19#ifndef _RTEMS_SCORE_CPU_H
20#define _RTEMS_SCORE_CPU_H
64 #if defined(RTEMS_SMP)
65 #define SPARC_USE_SYNCHRONOUS_FP_SWITCH
67 #define SPARC_USE_LAZY_FP_SWITCH
81#define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
91#define CPU_ISR_PASSES_FRAME_POINTER FALSE
101#if ( SPARC_HAS_FPU == 1 ) && !defined(SPARC_USE_SYNCHRONOUS_FP_SWITCH)
102 #define CPU_HARDWARE_FP TRUE
104 #define CPU_HARDWARE_FP FALSE
111#define CPU_SOFTWARE_FP FALSE
121#define CPU_ALL_TASKS_ARE_FP FALSE
132#define CPU_IDLE_TASK_IS_FP FALSE
134#define CPU_USE_DEFERRED_FP_SWITCH FALSE
136#define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
147#define CPU_STACK_GROWS_UP FALSE
150#define CPU_CACHE_LINE_BYTES 64
152#define CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES )
161#define CPU_MODES_INTERRUPT_MASK 0x0000000F
229#define CPU_STACK_FRAME_L0_OFFSET 0x00
231#define CPU_STACK_FRAME_L1_OFFSET 0x04
233#define CPU_STACK_FRAME_L2_OFFSET 0x08
235#define CPU_STACK_FRAME_L3_OFFSET 0x0c
237#define CPU_STACK_FRAME_L4_OFFSET 0x10
239#define CPU_STACK_FRAME_L5_OFFSET 0x14
241#define CPU_STACK_FRAME_L6_OFFSET 0x18
243#define CPU_STACK_FRAME_L7_OFFSET 0x1c
245#define CPU_STACK_FRAME_I0_OFFSET 0x20
247#define CPU_STACK_FRAME_I1_OFFSET 0x24
249#define CPU_STACK_FRAME_I2_OFFSET 0x28
251#define CPU_STACK_FRAME_I3_OFFSET 0x2c
253#define CPU_STACK_FRAME_I4_OFFSET 0x30
255#define CPU_STACK_FRAME_I5_OFFSET 0x34
257#define CPU_STACK_FRAME_I6_FP_OFFSET 0x38
259#define CPU_STACK_FRAME_I7_OFFSET 0x3c
261#define CPU_STRUCTURE_RETURN_ADDRESS_OFFSET 0x40
263#define CPU_STACK_FRAME_SAVED_ARG0_OFFSET 0x44
265#define CPU_STACK_FRAME_SAVED_ARG1_OFFSET 0x48
267#define CPU_STACK_FRAME_SAVED_ARG2_OFFSET 0x4c
269#define CPU_STACK_FRAME_SAVED_ARG3_OFFSET 0x50
271#define CPU_STACK_FRAME_SAVED_ARG4_OFFSET 0x54
273#define CPU_STACK_FRAME_SAVED_ARG5_OFFSET 0x58
275#define CPU_STACK_FRAME_PAD0_OFFSET 0x5c
277#define CPU_MAXIMUM_PROCESSORS 32
377 uint32_t isr_dispatch_disable;
379#if defined(SPARC_USE_LAZY_FP_SWITCH)
383#if defined(RTEMS_SMP)
384 volatile uint32_t is_executing;
393#define _CPU_Context_Get_SP( _context ) \
397 static inline bool _CPU_Context_Get_is_executing(
404 static inline void _CPU_Context_Set_is_executing(
409 context->is_executing = is_executing;
420#define G5_OFFSET 0x00
422#define G7_OFFSET 0x04
425#define L0_OFFSET 0x08
427#define L1_OFFSET 0x0C
429#define L2_OFFSET 0x10
431#define L3_OFFSET 0x14
433#define L4_OFFSET 0x18
435#define L5_OFFSET 0x1C
437#define L6_OFFSET 0x20
439#define L7_OFFSET 0x24
442#define I0_OFFSET 0x28
444#define I1_OFFSET 0x2C
446#define I2_OFFSET 0x30
448#define I3_OFFSET 0x34
450#define I4_OFFSET 0x38
