal(), RTEMS_FATAL_SOURCE_EXCEPTION, and rtems_exception_frame_print().
The documentation for this struct was generated from the following files:
