RTEMS 5.2
cpu.h
1
9/*
10 * Copyright (c) 2018.
11 * Amaan Cheval <amaan.cheval@gmail.com>
12 *
13 * Redistribution and use in source and binary forms, with or without
14 * modification, are permitted provided that the following conditions
15 * are met:
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 * 2. Redistributions in binary form must reproduce the above copyright
19 * notice, this list of conditions and the following disclaimer in the
20 * documentation and/or other materials provided with the distribution.
21 *
22 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
23 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
24 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
25 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
26 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
27 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
28 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
29 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
30 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
31 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
32 * SUCH DAMAGE.
33 */
34
35#ifndef _RTEMS_SCORE_CPU_H
36#define _RTEMS_SCORE_CPU_H
37
38#ifdef __cplusplus
39extern "C" {
40#endif
41
43#include <rtems/score/cpu_asm.h>
44#include <rtems/score/x86_64.h>
45
46#define CPU_SIMPLE_VECTORED_INTERRUPTS FALSE
47#define CPU_ISR_PASSES_FRAME_POINTER FALSE
48#define CPU_HARDWARE_FP FALSE
49#define CPU_SOFTWARE_FP FALSE
50#define CPU_ALL_TASKS_ARE_FP FALSE
51#define CPU_IDLE_TASK_IS_FP FALSE
52#define CPU_USE_DEFERRED_FP_SWITCH FALSE
53#define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
54#define CPU_STACK_GROWS_UP FALSE
55
56#define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED(64)
57#define CPU_CACHE_LINE_BYTES 64
58#define CPU_MODES_INTERRUPT_MASK 0x00000001
59#define CPU_MAXIMUM_PROCESSORS 32
60
61#define CPU_EFLAGS_INTERRUPTS_ON 0x00003202
62#define CPU_EFLAGS_INTERRUPTS_OFF 0x00003002
63
64#ifndef ASM
65
66typedef struct {
67 uint64_t rflags;
68
73 uint64_t rbx;
74 void *rsp;
75 void *rbp;
76 uint64_t r12;
77 uint64_t r13;
78 uint64_t r14;
79 uint64_t r15;
80
81 // XXX: FS segment descriptor for TLS
82
83#ifdef RTEMS_SMP
84 volatile bool is_executing;
85#endif
87
88#define _CPU_Context_Get_SP( _context ) \
89 (_context)->rsp
90
91/*
92 * Caller-saved registers for interrupt frames
93 */
94typedef struct {
103 uint64_t rax;
104 uint64_t rcx;
105 uint64_t rdx;
106 uint64_t rsi;
107 uint64_t r8;
108 uint64_t r9;
109 uint64_t r10;
110 uint64_t r11;
111
112 /*
113 * This holds the rsp just before _ISR_Handler is called; it's needed because
114 * in the handler, we align the stack to make further calls, and we're not
115 * sure how alignment may move the stack-pointer around, leaving no way to get
116 * back to the stack, and therefore the interrupt frame.
117 */
118 uint64_t saved_rsp;
119
120 /* XXX:
121 * - FS segment selector for TLS
122 * - x87 status word?
123 * - MMX?
124 * - XMM?
125 */
127
128#endif /* !ASM */
129
130#define CPU_INTERRUPT_FRAME_SIZE 72
131
132/*
133 * When SMP is enabled, percpuasm.c has a similar assert, but since we use the
134 * interrupt frame regardless of SMP, we'll confirm it here.
