RTEMS 5.2
cpu.h
1
10/*
11 * COPYRIGHT (c) 1989-2011.
12 * On-Line Applications Research Corporation (OAR).
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 */
18
19#ifndef _RTEMS_SCORE_CPU_H
20#define _RTEMS_SCORE_CPU_H
21
22#ifndef ASM
23#include <string.h> /* for memcpy */
24#endif
25
26#ifdef __cplusplus
27extern "C" {
28#endif
29
31#if defined(RTEMS_PARAVIRT)
32#include <rtems/score/paravirt.h>
33#endif
34#include <rtems/score/i386.h>
35
45/* conditional compilation parameters */
46
47/*
48 * Does the CPU follow the simple vectored interrupt model?
49 *
50 * If TRUE, then RTEMS allocates the vector table it internally manages.
51 * If FALSE, then the BSP is assumed to allocate and manage the vector
52 * table
53 *
54 * PowerPC Specific Information:
55 *
56 * The PowerPC and x86 were the first to use the PIC interrupt model.
57 * They do not use the simple vectored interrupt model.
58 */
59#define CPU_SIMPLE_VECTORED_INTERRUPTS FALSE
60
61/*
62 * Does the RTEMS invoke the user's ISR with the vector number and
63 * a pointer to the saved interrupt frame (1) or just the vector
64 * number (0)?
65 */
66
67#define CPU_ISR_PASSES_FRAME_POINTER FALSE
68
69/*
70 * Some family members have no FP, some have an FPU such as the i387
71 * for the i386, others have it built in (i486DX, Pentium).
72 */
73
74#ifdef __SSE__
75#define CPU_HARDWARE_FP TRUE
76#define CPU_SOFTWARE_FP FALSE
77
78#define CPU_ALL_TASKS_ARE_FP TRUE
79#define CPU_IDLE_TASK_IS_FP TRUE
80#define CPU_USE_DEFERRED_FP_SWITCH FALSE
81#else /* __SSE__ */
82
83#if ( I386_HAS_FPU == 1 )
84#define CPU_HARDWARE_FP TRUE /* i387 for i386 */
85#else
86#define CPU_HARDWARE_FP FALSE
87#endif
88#define CPU_SOFTWARE_FP FALSE
89
90#define CPU_ALL_TASKS_ARE_FP FALSE
91#define CPU_IDLE_TASK_IS_FP FALSE
92#if defined(RTEMS_SMP)
93 #define CPU_USE_DEFERRED_FP_SWITCH FALSE
94#else
95 #define CPU_USE_DEFERRED_FP_SWITCH TRUE
96#endif
97#endif /* __SSE__ */
98
99#define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
100
101#define CPU_STACK_GROWS_UP FALSE
102
103/* FIXME: The Pentium 4 used 128 bytes, it this processor still relevant? */
104#define CPU_CACHE_LINE_BYTES 64
105
106#define CPU_STRUCTURE_ALIGNMENT
107
108#define CPU_MAXIMUM_PROCESSORS 32
109
110#define I386_CONTEXT_CONTROL_EFLAGS_OFFSET 0
111#define I386_CONTEXT_CONTROL_ESP_OFFSET 4
112#define I386_CONTEXT_CONTROL_EBP_OFFSET 8
113#define I386_CONTEXT_CONTROL_EBX_OFFSET 12
114#define I386_CONTEXT_CONTROL_ESI_OFFSET 16
115#define I386_CONTEXT_CONTROL_EDI_OFFSET 20
116#define I386_CONTEXT_CONTROL_GS_0_OFFSET 24
117#define I386_CONTEXT_CONTROL_GS_1_OFFSET 28
118#define I386_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE 32
119
120#ifdef RTEMS_SMP
121 #define I386_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 36
122#endif
123
124/* structures */
125
126#ifndef ASM
127
128/*
129 * Basic integer context for the i386 family.