452#define I5_OFFSET 0x3C
454#define I6_FP_OFFSET 0x40
456#define I7_OFFSET 0x44
459#define O6_SP_OFFSET 0x48
461#define O7_OFFSET 0x4C
464#define PSR_OFFSET 0x50
466#define ISR_DISPATCH_DISABLE_STACK_OFFSET 0x54
468#if defined(RTEMS_SMP)
469 #define SPARC_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 0x58
522#define FO_F1_OFFSET 0x00
524#define F2_F3_OFFSET 0x08
526#define F4_F5_OFFSET 0x10
528#define F6_F7_OFFSET 0x18
530#define F8_F9_OFFSET 0x20
532#define F1O_F11_OFFSET 0x28
534#define F12_F13_OFFSET 0x30
536#define F14_F15_OFFSET 0x38
538#define F16_F17_OFFSET 0x40
540#define F18_F19_OFFSET 0x48
542#define F2O_F21_OFFSET 0x50
544#define F22_F23_OFFSET 0x58
546#define F24_F25_OFFSET 0x60
548#define F26_F27_OFFSET 0x68
550#define F28_F29_OFFSET 0x70
552#define F3O_F31_OFFSET 0x78
554#define FSR_OFFSET 0x80
557#define CONTEXT_CONTROL_FP_SIZE 0x84
652#define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
661#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 1024
686#define CPU_INTERRUPT_NUMBER_OF_VECTORS 256
692#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER 511
698#define SPARC_SYNCHRONOUS_TRAP_BIT_MASK 0x100
703#define SPARC_ASYNCHRONOUS_TRAP( _trap ) (_trap)
708#define SPARC_SYNCHRONOUS_TRAP( _trap ) ((_trap) + 256 )
713#define SPARC_REAL_TRAP_NUMBER( _trap ) ((_trap) % 256)
719#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
729#define CPU_STACK_MINIMUM_SIZE (1024*4)
734#define CPU_SIZEOF_POINTER 4
742#define CPU_ALIGNMENT 8
755#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
761#define CPU_STACK_ALIGNMENT CPU_ALIGNMENT
763#define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
774#define _CPU_Initialize_vectors()
780#define _CPU_ISR_Disable( _level ) \
781 (_level) = sparc_disable_interrupts()
788#define _CPU_ISR_Enable( _level ) \
789 sparc_enable_interrupts( _level )
797#define _CPU_ISR_Flash( _level ) \
798 sparc_flash_interrupts( _level )
800#define _CPU_ISR_Is_enabled( _isr_cookie ) \
801 sparc_interrupt_is_enabled( _isr_cookie )
813#define _CPU_ISR_Set_level( _newlevel ) \
814 sparc_enable_interrupts( _newlevel << 8)
852 uint32_t *stack_base,
873#define _CPU_Context_Initialization_at_thread_begin() \
875 __asm__ volatile ("set _Thread_Handler,%%i7\n"::); \
886#define _CPU_Context_Restart_self( _the_context ) \
887 _CPU_Context_restore( (_the_context) );
892#define _CPU_Context_Initialize_fp( _destination ) \
898#define _CPU_Context_save_fp( _fp_context_ptr ) \
904#define _CPU_Context_restore_fp( _fp_context_ptr ) \
922#if ( SPARC_HAS_BITSCAN == 0 )
927 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE
929 #error "scan instruction not currently supported by RTEMS!!"
