| #define | CPU_DATA_CACHE_ALIGNMENT ARM_CACHE_L1_CPU_DATA_ALIGNMENT |
| | Cache definitions and functions. More...
#define | L2C_310_ID_RTL_MASK 0x3f |
#define | L2C_310_ID_PART_MASK ( 0xf << 6 ) |
#define | L2C_310_ID_PART_L210 ( 1 << 6 ) |
#define | L2C_310_ID_PART_L310 ( 3 << 6 ) |
#define | L2C_310_ID_IMPL_MASK ( 0xff << 24 ) |
#define | L2C_310_TYPE_DATA_BANKING_MASK 0x80000000 |
| | 1 if data banking implemented, 0 if not
#define | L2C_310_TYPE_CTYPE_MASK 0x1E000000 |
| | 11xy, where: x=1 if pl310_LOCKDOWN_BY_MASTER is defined, otherwise 0
#define | L2C_310_TYPE_CTYPE_SHIFT 25 |
| | y=1 if pl310_LOCKDOWN_BY_LINE is defined, otherwise 0.
#define | L2C_310_TYPE_HARVARD_MASK 0x01000000 |
| | 1 for Harvard architecture, 0 for unified architecture
#define | L2C_310_TYPE_SIZE_D_WAYS_MASK 0x00700000 |
| | Data cache way size = 2 Exp(value + 2) KB.
#define | L2C_310_TYPE_SIZE_D_WAYS_SHIFT 20 |
#define | L2C_310_TYPE_NUM_D_WAYS_MASK 0x00040000 |
| | Assoziativity aka number of data ways = (value * 8) + 8.
#define | L2C_310_TYPE_NUM_D_WAYS_SHIFT 18 |
#define | L2C_310_TYPE_LENGTH_D_LINE_MASK 0x00003000 |
| | Data cache line length 00 - 32.
#define | L2C_310_TYPE_LENGTH_D_LINE_SHIFT 12 |
#define | L2C_310_TYPE_LENGTH_D_LINE_VAL_32 0x0 |
#define | L2C_310_TYPE_SIZE_I_WAYS_MASK 0x00000700 |
| | Instruction cache way size = 2 Exp(value + 2) KB.
#define | L2C_310_TYPE_SIZE_I_WAYS_SHIFT 8 |
#define | L2C_310_TYPE_NUM_I_WAYS_MASK 0x00000040 |
| | Assoziativity aka number of instruction ways = (value * 8) + 8.
#define | L2C_310_TYPE_NUM_I_WAYS_SHIFT 6 |
#define | L2C_310_TYPE_LENGTH_I_LINE_MASK 0x00000003 |
| | Instruction cache line length 00 - 32.
#define | L2C_310_TYPE_LENGTH_I_LINE_SHIFT 0 |
#define | L2C_310_TYPE_LENGTH_I_LINE_VAL_32 0x0 |
#define | L2C_310_CTRL_ENABLE 0x00000001 |
| | Enables the L2CC.
#define | L2C_310_CTRL_EXCL_CONFIG (1 << 12) |
#define | L2C_310_AUX_EBRESPE_MASK 0x40000000 |
| | Early BRESP Enable.
#define | L2C_310_AUX_IPFE_MASK 0x20000000 |
| | Instruction Prefetch Enable.
#define | L2C_310_AUX_DPFE_MASK 0x10000000 |
| | Data Prefetch Enable.
#define | L2C_310_AUX_NSIC_MASK 0x08000000 |
| | Non-secure interrupt access control.
#define | L2C_310_AUX_NSLE_MASK 0x04000000 |
| | Non-secure lockdown enable.
#define | L2C_310_AUX_CRP_MASK 0x02000000 |
| | Cache replacement policy.
#define | L2C_310_AUX_FWE_MASK 0x01800000 |
| | Force write allocate.
#define | L2C_310_AUX_SAOE_MASK 0x00400000 |
| | Shared attribute override enable.
#define | L2C_310_AUX_PE_MASK 0x00200000 |
| | Parity enable.
#define | L2C_310_AUX_EMBE_MASK 0x00100000 |
| | Event monitor bus enable.
#define | L2C_310_AUX_WAY_SIZE_MASK 0x000E0000 |
| | Way-size.
#define | L2C_310_AUX_WAY_SIZE_SHIFT 17 |
#define | L2C_310_AUX_ASSOC_MASK 0x00010000 |
| | Way-size.