130 */
131
132typedef struct {
133 uint32_t eflags; /* extended flags register */
134 void *esp; /* extended stack pointer register */
135 void *ebp; /* extended base pointer register */
136 uint32_t ebx; /* extended bx register */
137 uint32_t esi; /* extended source index register */
138 uint32_t edi; /* extended destination index flags register */
139 segment_descriptors gs; /* gs segment descriptor */
141#ifdef RTEMS_SMP
142 volatile bool is_executing;
143#endif
145
146#define _CPU_Context_Get_SP( _context ) \
147 (_context)->esp
148
149#ifdef RTEMS_SMP
150 static inline bool _CPU_Context_Get_is_executing(
152 )
153 {
154 return context->is_executing;
155 }
156
157 static inline void _CPU_Context_Set_is_executing(
159 bool is_executing
160 )
161 {
162 context->is_executing = is_executing;
163 }
164#endif
165
166/*
167 * FP context save area for the i387 numeric coprocessors.
168 */
169#ifdef __SSE__
170/* All FPU and SSE registers are volatile; hence, as long
171 * as we are within normally executing C code (including
172 * a task switch) there is no need for saving/restoring
173 * any of those registers.
174 * We must save/restore the full FPU/SSE context across
175 * interrupts and exceptions, however:
176 * - after ISR execution a _Thread_Dispatch() may happen
177 * and it is therefore necessary to save the FPU/SSE
178 * registers to be restored when control is returned
179 * to the interrupted task.
180 * - gcc may implicitly use FPU/SSE instructions in
181 * an ISR.
182 *
183 * Even though there is no explicit mentioning of the FPU
184 * control word in the SYSV ABI (i386) being non-volatile
185 * we maintain MXCSR and the FPU control-word for each task.
186 */
187typedef struct {
188 uint32_t mxcsr;
189 uint16_t fpucw;
191
192#else
193
194typedef struct {
195 uint8_t fp_save_area[108]; /* context size area for I80387 */
196 /* 28 bytes for environment */
198
199#endif
200
201
202/*
203 * The following structure defines the set of information saved
204 * on the current stack by RTEMS upon receipt of execptions.
205 *
206 * idtIndex is either the interrupt number or the trap/exception number.
207 * faultCode is the code pushed by the processor on some exceptions.
208 *
209 * Since the first registers are directly pushed by the CPU they
210 * may not respect 16-byte stack alignment, which is, however,
211 * mandatory for the SSE register area.
212 * Therefore, these registers are stored at an aligned address
213 * and a pointer is stored in the CPU_Exception_frame.
214 * If the executive was compiled without SSE support then
215 * this pointer is NULL.
216 */
217
219
220typedef struct {
221 struct Context_Control_sse *fp_ctxt;
222 uint32_t edi;
223 uint32_t esi;
224 uint32_t ebp;
225 uint32_t esp0;
226 uint32_t ebx;
227 uint32_t edx;
228 uint32_t ecx;
229 uint32_t eax;
230 uint32_t idtIndex;
231 uint32_t faultCode;
232 uint32_t eip;
233 uint32_t cs;
234 uint32_t eflags;
236
237#ifdef __SSE__
238typedef struct Context_Control_sse {
239 uint16_t fcw;
240 uint16_t fsw;
241 uint8_t ftw;
242 uint8_t res_1;
243 uint16_t fop;
244 uint32_t fpu_ip;
245 uint16_t cs;
246 uint16_t res_2;
247 uint32_t fpu_dp;
248 uint16_t ds;
249 uint16_t res_3;
250 uint32_t mxcsr;
251 uint32_t mxcsr_mask;
252 struct {
253 uint8_t fpreg[10];
254 uint8_t res_4[ 6];
255 } fp_mmregs[8];
256 uint8_t xmmregs[8][16];
257 uint8_t res_5[224];
259__attribute__((aligned(16)))
260;
261#endif
262
263typedef void (*cpuExcHandlerType) (CPU_Exception_frame*);
264extern cpuExcHandlerType _currentExcHandler;
265extern void rtems_exception_init_mngt(void);
266
267/*
268 * This port does not pass any frame info to the
269 * interrupt handler.
