The Fatal Manager provides functions for fatal system states and or irrecoverable errors.
More...
◆ rtems_fatal()
Terminates the system.
- Parameters
| [in] | fatal_source | The fatal source. |
| [in] | error_code | The error code. |
- See also
- _Terminate().
◆ rtems_fatal_error_occurred()
| void rtems_fatal_error_occurred |
uint32_t |
the_error | ) |
Invokes the internal error handler with a source of INTERNAL_ERROR_RTEMS_API and is internal set to false.
- Parameters
| [in] | the_error | is a 32-bit fatal error code. |
- See also
- _Terminate().
◆ rtems_fatal_source_text()
Returns a text for a fatal source.
The text for each fatal source is the enumerator constant.
- Parameters
| [in] | source | is the fatal source. |
- Return values
| text | The fatal source text. |
| ? | The passed fatal source is invalid. |
◆ rtems_internal_error_text()
| const char * rtems_internal_error_text |
rtems_fatal_code |
error | ) |
Returns a text for an internal error code.
The text for each internal error code is the enumerator constant.
- Parameters
| [in] | error | is the error code. |
- Return values
| text | The error code text. |
| ? | The passed error code is invalid. |
◆ rtems_panic()
Prints the specified message via printk() and terminates the system.
- Parameters
| [in] | fmt | The message format. |
| [in] | ... | The message parameters. |
- See also
- _Terminate().