#define | L2C_310_AUX_SAIE_MASK 0x00002000 |
| | Shared attribute invalidate enable.
#define | L2C_310_AUX_EXCL_CACHE_MASK 0x00001000 |
| | Exclusive cache configuration.
#define | L2C_310_AUX_SBDLE_MASK 0x00000800 |
| | Store buffer device limitation Enable.
#define | L2C_310_AUX_HPSODRE_MASK 0x00000400 |
| | High Priority for SO and Dev Reads Enable.
#define | L2C_310_AUX_FLZE_MASK 0x00000001 |
| | Full line of zero enable.
| #define | L2C_310_AUX_REG_DEFAULT_MASK |
| | Enable all prefetching,. More...
#define | L2C_310_AUX_REG_ZERO_MASK 0xFFF1FFFF |
#define | L2C_310_RAM_1_CYCLE_LAT_VAL 0x00000000 |
| | 1 cycle of latency, there is no additional latency fot tag RAM
#define | L2C_310_RAM_2_CYCLE_LAT_VAL 0x00000001 |
| | 2 cycles of latency for tag RAM
#define | L2C_310_RAM_3_CYCLE_LAT_VAL 0x00000002 |
| | 3 cycles of latency for tag RAM
#define | L2C_310_RAM_4_CYCLE_LAT_VAL 0x00000003 |
| | 4 cycles of latency for tag RAM
#define | L2C_310_RAM_5_CYCLE_LAT_VAL 0x00000004 |
| | 5 cycles of latency for tag RAM
#define | L2C_310_RAM_6_CYCLE_LAT_VAL 0x00000005 |
| | 6 cycles of latency for tag RAM
#define | L2C_310_RAM_7_CYCLE_LAT_VAL 0x00000006 |
| | 7 cycles of latency for tag RAM
#define | L2C_310_RAM_8_CYCLE_LAT_VAL 0x00000007 |
| | 8 cycles of latency for tag RAM
#define | L2C_310_RAM_SETUP_SHIFT 0x00000000 |
| | Shift left setup latency values by this value.
#define | L2C_310_RAM_READ_SHIFT 0x00000004 |
| | Shift left read latency values by this value.
#define | L2C_310_RAM_WRITE_SHIFT 0x00000008 |
| | Shift left write latency values by this value.
#define | L2C_310_RAM_SETUP_LAT_MASK 0x00000007 |
| | Mask for RAM setup latency.
#define | L2C_310_RAM_READ_LAT_MASK 0x00000070 |
| | Mask for RAM read latency.
#define | L2C_310_RAM_WRITE_LAT_MASK 0x00000700 |
| #define | L2C_310_TAG_RAM_DEFAULT_LAT |
| #define | L2C_310_DATA_RAM_DEFAULT_MASK |
| | Latency for data RAM. More...
#define | L2C_310_ADDR_FILTER_VALID_MASK 0xFFF00000 |
| | Address filtering valid bits.
#define | L2C_310_ADDR_FILTER_ENABLE_MASK 0x00000001 |
| | Address filtering enable bit.
#define | L2C_310_DEBUG_SPIDEN_MASK 0x00000004 |
| | Debug SPIDEN bit.
#define | L2C_310_DEBUG_DWB_MASK 0x00000002 |
| | Debug DWB bit, forces write through.
#define | L2C_310_DEBUG_DCL_MASK 0x00000002 |
| | Debug DCL bit, disables cache line fill.
#define | L2C_310_PREFETCH_OFFSET_MASK 0x0000001F |
| | Prefetch offset.
#define | L2C_310_ERRATA_IS_APPLICABLE_588369 |
| #define | CACHE_ARM_ERRATA_775420_HANDLER() |
uint32_t | L2CC::cache_id |
| | Cache ID.
uint32_t | L2CC::cache_type |
| | Cache type.
uint8_t | L2CC::reserved_8 [0x100 - 8] |
uint32_t | L2CC::ctrl |
uint32_t | L2CC::aux_ctrl |
| | Auxiliary control.
uint32_t | L2CC::tag_ram_ctrl |
| | Latency for tag RAM.
uint32_t | L2CC::data_ram_ctrl |
uint8_t | L2CC::reserved_110 [0x200 - 0x110] |
uint32_t | L2CC::ev_ctrl |
| | Event counter control.
uint32_t | L2CC::ev_cnt1_cfg |
| | Event counter 1 configuration.
uint32_t | L2CC::ev_cnt0_cfg |
| | Event counter 0 configuration.