270 */
271
272typedef struct {
273/* allow for 16B alignment (worst case 12 Bytes more) and isr right after pushfl */
274 uint32_t reserved[3];
275/* registers saved by _ISR_Handler */
276 uint32_t isr_vector;
277 uint32_t ebx;
278 uint32_t ebp;
279 uint32_t esp;
280/* registers saved by rtems_irq_prologue_##_vector */
281 uint32_t edx;
282 uint32_t ecx;
283 uint32_t eax;
284/* registers saved by CPU */
285 uint32_t eip;
286 uint32_t cs;
287 uint32_t eflags;
289
290typedef enum {
291 I386_EXCEPTION_DIVIDE_BY_ZERO = 0,
292 I386_EXCEPTION_DEBUG = 1,
293 I386_EXCEPTION_NMI = 2,
294 I386_EXCEPTION_BREAKPOINT = 3,
295 I386_EXCEPTION_OVERFLOW = 4,
296 I386_EXCEPTION_BOUND = 5,
297 I386_EXCEPTION_ILLEGAL_INSTR = 6,
298 I386_EXCEPTION_MATH_COPROC_UNAVAIL = 7,
299 I386_EXCEPTION_DOUBLE_FAULT = 8,
300 I386_EXCEPTION_I386_COPROC_SEG_ERR = 9,
301 I386_EXCEPTION_INVALID_TSS = 10,
302 I386_EXCEPTION_SEGMENT_NOT_PRESENT = 11,
303 I386_EXCEPTION_STACK_SEGMENT_FAULT = 12,
304 I386_EXCEPTION_GENERAL_PROT_ERR = 13,
305 I386_EXCEPTION_PAGE_FAULT = 14,
306 I386_EXCEPTION_INTEL_RES15 = 15,
307 I386_EXCEPTION_FLOAT_ERROR = 16,
308 I386_EXCEPTION_ALIGN_CHECK = 17,
309 I386_EXCEPTION_MACHINE_CHECK = 18,
310 I386_EXCEPTION_ENTER_RDBG = 50 /* to enter manually RDBG */
311
312} Intel_symbolic_exception_name;
313
314
315/*
316 * context size area for floating point
317 *
318 * NOTE: This is out of place on the i386 to avoid a forward reference.
319 */
320
321#define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
322
323/* variables */
324
326
327#endif /* ASM */
328
329/* constants */
330
331/*
332 * This defines the number of levels and the mask used to pick those
333 * bits out of a thread mode.
334 */
335
336#define CPU_MODES_INTERRUPT_MASK 0x00000001 /* interrupt level in mode */
337
338/*
339 * extra stack required by the MPCI receive server thread
340 */
341
342#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 1024
343
344/*
345 * This is defined if the port has a special way to report the ISR nesting
346 * level. Most ports maintain the variable _ISR_Nest_level.
347 */
348
349#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
350
351/*
352 * Minimum size of a thread's stack.
353 */
354
355#define CPU_STACK_MINIMUM_SIZE 4096
356
357#define CPU_SIZEOF_POINTER 4
358
359/*
360 * i386 is pretty tolerant of alignment. Just put things on 4 byte boundaries.
361 */
362
363#define CPU_ALIGNMENT 4
364#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
365
366/*
367 * On i386 thread stacks require no further alignment after allocation
368 * from the Workspace. However, since gcc maintains 16-byte alignment
369 * we try to respect that. If you find an option to let gcc squeeze
370 * the stack more tightly then setting CPU_STACK_ALIGNMENT to 16 still
371 * doesn't waste much space since this only determines the *initial*
372 * alignment.
373 */
374
375#define CPU_STACK_ALIGNMENT 16
376
377#define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
378
379/* macros */
380
381#ifndef ASM
382/*
383 * ISR handler macros
384 *
385 * These macros perform the following functions:
386 * + initialize the RTEMS vector table
387 * + disable all maskable CPU interrupts
388 * + restore previous interrupt level (enable)
389 * + temporarily restore interrupts (flash)
390 * + set a particular level
391 */
392
393#if !defined(I386_DISABLE_INLINE_ISR_DISABLE_ENABLE)
394#define _CPU_ISR_Disable( _level ) i386_disable_interrupts( _level )
395
396#define _CPU_ISR_Enable( _level ) i386_enable_interrupts( _level )
397
398#define _CPU_ISR_Flash( _level ) i386_flash_interrupts( _level )
399
400#define _CPU_ISR_Set_level( _new_level ) \
401 { \
402 if ( _new_level ) __asm__ volatile ( "cli" ); \
403 else __asm__ volatile ( "sti" ); \
404 }
405#else
406#define _CPU_ISR_Disable( _level ) _level = i386_disable_interrupts()
407#define _CPU_ISR_Enable( _level ) i386_enable_interrupts( _level )
408#define _CPU_ISR_Flash( _level ) i386_flash_interrupts( _level )
409#define _CPU_ISR_Set_level( _new_level ) i386_set_interrupt_level(_new_level)
410#endif
411
412RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( uint32_t level )
413{
414 return ( level & EFLAGS_INTR_ENABLE ) != 0;
415}
416
417uint32_t _CPU_ISR_Get_level( void );
418
419/* Make sure interrupt stack has space for ISR
420 * 'vector' arg at the top and that it is aligned
421 * properly.
