RTEMS 5.2
Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
cpu.h File Reference
Intel I386 CPU Dependent Source. More...
#include <rtems/score/i386.h>
struct  Context_Control
 Thread register context. More...
struct  Context_Control_fp
 SPARC basic context. More...
struct  CPU_Exception_frame
 The set of registers that specifies the complete processor state. More...
struct  CPU_Interrupt_frame
 Interrupt stack frame (ISF). More...
#define CPU_SIMPLE_VECTORED_INTERRUPTS   FALSE
#define CPU_ISR_PASSES_FRAME_POINTER   FALSE
#define CPU_HARDWARE_FP   FALSE
#define CPU_SOFTWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   FALSE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   TRUE
#define CPU_ENABLE_ROBUST_THREAD_DISPATCH   FALSE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_CACHE_LINE_BYTES   64
#define CPU_STRUCTURE_ALIGNMENT
#define CPU_MAXIMUM_PROCESSORS   32
#define I386_CONTEXT_CONTROL_EFLAGS_OFFSET   0
#define I386_CONTEXT_CONTROL_ESP_OFFSET   4
#define I386_CONTEXT_CONTROL_EBP_OFFSET   8
#define I386_CONTEXT_CONTROL_EBX_OFFSET   12
#define I386_CONTEXT_CONTROL_ESI_OFFSET   16
#define I386_CONTEXT_CONTROL_EDI_OFFSET   20
#define I386_CONTEXT_CONTROL_GS_0_OFFSET   24
#define I386_CONTEXT_CONTROL_GS_1_OFFSET   28
#define I386_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE   32
#define _CPU_Context_Get_SP(_context)    (_context)->esp
#define CPU_CONTEXT_FP_SIZE   sizeof( Context_Control_fp )
#define CPU_MODES_INTERRUPT_MASK   0x00000001 /* interrupt level in mode */
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   1024
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
#define CPU_STACK_MINIMUM_SIZE   4096
#define CPU_SIZEOF_POINTER   4
#define CPU_ALIGNMENT   4
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   16
#define CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES
#define _CPU_ISR_Disable(_level)   i386_disable_interrupts( _level )
#define _CPU_ISR_Enable(_level)   i386_enable_interrupts( _level )
#define _CPU_ISR_Flash(_level)   i386_flash_interrupts( _level )
#define _CPU_ISR_Set_level(_new_level)
#define _CPU_Interrupt_stack_setup(_lo, _hi)
#define CPU_EFLAGS_INTERRUPTS_ON   0x00003202
#define CPU_EFLAGS_INTERRUPTS_OFF   0x00003002
#define _CPU_Context_Restart_self(_the_context)    _CPU_Context_restore( (_the_context) );
#define _CPU_Context_Initialize_fp(_fp_area)
#define CPU_USE_GENERIC_BITFIELD_CODE   FALSE
#define _CPU_Bitfield_Find_first_bit(_value, _output)
#define _CPU_Priority_Mask(_bit_number)    ( 1 << (_bit_number) )
#define _CPU_Priority_bits_index(_priority)    (_priority)
typedef void(* cpuExcHandlerType) (CPU_Exception_frame *)
typedef void(* CPU_ISR_handler) (void)
typedef uint32_t CPU_Counter_ticks
typedef uintptr_t CPU_Uint32ptr
enum  Intel_symbolic_exception_name {
  I386_EXCEPTION_DIVIDE_BY_ZERO = 0 , I386_EXCEPTION_DEBUG = 1 , I386_EXCEPTION_NMI = 2 , I386_EXCEPTION_BREAKPOINT = 3 ,
  I386_EXCEPTION_OVERFLOW = 4 , I386_EXCEPTION_BOUND = 5 , I386_EXCEPTION_ILLEGAL_INSTR = 6 , I386_EXCEPTION_MATH_COPROC_UNAVAIL = 7 ,
  I386_EXCEPTION_DOUBLE_FAULT = 8 , I386_EXCEPTION_I386_COPROC_SEG_ERR = 9 , I386_EXCEPTION_INVALID_TSS = 10 , I386_EXCEPTION_SEGMENT_NOT_PRESENT = 11 ,
  I386_EXCEPTION_STACK_SEGMENT_FAULT = 12 , I386_EXCEPTION_GENERAL_PROT_ERR = 13 , I386_EXCEPTION_PAGE_FAULT = 14 , I386_EXCEPTION_INTEL_RES15 = 15 ,
  I386_EXCEPTION_FLOAT_ERROR = 16 , I386_EXCEPTION_ALIGN_CHECK = 17 , I386_EXCEPTION_MACHINE_CHECK = 18 , I386_EXCEPTION_ENTER_RDBG = 50
void rtems_exception_init_mngt (void)
RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled (uint32_t level)
uint32_t _CPU_ISR_Get_level (void)
void _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
 Initializes the CPU context. More...
void _CPU_Fatal_halt (uint32_t source, uint32_t error) RTEMS_NO_RETURN
void _CPU_Initialize (void)
 CPU initialization. More...
void _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
void * _CPU_Thread_Idle_body (uintptr_t ignored)
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context. More...
void _CPU_Context_restore (Context_Control *new_context) RTEMS_NO_RETURN
void _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr)
void _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr)
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
 Prints the exception frame via printk(). More...
uint32_t _CPU_Counter_frequency (void)
CPU_Counter_ticks _CPU_Counter_read (void)
cpuExcHandlerType _currentExcHandler
Context_Control_fp _CPU_Null_fp_context
This include file contains information pertaining to the Intel i386 processor.
Typedef Documentation
◆ CPU_Uint32ptr
Type that can store a 32-bit integer or a pointer.
