RTEMS 5.2
x86_64 Dependent Source More...
| struct | Context_Control |
| Thread register context. More... | |
| struct | CPU_Interrupt_frame |
| Interrupt stack frame (ISF). More... | |
| struct | CPU_Exception_frame |
| The set of registers that specifies the complete processor state. More... | |
| #define | CPU_SIMPLE_VECTORED_INTERRUPTS FALSE |
| #define | CPU_ISR_PASSES_FRAME_POINTER FALSE |
| #define | CPU_HARDWARE_FP FALSE |
| #define | CPU_SOFTWARE_FP FALSE |
| #define | CPU_ALL_TASKS_ARE_FP FALSE |
| #define | CPU_IDLE_TASK_IS_FP FALSE |
| #define | CPU_USE_DEFERRED_FP_SWITCH FALSE |
| #define | CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE |
| #define | CPU_STACK_GROWS_UP FALSE |
| #define | CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED(64) |
| #define | CPU_CACHE_LINE_BYTES 64 |
| #define | CPU_MODES_INTERRUPT_MASK 0x00000001 |
| #define | CPU_MAXIMUM_PROCESSORS 32 |
| #define | CPU_EFLAGS_INTERRUPTS_ON 0x00003202 |
| #define | CPU_EFLAGS_INTERRUPTS_OFF 0x00003002 |
| #define | _CPU_Context_Get_SP(_context) (_context)->rsp |
| #define | CPU_INTERRUPT_FRAME_SIZE 72 |
| #define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
| #define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
| #define | CPU_STACK_MINIMUM_SIZE (1024*4) |
| #define | CPU_SIZEOF_POINTER 8 |
| #define | CPU_ALIGNMENT 8 |
| #define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
| #define | CPU_STACK_ALIGNMENT 16 |
| #define | CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES |
| #define | _CPU_Initialize_vectors() |
| #define | _CPU_ISR_Enable(_level) |
| #define | _CPU_ISR_Disable(_level) |
| #define | _CPU_ISR_Flash(_level) |
| #define | _CPU_Context_Destroy(_the_thread, _the_context) |
| #define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
| #define | _CPU_Context_Initialize_fp(_destination) |
| #define | _CPU_Fatal_halt(_source, _error) |
| #define | CPU_USE_GENERIC_BITFIELD_CODE TRUE |
| #define | _CPU_Bitfield_Find_first_bit(_value, _output) |
| #define | _CPU_Priority_Mask(_bit_number) ( 1 << (_bit_number) ) |
| #define | _CPU_Priority_bits_index(_priority) (_priority) |
| #define | CPU_swap_u16(value) (((value&0xff) << 8) | ((value >> 8)&0xff)) |
Typedefs | |
| typedef uint32_t | CPU_Counter_ticks |
| typedef uintptr_t | CPU_Uint32ptr |
| RTEMS_STATIC_ASSERT (sizeof(CPU_Interrupt_frame)==CPU_INTERRUPT_FRAME_SIZE, CPU_INTERRUPT_FRAME_SIZE) | |
| RTEMS_INLINE_ROUTINE bool | _CPU_ISR_Is_enabled (uint32_t level) |
| Returns true if interrupts are enabled in the specified ISR level, otherwise returns false. More... | |
| RTEMS_INLINE_ROUTINE void | _CPU_ISR_Set_level (uint32_t new_level) |
| Sets the hardware interrupt level by the level value. More... | |
| RTEMS_INLINE_ROUTINE uint32_t | _CPU_ISR_Get_level (void) |
| Returns the interrupt level of the executing thread. More... | |
| void | _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area) |
| Initializes the CPU context. More... | |
| void | _CPU_Initialize (void) |
| CPU initialization. More... | |
| void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
| void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
| CPU switch context. More... | |
| void | _CPU_Context_restore (Context_Control *new_context) RTEMS_NO_RETURN |
| SPARC specific context restore. More... | |
| void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
| Prints the exception frame via printk(). More... | |
| uint32_t | _CPU_Counter_frequency (void) |
| Returns the current CPU counter frequency in Hz. More... | |
| CPU_Counter_ticks | _CPU_Counter_read (void) |
| Returns the current CPU counter value. More... | |
This include file contains information pertaining to the x86_64 processor.
| #define _CPU_Bitfield_Find_first_bit | ( | _value, | |
| _output | |||
| #define _CPU_Context_Destroy | ( | _the_thread, | |
| _the_context | |||
| #define _CPU_Context_Initialize_fp | ( | _destination | ) |
| #define _CPU_Fatal_halt | ( | _source, | |
| _error | |||
| #define _CPU_ISR_Disable | ( | _level | ) |
| #define _CPU_ISR_Enable | ( | _level | ) |
| #define _CPU_ISR_Flash | ( | _level | ) |
