RTEMS 5.2
Modules | Macros | Variables
 CMSIS SIMD Intrinsics
#define __CMSIS_GCC_OUT_REG(r)   "=r" (r)
#define __CMSIS_GCC_USE_REG(r)   "r" (r)
#define __BKPT(value)   __ASM volatile ("bkpt "#value)
 Breakpoint. More...
#define __CLZ   __builtin_clz
 Count leading zeros. More...
uint32_t op2
Access to dedicated instructions
◆ __BKPT
#define __BKPT (   value)    __ASM volatile ("bkpt "#value)
Breakpoint.
Causes the processor to enter Debug state. Debug tools can use this to investigate system state when the instruction at a particular address is reached.
Parameters
[in]valueis ignored by the processor. If required, a debugger can use it to store additional information about the breakpoint.
◆ __CLZ
Counts the number of leading zeros of a data value.
Parameters
[in]valueValue to count the leading zeros
Returns
number of leading zeros in value
Variable Documentation
◆ op2
uint32_t op2
Initial value:
return (op1 >> op2) | (op1 << (32U - op2))