uint32_t | L2CC::ev_cnt1 |
| | Event counter 1 value.
uint32_t | L2CC::ev_cnt0 |
| | Event counter 0 value.
uint32_t | L2CC::int_mask |
| | Interrupt enable mask.
uint32_t | L2CC::int_mask_status |
| | Masked interrupt status (read-only)
uint32_t | L2CC::int_raw_status |
| | Unmasked interrupt status.
uint32_t | L2CC::int_clr |
| | Interrupt clear.
uint8_t | L2CC::reserved_224 [0x730 - 0x224] |
uint32_t | L2CC::cache_sync |
| | Drain the STB.
uint8_t | L2CC::reserved_734 [0x740 - 0x734] |
uint32_t | L2CC::dummy_cache_sync_reg |
| | ARM Errata 753970 for pl310-r3p0.
uint8_t | L2CC::reserved_744 [0x770 - 0x744] |
uint32_t | L2CC::inv_pa |
| | Invalidate line by PA.
uint8_t | L2CC::reserved_774 [0x77c - 0x774] |
uint32_t | L2CC::inv_way |
| | Invalidate by Way.
uint8_t | L2CC::reserved_780 [0x7b0 - 0x780] |
uint32_t | L2CC::clean_pa |
| | Clean Line by PA.
uint8_t | L2CC::reserved_7b4 [0x7b8 - 0x7b4] |
uint32_t | L2CC::clean_index |
| | Clean Line by Set/Way.
uint32_t | L2CC::clean_way |
| | Clean by Way.
uint8_t | L2CC::reserved_7c0 [0x7f0 - 0x7c0] |
uint32_t | L2CC::clean_inv_pa |
| | Clean and Invalidate Line by PA.
uint8_t | L2CC::reserved_7f4 [0x7f8 - 0x7f4] |
uint32_t | L2CC::clean_inv_indx |
| | Clean and Invalidate Line by Set/Way.
uint32_t | L2CC::clean_inv_way |
| | Clean and Invalidate by Way.
uint32_t | L2CC::d_lockdown_0 |
| | Data lock down 0.
uint32_t | L2CC::i_lockdown_0 |
| | Instruction lock down 0.
uint32_t | L2CC::d_lockdown_1 |
| | Data lock down 1.
uint32_t | L2CC::i_lockdown_1 |
| | Instruction lock down 1.
uint32_t | L2CC::d_lockdown_2 |
| | Data lock down 2.
uint32_t | L2CC::i_lockdown_2 |
| | Instruction lock down 2.
uint32_t | L2CC::d_lockdown_3 |
| | Data lock down 3.
uint32_t | L2CC::i_lockdown_3 |
| | Instruction lock down 3.
uint32_t | L2CC::d_lockdown_4 |
| | Data lock down 4.
uint32_t | L2CC::i_lockdown_4 |
| | Instruction lock down 4.
uint32_t | L2CC::d_lockdown_5 |
| | Data lock down 5.
uint32_t | L2CC::i_lockdown_5 |
| | Instruction lock down 5.
uint32_t | L2CC::d_lockdown_6 |
| | Data lock down 6.
uint32_t | L2CC::i_lockdown_6 |
| | Instruction lock down 6.
uint32_t | L2CC::d_lockdown_7 |
| | Data lock down 7.
uint32_t | L2CC::i_lockdown_7 |
| | Instruction lock down 7.
uint8_t | L2CC::reserved_940 [0x950 - 0x940] |
uint32_t | L2CC::lock_line_en |
| | Lockdown by Line Enable.
uint32_t | L2CC::unlock_way |
| | Cache lockdown by way.
uint8_t | L2CC::reserved_958 [0xc00 - 0x958] |
uint32_t | L2CC::addr_filtering_start |
| | Address range redirect, part 1.
uint32_t | L2CC::addr_filtering_end |
| | Address range redirect, part 2.
uint8_t | L2CC::reserved_c08 [0xf40 - 0xc08] |
uint32_t | L2CC::debug_ctrl |
| | Debug control.
uint8_t | L2CC::reserved_f44 [0xf60 - 0xf44] |
uint32_t | L2CC::prefetch_ctrl |
| | Purpose prefetch enables.
uint8_t | L2CC::reserved_f64 [0xf80 - 0xf64] |
uint32_t | L2CC::power_ctrl |
| | Purpose power controls.
| rtems_interrupt_lock | l2c_310_lock |
Cache Functions and Defitions.
