RTEMS 5.2
Typedefs | Functions | Variables
bspIo.h File Reference
Interface to Kernel Print Methods. More...
#include <stdarg.h>
typedef void(* BSP_output_char_function_type) (char c)
typedef int(* BSP_polling_getchar_function_type) (void)
int getchark (void)
 Get Character (kernel I/O) More...
int vprintk (const char *fmt, va_list ap)
 Variable Argument printk() More...
int rtems_printk_printer (void *ignored, const char *format, va_list ap)
int printk (const char *fmt,...) RTEMS_PRINTFLIKE(1
 Kernel Print. More...
int int putk (const char *s)
 Kernel Put String. More...
void rtems_putc (char c)
 Kernel Put Character. More...
void rtems_put_char (int c, void *arg)
 Puts the character via rtems_putc(). More...
BSP_output_char_function_type BSP_output_char
BSP_polling_getchar_function_type BSP_poll_char
This include file defines the interface to kernel print methods.
Typedef Documentation
◆ BSP_output_char_function_type
This type defines the prototype for the BSP provided method to print a single character. It is assumed to be polled.
◆ BSP_polling_getchar_function_type
This type defines the prototype for the BSP provided method to input a single character. It is assumed to be polled.
◆ getchark()
int getchark ( void  )
This method polls for a key in the simplest possible fashion from whatever the debug console device is.
Returns
If a character is available, it is returned. Otherwise this method returns -1.
Note
This method uses the BSP_poll_char pointer to a BSP provided method.
◆ printk()
int printk ( const char *  fmt,
Kernel Print.
This method allows the user to perform a debug printk(). It performs a character translation from "\n" to "\r\n".
Parameters
[in]fmtis a printf()-style format string
Returns
The number of characters output.
◆ putk()
int int putk ( const char *  s)
Kernel Put String.
This method allows the user to perform a debug puts().
Parameters
[in]sis the string to print
Returns
Kernel putk (e.g. puts) function requiring minimal infrastrure.
◆ rtems_put_char()
void rtems_put_char ( int  c,
void *  arg
This is a compatibility function to support an internal API.
Parameters
cThe character to put.
argIgnored.
◆ rtems_putc()
void rtems_putc ( char  c)
This method allows the user to perform a debug putc(). It performs a character translation from "\n" to "\r\n".
Parameters
[in]cis the character to print
◆ vprintk()
int vprintk ( const char *  fmt,
va_list  ap
This method allows the user to access printk() functionality with a va_list style argument.
Parameters
[in]apis a va_list pointer to arguments
Returns
Variable Documentation
◆ BSP_output_char
extern
This variable points to the BSP provided method to output a character for the purposes of debug output.
It must output only the specific character. It must not perform character translations, e.g. "\n" to "\r\n".
◆ BSP_poll_char
extern
This variable points to the BSP provided method to input a character for the purposes of debug input.