943typedef void ( *CPU_ISR_raw_handler )( void );
957 CPU_ISR_raw_handler new_handler,
958 CPU_ISR_raw_handler *old_handler
961typedef void ( *CPU_ISR_handler )( uint32_t );
975 CPU_ISR_handler new_handler,
976 CPU_ISR_handler *old_handler
1006#if defined(RTEMS_SMP)
1007 uint32_t _CPU_SMP_Initialize(
void );
1009 bool _CPU_SMP_Start_processor( uint32_t cpu_index );
1011 void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
1013 void _CPU_SMP_Prepare_start_multitasking(
void );
1015 #if defined(__leon__) && !defined(RTEMS_PARAVIRT)
1016 static inline uint32_t _CPU_SMP_Get_current_processor(
void )
1018 return _LEON3_Get_current_processor();
1021 uint32_t _CPU_SMP_Get_current_processor(
void );
1024 void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
1026 static inline void _CPU_SMP_Processor_event_broadcast(
void )
1028 __asm__ volatile (
"memory" );
1031 static inline void _CPU_SMP_Processor_event_receive(
void )
1033 __asm__ volatile (
"memory" );
1037#if defined(SPARC_USE_LAZY_FP_SWITCH)
1038#define _CPU_Context_Destroy( _the_thread, _the_context ) \
1040 Per_CPU_Control *cpu_self = _Per_CPU_Get(); \
1041 Thread_Control *_fp_owner = cpu_self->cpu_per_cpu.fp_owner; \
1042 if ( _fp_owner == _the_thread ) { \
1043 cpu_self->cpu_per_cpu.fp_owner = NULL; \
1075static inline uint32_t CPU_swap_u32(
1079 uint32_t byte1, byte2, byte3, byte4, swapped;
1081 byte4 = (value >> 24) & 0xff;
1082 byte3 = (value >> 16) & 0xff;
1083 byte2 = (value >> 8) & 0xff;
1084 byte1 = value & 0xff;
1086 swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
1097#define CPU_swap_u16( value ) \
1098 (((value&0xff) << 8) | ((value >> 8)&0xff))
1114 SPARC_Counter_read read_isr_disabled;
1115 SPARC_Counter_read
read;
1116 volatile const CPU_Counter_ticks *counter_register;
1117 volatile const uint32_t *pending_register;
1118 uint32_t pending_mask;
1119 CPU_Counter_ticks accumulated;
1120 CPU_Counter_ticks interval;
1127 return ( *_SPARC_Counter.read )();
1130static inline CPU_Counter_ticks _CPU_Counter_difference(
1131 CPU_Counter_ticks second,
1132 CPU_Counter_ticks first
1135 return second - first;
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
bool _CPU_ISR_Is_enabled(uint32_t level)
Returns true if interrupts are enabled in the specified ISR level, otherwise returns false.
Definition: cpu.h:375
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: idle-mcf5272.c:20
void _CPU_Initialize(void)
CPU initialization.
Definition: cpu.c:45
uintptr_t CPU_Uint32ptr
Definition: cpu.h:662
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
SPARC specific RTEMS ISR installer.
Definition: cpu.h:493
uint32_t _CPU_Counter_frequency(void)
Returns the current CPU counter frequency in Hz.
Definition: system-clocks.c:112
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:91
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: system-clocks.c:117
void _CPU_Context_restore(Context_Control *new_context) RTEMS_NO_RETURN
Definition: cpu_asm.c:111
uint32_t _CPU_ISR_Get_level(void)
Definition: cpu.c:88
void _CPU_Context_Initialize(Context_Control *context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
Initializes the CPU context.
Definition: epiphany-context-initialize.c:40
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: vectorexceptions.c:45
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
void _CPU_Fatal_halt(uint32_t source, uint32_t error) RTEMS_NO_RETURN
Definition: bsp_fatal_halt.c:12
RTEMS_INLINE_ROUTINE void _CPU_ISR_install_raw_handler(uint32_t vector, CPU_ISR_raw_handler new_handler, CPU_ISR_raw_handler *old_handler)
SPARC specific raw ISR installer.
Definition: cpu.h:649
ssize_t read(int fd, void *buffer, size_t count)
Definition: read.c:27
uint32_t CPU_Counter_ticks
Unsigned integer type for CPU counter values.
Definition: cpu.h:1210
const CPU_Trap_table_entry _CPU_Trap_slot_template
Definition: cpu.c:156
Information Required to Build RTEMS for a Particular Member of the SPARC Family.
#define SPARC_PSR_PIL_MASK
Definition: sparc.h:127
The set of registers that specifies the complete processor state.
Definition: cpu.h:629
Interrupt stack frame (ISF).
