RTEMS 5.2
Macros for use with bit field definitions (xxx_Pos, xxx_Msk). More...
 Core Definitions
 Definitions for base addresses, unions, and structures.
#define _VAL2FLD(field, value)   ((value << field ## _Pos) & field ## _Msk)
 Mask and shift a bit field value for use in a register bit range. More...
#define _FLD2VAL(field, value)   ((value & field ## _Msk) >> field ## _Pos)
 Mask and shift a register value to extract a bit filed value. More...
◆ _FLD2VAL
#define _FLD2VAL (   field,
  value
Parameters
[in]fieldName of the register bit field.
[in]valueValue of register.
Returns
Masked and shifted bit field value.
◆ _VAL2FLD
#define _VAL2FLD (   field,
  value
Parameters
[in]valueValue of the bit field.
Returns
Masked and shifted value.
