RTEMS 5.2
rtems_api_configuration_table Struct Reference
#include <config.h>
uint32_t maximum_tasks
bool notepads_enabled
uint32_t maximum_timers
uint32_t maximum_semaphores
uint32_t maximum_message_queues
uint32_t maximum_partitions
uint32_t maximum_regions
uint32_t maximum_ports
uint32_t maximum_periods
uint32_t maximum_barriers
uint32_t number_of_initialization_tasks
const rtems_initialization_tasks_tableUser_initialization_tasks_table
The following records define the Configuration Table. The information contained in this table is required in all RTEMS systems, whether single or multiprocessor. This table primarily defines the following:
Field Documentation
◆ maximum_barriers
uint32_t rtems_api_configuration_table::maximum_barriers
This field contains the maximum number of Classic API Barriers which are configured for this application.
◆ maximum_message_queues
uint32_t rtems_api_configuration_table::maximum_message_queues
This field contains the maximum number of Classic API Message Queues which are configured for this application.
◆ maximum_partitions
uint32_t rtems_api_configuration_table::maximum_partitions
This field contains the maximum number of Classic API Partitions which are configured for this application.
◆ maximum_periods
uint32_t rtems_api_configuration_table::maximum_periods
This field contains the maximum number of Classic API Rate Monotonic Periods which are configured for this application.
◆ maximum_ports
uint32_t rtems_api_configuration_table::maximum_ports
This field contains the maximum number of Classic API Dual Ported Memory Areas which are configured for this application.
◆ maximum_regions
uint32_t rtems_api_configuration_table::maximum_regions
This field contains the maximum number of Classic API Regions which are configured for this application.
◆ maximum_semaphores
uint32_t rtems_api_configuration_table::maximum_semaphores
This field contains the maximum number of Classic API Semaphores which are configured for this application.
◆ maximum_tasks
uint32_t rtems_api_configuration_table::maximum_tasks
This field contains the maximum number of Classic API Tasks which are configured for this application.
◆ maximum_timers
uint32_t rtems_api_configuration_table::maximum_timers
This field contains the maximum number of Classic API Timers which are configured for this application.
◆ notepads_enabled
bool rtems_api_configuration_table::notepads_enabled
This field indicates whether Classic API notepads are enabled or disabled.
◆ number_of_initialization_tasks
uint32_t rtems_api_configuration_table::number_of_initialization_tasks
This field contains the number of Classic API Initialization Tasks which are configured for this application.
◆ User_initialization_tasks_table
const rtems_initialization_tasks_table* rtems_api_configuration_table::User_initialization_tasks_table
This field is the set of Classic API Initialization Tasks which are configured for this application.