135 */
136#ifndef ASM
137 RTEMS_STATIC_ASSERT(
140 );
141#endif
142
143#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
144#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
145#define CPU_STACK_MINIMUM_SIZE (1024*4)
146#define CPU_SIZEOF_POINTER 8
147#define CPU_ALIGNMENT 8
148#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
149#define CPU_STACK_ALIGNMENT 16
150#define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
151
152/*
153 * ISR handler macros
154 */
155
156#ifndef ASM
157
158#define _CPU_Initialize_vectors()
159
160#define _CPU_ISR_Enable(_level) \
161{ \
162 amd64_enable_interrupts(); \
163 _level = 0; \
164 (void) _level; /* Prevent -Wunused-but-set-variable */ \
165}
166
167#define _CPU_ISR_Disable(_level) \
168{ \
169 amd64_enable_interrupts(); \
170 _level = 1; \
171 (void) _level; /* Prevent -Wunused-but-set-variable */ \
172}
173
174#define _CPU_ISR_Flash(_level) \
175{ \
176 amd64_enable_interrupts(); \
177 amd64_disable_interrupts(); \
178 _level = 1; \
179 (void) _level; /* Prevent -Wunused-but-set-variable */ \
180}
181
183{
184 return (level & EFLAGS_INTR_ENABLE) != 0;
185}
186
188{
189 if ( new_level ) {
190 amd64_disable_interrupts();
191 }
192 else {
193 amd64_enable_interrupts();
194 }
195}
196
198{
199 uint64_t rflags;
200
201 __asm__ volatile ( "pushf; \
202 popq %0"
203 : "=rm" (rflags)
204 );
205
206 uint32_t level = (rflags & EFLAGS_INTR_ENABLE) ? 0 : 1;
207 return level;
208}
209
210/* end of ISR handler macros */
211
212/* Context handler macros */
213#define _CPU_Context_Destroy( _the_thread, _the_context ) \
214 { \
215 }
216
218 Context_Control *the_context,
219 void *stack_area_begin,
220 size_t stack_area_size,
221 uint32_t new_level,
222 void (*entry_point)( void ),
223 bool is_fp,
224 void *tls_area
225);
226
227#define _CPU_Context_Restart_self( _the_context ) \
228 _CPU_Context_restore( (_the_context) );
229
230#define _CPU_Context_Initialize_fp( _destination ) \
231 { \
232 *(*(_destination)) = _CPU_Null_fp_context; \
233 }
234
235/* end of Context handler macros */
236
237/* Fatal Error manager macros */
238
239#define _CPU_Fatal_halt( _source, _error ) \
240 { \
241 }
242
243/* end of Fatal Error manager macros */
244
245/* Bitfield handler macros */
246
247#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
248
249#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
250#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
251 { \
252 (_output) = 0; /* do something to prevent warnings */ \
253 }
254#endif
255
256/* end of Bitfield handler macros */
257
258#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
259#define _CPU_Priority_Mask( _bit_number ) \
260 ( 1 << (_bit_number) )
261#endif
262
263#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
264#define _CPU_Priority_bits_index( _priority ) \
265 (_priority)
266#endif
267
268/* end of Priority handler macros */
269
270/* functions */
271
272void _CPU_Initialize(void);
273
274void *_CPU_Thread_Idle_body( uintptr_t ignored );
275
277 Context_Control *run,
278 Context_Control *heir
279);
280
282 Context_Control *new_context
284
285typedef struct {
286 uint32_t processor_state_register;
287 uint32_t integer_registers [1];
288 double float_registers [1];
290
292
293static inline uint32_t CPU_swap_u32(
294 uint32_t value
295)
296{
297 uint32_t byte1, byte2, byte3, byte4, swapped;
298
299 byte4 = (value >> 24) & 0xff;
300 byte3 = (value >> 16) & 0xff;
301 byte2 = (value >> 8) & 0xff;
302 byte1 = value & 0xff;
303
304 swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
305 return swapped;
306}
307
308#define CPU_swap_u16( value ) \
309 (((value&0xff) << 8) | ((value >> 8)&0xff))
310
311typedef uint32_t CPU_Counter_ticks;
312
313uint32_t _CPU_Counter_frequency( void );
314
315CPU_Counter_ticks _CPU_Counter_read( void );
316
317
318static inline CPU_Counter_ticks _CPU_Counter_difference(
319 CPU_Counter_ticks second,
320 CPU_Counter_ticks first
321)
322{
323 return second - first;
324}
325
326#ifdef RTEMS_SMP
327 *
328 uint32_t _CPU_SMP_Initialize( void );
329
330 bool _CPU_SMP_Start_processor( uint32_t cpu_index );
331
332 void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
333
334 void _CPU_SMP_Prepare_start_multitasking( void );
335
336 static inline uint32_t _CPU_SMP_Get_current_processor( void )
337 {
338 return 123;
339 }
340
341 void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
342
343 static inline void _CPU_SMP_Processor_event_broadcast( void )
344 {
345 __asm__ volatile ( "" : : : "memory" );
346 }
347
348 static inline void _CPU_SMP_Processor_event_receive( void )
349 {
350 __asm__ volatile ( "" : : : "memory" );
351 }
352
353 static inline bool _CPU_Context_Get_is_executing(
355 )
356 return context->is_executing;
357 }
358
359 static inline void _CPU_Context_Set_is_executing(
361 bool is_executing
362 )
363 {
364 }
365
366#endif /* RTEMS_SMP */
367
368typedef uintptr_t CPU_Uint32ptr;
369
370#ifdef __cplusplus
371}
372#endif
373
374#endif /* ASM */
375
376#endif /* _RTEMS_SCORE_CPU_H */
Basic Definitions.
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
void _CPU_ISR_Set_level(uint32_t level)
Sets the hardware interrupt level by the level value.
Definition: cpu.c:57
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
CPU initialization.
Definition: cpu.c:45
Definition: cpu.h:662
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
Definition: cpuimpl.h:78
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
Interrupt stack frame (ISF).
Definition: cpu.h:191
uint64_t rax
Definition: cpu.h:103
Thread register context.
Definition: cpu.h:194
uint64_t rbx
Definition: cpu.h:73
unsigned context
Definition: tlb.h:1
