RTEMS 5.2
Modules | |
| CMSIS Core Instruction Interface | |
Typedefs | |
| typedef unsigned short int uint16 | __attribute__((__may_alias__)) = 100 |
| Disable IRQ Interrupts. More... | |
| __attribute__ ((always_inline)) __STATIC_INLINE void __enable_irq(void) | |
| Enable IRQ Interrupts. More... | |
| typedef float __vf __attribute__((vector_size(16))) = 100 |
The 64-bit format record item.
Reverse bit order of value.
Rotate Right in unsigned value (32 bit)
Reverse byte order in signed short value.
Reverse byte order (16 bit)
Reverse byte order (32 bit)
Data Memory Barrier.
Data Synchronization Barrier.
Instruction Synchronization Barrier.
Send Event.
Wait For Event.
Wait For Interrupt.
No Operation.
Set Priority Mask.
Get Priority Mask.
Set Main Stack Pointer.
Get Main Stack Pointer.
Set Process Stack Pointer.
Get Process Stack Pointer.
Get xPSR Register.
Get APSR Register.
Get IPSR Register.
Set Control Register.
Get Control Register.
Disables IRQ interrupts by setting the I-bit in the CPSR. Can only be executed in Privileged modes.
Returns the content of the Control Register.
Writes the given value to the Control Register.
| [in] | control | Control Register value to set |
Returns the content of the IPSR Register.
Returns the content of the APSR Register.
Returns the content of the xPSR Register.
Returns the current value of the Process Stack Pointer (PSP).
Assigns the given value to the Process Stack Pointer (PSP).
| [in] | topOfProcStack | Process Stack Pointer value to set |
Returns the current value of the Main Stack Pointer (MSP).
Assigns the given value to the Main Stack Pointer (MSP).
| [in] | topOfMainStack | Main Stack Pointer value to set |
Returns the current state of the priority mask bit from the Priority Mask Register.
Assigns the given value to the Priority Mask Register.
| [in] | priMask | Priority Mask |
No Operation does nothing. This instruction can be used for code alignment purposes.
Wait For Interrupt is a hint instruction that suspends execution until one of a number of events occurs.
Wait For Event is a hint instruction that permits the processor to enter a low-power state until one of a number of events occurs.
Send Event is a hint instruction. It causes an event to be signaled to the CPU.
Instruction Synchronization Barrier flushes the pipeline in the processor, so that all instructions following the ISB are fetched from cache or memory, after the instruction has been completed.
Acts as a special kind of Data Memory Barrier. It completes when all explicit memory accesses before this instruction complete.
Ensures the apparent order of the explicit memory operations before and after the instruction, without ensuring their completion.
Reverses the byte order in integer value.
| [in] | value | Value to reverse |
Reverses the byte order in two unsigned short values.
Reverses the byte order in a signed short value with sign extension to integer.
Rotate Right (immediate) provides the value of the contents of a register rotated by a variable number of bits.
| [in] | value | Value to rotate |
| [in] | value | Number of Bits to rotate |
Reverses the bit order of the given value.
| __attribute__ | ( | (always_inline) | ) |
Send Event.
Wait For Event.
Wait For Interrupt.
No Operation.
Set Priority Mask.
Get Priority Mask.
Get xPSR Register.
Get APSR Register.
Get IPSR Register.
Enables IRQ interrupts by clearing the I-bit in the CPSR. Can only be executed in Privileged modes.
