RTEMS
5.2
Here is a list of all documented struct and union fields with links to the struct/union documentation for each field:
- u -
u16 :
ITM_Type
u32 :
ITM_Type
u8 :
ITM_Type
uart_baseAddress :
bfin_uart_channel_t
uart_baud :
bfin_uart_channel_t
UART_BRGR :
Uart
UART_CMPR :
Uart
UART_CR :
Uart
UART_IDR :
Uart
UART_IER :
Uart
UART_IMR :
Uart
UART_MR :
Uart
UART_RHR :
Uart
uart_rxDmaBaseAddress :
bfin_uart_channel_t
UART_SR :
Uart
UART_THR :
Uart
uart_txDmaBaseAddress :
bfin_uart_channel_t
uart_useDma :
bfin_uart_channel_t
uart_useInterrupts :
bfin_uart_channel_t
UART_VERSION :
Uart
UART_WPMR :
Uart
uartId :
UartDma
uid :
rtems_shell_env_t
rtems_user_env_t
ulClock :
_console_tbl
ulCtrlPort1 :
_console_tbl
ulCtrlPort2 :
_console_tbl
ulDataPort :
_console_tbl
ulHysteresis :
_console_tbl
ulIntVector :
_console_tbl
ulMargin :
_console_tbl
umask :
rtems_user_env_t
unallocated :
rtems_object_api_class_information
unavail_blocks :
rtems_flashdisk
rtems_flashdisk_config
unblock :
Scheduler_Operations
unite :
drvmgr_bus_ops
unload :
rtems_rtl_loader_table
unlock_way :
L2CC
unmap_priority :
unmount_task :
rtems_filesystem_mount_table_entry_tt
unresolved :
rtems_rtl_data
rtems_rtl_elf_reloc_data
rtems_rtl_obj
update :
pfpu_td
Thread_queue_Context
update_count :
update_priority :
upper_wrprot_block :
ALT_QSPI_DEV_SIZE_CONFIG_s
uptime :
rtems_record_client_per_cpu
US_BRGR :
Usart
US_CR :
Usart
US_CSR :
Usart
US_FIDI :
Usart
US_ICDIFF :
Usart
US_IDR :
Usart
US_IDTRX :
Usart
US_IDTTX :
Usart
US_IER :
Usart
US_IF :
Usart
US_IMR :
Usart
US_LINBRR :
Usart
US_LINIR :
Usart
US_LINMR :
Usart
US_LONB1RX :
Usart
US_LONB1TX :
Usart
US_LONBL :
Usart
US_LONDL :
Usart
US_LONL2HDR :
Usart
US_LONMR :
Usart
US_LONPR :
Usart
US_LONPRIO :
Usart
US_MAN :
Usart
US_MR :
Usart
US_NER :
Usart
US_RHR :
Usart
US_RTOR :
Usart
US_THR :
Usart
US_TTGR :
Usart
US_VERSION :
Usart
US_WPMR :
Usart
US_WPSR :
Usart
usage_count :
rtems_profiling_smp_lock
usartId :
UsartDma
usbclksel :
lpc176x_scb
USBHS_CTRL :
Usbhs
USBHS_DEVCTRL :
Usbhs
USBHS_DEVDMA :
Usbhs
USBHS_DEVDMAADDRESS :
UsbhsDevdma
USBHS_DEVDMACONTROL :
UsbhsDevdma
USBHS_DEVDMANXTDSC :
UsbhsDevdma
USBHS_DEVDMASTATUS :
UsbhsDevdma
USBHS_DEVEPT :
Usbhs
USBHS_DEVEPTCFG :
Usbhs
USBHS_DEVEPTICR :
Usbhs
USBHS_DEVEPTIDR :
Usbhs
USBHS_DEVEPTIER :
Usbhs
USBHS_DEVEPTIFR :
Usbhs
USBHS_DEVEPTIMR :
Usbhs
USBHS_DEVEPTISR :
Usbhs
USBHS_DEVFNUM :
Usbhs
USBHS_DEVICR :
Usbhs
USBHS_DEVIDR :
Usbhs
USBHS_DEVIER :
Usbhs
USBHS_DEVIFR :
Usbhs
USBHS_DEVIMR :
Usbhs
USBHS_DEVISR :
Usbhs
USBHS_FSM :
Usbhs
USBHS_HSTADDR1 :
Usbhs
USBHS_HSTADDR2 :
Usbhs
USBHS_HSTADDR3 :
Usbhs
USBHS_HSTCTRL :
Usbhs
USBHS_HSTDMA :
Usbhs
USBHS_HSTDMAADDRESS :
UsbhsHstdma
USBHS_HSTDMACONTROL :
UsbhsHstdma
USBHS_HSTDMANXTDSC :
UsbhsHstdma
USBHS_HSTDMASTATUS :
UsbhsHstdma
USBHS_HSTFNUM :
Usbhs
USBHS_HSTICR :
Usbhs
USBHS_HSTIDR :
Usbhs
USBHS_HSTIER :
Usbhs
USBHS_HSTIFR :
Usbhs
USBHS_HSTIMR :
Usbhs
USBHS_HSTISR :
Usbhs
USBHS_HSTPIP :
Usbhs
USBHS_HSTPIPCFG :
Usbhs
USBHS_HSTPIPERR :
Usbhs
USBHS_HSTPIPICR :
Usbhs
USBHS_HSTPIPIDR :
Usbhs
USBHS_HSTPIPIER :
Usbhs
USBHS_HSTPIPIFR :
Usbhs
USBHS_HSTPIPIMR :
Usbhs
USBHS_HSTPIPINRQ :
Usbhs
USBHS_HSTPIPISR :
Usbhs
USBHS_SCR :
Usbhs
USBHS_SFR :
Usbhs
USBHS_SR :
Usbhs
USBHS_TSTA1 :
Usbhs
USBHS_TSTA2 :
Usbhs
USBHS_VERSION :
Usbhs
use_pec :
i2c_bus
used :
rtems_flashdisk
used_blocks :
Heap_Statistics
used_size :
rtems_jffs2_info
user :
_rtems_rfs_file_system
rtems_bdbuf_buffer
rtems_blkdev_sg_buffer
user_data :
Timer_Control
user_environment :
_Thread_Control
User_initialization_tasks_table :
rtems_api_configuration_table
User_mpci_table :
MPCI_Configuration
users :
rtems_bdbuf_group
rtems_rtl_obj
uses :
rtems_disk_device
UTMI_CKTRIM :
Utmi
UTMI_OHCIICR :
Utmi