Definition: cpu.h:191
uint32_t g4
Definition: cpu.h:587
uint32_t i1
Definition: cpu.h:597
uint32_t i3
Definition: cpu.h:601
SPARC_Minimum_stack_frame Stack_frame
Definition: cpu.h:573
uint32_t g1
Definition: cpu.h:581
uint32_t tpc
Definition: cpu.h:613
uint32_t g2
Definition: cpu.h:583
uint32_t i6_fp
Definition: cpu.h:607
uint32_t i2
Definition: cpu.h:599
uint32_t i7
Definition: cpu.h:609
uint32_t pc
Definition: cpu.h:577
uint32_t reserved_for_alignment
Definition: cpu.h:591
uint32_t y
Definition: cpu.h:611
uint32_t g7
Definition: cpu.h:593
uint32_t psr
Definition: cpu.h:575
uint32_t g5
Definition: cpu.h:589
uint32_t i5
Definition: cpu.h:605
uint32_t i0
Definition: cpu.h:595
uint32_t i4
Definition: cpu.h:603
uint32_t npc
Definition: cpu.h:579
uint32_t g3
Definition: cpu.h:585
uint32_t mov_vector_l3
Definition: cpu.h:635
uint32_t mov_psr_l0
uint32_t jmp_to_low_of_handler_plus_l4
Definition: cpu.h:633
uint32_t sethi_of_handler_to_l4
Definition: cpu.h:631
SPARC basic context.
Definition: cpu.h:194
double f24_f25
Definition: cpu.h:504
double f28_f29
Definition: cpu.h:508
uint32_t fsr
Definition: cpu.h:512
double f2_f3
Definition: cpu.h:482
double f0_f1
Definition: cpu.h:480
double f16_f17
Definition: cpu.h:496
double f4_f5
Definition: cpu.h:484
double f20_f21
Definition: cpu.h:500
double f26_f27
Definition: cpu.h:506
double f8_f9
Definition: cpu.h:488
double f30_f31
Definition: cpu.h:510
double f18_f19
Definition: cpu.h:498
double f10_f11
Definition: cpu.h:490
double f22_f23
Definition: cpu.h:502
double f6_f7
Definition: cpu.h:486
double f12_f13
Definition: cpu.h:492
double f14_f15
Definition: cpu.h:494
Thread register context.
uint32_t i4
Definition: cpu.h:354
uint32_t i5
Definition: cpu.h:356
uint32_t i3
Definition: cpu.h:352
uint32_t o6_sp
Definition: cpu.h:363
uint32_t g7
Definition: cpu.h:322
uint32_t l5
Definition: cpu.h:339
uint32_t g5
Definition: cpu.h:320
uint32_t i0
Definition: cpu.h:346
uint32_t psr
Definition: cpu.h:371
uint32_t l3
Definition: cpu.h:335
uint32_t l4
Definition: cpu.h:337
uint32_t o7
Definition: cpu.h:368
uint32_t l2
Definition: cpu.h:333
uint32_t i7
Definition: cpu.h:360
uint32_t i2
Definition: cpu.h:350
uint32_t i1
Definition: cpu.h:348
uint32_t l6
Definition: cpu.h:341
uint32_t i6_fp
Definition: cpu.h:358
uint32_t l7
Definition: cpu.h:343
double l0_and_l1
Definition: cpu.h:331
uint32_t l7
Definition: cpu.h:186
uint32_t saved_arg5
Definition: cpu.h:221
uint32_t saved_arg4
Definition: cpu.h:219
uint32_t saved_arg1
Definition: cpu.h:213
uint32_t pad0
Definition: cpu.h:223
uint32_t i7
Definition: cpu.h:202
uint32_t i2
Definition: cpu.h:192
uint32_t l0
Definition: cpu.h:172
uint32_t l3
Definition: cpu.h:178
uint32_t l1
Definition: cpu.h:174
uint32_t i0
Definition: cpu.h:188
uint32_t i3
uint32_t saved_arg2
Definition: cpu.h:215
uint32_t i6_fp
Definition: cpu.h:200
uint32_t l2
Definition: cpu.h:176
void * structure_return_address
Definition: cpu.h:204
uint32_t saved_arg0
Definition: cpu.h:211
uint32_t i4
Definition: cpu.h:196
uint32_t l6
Definition: cpu.h:184
uint32_t saved_arg3
Definition: cpu.h:217
uint32_t i1
Definition: cpu.h:190
uint32_t l5
Definition: cpu.h:182
uint32_t i5
Definition: cpu.h:198
uint32_t l4
Definition: cpu.h:180
unsigned context
Definition: tlb.h:1
unsigned size
Definition: tte.h:1
