I2C bus control.
More...
#include <i2c.h>
| int(* | transfer )(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count) |
| | Transfers I2C messages. More...
| int(* | set_clock )(i2c_bus *bus, unsigned long clock) |
| | Sets the bus clock. More...
| void(* | destroy )(i2c_bus *bus) |
| | Destroys the bus. More...
rtems_recursive_mutex | mutex |
| | Mutex to protect the bus access.
uint16_t | default_address |
| | Default slave device address.
bool | ten_bit_address |
| | Use 10-bit addresses.
bool | use_pec |
| | Use SMBus PEC.
unsigned long | retries |
| | Transfer retry count.
rtems_interval | timeout |
| | Transaction timeout in ticks.
unsigned long | functionality |
| | Controller functionality.
◆ destroy
| void(* i2c_bus::destroy) (i2c_bus *bus) |
Destroys the bus.
- Parameters
◆ set_clock
| int(* i2c_bus::set_clock) (i2c_bus *bus, unsigned long clock) |
Sets the bus clock.
- Parameters
| [in] | bus | The bus control. |
| [in] | clock | The desired bus clock in Hz. |
- Return values
| 0 | Successful operation. |
| negative | Negative error number in case of an error. |
◆ transfer
| int(* i2c_bus::transfer) (i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count) |
- Parameters
| [in] | msgs | The messages to transfer. |
| [in] | msg_count | The count of messages to transfer. It must be positive. |
- Return values
- cpukit/include/dev/i2c/i2c.h
