RTEMS 5.2
i2c.h
1
9/*
10 * Copyright (c) 2014, 2017 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Dornierstr. 4
14 * 82178 Puchheim
15 * Germany
16 * <rtems@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef _DEV_I2C_I2C_H
24#define _DEV_I2C_I2C_H
25
26#include <linux/i2c.h>
27#include <linux/i2c-dev.h>
28
29#include <rtems.h>
30#include <rtems/seterr.h>
31#include <rtems/thread.h>
32
33#include <sys/ioctl.h>
34#include <sys/stat.h>
35
36#ifdef __cplusplus
37extern "C" {
38#endif /* __cplusplus */
39
40typedef struct i2c_msg i2c_msg;
41
42typedef struct i2c_bus i2c_bus;
43
44typedef struct i2c_dev i2c_dev;
45
47
77#define I2C_BUS_OBTAIN 0x800
78
84#define I2C_BUS_RELEASE 0x801
85
91#define I2C_BUS_GET_CONTROL 0x802
92
98#define I2C_BUS_SET_CLOCK 0x803
99
105#define I2C_BUS_CLOCK_DEFAULT 100000
106
110struct i2c_bus {
122 int (*transfer)(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count);
123
133 int (*set_clock)(i2c_bus *bus, unsigned long clock);
134
140 void (*destroy)(i2c_bus *bus);
141
145 rtems_recursive_mutex mutex;
146
151
156
161
165 unsigned long retries;
166
171
175 unsigned long functionality;
176};
177
193int i2c_bus_init(i2c_bus *bus);
194
213
219void i2c_bus_destroy(i2c_bus *bus);
220
227
241 i2c_bus *bus,
242 const char *bus_path
243);
244
250void i2c_bus_obtain(i2c_bus *bus);
251
257void i2c_bus_release(i2c_bus *bus);
258
272int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count);
273
287#define I2C_DEV_IO_CONTROL 0x900
288
292struct i2c_dev {
299 ssize_t (*read)(i2c_dev *dev, void *buf, size_t n, off_t offset);
300
307 ssize_t (*write)(i2c_dev *dev, const void *buf, size_t n, off_t offset);
308
315 int (*ioctl)(i2c_dev *dev, ioctl_command_t command, void *arg);
316
320 off_t (*get_size)(i2c_dev *dev);
321
325 blksize_t (*get_block_size)(i2c_dev *dev);
326
330 void (*destroy)(i2c_dev *dev);
331
336
340 uint16_t address;
341
349};
350
351
369int i2c_dev_init(i2c_dev *dev, const char *bus_path, uint16_t address);
370
391 size_t size,
392 const char *bus_path,
393 uint16_t address
394);
395
401void i2c_dev_destroy(i2c_dev *dev);
402
409
423 i2c_dev *dev,
424 const char *dev_path
425);
426 /* end of i2c device driver */
428
431#ifdef __cplusplus
432}
433#endif /* __cplusplus */
434
435#endif /* _DEV_I2C_I2C_H */
RTEMS Port of Linux I2C API.
Watchdog_Interval rtems_interval
Used to manage and manipulate intervals specified by clock ticks.
Definition: types.h:127
Destroys a bus control.
Definition: i2c-bus.c:289
Transfers I2C messages.
Definition: i2c-bus.c:44
void i2c_bus_destroy_and_free(i2c_bus *bus)
Destroys a bus control and frees its memory.
Definition: i2c-bus.c:294
Obtains the bus.
Definition: i2c-bus.c:34
Initializes a bus control.
Definition: i2c-bus.c:300
int i2c_bus_register(i2c_bus *bus, const char *bus_path)
Registers a bus control.
Definition: i2c-bus.c:235
i2c_bus * i2c_bus_alloc_and_init(size_t size)
Allocates a bus control from the heap and initializes it.
Definition: i2c-bus.c:307
Releases the bus.
Definition: i2c-bus.c:39
Initializes a device control.
Definition: i2c-dev.c:266
Destroys a device control.
Definition: i2c-dev.c:251
i2c_dev * i2c_dev_alloc_and_init(size_t size, const char *bus_path, uint16_t address)
Allocates a device control from the heap and initializes it.
Definition: i2c-dev.c:271
int i2c_dev_register(i2c_dev *dev, const char *dev_path)
Registers a device control.
Definition: i2c-dev.c:140
void i2c_dev_destroy_and_free(i2c_dev *dev)
Destroys a device control and frees its memory.
Definition: i2c-dev.c:260
RTEMS Port of Linux I2C Device API.
Data which Ease the Burden of Consistently Setting Errno.
I2C bus control.
Definition: i2c.h:110
Controller functionality.
Definition: i2c.h:175
Transfer retry count.
Definition: i2c.h:165
rtems_interval timeout
Transaction timeout in ticks.
Definition: i2c.h:170
void(* destroy)(i2c_bus *bus)
Destroys the bus.
Definition: i2c.h:140
uint16_t default_address
Default slave device address.
Definition: i2c.h:150
bool use_pec
Use SMBus PEC.
Definition: i2c.h:160
Mutex to protect the bus access.
Definition: i2c.h:145
int(* set_clock)(i2c_bus *bus, unsigned long clock)
Sets the bus clock.
Definition: i2c.h:133
int(* transfer)(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
Definition: i2c.h:122
bool ten_bit_address
Use 10-bit addresses.
Definition: i2c.h:155
I2C slave device control.
Definition: i2c.h:292
ssize_t(* read)(i2c_dev *dev, void *buf, size_t n, off_t offset)
Reads from the device.
Definition: i2c.h:299
off_t(* get_size)(i2c_dev *dev)
Gets the file size.
Definition: i2c.h:320
int(* ioctl)(i2c_dev *dev, ioctl_command_t command, void *arg)
Device IO control.
Definition: i2c.h:315
i2c_bus * bus
The bus control.
Definition: i2c.h:335
blksize_t(* get_block_size)(i2c_dev *dev)
Gets the file block size.
Definition: i2c.h:325
void(* destroy)(i2c_dev *dev)
Destroys the device.
Definition: i2c.h:330
uint16_t address
The device address.
Definition: i2c.h:340
int bus_fd
File descriptor of the bus.
Definition: i2c.h:348
ssize_t(* write)(i2c_dev *dev, const void *buf, size_t n, off_t offset)
Writes to the device.
Definition: i2c.h:307
I2C transfer message.
Definition: i2c.h:138
Argument type for I2C_RDWR IO control call.
Definition: i2c-dev.h:125
unsigned size
Definition: tte.h:1