422 */
423
424#define _CPU_Interrupt_stack_setup( _lo, _hi ) \
425 do { \
426 _hi = (void*)(((uintptr_t)(_hi) - 4) & ~ (CPU_STACK_ALIGNMENT - 1)); \
427 } while (0)
428
429#endif /* ASM */
430
431/* end of ISR handler macros */
432
433/*
434 * Context handler macros
435 *
436 * These macros perform the following functions:
437 * + initialize a context area
438 * + restart the current thread
439 * + calculate the initial pointer into a FP context area
440 * + initialize an FP context area
441 */
442
443#define CPU_EFLAGS_INTERRUPTS_ON 0x00003202
444#define CPU_EFLAGS_INTERRUPTS_OFF 0x00003002
445
446#ifndef ASM
447
449 Context_Control *the_context,
450 void *stack_area_begin,
451 size_t stack_area_size,
452 uint32_t new_level,
453 void (*entry_point)( void ),
454 bool is_fp,
455 void *tls_area
456);
457
458#define _CPU_Context_Restart_self( _the_context ) \
459 _CPU_Context_restore( (_the_context) );
460
461#if defined(RTEMS_SMP)
462 uint32_t _CPU_SMP_Initialize( void );
463
464 bool _CPU_SMP_Start_processor( uint32_t cpu_index );
465
466 void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
467
468 void _CPU_SMP_Prepare_start_multitasking( void );
469
470 uint32_t _CPU_SMP_Get_current_processor( void );
471
472 void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
473
474 static inline void _CPU_SMP_Processor_event_broadcast( void )
475 {
476 __asm__ volatile ( "" : : : "memory" );
477 }
478
479 static inline void _CPU_SMP_Processor_event_receive( void )
480 {
481 __asm__ volatile ( "" : : : "memory" );
482 }
483#endif
484
485#define _CPU_Context_Initialize_fp( _fp_area ) \
486 { \
487 memcpy( *_fp_area, &_CPU_Null_fp_context, CPU_CONTEXT_FP_SIZE ); \
488 }
489
490/* end of Context handler macros */
491
492/*
493 * Fatal Error manager macros
494 *
495 * These macros perform the following functions:
496 * + disable interrupts and halt the CPU
497 */
498
499extern void _CPU_Fatal_halt(uint32_t source, uint32_t error)
501
502#endif /* ASM */
503
504/* end of Fatal Error manager macros */
505
506/*
507 * Bitfield handler macros
508 *
509 * These macros perform the following functions:
510 * + scan for the highest numbered (MSB) set in a 16 bit bitfield
511 */
512
513#define CPU_USE_GENERIC_BITFIELD_CODE FALSE
514
515#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
516 { \
517 uint16_t __value_in_register = ( _value ); \
518 uint16_t __output = 0; \
519 __asm__ volatile ( "bsfw %0,%1 " \
520 : "=r" ( __value_in_register ), "=r" ( __output ) \
521 : "0" ( __value_in_register ), "1" ( __output ) \
522 ); \
523 ( _output ) = __output; \
524 }
525
526/* end of Bitfield handler macros */
527
528/*
529 * Priority handler macros
530 *
531 * These macros perform the following functions:
532 * + return a mask with the bit for this major/minor portion of
533 * of thread priority set.
534 * + translate the bit number returned by "Bitfield_find_first_bit"
535 * into an index into the thread ready chain bit maps
536 */
537
538#define _CPU_Priority_Mask( _bit_number ) \
539 ( 1 << (_bit_number) )
540
541#define _CPU_Priority_bits_index( _priority ) \
542 (_priority)
543
544/* functions */
545
546#ifndef ASM
547/*
548 * _CPU_Initialize
549 *
550 * This routine performs CPU dependent initialization.
551 */
552
553void _CPU_Initialize(void);
554
555typedef void ( *CPU_ISR_handler )( void );
556
558 uint32_t vector,
559 CPU_ISR_handler new_handler,
560 CPU_ISR_handler *old_handler
561);
562
563void *_CPU_Thread_Idle_body( uintptr_t ignored );
564
565/*
566 * _CPU_Context_switch
567 *
568 * This routine switches from the run context to the heir context.
569 */
570
572 Context_Control *run,
573 Context_Control *heir
574);
575
576/*
577 * _CPU_Context_restore
578 *
579 * This routine is generally used only to restart self in an
580 * efficient manner and avoid stack conflicts.
581 */
582
584 Context_Control *new_context
586
587/*
588 * _CPU_Context_save_fp
589 *
590 * This routine saves the floating point context passed to it.
591 */
592
593#ifdef __SSE__
594#define _CPU_Context_save_fp(fp_context_pp) \
595 do { \
596 __asm__ __volatile__( \
597 "fstcw %0" \
598 :"=m"((*(fp_context_pp))->fpucw) \
599 ); \
600 __asm__ __volatile__( \
601 "stmxcsr %0" \
602 :"=m"((*(fp_context_pp))->mxcsr) \
603 ); \
604 } while (0)
605#else
607 Context_Control_fp **fp_context_ptr
608);
609#endif
610
611/*
612 * _CPU_Context_restore_fp
613 *
614 * This routine restores the floating point context passed to it.
615 */
616#ifdef __SSE__
617#define _CPU_Context_restore_fp(fp_context_pp) \
618 do { \
619 __asm__ __volatile__( \
620 "fldcw %0" \
621 ::"m"((*(fp_context_pp))->fpucw) \
622 :"fpcr" \
623 ); \
624 __builtin_ia32_ldmxcsr(_Thread_Executing->fp_context->mxcsr); \
625 } while (0)
626#else
628 Context_Control_fp **fp_context_ptr
629);
630#endif
631
632#ifdef __SSE__
633#define _CPU_Context_Initialization_at_thread_begin() \
634 do { \
635 __asm__ __volatile__( \
636 "finit" \
637 : \
638 : \
639 :"st","st(1)","st(2)","st(3)", \
640 "st(4)","st(5)","st(6)","st(7)", \
641 "fpsr","fpcr" \
642 ); \
643 if ( _Thread_Executing->fp_context ) { \
644 _CPU_Context_restore_fp(&_Thread_Executing->fp_context); \
645 } \
646 } while (0)
647#endif
648
650
651typedef uint32_t CPU_Counter_ticks;
652
653uint32_t _CPU_Counter_frequency( void );
654
655CPU_Counter_ticks _CPU_Counter_read( void );
656
657static inline CPU_Counter_ticks _CPU_Counter_difference(
658 CPU_Counter_ticks second,
659 CPU_Counter_ticks first
660)
661{
662 return second - first;
663}
664
668typedef uintptr_t CPU_Uint32ptr;
669
670#endif /* ASM */
671
672#ifdef __cplusplus
673}
674#endif
675
676#endif
Basic Definitions.
lpc176x_can_isr_vector isr_vector
Vector of isr for the can_driver .
Definition: can.c:37
unsigned short int uint16 __attribute__((__may_alias__))
Disable IRQ Interrupts.
Definition: mcf5282.h:37
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
CPU initialization.
Definition: cpu.c:45
Definition: cpu.h:662
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
SPARC specific RTEMS ISR installer.
Definition: cpu.h:493
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
void _CPU_Fatal_halt(uint32_t source, uint32_t error) RTEMS_NO_RETURN
Definition: bsp_fatal_halt.c:12
Intel I386 CPU Dependent Source.
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
Context_Control_fp _CPU_Null_fp_context
#define _CPU_Context_restore_fp(_fp_context_ptr)
Nothing to do due to the synchronous or lazy floating point switch.
Definition: cpu.h:904
#define _CPU_Context_save_fp(_fp_context_ptr)
Definition: cpu.h:898
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
Interrupt stack frame (ISF).
Definition: cpu.h:191
SPARC basic context.
Definition: cpu.h:194
Definition: sse_test.c:126
Thread register context.
uint32_t isr_dispatch_disable
Definition: cpu.h:140
unsigned context
Definition: tlb.h:1
